feat(rcomb): Added proper error message when input file cannot be opened
docs(rcomb): Added better commenting to functions
fix(rcomb,rmtxop): Allow -c and -C file paths starting with '.'
feat(rcomb): Added -mt option to transpose concatenation matrix after load
feat(rcomb,rmtxop): Added warning when 32-bit results written as 64-bit
refactor: Made MAXCOMP redefinable and common between rmatrix tools
refactor: Simplified some error messages
fix(rcomb,rmtxop): Fix to matrix deallocation
fix(rcomb,rmtxop): Fixing compile error with const array type
fix(rcomb): pay better attention to -w option
fix(rcomb: Cleaned up logic and error reporting and fixed bug caused by subtle fclose(3) behavior that moved underlying file pointer shared with parent
refactor(rcomb): Minor changes should not affect performance
perf: minor optimization to avoid unnecessary system calls
fix(rcomb): Added child process to sequence output; seems to finally work
refactor: Changed buffer types in process(), readbuf(), writebuf()
fix(rcomb): Avoid inappropriate byte-swapping and improved final fclose() wait
fix(rcomb): Error in record size calc and cleanup of child processes on failure
fix(rcomb): Reverted to original synchronization method as signals proved unreliable for multi-processing
fix(rcomb): Fixed confusion over #components with symbolic -c in final xform
perf(rcomb): Minor optimization of signal blocking during child input
fix(rcomb): added sigprocmask() calls to avoid child synchronization issue
fix(rcomb): Switched to group-signaling to make multi-processing more reliable
perf(rcomb): Minor performance improvements for multi-processing mode
feat: Added facility for app-managed matrix memory
fix: Made use of resolu.h more consistent and reliable
fix(rcomb): Fixed issue with final operations (reallocation error)
fix(rcomb): Restored error message if no rows read from input
fix(rmtxop,rcomb): Added checks for "xyz" and "rgb" format output
feat(rmtxop,rcomb): Added lower-case versions of component outputs w/o efficacy conversions
fix(rcomb): Fixed handling of matrix inputs where NROWS is unspecified
