root/radiance/ray/src/util/rcomb.c
Revision: 2.1
Committed: Tue Dec 12 16:31:45 2023 UTC (6 months ago) by greg
2 static const char RCSid[] = "$Id: rmtxcomb.c,v 2.6 2023/12/11 15:13:39 greg Exp $";
5 * General component matrix combiner, operating on a row at a time.
6 */
7
8 #include <errno.h>
9 #include <math.h>
10 #include "platform.h"
11 #include "rtio.h"
12 #include "resolu.h"
13 #include "rmatrix.h"
14 #include "calcomp.h"
15 #include "paths.h"
16
17 #ifndef M_PI
18 #define M_PI 3.14159265358979323846
19 #endif
20
21 #define MAXCOMP MAXCSAMP /* #components we support */
22
23 /* Unary matrix operation(s) */
24 typedef struct {
25 double cmat[MAXCOMP*MAXCOMP]; /* component transformation */
26 double sca[MAXCOMP]; /* scalar coefficients */
27 const char *csym; /* symbolic coefficients */
28 short clen; /* number of coefficients */
29 short nsf; /* number of scalars */
30 } RUNARYOP;
31
32 /* Input matrix */
33 typedef struct {
34 const char *inspec; /* input specification */
35 RUNARYOP preop; /* transform operation */
36 RMATRIX imx; /* input matrix header info */
37 RMATRIX *rmp; /* active single-row matrix */
38 FILE *infp; /* open input stream */
39 } ROPMAT;
40
41 ROPMAT *mop = NULL; /* allocated input array */
42 int nall = 0; /* number allocated */
43 int nmats = 0; /* number of actual inputs */
44
45 RMATRIX *mcat = NULL; /* final concatenation */
46 int mcat_last = 0; /* goes after trailing ops? */
47
48 int in_nrows; /* input row count */
49 #define in_ncols (mop[0].rmp->ncols) /* input column count */
50 #define in_ncomp (mop[0].rmp->ncomp) /* input #components */
51
52 extern int nowarn; /* turn off warnings? */
53
54 int cur_row; /* current input/output row */
55 int cur_col; /* current input/output column */
56 int cur_chan; /* if we're looping channels */
57
58 static int checksymbolic(ROPMAT *rop);
59
60 static int
61 split_input(ROPMAT *rop)
62 {
63 if (rop->rmp == &rop->imx && !(rop->rmp = rmx_copy(&rop->imx))) {
64 fputs("Out of memory in split_input()\n", stderr);
65 return(0);
66 }
67 rmx_reset(rop->rmp);
68 return(1);
69 }
70
71 /* Check/set transform based on a reference input file */
72 static int
73 checkreffile(ROPMAT *rop)
74 {
75 static const char *curRF = NULL;
76 static RMATRIX refm;
77 const int nc = rop->imx.ncomp;
78 int i;
79
80 if (!curRF || strcmp(rop->preop.csym, curRF)) {
81 FILE *fp = fopen(rop->preop.csym, "rb");
82 if (!rmx_load_header(&refm, fp)) {
83 fprintf(stderr, "%s: cannot read info header\n",
84 rop->preop.csym);
85 curRF = NULL;
86 if (fp) fclose(fp);
87 return(0);
88 }
89 fclose(fp);
90 curRF = rop->preop.csym;
91 }
92 if (refm.ncomp == 3) {
93 rop->preop.csym = (refm.dtype == DTxyze) ? "XYZ" : "RGB";
94 return(checksymbolic(rop));
95 }
96 if (refm.ncomp == 2) {
97 fprintf(stderr, "%s: cannot convert to 2 components\n",
98 curRF);
99 return(0);
100 }
101 if (refm.ncomp == 1) {
102 rop->preop.csym = "Y"; /* XXX big assumption */
103 return(checksymbolic(rop));
104 }
105 if (refm.ncomp == nc &&
106 !memcmp(refm.wlpart, rop->imx.wlpart, sizeof(refm.wlpart)))
107 return(1); /* nothing to do */
108
109 if ((nc <= 3) | (nc > MAXCSAMP) | (refm.ncomp > MAXCSAMP)) {
110 fprintf(stderr, "%s: cannot resample from %d to %d components\n",
111 curRF, nc, refm.ncomp);
112 return(0);
113 }
114 if (!split_input(rop)) /* get our own struct */
115 return(0);
116 rop->preop.clen = refm.ncomp * nc; /* compute spec to ref */
117
118 for (i = 0; i < nc; i++) {
119 SCOLOR scstim, scresp;
120 int j;
121 memset(scstim, 0, sizeof(COLORV)*nc);
122 scstim[i] = 1.f;
123 convertscolor(scresp, refm.ncomp, refm.wlpart[0], refm.wlpart[3],
124 scstim, nc, rop->imx.wlpart[0], rop->imx.wlpart[3]);
125 for (j = refm.ncomp; j-- > 0; )
126 rop->preop.cmat[j*nc + i] = scresp[j];
127 }
128 /* remember new spectral params */
129 memcpy(rop->rmp->wlpart, refm.wlpart, sizeof(rop->rmp->wlpart));
130 rop->rmp->ncomp = refm.ncomp;
131 return(1);
132 }
133
134 /* Compute conversion row from spectrum to one channel of RGB */
135 static void
136 rgbrow(ROPMAT *rop, int r, int p)
137 {
138 const int nc = rop->imx.ncomp;
139 const float * wlp = rop->imx.wlpart;
140 int i;
141
142 for (i = nc; i--; ) {
143 int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc;
144 int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc;
145 COLOR crgb;
146 spec_rgb(crgb, nmStart, nmEnd);
147 rop->preop.cmat[r*nc+i] = crgb[p];
148 }
149 }
150
151 /* Compute conversion row from spectrum to one channel of XYZ */
152 static void
153 xyzrow(ROPMAT *rop, int r, int p)
154 {
155 const int nc = rop->imx.ncomp;
156 const float * wlp = rop->imx.wlpart;
157 int i;
158
159 for (i = nc; i--; ) {
160 int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc;
161 int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc;
162 COLOR cxyz;
163 spec_cie(cxyz, nmStart, nmEnd);
164 rop->preop.cmat[r*nc+i] = cxyz[p];
165 }
166 }
167
168 /* Use the spectral sensitivity function to compute matrix coefficients */
169 static void
170 sensrow(ROPMAT *rop, int r, double (*sf)(SCOLOR sc, int ncs, const float wlpt[4]))
171 {
172 const int nc = rop->imx.ncomp;
173 int i;
174
175 for (i = nc; i--; ) {
176 SCOLOR sclr;
177 memset(sclr, 0, sizeof(COLORV)*nc);
178 sclr[i] = 1.f;
179 rop->preop.cmat[r*nc+i] = (*sf)(sclr, nc, rop->imx.wlpart);
180 }
181 }
182
183 /* Check/set symbolic transform */
184 static int
185 checksymbolic(ROPMAT *rop)
186 {
187 const int nc = rop->imx.ncomp;
188 const int dt = rop->imx.dtype;
189 int i, j;
190 /* check suffix => reference file */
191 if (strchr(rop->preop.csym, '.') > rop->preop.csym)
192 return(checkreffile(rop));
193
194 if (nc < 3) {
195 fprintf(stderr, "%s: -c '%s' requires at least 3 components\n",
196 rop->inspec, rop->preop.csym);
197 return(0);
198 }
199 rop->preop.clen = strlen(rop->preop.csym) * nc;
200 if (rop->preop.clen > MAXCOMP*MAXCOMP) {
201 fprintf(stderr, "%s: -c '%s' results in too many components\n",
202 rop->inspec, rop->preop.csym);
203 return(0);
204 }
205 for (j = 0; rop->preop.csym[j]; j++) {
206 int comp = 0;
207 switch (rop->preop.csym[j]) {
208 case 'B':
209 ++comp;
210 /* fall through */
211 case 'G':
212 ++comp;
213 /* fall through */
214 case 'R':
215 if (dt == DTxyze) {
216 for (i = 3; i--; )
217 rop->preop.cmat[j*nc+i] = 1./WHTEFFICACY *
218 xyz2rgbmat[comp][i];
219 } else if (nc == 3)
220 rop->preop.cmat[j*nc+comp] = 1.;
221 else
222 rgbrow(rop, j, comp);
223 break;
224 case 'Z':
225 ++comp;
226 /* fall through */
227 case 'Y':
228 ++comp;
229 /* fall through */
230 case 'X':
231 if (dt == DTxyze) {
232 rop->preop.cmat[j*nc+comp] = 1.;
233 } else if (nc == 3) {
234 for (i = 3; i--; )
235 rop->preop.cmat[j*nc+i] =
236 rgb2xyzmat[comp][i];
237 } else if (comp == CIEY)
238 sensrow(rop, j, scolor2photopic);
239 else
240 xyzrow(rop, j, comp);
241
242 for (i = nc*(dt != DTxyze); i--; )
243 rop->preop.cmat[j*nc+i] *= WHTEFFICACY;
244 break;
245 case 'S': /* scotopic (il)luminance */
246 sensrow(rop, j, scolor2scotopic);
247 for (i = nc; i--; )
248 rop->preop.cmat[j*nc+i] *= WHTSCOTOPIC;
249 break;
250 case 'M': /* melanopic (il)luminance */
251 sensrow(rop, j, scolor2melanopic);
252 for (i = nc; i--; )
253 rop->preop.cmat[j*nc+i] *= WHTMELANOPIC;
254 break;
255 case 'A': /* average component */
256 for (i = nc; i--; )
257 rop->preop.cmat[j*nc+i] = 1./(double)nc;
258 break;
259 default:
260 fprintf(stderr, "%s: -c '%c' unsupported\n",
261 rop->inspec, rop->preop.csym[j]);
262 return(0);
263 }
264 }
265 if (!split_input(rop)) /* get our own struct */
266 return(0);
267 memcpy(rop->rmp->wlpart, WLPART, sizeof(rop->rmp->wlpart));
268 rop->rmp->ncomp = rop->preop.clen / nc;
269 /* decide on output type */
270 if (!strcmp(rop->preop.csym, "XYZ")) {
271 if (dt <= DTspec)
272 rop->rmp->dtype = DTxyze;
273 } else if (!strcmp(rop->preop.csym, "RGB")) {
274 if (dt <= DTspec)
275 rop->rmp->dtype = DTrgbe;
276 } else if (rop->rmp->dtype == DTspec)
277 rop->rmp->dtype = DTfloat;
278 return(1);
279 }
280
281 static int
282 get_component_xfm(ROPMAT *rop)
283 {
284 int i, j;
285
286 if (rop->rmp != &rop->imx) { /* reset destination matrix */
287 rmx_free(rop->rmp);
288 rop->rmp = &rop->imx;
289 }
290 if (rop->preop.csym && /* symbolic transform? */
291 !checksymbolic(rop))
292 return(0);
293 /* undo exposure? */
294 if (fabs(1. - bright(rop->rmp->cexp)) > .025) {
295 if (rop->rmp->ncomp == 1)
296 rop->rmp->cexp[RED] = rop->rmp->cexp[GRN] =
297 rop->rmp->cexp[BLU] = bright(rop->rmp->cexp);
298 if (rop->preop.nsf <= 0) {
299 rop->preop.nsf = i = rop->rmp->ncomp;
300 while (i--)
301 rop->preop.sca[i] = 1.;
302 }
303 if (rop->preop.nsf == 1) {
304 if (rop->rmp->ncomp == 3) {
305 rop->preop.sca[2] = rop->preop.sca[1] =
306 rop->preop.sca[0];
307 rop->preop.nsf = 3;
308 } else
309 rop->preop.sca[0] /= bright(rop->rmp->cexp);
310 }
311 if (rop->preop.nsf == 3) {
312 opcolor(rop->preop.sca, /=, rop->rmp->cexp);
313 } else if (rop->preop.nsf > 3) { /* punt */
314 double mult = 1./bright(rop->rmp->cexp);
315 for (i = rop->preop.nsf; i--; )
316 rop->preop.sca[i] *= mult;
317 }
318 setcolor(rop->rmp->cexp, 1., 1., 1.);
319 }
320 if (rop->preop.clen > 0) { /* use component transform? */
321 if (rop->preop.clen % rop->imx.ncomp) {
322 fprintf(stderr, "%s: -c must have N x %d coefficients\n",
323 rop->inspec, rop->imx.ncomp);
324 return(0);
325 }
326 if (rop->preop.nsf > 0) { /* scale transform, instead */
327 if (rop->preop.nsf == 1) {
328 for (i = rop->preop.clen; i--; )
329 rop->preop.cmat[i] *= rop->preop.sca[0];
330 } else if (rop->preop.nsf*rop->imx.ncomp != rop->preop.clen) {
331 fprintf(stderr, "%s: -s must have one or %d factors\n",
332 rop->inspec,
333 rop->preop.clen/rop->imx.ncomp);
334 return(0);
335 } else {
336 for (i = rop->preop.nsf; i--; )
337 for (j = rop->imx.ncomp; j--; )
338 rop->preop.cmat[i*rop->imx.ncomp+j]
339 *= rop->preop.sca[i];
340 }
341 }
342 rop->preop.nsf = 0; /* now folded in */
343 if (!split_input(rop)) /* get our own struct */
344 return(0);
345 rop->rmp->ncomp = rop->preop.clen / rop->imx.ncomp;
346 if ((rop->rmp->ncomp > 3) & (rop->rmp->dtype <= DTspec)) {
347 rop->rmp->dtype = DTfloat; /* probably not actual spectrum */
348 memcpy(rop->rmp->wlpart, WLPART, sizeof(rop->rmp->wlpart));
349 }
350 } else if (rop->preop.nsf > 0) { /* else use scalar(s)? */
351 if (rop->preop.nsf == 1) {
352 for (i = rop->rmp->ncomp; --i; )
353 rop->preop.sca[i] = rop->preop.sca[0];
354 rop->preop.nsf = rop->rmp->ncomp;
355 } else if (rop->preop.nsf != rop->rmp->ncomp) {
356 fprintf(stderr, "%s: -s must have one or %d factors\n",
357 rop->inspec, rop->rmp->ncomp);
358 return(0);
359 }
360 }
361 return(1);
362 }
363
364 static int
365 apply_op(RMATRIX *dst, const RMATRIX *src, const RUNARYOP *ro)
366 {
367 if (ro->clen > 0) {
368 RMATRIX *res = rmx_transform(src, dst->ncomp, ro->cmat);
369 if (!res) {
370 fputs("Error in call to rmx_transform()\n", stderr);
371 return(0);
372 }
373 if (!rmx_transfer_data(dst, res, 0))
374 return(0);
375 rmx_free(res);
376 } else if (dst != src)
377 memcpy(dst->mtx, src->mtx,
378 sizeof(double)*dst->ncomp*dst->ncols*dst->nrows);
379 if (ro->nsf == dst->ncomp)
380 rmx_scale(dst, ro->sca);
381 return(1);
382 }
383
384 static int
385 open_input(ROPMAT *rop)
386 {
387 int outtype;
388
389 if (!rop || !rop->inspec || !rop->inspec[0])
390 return(0);
391 if (rop->inspec == stdin_name)
392 rop->infp = stdin;
393 else if (rop->inspec[0] == '!')
394 rop->infp = popen(rop->inspec+1, "r");
395 else
396 rop->infp = fopen(rop->inspec, "rb");
397
398 if (!rmx_load_header(&rop->imx, rop->infp)) {
399 fprintf(stderr, "Bad header from: %s\n", rop->inspec);
400 return(0);
401 }
402 return(get_component_xfm(rop));
403 }
404
405 /* Return nominal wavelength associated with input component (return nm) */
406 static double
407 l_wavelength(char *nam)
408 {
409 double comp = argument(1);
410
411 if ((comp < -.5) | (comp >= in_ncomp+.5)) {
412 errno = EDOM;
413 return(.0);
414 }
415 if (comp < .5) /* asking for #components? */
416 return(in_ncomp);
417
418 if (in_ncomp == 3) { /* special case for RGB */
419 const int w0 = (int)(comp - .5);
420 return(mop[0].rmp->wlpart[w0] +
421 (comp-.5)*(mop[0].rmp->wlpart[w0+1] -
422 mop[0].rmp->wlpart[w0]));
423 }
424 return(mop[0].rmp->wlpart[0] + /* general case, even div. */
425 (comp-.5)/(double)in_ncomp *
426 (mop[0].rmp->wlpart[3] - mop[0].rmp->wlpart[0]));
427 }
428
429 /* Return ith input with optional channel selector */
430 static double
431 l_chanin(char *nam)
432 {
433 double inp = argument(1);
434 int mi, chan;
435
436 if ((mi = (int)(inp-.5)) < 0 || mi >= nmats) {
437 errno = EDOM;
438 return(.0);
439 }
440 if (inp < .5) /* asking for #inputs? */
441 return(nmats);
442
443 if (nargum() >= 2) {
444 double cval = argument(2);
445 if (cval < .5 || (chan = (int)(cval-.5)) >= in_ncomp) {
446 errno = EDOM;
447 return(.0);
448 }
449 } else
450 chan = cur_chan;
451
452 return(mop[mi].rmp->mtx[cur_col*in_ncomp + chan]);
453 }
454
455 static int
456 initialize(RMATRIX *imp)
457 {
458 int i;
459 /* XXX struct is zeroed coming in */
460 setcolor(imp->cexp, 1.f, 1.f, 1.f);
461 for (i = 0; i < nmats; i++) { /* open each input */
462 int restype;
463 if (!open_input(&mop[i]))
464 return(0);
465 restype = mop[i].rmp->dtype;
466 if (!imp->dtype || (restype = rmx_newtype(restype, imp->dtype)) > 0)
467 imp->dtype = restype;
468 else
469 fprintf(stderr, "%s: warning - data type mismatch\n",
470 mop[i].inspec);
471 if (!i) {
472 imp->nrows = in_nrows = mop[0].rmp->nrows;
473 imp->ncols = mop[0].rmp->ncols;
474 imp->ncomp = mop[0].rmp->ncomp;
475 memcpy(imp->wlpart, mop[0].rmp->wlpart, sizeof(imp->wlpart));
476 } else if ((mop[i].rmp->nrows != imp->nrows) |
477 (mop[i].rmp->ncols != imp->ncols) |
478 (mop[i].rmp->ncomp != imp->ncomp)) {
479 fprintf(stderr, "%s: mismatch in size or #components\n",
480 mop[i].inspec);
481 return(0);
482 } /* XXX should check wlpart? */
483 } /* set up .cal environment */
484 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
485 esupport &= ~(E_OUTCHAN|E_INCHAN);
486 varset("PI", ':', M_PI);
487 varset("nfiles", ':', nmats);
488 varset("nrows", ':', in_nrows);
489 varset("ncols", ':', in_ncols);
490 varset("ncomp", ':', in_ncomp);
491 varset("R", ':', 1.);
492 varset("G", ':', 2.);
493 varset("B", ':', 3.);
494 funset("wl", 1, ':', l_wavelength);
495 funset("ci", 1, '=', l_chanin);
496 scompile("ri(i)=ci(i,R);gi(i)=ci(i,G);bi(i)=ci(i,B)", NULL, 0);
497 return(1);
498 }
499
500 static void
501 output_headinfo(FILE *fp)
502 {
503 int i;
504
505 for (i = 0; i < nmats; i++) {
506 const char *cp = mop[i].imx.info;
507 fputs(mop[i].inspec, fp);
508 fputs(":\n", fp);
509 if (!cp) continue;
510 while (*cp) {
511 if (*cp == '\n') {
512 cp++; /* avoid inadvertant terminus */
513 continue;
514 }
515 fputc('\t', fp); /* indent this input's info */
516 do
517 putc(*cp, fp);
518 while (*cp++ != '\n');
519 }
520 }
521 }
522
523 static int
524 combine_input(ROPMAT *res, FILE *fout)
525 {
526 int set_r, set_c;
527 RMATRIX *tmp = NULL;
528 int co_set;
529 int i;
530 /* allocate input row buffers */
531 for (i = 0; i < nmats; i++) {
532 mop[i].imx.nrows = 1; /* we'll be doing a row at a time */
533 if (!rmx_prepare(&mop[i].imx))
534 goto memerror;
535 if (mop[i].rmp != &mop[i].imx) {
536 mop[i].rmp->nrows = 1;
537 if (!rmx_prepare(mop[i].rmp))
538 goto memerror;
539 }
540 }
541 /* prep output row buffers */
542 if (mcat || res->preop.clen > 0) {
543 if (!split_input(res)) /* need separate buffer */
544 return(0);
545 if (res->preop.clen > 0)
546 res->rmp->ncomp = res->preop.clen / res->imx.ncomp;
547 res->rmp->nrows = 1;
548 if (!mcat | !mcat_last && !rmx_prepare(res->rmp))
549 goto memerror;
550 }
551 if (mcat && mcat_last &&
552 !(tmp = rmx_alloc(1, res->imx.ncols, res->rmp->ncomp)))
553 goto memerror;
554 res->imx.nrows = 1;
555 if (!rmx_prepare(&res->imx))
556 goto memerror;
557 /* figure out what the user set */
558 co_set = fundefined("co");
559 if (!co_set)
560 co_set = -vardefined("co");
561 if (!co_set & (in_ncomp == 3) && vardefined("ro") &&
562 vardefined("go") && vardefined("bo")) {
563 scompile("co(p)=select(p,ro,go,bo)", NULL, 0);
564 co_set = 1;
565 }
566 if (co_set) { /* set if user wants, didn't set */
567 set_r = varlookup("r") != NULL && !vardefined("r");
568 set_c = varlookup("c") != NULL && !vardefined("c");
569 } else /* save a little time */
570 set_r = set_c = 0;
571 /* read/process row-by-row */
572 for (cur_row = 0; cur_row < in_nrows; cur_row++) {
573 RMATRIX *mres = NULL;
574 for (i = 0; i < nmats; i++) {
575 if (!rmx_load_row(mop[i].imx.mtx, &mop[i].imx, mop[i].infp)) {
576 fprintf(stderr, "%s: read error at row %d\n",
577 mop[i].inspec, cur_row);
578 return(0);
579 }
580 if (!apply_op(mop[i].rmp, &mop[i].imx, &mop[i].preop))
581 return(0);
582 }
583 if (set_r) varset("r", '=', cur_row);
584 for (cur_col = 0; cur_col < in_ncols; cur_col++) {
585 if (set_c) varset("c", '=', cur_col);
586 for (cur_chan = 0; cur_chan < in_ncomp; cur_chan++) {
587 const int ndx = cur_col*in_ncomp + cur_chan;
588 eclock++;
589 if (!co_set) { /* just summing elements? */
590 res->imx.mtx[ndx] = 0;
591 for (i = nmats; i--; )
592 res->imx.mtx[ndx] += mop[i].rmp->mtx[ndx];
593 } else if (co_set > 0) {
594 double dchan = cur_chan+1;
595 res->imx.mtx[ndx] = funvalue("co", 1, &dchan);
596 } else
597 res->imx.mtx[ndx] = varvalue("co");
598 }
599 } /* final conversions */
600 if (!mcat) {
601 if (!apply_op(res->rmp, &res->imx, &res->preop))
602 return(0);
603 } else if (mcat_last) {
604 if (!apply_op(tmp, &res->imx, &res->preop))
605 return(0);
606 mres = rmx_multiply(tmp, mcat);
607 if (!mres)
608 goto multerror;
609 if (!rmx_transfer_data(res->rmp, mres, 0))
610 return(0);
611 } else /* mcat && !mcat_last */ {
612 mres = rmx_multiply(&res->imx, mcat);
613 if (!mres)
614 goto multerror;
615 if (!apply_op(res->rmp, mres, &res->preop))
616 return(0);
617 }
618 rmx_free(mres); mres = NULL;
619 if (!rmx_write_data(res->rmp->mtx, res->rmp->ncomp,
620 res->rmp->ncols, res->rmp->dtype, fout))
621 return(0);
622 }
623 #if 0 /* we're about to exit, so who cares? */
624 rmx_free(tmp); /* clean up */
625 rmx_reset(res->rmp);
626 rmx_reset(&res->imx);
627 for (i = 0; i < nmats; i++) {
628 rmx_reset(mop[i].rmp);
629 rmx_reset(&mop[i].imx);
630 if (mop[i].inspec[0] == '!')
631 pclose(mop[i].infp);
632 else if (mop[i].inspec != stdin_name)
633 fclose(mop[i].infp);
634 mop[i].infp = NULL;
635 }
636 #endif
637 return(fflush(fout) != EOF);
638 memerror:
639 fputs("Out of buffer space in combine_input()\n", stderr);
640 return(0);
641 multerror:
642 fputs("Unexpected matrix multiply error in combine_input()\n", stderr);
643 return(0);
644 }
645
646 static int
647 get_factors(double da[], int n, char *av[])
648 {
649 int ac;
650
651 for (ac = 0; ac < n && isflt(av[ac]); ac++)
652 da[ac] = atof(av[ac]);
653 return(ac);
654 }
655
656 static void
657 resize_inparr(int n2alloc)
658 {
659 int i;
660
661 for (i = nmats; i > n2alloc; i--) {
662 rmx_reset(&mop[i].imx);
663 if (mop[i].rmp != &mop[i].imx)
664 rmx_free(mop[i].rmp);
665 }
666 mop = (ROPMAT *)realloc(mop, n2alloc*sizeof(ROPMAT));
667 if (mop == NULL) {
668 fputs("Out of memory in resize_inparr()\n", stderr);
669 exit(1);
670 }
671 if (n2alloc > nmats)
672 memset(mop+nmats, 0, (n2alloc-nmats)*sizeof(ROPMAT));
673 nall = n2alloc;
674 }
675
676 /* Load one or more matrices and operate on them, sending results to stdout */
677 int
678 main(int argc, char *argv[])
679 {
680
681 int outfmt = DTfromHeader;
682 const char *defCsym = NULL;
683 int echoheader = 1;
684 int stdin_used = 0;
685 const char *mcat_spec = NULL;
686 int n2comp = 0;
687 uby8 comp_ndx[128];
688 int i;
689 /* get starting input array */
690 mop = (ROPMAT *)calloc(nall=2, sizeof(ROPMAT));
691 /* get options and arguments */
692 for (i = 1; i < argc; i++)
693 if (argv[i][0] != '-' || !argv[i][1]) {
694 if (argv[i][0] == '-') {
695 if (stdin_used++) goto stdin_error;
696 mop[nmats].inspec = stdin_name;
697 } else
698 mop[nmats].inspec = argv[i];
699 if (!mop[nmats].preop.csym)
700 mop[nmats].preop.csym = defCsym;
701 if (++nmats >= nall)
702 resize_inparr(nmats + (nmats>>2) + 2);
703 } else {
704 int n = argc-1 - i;
705 switch (argv[i][1]) { /* get option */
706 case 'w':
707 nowarn = !nowarn;
708 break;
709 case 'h':
710 echoheader = !echoheader;
711 break;
712 case 'e':
713 if (!n) goto userr;
714 comp_ndx[n2comp++] = i++;
715 break;
716 case 'f':
717 switch (argv[i][2]) {
718 case '\0':
719 if (!n) goto userr;
720 comp_ndx[n2comp++] = i++;
721 break;
722 case 'd':
723 outfmt = DTdouble;
724 break;
725 case 'f':
726 outfmt = DTfloat;
727 break;
728 case 'a':
729 outfmt = DTascii;
730 break;
731 case 'c':
732 outfmt = DTrgbe;
733 break;
734 default:
735 goto userr;
736 }
737 break;
738 case 's':
739 if (n > MAXCOMP) n = MAXCOMP;
740 i += mop[nmats].preop.nsf =
741 get_factors(mop[nmats].preop.sca,
742 n, argv+i+1);
743 if (mop[nmats].preop.nsf <= 0) {
744 fprintf(stderr, "%s: -s missing arguments\n",
745 argv[0]);
746 goto userr;
747 }
748 break;
749 case 'C':
750 if (!n || isflt(argv[i+1]))
751 goto userr;
752 defCsym = mop[nmats].preop.csym = argv[++i];
753 mop[nmats].preop.clen = 0;
754 mcat_last = 0;
755 break;
756 case 'c':
757 if (n && !isflt(argv[i+1])) {
758 mop[nmats].preop.csym = argv[++i];
759 mop[nmats].preop.clen = 0;
760 break;
761 }
762 if (n > MAXCOMP*MAXCOMP) n = MAXCOMP*MAXCOMP;
763 i += mop[nmats].preop.clen =
764 get_factors(mop[nmats].preop.cmat,
765 n, argv+i+1);
766 if (mop[nmats].preop.clen <= 0) {
767 fprintf(stderr, "%s: -c missing arguments\n",
768 argv[0]);
769 goto userr;
770 }
771 mop[nmats].preop.csym = NULL;
772 mcat_last = 0;
773 break;
774 case 'm':
775 if (!n) goto userr;
776 if (argv[++i][0] == '-' && !argv[i][1]) {
777 if (stdin_used++) goto stdin_error;
778 mcat_spec = stdin_name;
779 } else
780 mcat_spec = argv[i];
781 mcat_last = 1;
782 break;
783 default:
784 fprintf(stderr, "%s: unknown option '%s'\n",
785 argv[0], argv[i]);
786 goto userr;
787 }
788 }
789 if (!nmats) {
790 fprintf(stderr, "%s: need at least one input matrix\n", argv[0]);
791 goto userr;
792 }
793 resize_inparr(nmats+1); /* extra matrix at end for result */
794 mop[nmats].inspec = "trailing_ops";
795 /* load final concatenation matrix */
796 if (mcat_spec && !(mcat = rmx_load(mcat_spec, RMPnone))) {
797 fprintf(stderr, "%s: error loading concatenation matrix: %s\n",
798 argv[0], mcat_spec);
799 return(1);
800 }
801 /* get/check inputs, set constants */
802 if (!initialize(&mop[nmats].imx))
803 return(1);
804
805 for (i = 0; i < n2comp; i++) /* user .cal files and expressions */
806 if (argv[comp_ndx[i]][1] == 'f') {
807 char *fpath = getpath(argv[comp_ndx[i]+1],
808 getrlibpath(), 0);
809 if (fpath == NULL) {
810 fprintf(stderr, "%s: cannot find file '%s'\n",
811 argv[0], argv[comp_ndx[i]+1]);
812 return(1);
813 }
814 fcompile(fpath);
815 } else /* (argv[comp_ndx[i]][1] == 'e') */
816 scompile(argv[comp_ndx[i]+1], NULL, 0);
817
818 /* get trailing color transform */
819 if (!get_component_xfm(&mop[nmats]))
820 return(1);
821 /* adjust output dimensions and #components */
822 if (mcat) {
823 if (mop[nmats].imx.ncols != mcat->nrows) {
824 fprintf(stderr,
825 "%s: number of input columns does not match number of rows in '%s'\n",
826 argv[0], mcat_spec);
827 return(1);
828 }
829 if (mcat->ncomp != (mcat_last ? mop[nmats].rmp->ncomp : mop[nmats].imx.ncomp)) {
830 fprintf(stderr,
831 "%s: number of components does not match those in '%s'\n",
832 argv[0], mcat_spec);
833 return(1);
834 }
835 if (!split_input(&mop[nmats]))
836 return(1);
837 mop[nmats].rmp->ncols = mcat->ncols;
838 }
839 newheader("RADIANCE", stdout); /* write output header */
840 if (echoheader)
841 output_headinfo(stdout);
842 printargs(argc, argv, stdout);
843 fputnow(stdout);
844 mop[nmats].rmp->dtype = rmx_write_header(mop[nmats].rmp, outfmt, stdout);
845 if (!mop[nmats].rmp->dtype) {
846 fprintf(stderr, "%s: unsupported output format\n", argv[0]);
847 return(1);
848 }
849 /* process & write rows */
850 return(combine_input(&mop[nmats], stdout) ? 0 : 1);
851 stdin_error:
852 fprintf(stderr, "%s: %s used for more than one input\n",
853 argv[0], stdin_name);
854 return(1);
855 userr:
856 fprintf(stderr,
857 "Usage: %s [-h][-f{adfc}][-e expr][-f file][-s sf .. | -c ce ..] m1 .. -m mcat > mres\n",
858 argv[0]);
859 return(1);
860 }
