root/radiance/ray/src/util/rcomb.c
Sun May 19 15:32:24 2024 UTC (21 hours, 7 minutes ago) by greg
feat: Added facility for app-managed matrix memory
Thu May 16 18:59:19 2024 UTC (3 days, 17 hours ago) by greg
fix: Made use of resolu.h more consistent and reliable
Fri Feb 23 03:47:57 2024 UTC (2 months, 3 weeks ago) by greg
Fri Feb 9 19:58:56 2024 UTC (3 months, 1 week ago) by greg
Changes since 2.5: +6 -4 lines
fix(rcomb): Fixed issue with final operations (reallocation error)
Tue Dec 19 20:38:38 2023 UTC (5 months ago) by greg
fix(rcomb): Restored error message if no rows read from input
Tue Dec 19 16:09:20 2023 UTC (5 months ago) by greg
fix(rmtxop,rcomb): Added checks for "xyz" and "rgb" format output
Tue Dec 19 00:39:03 2023 UTC (5 months ago) by greg
Changes since 2.2: +26 -9 lines
feat(rmtxop,rcomb): Added lower-case versions of component outputs w/o efficacy conversions
Mon Dec 18 23:04:05 2023 UTC (5 months ago) by greg
Changes since 2.1: +13 -8 lines
fix(rcomb): Fixed handling of matrix inputs where NROWS is unspecified
Tue Dec 12 16:31:45 2023 UTC (5 months, 1 week ago) by greg
Diff to selected 2.3
