1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rcomb.c,v 2.31 2025/04/18 23:59:03 greg Exp $"; |
3 |
#endif |
4 |
5 |
* General component matrix combiner, operating on a row at a time. |
6 |
7 |
* Multi-processing mode under Unix creates children that each work |
8 |
* on one input row at a time, fed by the original process. Final conversion |
9 |
* and output to stdout is sorted by last child while its siblings send it |
10 |
* their record calculations. |
11 |
12 |
13 |
#include <math.h> |
14 |
#include "platform.h" |
15 |
#include "rtprocess.h" |
16 |
#include "rtio.h" |
17 |
#include "rmatrix.h" |
18 |
#include "calcomp.h" |
19 |
20 |
#ifndef M_PI |
21 |
#define M_PI 3.14159265358979323846 |
22 |
#endif |
23 |
24 |
/* Unary matrix operation(s) */ |
25 |
typedef struct { |
26 |
double cmat[MAXCOMP*MAXCOMP]; /* component transformation */ |
27 |
double sca[MAXCOMP]; /* scalar coefficients */ |
28 |
const char *csym; /* symbolic coefficients */ |
29 |
short clen; /* number of coefficients */ |
30 |
short nsf; /* number of scalars */ |
31 |
} RUNARYOP; |
32 |
33 |
/* Input matrix */ |
34 |
typedef struct { |
35 |
const char *inspec; /* input specification */ |
36 |
RUNARYOP preop; /* transform operation */ |
37 |
RMATRIX imx; /* input matrix header info */ |
38 |
RMATRIX *rmp; /* active single-row matrix */ |
39 |
FILE *infp; /* open input stream */ |
40 |
} ROPMAT; |
41 |
42 |
ROPMAT *mop = NULL; /* allocated input array */ |
43 |
int nall = 0; /* number allocated */ |
44 |
int nmats = 0; /* number of actual inputs */ |
45 |
46 |
RMATRIX *mcat = NULL; /* final concatenation */ |
47 |
int mcat_last = 0; /* goes after trailing ops? */ |
48 |
49 |
int in_nrows; /* number of input rows (or 0) */ |
50 |
#define in_ncols (mop[0].rmp->ncols) /* number of input columns */ |
51 |
#define in_ncomp (mop[0].rmp->ncomp) /* input #components */ |
52 |
53 |
extern int nowarn; /* turn off warnings? */ |
54 |
55 |
int cur_row; /* current input/output row */ |
56 |
int cur_col; /* current input/output column */ |
57 |
int cur_chan; /* if we're looping channels */ |
58 |
59 |
SUBPROC *cproc = NULL; /* child process array */ |
60 |
int nchildren = 0; /* # of child processes */ |
61 |
int inchild = -1; /* our child ID (-1: parent) */ |
62 |
63 |
extern int checksymbolic(ROPMAT *rop); |
64 |
65 |
int |
66 |
split_input(ROPMAT *rop) |
67 |
68 |
if (rop->rmp == &rop->imx && !(rop->rmp = rmx_copy(&rop->imx))) { |
69 |
fputs("Out of memory in split_input()\n", stderr); |
70 |
return(0); |
71 |
72 |
rmx_reset(rop->rmp); |
73 |
return(1); |
74 |
75 |
76 |
/* Check/set transform based on a reference input file */ |
77 |
int |
78 |
checkreffile(ROPMAT *rop) |
79 |
80 |
static const char *curRF = NULL; |
81 |
static RMATRIX refm; |
82 |
const int nc = rop->imx.ncomp; |
83 |
int i; |
84 |
85 |
if (!curRF || strcmp(rop->preop.csym, curRF)) { |
86 |
FILE *fp = fopen(rop->preop.csym, "rb"); |
87 |
if (!rmx_load_header(&refm, fp)) { |
88 |
fprintf(stderr, "%s: cannot read info header\n", |
89 |
rop->preop.csym); |
90 |
curRF = NULL; |
91 |
if (fp) fclose(fp); |
92 |
return(0); |
93 |
94 |
fclose(fp); |
95 |
curRF = rop->preop.csym; |
96 |
97 |
if (refm.ncomp == 3) { |
98 |
rop->preop.csym = (refm.dtype == DTxyze) ? "XYZ" : "RGB"; |
99 |
return(checksymbolic(rop)); |
100 |
101 |
if (refm.ncomp == 2) { |
102 |
fprintf(stderr, "%s: cannot convert to 2 components\n", |
103 |
curRF); |
104 |
return(0); |
105 |
106 |
if (refm.ncomp == 1) { |
107 |
rop->preop.csym = "Y"; /* XXX big assumption */ |
108 |
109 |
110 |
if (refm.ncomp == nc && |
111 |
!memcmp(refm.wlpart, rop->imx.wlpart, sizeof(refm.wlpart))) |
112 |
return(1); /* nothing to do */ |
113 |
114 |
if ((nc <= 3) | (nc > MAXCSAMP) | (refm.ncomp > MAXCSAMP)) { |
115 |
fprintf(stderr, "%s: cannot resample from %d to %d components\n", |
116 |
curRF, nc, refm.ncomp); |
117 |
return(0); |
118 |
119 |
if (!split_input(rop)) /* get our own struct */ |
120 |
return(0); |
121 |
rop->preop.clen = refm.ncomp * nc; /* compute spec to ref */ |
122 |
123 |
for (i = 0; i < nc; i++) { |
124 |
SCOLOR scstim, scresp; |
125 |
int j; |
126 |
memset(scstim, 0, sizeof(COLORV)*nc); |
127 |
scstim[i] = 1.f; |
128 |
convertscolor(scresp, refm.ncomp, refm.wlpart[0], refm.wlpart[3], |
129 |
scstim, nc, rop->imx.wlpart[0], rop->imx.wlpart[3]); |
130 |
for (j = refm.ncomp; j-- > 0; ) |
131 |
rop->preop.cmat[j*nc + i] = scresp[j]; |
132 |
133 |
/* remember new spectral params */ |
134 |
memcpy(rop->rmp->wlpart, refm.wlpart, sizeof(rop->rmp->wlpart)); |
135 |
rop->rmp->ncomp = refm.ncomp; |
136 |
return(1); |
137 |
138 |
139 |
/* Compute conversion row from spectrum to one channel of RGB */ |
140 |
void |
141 |
rgbrow(ROPMAT *rop, int r, int p) |
142 |
143 |
144 |
const float * wlp = rop->imx.wlpart; |
145 |
int i; |
146 |
147 |
for (i = nc; i--; ) { |
148 |
int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc; |
149 |
int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc; |
150 |
COLOR crgb; |
151 |
spec_rgb(crgb, nmStart, nmEnd); |
152 |
rop->preop.cmat[r*nc+i] = crgb[p]; |
153 |
154 |
155 |
156 |
/* Compute conversion row from spectrum to one channel of XYZ */ |
157 |
void |
158 |
xyzrow(ROPMAT *rop, int r, int p) |
159 |
160 |
161 |
162 |
int i; |
163 |
164 |
165 |
166 |
167 |
COLOR cxyz; |
168 |
spec_cie(cxyz, nmStart, nmEnd); |
169 |
rop->preop.cmat[r*nc+i] = cxyz[p]; |
170 |
171 |
172 |
173 |
/* Use the spectral sensitivity function to compute matrix coefficients */ |
174 |
void |
175 |
sensrow(ROPMAT *rop, int r, double (*sf)(const SCOLOR sc, int ncs, const float wlpt[4])) |
176 |
177 |
178 |
int i; |
179 |
180 |
181 |
SCOLOR sclr; |
182 |
memset(sclr, 0, sizeof(COLORV)*nc); |
183 |
sclr[i] = 1.f; |
184 |
rop->preop.cmat[r*nc+i] = (*sf)(sclr, nc, rop->imx.wlpart); |
185 |
186 |
187 |
188 |
/* Check/set symbolic transform */ |
189 |
int |
190 |
checksymbolic(ROPMAT *rop) |
191 |
192 |
193 |
const int dt = rop->imx.dtype; |
194 |
double cf = 1; |
195 |
int i, j; |
196 |
/* check suffix => reference file */ |
197 |
if (strchr(rop->preop.csym, '.') > rop->preop.csym) |
198 |
return(checkreffile(rop)); |
199 |
200 |
if (nc < 3) { |
201 |
fprintf(stderr, "%s: -c '%s' requires at least 3 components\n", |
202 |
rop->inspec, rop->preop.csym); |
203 |
return(0); |
204 |
205 |
rop->preop.clen = strlen(rop->preop.csym) * nc; |
206 |
if (rop->preop.clen > MAXCOMP*MAXCOMP) { |
207 |
fprintf(stderr, "%s: -c '%s' results in too many components\n", |
208 |
209 |
return(0); |
210 |
211 |
for (j = 0; rop->preop.csym[j]; j++) { |
212 |
int comp = 0; |
213 |
switch (rop->preop.csym[j]) { |
214 |
case 'B': |
215 |
case 'b': |
216 |
++comp; |
217 |
/* fall through */ |
218 |
case 'G': |
219 |
case 'g': |
220 |
++comp; |
221 |
222 |
case 'R': |
223 |
case 'r': |
224 |
if (rop->preop.csym[j] <= 'Z') |
225 |
cf = 1./WHTEFFICACY; |
226 |
if (dt == DTxyze) { |
227 |
for (i = 3; i--; ) |
228 |
rop->preop.cmat[j*nc+i] = cf*xyz2rgbmat[comp][i]; |
229 |
} else if (nc == 3) |
230 |
rop->preop.cmat[j*nc+comp] = 1.; |
231 |
else |
232 |
rgbrow(rop, j, comp); |
233 |
break; |
234 |
case 'Z': |
235 |
case 'z': |
236 |
++comp; |
237 |
238 |
case 'Y': |
239 |
case 'y': |
240 |
++comp; |
241 |
242 |
case 'X': |
243 |
case 'x': |
244 |
if ((rop->preop.csym[j] <= 'Z') & (dt != DTxyze)) |
245 |
cf = WHTEFFICACY; |
246 |
247 |
248 |
} else if (nc == 3) { |
249 |
250 |
rop->preop.cmat[j*nc+i] = |
251 |
rgb2xyzmat[comp][i]; |
252 |
} else if (comp == CIEY) |
253 |
sensrow(rop, j, scolor2photopic); |
254 |
else |
255 |
xyzrow(rop, j, comp); |
256 |
257 |
for (i = nc*(cf != 1); i--; ) |
258 |
rop->preop.cmat[j*nc+i] *= cf; |
259 |
break; |
260 |
case 'S': /* scotopic (il)luminance */ |
261 |
cf = WHTSCOTOPIC; |
262 |
263 |
case 's': |
264 |
sensrow(rop, j, scolor2scotopic); |
265 |
266 |
267 |
break; |
268 |
case 'M': /* melanopic (il)luminance */ |
269 |
cf = WHTMELANOPIC; |
270 |
271 |
case 'm': |
272 |
sensrow(rop, j, scolor2melanopic); |
273 |
274 |
275 |
break; |
276 |
case 'A': /* average component */ |
277 |
case 'a': |
278 |
for (i = nc; i--; ) |
279 |
rop->preop.cmat[j*nc+i] = 1./(double)nc; |
280 |
break; |
281 |
default: |
282 |
fprintf(stderr, "%s: -c '%c' unsupported\n", |
283 |
rop->inspec, rop->preop.csym[j]); |
284 |
return(0); |
285 |
286 |
287 |
288 |
return(0); |
289 |
memcpy(rop->rmp->wlpart, WLPART, sizeof(rop->rmp->wlpart)); |
290 |
rop->rmp->ncomp = rop->preop.clen / nc; |
291 |
/* decide on output type */ |
292 |
if (!strcasecmp(rop->preop.csym, "XYZ")) { |
293 |
if (dt <= DTspec) |
294 |
rop->rmp->dtype = DTxyze; |
295 |
} else if (!strcasecmp(rop->preop.csym, "RGB")) { |
296 |
if (dt <= DTspec) |
297 |
rop->rmp->dtype = DTrgbe; |
298 |
} else if (rop->rmp->dtype == DTspec) |
299 |
rop->rmp->dtype = DTfloat; |
300 |
return(1); |
301 |
302 |
303 |
int |
304 |
get_component_xfm(ROPMAT *rop) |
305 |
306 |
int i, j; |
307 |
308 |
if (rop->rmp != &rop->imx) { /* reset destination matrix */ |
309 |
rmx_free(rop->rmp); |
310 |
rop->rmp = &rop->imx; |
311 |
312 |
if (rop->preop.csym && /* symbolic transform? */ |
313 |
!checksymbolic(rop)) |
314 |
return(0); |
315 |
/* undo exposure? */ |
316 |
if (fabs(1. - bright(rop->rmp->cexp)) > .025) { |
317 |
if (rop->rmp->ncomp == 1) |
318 |
rop->rmp->cexp[RED] = rop->rmp->cexp[GRN] = |
319 |
rop->rmp->cexp[BLU] = bright(rop->rmp->cexp); |
320 |
if (rop->preop.nsf <= 0) { |
321 |
rop->preop.nsf = i = rop->rmp->ncomp; |
322 |
while (i--) |
323 |
rop->preop.sca[i] = 1.; |
324 |
325 |
if (rop->preop.nsf == 1) { |
326 |
if (rop->rmp->ncomp == 3) { |
327 |
rop->preop.sca[2] = rop->preop.sca[1] = |
328 |
rop->preop.sca[0]; |
329 |
rop->preop.nsf = 3; |
330 |
} else |
331 |
rop->preop.sca[0] /= bright(rop->rmp->cexp); |
332 |
333 |
if (rop->preop.nsf == 3) { |
334 |
opcolor(rop->preop.sca, /=, rop->rmp->cexp); |
335 |
} else if (rop->preop.nsf > 3) { /* punt */ |
336 |
double mult = 1./bright(rop->rmp->cexp); |
337 |
for (i = rop->preop.nsf; i--; ) |
338 |
rop->preop.sca[i] *= mult; |
339 |
340 |
setcolor(rop->rmp->cexp, 1., 1., 1.); |
341 |
342 |
if (rop->preop.clen > 0) { /* use component transform? */ |
343 |
if (rop->preop.clen % rop->imx.ncomp) { |
344 |
fprintf(stderr, "%s: -c must have N x %d coefficients\n", |
345 |
rop->inspec, rop->imx.ncomp); |
346 |
return(0); |
347 |
348 |
if (rop->preop.nsf > 0) { /* scale transform, instead */ |
349 |
350 |
for (i = rop->preop.clen; i--; ) |
351 |
rop->preop.cmat[i] *= rop->preop.sca[0]; |
352 |
} else if (rop->preop.nsf*rop->imx.ncomp != rop->preop.clen) { |
353 |
fprintf(stderr, "%s: -s must have one or %d factors\n", |
354 |
rop->inspec, |
355 |
rop->preop.clen/rop->imx.ncomp); |
356 |
return(0); |
357 |
} else { |
358 |
359 |
for (j = rop->imx.ncomp; j--; ) |
360 |
rop->preop.cmat[i*rop->imx.ncomp+j] |
361 |
*= rop->preop.sca[i]; |
362 |
363 |
364 |
rop->preop.nsf = 0; /* now folded in */ |
365 |
366 |
return(0); |
367 |
rop->rmp->ncomp = rop->preop.clen / rop->imx.ncomp; |
368 |
if ((rop->rmp->ncomp > 3) & (rop->rmp->dtype <= DTspec)) { |
369 |
rop->rmp->dtype = DTfloat; /* probably not actual spectrum */ |
370 |
371 |
372 |
} else if (rop->preop.nsf > 0) { /* else use scalar(s)? */ |
373 |
374 |
for (i = rop->rmp->ncomp; --i; ) |
375 |
rop->preop.sca[i] = rop->preop.sca[0]; |
376 |
rop->preop.nsf = rop->rmp->ncomp; |
377 |
} else if (rop->preop.nsf != rop->rmp->ncomp) { |
378 |
379 |
rop->inspec, rop->rmp->ncomp); |
380 |
return(0); |
381 |
382 |
383 |
return(1); |
384 |
385 |
386 |
int |
387 |
apply_op(RMATRIX *dst, const RMATRIX *src, const RUNARYOP *ro) |
388 |
389 |
if (ro->clen > 0) { |
390 |
RMATRIX *res = rmx_transform(src, dst->ncomp, ro->cmat); |
391 |
if (!res) { |
392 |
fputs("Error in call to rmx_transform()\n", stderr); |
393 |
return(0); |
394 |
395 |
if (!rmx_transfer_data(dst, res, 0)) |
396 |
return(0); |
397 |
rmx_free(res); |
398 |
} else if (dst != src) |
399 |
memcpy(dst->mtx, src->mtx, rmx_array_size(dst)); |
400 |
if (ro->nsf == dst->ncomp) |
401 |
rmx_scale(dst, ro->sca); |
402 |
return(1); |
403 |
404 |
405 |
int |
406 |
open_input(ROPMAT *rop) |
407 |
408 |
int outtype; |
409 |
410 |
if (!rop || !rop->inspec || !rop->inspec[0]) |
411 |
return(0); |
412 |
if (rop->inspec == stdin_name) |
413 |
rop->infp = stdin; |
414 |
else if (rop->inspec[0] == '!') |
415 |
rop->infp = popen(rop->inspec+1, "r"); |
416 |
else |
417 |
rop->infp = fopen(rop->inspec, "rb"); |
418 |
419 |
if (!rmx_load_header(&rop->imx, rop->infp)) { |
420 |
fprintf(stderr, "Bad header from: %s\n", rop->inspec); |
421 |
return(0); |
422 |
423 |
return(get_component_xfm(rop)); |
424 |
425 |
426 |
/* Return nominal wavelength associated with input component (return nm) */ |
427 |
double |
428 |
l_wavelength(char *nam) |
429 |
430 |
double comp = argument(1); |
431 |
432 |
if ((comp < -.5) | (comp >= in_ncomp+.5)) { |
433 |
errno = EDOM; |
434 |
return(.0); |
435 |
436 |
if (comp < .5) /* asking for #components? */ |
437 |
return(in_ncomp); |
438 |
439 |
if (in_ncomp == 3) { /* special case for RGB */ |
440 |
const int w0 = (int)(comp - .5); |
441 |
return(mop[0].rmp->wlpart[w0] + |
442 |
(comp-.5)*(mop[0].rmp->wlpart[w0+1] - |
443 |
mop[0].rmp->wlpart[w0])); |
444 |
445 |
return(mop[0].rmp->wlpart[0] + /* general case, even div. */ |
446 |
(comp-.5)/(double)in_ncomp * |
447 |
(mop[0].rmp->wlpart[3] - mop[0].rmp->wlpart[0])); |
448 |
449 |
450 |
/* Return ith input with optional channel selector */ |
451 |
double |
452 |
l_chanin(char *nam) |
453 |
454 |
double inp = argument(1); |
455 |
int mi, chan; |
456 |
457 |
if ((mi = (int)(inp-.5)) < 0 || mi >= nmats) { |
458 |
errno = EDOM; |
459 |
return(.0); |
460 |
461 |
if (inp < .5) /* asking for #inputs? */ |
462 |
return(nmats); |
463 |
464 |
if (nargum() >= 2) { |
465 |
double cval = argument(2); |
466 |
if (cval < .5 || (chan = (int)(cval-.5)) >= in_ncomp) { |
467 |
errno = EDOM; |
468 |
return(.0); |
469 |
470 |
} else |
471 |
chan = cur_chan; |
472 |
473 |
return(mop[mi].rmp->mtx[cur_col*in_ncomp + chan]); |
474 |
475 |
476 |
int |
477 |
initialize(RMATRIX *imp) |
478 |
479 |
int i; |
480 |
/* XXX struct is zeroed coming in */ |
481 |
setcolor(imp->cexp, 1.f, 1.f, 1.f); |
482 |
for (i = 0; i < nmats; i++) { /* open each input */ |
483 |
int restype; |
484 |
if (!open_input(&mop[i])) |
485 |
return(0); |
486 |
restype = mop[i].rmp->dtype; |
487 |
if (!imp->dtype || (restype = rmx_newtype(restype, imp->dtype)) > 0) |
488 |
imp->dtype = restype; |
489 |
else if (!nowarn) |
490 |
fprintf(stderr, "%s: warning - data type mismatch\n", |
491 |
mop[i].inspec); |
492 |
if (!i) { |
493 |
imp->ncols = mop[0].rmp->ncols; |
494 |
imp->ncomp = mop[0].rmp->ncomp; |
495 |
memcpy(imp->wlpart, mop[0].rmp->wlpart, sizeof(imp->wlpart)); |
496 |
} else if ((mop[i].rmp->ncols != imp->ncols) | |
497 |
(mop[i].rmp->ncomp != imp->ncomp) | |
498 |
((in_nrows > 0) & (mop[i].rmp->nrows > 0) & |
499 |
(mop[i].rmp->nrows != in_nrows))) { |
500 |
fprintf(stderr, "%s: mismatch in size or #components\n", |
501 |
mop[i].inspec); |
502 |
return(0); |
503 |
} /* XXX should check wlpart? */ |
504 |
if (in_nrows <= 0) |
505 |
in_nrows = imp->nrows = mop[i].rmp->nrows; |
506 |
} /* set up .cal environment */ |
507 |
esupport |= E_VARIABLE|E_FUNCTION|E_RCONST; |
508 |
esupport &= ~(E_OUTCHAN|E_INCHAN); |
509 |
varset("PI", ':', M_PI); |
510 |
varset("nfiles", ':', nmats); |
511 |
varset("nrows", ':', in_nrows); |
512 |
varset("ncols", ':', in_ncols); |
513 |
varset("ncomp", ':', in_ncomp); |
514 |
varset("R", ':', 1.); |
515 |
varset("G", ':', 2.); |
516 |
varset("B", ':', 3.); |
517 |
funset("wl", 1, ':', l_wavelength); |
518 |
funset("ci", 1, '=', l_chanin); |
519 |
scompile("ri(i)=ci(i,R);gi(i)=ci(i,G);bi(i)=ci(i,B)", NULL, 0); |
520 |
return(1); |
521 |
522 |
523 |
void |
524 |
output_headinfo(FILE *fp) |
525 |
526 |
int i; |
527 |
528 |
for (i = 0; i < nmats; i++) { |
529 |
const char *cp = mop[i].imx.info; |
530 |
fputs(mop[i].inspec, fp); |
531 |
fputs(":\n", fp); |
532 |
if (!cp) continue; |
533 |
while (*cp) { |
534 |
if (*cp == '\n') { |
535 |
cp++; /* avoid inadvertant terminus */ |
536 |
continue; |
537 |
538 |
fputc('\t', fp); /* indent this input's info */ |
539 |
do |
540 |
putc(*cp, fp); |
541 |
while (*cp++ != '\n'); |
542 |
543 |
544 |
545 |
546 |
int |
547 |
spawned_children(int np) |
548 |
549 |
int i, rv; |
550 |
551 |
#if defined(_WIN32) || defined(_WIN64) |
552 |
if (np > 1) { |
553 |
if (!nowarn) |
554 |
fputs("Warning: only one process under Windows\n", stderr); |
555 |
np = 1; |
556 |
} else |
557 |
#endif |
558 |
if ((in_nrows > 0) & (np*4 > in_nrows)) |
559 |
np = in_nrows/4; |
560 |
/* we'll be doing a row at a time */ |
561 |
562 |
mop[i].imx.nrows = 1; |
563 |
if (!rmx_prepare(&mop[i].imx)) |
564 |
goto memerror; |
565 |
if (mop[i].rmp != &mop[i].imx) { |
566 |
mop[i].rmp->nrows = 1; |
567 |
if (!rmx_prepare(mop[i].rmp)) |
568 |
goto memerror; |
569 |
570 |
571 |
/* prep output row buffer(s) */ |
572 |
if (mop[nmats].preop.clen > 0) { |
573 |
if (!split_input(&mop[nmats])) /* need separate buffer */ |
574 |
goto memerror; |
575 |
mop[nmats].rmp->ncomp = mop[nmats].preop.clen / |
576 |
mop[nmats].imx.ncomp; |
577 |
578 |
mop[nmats].imx.nrows = 1; |
579 |
if (!rmx_prepare(&mop[nmats].imx)) |
580 |
goto memerror; |
581 |
if (mop[nmats].rmp != &mop[nmats].imx) { |
582 |
mop[nmats].rmp->nrows = 1; |
583 |
if (!rmx_prepare(mop[nmats].rmp)) |
584 |
goto memerror; |
585 |
586 |
if (np <= 1) { /* single process return */ |
587 |
#ifdef getc_unlocked |
588 |
for (i = 0; i < nmats; i++) |
589 |
flockfile(mop[i].infp); |
590 |
flockfile(stdout); |
591 |
#endif |
592 |
return(0); |
593 |
594 |
fflush(stdout); /* flush header & spawn children */ |
595 |
nchildren = np + 1; /* extra child to sequence output */ |
596 |
cproc = (SUBPROC *)malloc(sizeof(SUBPROC)*nchildren); |
597 |
if (!cproc) |
598 |
goto memerror; |
599 |
for (i = nchildren; i--; ) cproc[i] = sp_inactive; |
600 |
cproc[nchildren-1].flags |= PF_FILT_OUT; |
601 |
/* start each child from parent */ |
602 |
for (i = 0; i < nchildren; i++) |
603 |
if ((rv = open_process(&cproc[i], NULL)) <= 0) |
604 |
break; /* child breaks here */ |
605 |
if (rv < 0) { |
606 |
perror("fork"); /* WTH? */ |
607 |
close_processes(cproc, i); |
608 |
exit(1); |
609 |
610 |
if (i != nchildren-1) { /* last child is sole reader */ |
611 |
int j = i; |
612 |
while (j-- > 0) { |
613 |
close(cproc[j].r); |
614 |
cproc[j].r = -1; |
615 |
616 |
617 |
if (rv > 0) |
618 |
return(1); /* parent return value */ |
619 |
620 |
inchild = i; /* else set our child index */ |
621 |
while (i-- > 0) /* only parent writes siblings */ |
622 |
close(cproc[i].w); |
623 |
624 |
i = nmats; /* close matrix streams (carefully) */ |
625 |
while (i-- > 0) { |
626 |
if (mop[i].infp != stdin) { |
627 |
close(fileno(mop[i].infp)); /* avoid lseek() */ |
628 |
fclose(mop[i].infp); /* ! pclose() */ |
629 |
630 |
mop[i].infp = NULL; |
631 |
632 |
fpurge(stdin); /* discard previously buffered input */ |
633 |
634 |
if (inchild == nchildren-1) |
635 |
return(-1); /* output process return value */ |
636 |
637 |
i = nmats; /* get matrix rows from parent */ |
638 |
while (i-- > 0) { |
639 |
mop[i].infp = stdin; |
640 |
mop[i].imx.dtype = DTrmx_native; |
641 |
mop[i].imx.pflags &= ~RMF_SWAPIN; |
642 |
643 |
644 |
flockfile(stdin); |
645 |
#endif |
646 |
mop[nmats].rmp->dtype = DTrmx_native; |
647 |
return(0); /* worker child return value */ |
648 |
memerror: |
649 |
fputs("Out of memory in spawned_children()\n", stderr); |
650 |
exit(1); |
651 |
652 |
653 |
int |
654 |
parent_loop(void) |
655 |
656 |
int i; |
657 |
658 |
rmx_reset(&mop[nmats].imx); /* not touching output side */ |
659 |
660 |
rmx_free(mop[nmats].rmp); |
661 |
mop[nmats].rmp = &mop[nmats].imx; |
662 |
663 |
664 |
for (i = 0; i < nmats; i++) /* we handle matrix inputs */ |
665 |
666 |
#endif |
667 |
/* load & send rows to kids */ |
668 |
for (cur_row = 0; (in_nrows <= 0) | (cur_row < in_nrows); cur_row++) { |
669 |
int wfd = cproc[cur_row % (nchildren-1)].w; |
670 |
671 |
if (!rmx_load_row(mop[i].imx.mtx, &mop[i].imx, mop[i].infp)) { |
672 |
if (cur_row > in_nrows) /* unknown #input rows? */ |
673 |
break; |
674 |
fprintf(stderr, "%s: load error at row %d\n", |
675 |
mop[i].inspec, cur_row); |
676 |
return(0); |
677 |
678 |
if (i < nmats) |
679 |
break; |
680 |
681 |
if (writebuf(wfd, mop[i].imx.mtx, rmx_array_size(&mop[i].imx)) |
682 |
!= rmx_array_size(&mop[i].imx)) { |
683 |
fprintf(stderr, "%s: write error at row %d\n", |
684 |
685 |
return(0); |
686 |
687 |
688 |
i = close_processes(cproc, nchildren); /* collect family */ |
689 |
free(cproc); cproc = NULL; nchildren = 0; |
690 |
if (i < 0) { |
691 |
if (!nowarn) |
692 |
fputs("Warning: lost child process\n", stderr); |
693 |
return(1); |
694 |
695 |
if (i > 0) { |
696 |
fprintf(stderr, "Child exited with status %d\n", i); |
697 |
return(0); |
698 |
699 |
return(1); /* return success! */ |
700 |
701 |
702 |
int |
703 |
combine_input(void) |
704 |
705 |
const int row0 = (inchild >= 0)*inchild; |
706 |
const int rstep = nchildren ? nchildren-1 : 1; |
707 |
ROPMAT *res = &mop[nmats]; |
708 |
int set_r, set_c; |
709 |
RMATRIX *tmp = NULL; |
710 |
int co_set; |
711 |
int i; |
712 |
713 |
if (mcat_last && !(tmp = rmx_alloc(1, res->imx.ncols, res->rmp->ncomp))) { |
714 |
fputs("Out of buffer space in combine_input()\n", stderr); |
715 |
return(0); |
716 |
717 |
/* figure out what the user set */ |
718 |
co_set = fundefined("co"); |
719 |
if (!co_set) |
720 |
co_set = -vardefined("co"); |
721 |
if (!co_set & (in_ncomp == 3) && vardefined("ro") && |
722 |
vardefined("go") && vardefined("bo")) { |
723 |
scompile("co(p)=select(p,ro,go,bo)", NULL, 0); |
724 |
co_set = 1; |
725 |
726 |
if (co_set) { /* set if user wants, didn't set */ |
727 |
set_r = varlookup("r") != NULL && !vardefined("r"); |
728 |
set_c = varlookup("c") != NULL && !vardefined("c"); |
729 |
} else /* save a little time */ |
730 |
set_r = set_c = 0; |
731 |
/* read/process row-by-row */ |
732 |
for (cur_row = row0; (in_nrows <= 0) | (cur_row < in_nrows); cur_row += rstep) { |
733 |
RMATRIX *mres = NULL; |
734 |
735 |
736 |
737 |
break; |
738 |
739 |
740 |
return(0); |
741 |
742 |
if (i < nmats) |
743 |
break; |
744 |
745 |
if (!apply_op(mop[i].rmp, &mop[i].imx, &mop[i].preop)) |
746 |
return(0); |
747 |
if (set_r) varset("r", '=', cur_row); |
748 |
for (cur_col = 0; cur_col < in_ncols; cur_col++) { |
749 |
if (set_c) varset("c", '=', cur_col); |
750 |
for (cur_chan = 0; cur_chan < in_ncomp; cur_chan++) { |
751 |
const int ndx = cur_col*in_ncomp + cur_chan; |
752 |
eclock++; |
753 |
if (!co_set) { /* just summing elements? */ |
754 |
res->imx.mtx[ndx] = 0; |
755 |
for (i = nmats; i--; ) |
756 |
res->imx.mtx[ndx] += mop[i].rmp->mtx[ndx]; |
757 |
} else if (co_set > 0) { |
758 |
double dchan = cur_chan+1; |
759 |
res->imx.mtx[ndx] = funvalue("co", 1, &dchan); |
760 |
} else |
761 |
res->imx.mtx[ndx] = varvalue("co"); |
762 |
763 |
} /* final conversions */ |
764 |
if (!mcat) { |
765 |
if (!apply_op(res->rmp, &res->imx, &res->preop)) |
766 |
return(0); |
767 |
} else if (mcat_last) { |
768 |
if (!apply_op(tmp, &res->imx, &res->preop)) |
769 |
return(0); |
770 |
mres = rmx_multiply(tmp, mcat); |
771 |
if (!mres) |
772 |
goto multerror; |
773 |
if (!rmx_transfer_data(res->rmp, mres, 0)) |
774 |
return(0); |
775 |
} else /* mcat && !mcat_last */ { |
776 |
mres = rmx_multiply(&res->imx, mcat); |
777 |
if (!mres) |
778 |
goto multerror; |
779 |
if (!apply_op(res->rmp, mres, &res->preop)) |
780 |
return(0); |
781 |
782 |
rmx_free(mres); mres = NULL; |
783 |
if (!rmx_write_data(res->rmp->mtx, res->rmp->ncomp, |
784 |
res->rmp->ncols, res->rmp->dtype, stdout) || |
785 |
(inchild >= 0 && fflush(stdout) == EOF)) { |
786 |
fprintf(stderr, "Conversion/write error at row %d\n", |
787 |
cur_row); |
788 |
return(0); |
789 |
790 |
791 |
return(inchild >= 0 || fflush(stdout) != EOF); |
792 |
multerror: |
793 |
fputs("Unexpected matrix multiply error\n", stderr); |
794 |
return(0); |
795 |
796 |
797 |
int |
798 |
output_loop(void) |
799 |
800 |
const size_t row_size = rmx_array_size(mop[nmats].rmp); |
801 |
int cur_child = 0; |
802 |
int i = nmats; |
803 |
804 |
while (i-- > 0) { /* free input buffers */ |
805 |
rmx_reset(&mop[i].imx); |
806 |
807 |
rmx_free(mop[i].rmp); |
808 |
mop[i].rmp = &mop[i].imx; |
809 |
810 |
811 |
if (mop[nmats].rmp != &mop[nmats].imx) /* output is split? */ |
812 |
rmx_reset(&mop[nmats].imx); |
813 |
814 |
flockfile(stdout); /* we own this, now */ |
815 |
#endif |
816 |
for ( ; ; ) { /* loop until no more */ |
817 |
ssize_t rv; |
818 |
rv = readbuf(cproc[cur_child].r, mop[nmats].rmp->mtx, row_size); |
819 |
if (!rv) /* out of rows? */ |
820 |
break; |
821 |
if (rv != row_size) { |
822 |
fputs("Read error\n", stderr); |
823 |
return(0); |
824 |
} /* do final conversion */ |
825 |
if (!rmx_write_data(mop[nmats].rmp->mtx, mop[nmats].rmp->ncomp, |
826 |
mop[nmats].rmp->ncols, mop[nmats].rmp->dtype, stdout)) { |
827 |
fputs("Conversion/write error\n", stderr); |
828 |
return(0); |
829 |
830 |
cur_child++; |
831 |
cur_child *= (cur_child < inchild); /* loop over workers */ |
832 |
833 |
return(fflush(stdout) != EOF); |
834 |
835 |
836 |
int |
837 |
get_factors(double da[], int n, char *av[]) |
838 |
839 |
int ac; |
840 |
841 |
for (ac = 0; ac < n && isflt(av[ac]); ac++) |
842 |
da[ac] = atof(av[ac]); |
843 |
return(ac); |
844 |
845 |
846 |
void |
847 |
resize_inparr(int n2alloc) |
848 |
849 |
int i; |
850 |
851 |
if (n2alloc == nall) |
852 |
return; |
853 |
for (i = nall; i-- > n2alloc; ) { |
854 |
855 |
if (mop[i].rmp != &mop[i].imx) |
856 |
857 |
858 |
mop = (ROPMAT *)realloc(mop, n2alloc*sizeof(ROPMAT)); |
859 |
if (mop == NULL) { |
860 |
fputs("Out of memory in resize_inparr()\n", stderr); |
861 |
exit(1); |
862 |
863 |
if (n2alloc > nall) |
864 |
memset(mop+nall, 0, (n2alloc-nall)*sizeof(ROPMAT)); |
865 |
nall = n2alloc; |
866 |
867 |
868 |
/* Load one or more matrices and operate on them, sending results to stdout */ |
869 |
int |
870 |
main(int argc, char *argv[]) |
871 |
872 |
873 |
int outfmt = DTfromHeader; |
874 |
const char *defCsym = NULL; |
875 |
int echoheader = 1; |
876 |
int stdin_used = 0; |
877 |
int nproc = 1; |
878 |
const char *mcat_spec = NULL; |
879 |
int transpose_mcat = 0; |
880 |
int n2comp = 0; |
881 |
uby8 comp_ndx[128]; |
882 |
int i; |
883 |
/* get starting input array */ |
884 |
mop = (ROPMAT *)calloc(nall=2, sizeof(ROPMAT)); |
885 |
/* get options and arguments */ |
886 |
for (i = 1; i < argc; i++) |
887 |
if (argv[i][0] != '-' || !argv[i][1]) { |
888 |
if (argv[i][0] == '-') { |
889 |
if (stdin_used++) goto stdin_error; |
890 |
mop[nmats].inspec = stdin_name; |
891 |
} else |
892 |
mop[nmats].inspec = argv[i]; |
893 |
if (!mop[nmats].preop.csym) |
894 |
mop[nmats].preop.csym = defCsym; |
895 |
if (++nmats >= nall) |
896 |
resize_inparr(nmats + (nmats>>2) + 2); |
897 |
} else { |
898 |
int n = argc-1 - i; |
899 |
switch (argv[i][1]) { /* get option */ |
900 |
case 'w': |
901 |
nowarn = !nowarn; |
902 |
break; |
903 |
case 'h': |
904 |
echoheader = !echoheader; |
905 |
break; |
906 |
case 'n': |
907 |
nproc = atoi(argv[++i]); |
908 |
if (nproc <= 0) |
909 |
goto userr; |
910 |
break; |
911 |
case 'e': |
912 |
if (!n) goto userr; |
913 |
comp_ndx[n2comp++] = i++; |
914 |
break; |
915 |
case 'f': |
916 |
switch (argv[i][2]) { |
917 |
case '\0': |
918 |
919 |
920 |
break; |
921 |
case 'd': |
922 |
outfmt = DTdouble; |
923 |
break; |
924 |
case 'f': |
925 |
outfmt = DTfloat; |
926 |
break; |
927 |
case 'a': |
928 |
outfmt = DTascii; |
929 |
break; |
930 |
case 'c': |
931 |
outfmt = DTrgbe; |
932 |
break; |
933 |
default: |
934 |
goto userr; |
935 |
936 |
break; |
937 |
case 's': |
938 |
if (n > MAXCOMP) n = MAXCOMP; |
939 |
i += mop[nmats].preop.nsf = |
940 |
get_factors(mop[nmats].preop.sca, |
941 |
n, argv+i+1); |
942 |
if (mop[nmats].preop.nsf <= 0) { |
943 |
fprintf(stderr, "%s: -s missing arguments\n", |
944 |
argv[0]); |
945 |
goto userr; |
946 |
947 |
break; |
948 |
case 'C': |
949 |
mcat_last = 0; |
950 |
if (!n || isflt(argv[i+1])) |
951 |
goto userr; |
952 |
defCsym = mop[nmats].preop.csym = argv[++i]; |
953 |
mop[nmats].preop.clen = 0; |
954 |
break; |
955 |
case 'c': |
956 |
mcat_last = 0; |
957 |
if (n && !isflt(argv[i+1])) { |
958 |
959 |
960 |
break; |
961 |
962 |
if (n > MAXCOMP*MAXCOMP) n = MAXCOMP*MAXCOMP; |
963 |
i += mop[nmats].preop.clen = |
964 |
get_factors(mop[nmats].preop.cmat, |
965 |
n, argv+i+1); |
966 |
if (mop[nmats].preop.clen <= 0) { |
967 |
fprintf(stderr, "%s: -c missing arguments\n", |
968 |
argv[0]); |
969 |
goto userr; |
970 |
971 |
mop[nmats].preop.csym = NULL; |
972 |
break; |
973 |
case 'm': |
974 |
975 |
mcat_last = 1; |
976 |
transpose_mcat = (argv[i][2] == 't'); |
977 |
if (argv[++i][0] == '-' && !argv[i][1]) { |
978 |
979 |
mcat_spec = stdin_name; |
980 |
} else |
981 |
mcat_spec = argv[i]; |
982 |
break; |
983 |
default: |
984 |
fprintf(stderr, "%s: unknown option '%s'\n", |
985 |
argv[0], argv[i]); |
986 |
goto userr; |
987 |
988 |
989 |
if (!nmats) { |
990 |
fprintf(stderr, "%s: need at least one input matrix\n", argv[0]); |
991 |
goto userr; |
992 |
993 |
resize_inparr(nmats+1); /* extra matrix at end for result */ |
994 |
mop[nmats].inspec = "trailing_ops"; |
995 |
996 |
if (mcat_spec) { /* load final concatenation matrix? */ |
997 |
mcat = rmx_load(mcat_spec); |
998 |
if (!mcat) { |
999 |
fprintf(stderr, "%s: error loading concatenation matrix: %s\n", |
1000 |
argv[0], mcat_spec); |
1001 |
return(1); |
1002 |
1003 |
if (transpose_mcat && !rmx_transpose(mcat)) { |
1004 |
fprintf(stderr, "%s: error transposing concatenation matrix: %s\n", |
1005 |
1006 |
return(1); |
1007 |
1008 |
1009 |
/* get/check inputs, set constants */ |
1010 |
if (!initialize(&mop[nmats].imx)) |
1011 |
return(1); |
1012 |
1013 |
for (i = 0; i < n2comp; i++) /* user .cal files and expressions */ |
1014 |
if (argv[comp_ndx[i]][1] == 'f') { |
1015 |
char *fpath = getpath(argv[comp_ndx[i]+1], |
1016 |
getrlibpath(), 0); |
1017 |
if (fpath == NULL) { |
1018 |
fprintf(stderr, "%s: cannot find file '%s'\n", |
1019 |
argv[0], argv[comp_ndx[i]+1]); |
1020 |
return(1); |
1021 |
1022 |
fcompile(fpath); |
1023 |
} else /* (argv[comp_ndx[i]][1] == 'e') */ |
1024 |
scompile(argv[comp_ndx[i]+1], NULL, 0); |
1025 |
1026 |
/* get trailing color transform */ |
1027 |
if (!get_component_xfm(&mop[nmats])) |
1028 |
return(1); |
1029 |
/* adjust output dimensions and #components */ |
1030 |
if (mcat) { |
1031 |
if (mop[nmats].imx.ncols != mcat->nrows) { |
1032 |
fprintf(stderr, |
1033 |
"%s: number of input columns does not match number of rows in '%s'\n", |
1034 |
1035 |
return(1); |
1036 |
1037 |
if (mcat->ncomp != (mcat_last ? mop[nmats].rmp->ncomp : mop[nmats].imx.ncomp)) { |
1038 |
fprintf(stderr, |
1039 |
"%s: number of components does not match those in '%s'\n", |
1040 |
1041 |
return(1); |
1042 |
1043 |
if (!split_input(&mop[nmats])) |
1044 |
return(1); |
1045 |
mop[nmats].rmp->ncols = mcat->ncols; |
1046 |
1047 |
#if DTrmx_native==DTfloat |
1048 |
if (outfmt == DTdouble) |
1049 |
fprintf(stderr, "%s: warning - writing float result as double\n", argv[0]); |
1050 |
#endif |
1051 |
newheader("RADIANCE", stdout); /* write output header */ |
1052 |
if (echoheader) |
1053 |
output_headinfo(stdout); |
1054 |
printargs(argc, argv, stdout); |
1055 |
fputnow(stdout); |
1056 |
mop[nmats].rmp->dtype = rmx_write_header(mop[nmats].rmp, outfmt, stdout); |
1057 |
if (!mop[nmats].rmp->dtype) { |
1058 |
fprintf(stderr, "%s: unsupported output format\n", argv[0]); |
1059 |
return(1); |
1060 |
1061 |
doptimize(1); /* optimize definitions */ |
1062 |
i = spawned_children(nproc); /* create multiple processes if requested */ |
1063 |
if (i > 0) /* running in parent process? */ |
1064 |
return(parent_loop() ? 0 : 1); |
1065 |
if (i < 0) /* running in output process? */ |
1066 |
return(output_loop() ? 0 : 1); |
1067 |
/* else we are a worker process */ |
1068 |
return(combine_input() ? 0 : 1); |
1069 |
stdin_error: |
1070 |
fprintf(stderr, "%s: %s used for more than one input\n", |
1071 |
argv[0], stdin_name); |
1072 |
return(1); |
1073 |
userr: |
1074 |
fprintf(stderr, |
1075 |
"Usage: %s [-h][-f{adfc}][-n nproc][-e expr][-f file][-s sf .. | -c ce ..] m1 .. -m mcat > mres\n", |
1076 |
argv[0]); |
1077 |
return(1); |
1078 |
