root/radiance/ray/src/util/rcollate.c
Revision: 2.8
Committed: Fri Feb 21 13:49:00 2014 UTC (10 years, 3 months ago) by greg
Reduced number of calls to realloc() when loading from stdin
2 static const char RCSid[] = "$Id: rcollate.c,v 2.7 2013/11/18 22:02:12 greg Exp $";
5 * Utility to re-order records in a binary or ASCII data file (matrix)
6 */
7
8 #include <stdlib.h>
9 #include <string.h>
10 #include <ctype.h>
11 #include "platform.h"
12 #include "rtio.h"
13 #include "resolu.h"
14 #ifdef _WIN32
15 #undef ftello
16 #define ftello ftell
17 #undef ssize_t
18 #define ssize_t size_t
19 #else
20 #include <sys/mman.h>
21 #endif
22
23 #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
24 #undef getc
25 #undef putc
26 #define getc getc_unlocked
27 #define putc putc_unlocked
28 #endif
29
30 typedef struct {
31 void *base; /* pointer to base memory */
32 size_t len; /* allocated memory length */
33 int mapped; /* memory-mapped file? */
34 } MEMLOAD; /* file loaded/mapped into memory */
35
36 typedef struct {
37 int nw_rec; /* number of words per record */
38 int nrecs; /* number of records we found */
39 char *rec[1]; /* record array (extends struct) */
40 } RECINDEX;
41
42 int warnings = 1; /* report warnings? */
43
44 /* free loaded file */
45 static void
46 free_load(MEMLOAD *mp)
47 {
48 if (mp == NULL || (mp->base == NULL) | (mp->len <= 0))
49 return;
50 #ifdef MAP_FILE
51 if (mp->mapped)
52 munmap(mp->base, mp->len);
53 else
54 #endif
55 free(mp->base);
56 mp->base = NULL;
57 mp->len = 0;
58 }
59
60 /* load a file into memory */
61 static int
62 load_file(MEMLOAD *mp, FILE *fp)
63 {
64 int fd;
65 off_t skip, flen;
66
67 if (mp == NULL)
68 return(-1);
69 mp->base = NULL;
70 mp->len = 0;
71 mp->mapped = 0;
72 if (fp == NULL)
73 return(-1);
74 fd = fileno(fp);
75 skip = ftello(fp);
76 flen = lseek(fd, 0, SEEK_END);
77 if (flen <= skip)
78 return((int)(flen - skip));
79 mp->len = (size_t)(flen - skip);
80 #ifdef MAP_FILE
81 if (mp->len > 1L<<20) { /* map file if > 1 MByte */
82 mp->base = mmap(NULL, mp->len, PROT_READ, MAP_PRIVATE, fd, skip);
83 if (mp->base != MAP_FAILED) {
84 mp->mapped = 1;
85 return(1); /* mmap() success */
86 }
87 mp->base = NULL; /* fall back to reading it in... */
88 }
89 #endif
90 if (lseek(fd, skip, SEEK_SET) != skip ||
91 (mp->base = malloc(mp->len)) == NULL) {
92 mp->len = 0;
93 return(-1);
94 }
95 if (read(fd, (char *)mp->base, mp->len) != mp->len) {
96 free_load(mp);
97 return(-1);
98 }
99 return(1);
100 }
101
102 /* load memory from an input stream, starting from current position */
103 static int
104 load_stream(MEMLOAD *mp, FILE *fp)
105 {
106 size_t alloced = 0;
107 char buf[8192];
108 size_t nr;
109
110 if (mp == NULL)
111 return(-1);
112 mp->base = NULL;
113 mp->len = 0;
114 mp->mapped = 0;
115 if (fp == NULL)
116 return(-1);
117 while ((nr = fread(buf, 1, sizeof(buf), fp)) > 0) {
118 if (!alloced)
119 mp->base = malloc(nr);
120 else if (mp->len+nr > alloced)
121 mp->base = realloc(mp->base,
122 alloced = alloced*(2+(nr==sizeof(buf)))/2+nr);
123 if (mp->base == NULL)
124 return(-1);
125 memcpy((char *)mp->base + mp->len, buf, nr);
126 mp->len += nr;
127 }
128 if (ferror(fp)) {
129 free_load(mp);
130 return(-1);
131 }
132 if (alloced > mp->len*5/4) /* don't waste too much space */
133 mp->base = realloc(mp->base, mp->len);
134 return(mp->len > 0);
135 }
136
137 /* free a record index */
138 #define free_records(rp) free(rp)
139
140 /* compute record index */
141 static RECINDEX *
142 index_records(const MEMLOAD *mp, int nw_rec)
143 {
144 RECINDEX *rp;
145 char *cp, *mend;
146 int n;
147
148 if (mp == NULL || (mp->base == NULL) | (mp->len <= 0))
149 return(NULL);
150 if (nw_rec <= 0)
151 return(NULL);
152 rp = (RECINDEX *)malloc(sizeof(RECINDEX) + mp->len/(2*nw_rec)*sizeof(char *));
153 if (rp == NULL)
154 return(NULL);
155 rp->nw_rec = nw_rec;
156 rp->nrecs = 0;
157 cp = (char *)mp->base;
158 mend = cp + mp->len;
159 for ( ; ; ) { /* whitespace-separated words */
160 while (cp < mend && !*cp | isspace(*cp))
161 ++cp;
162 if (cp >= mend)
163 break;
164 rp->rec[rp->nrecs++] = cp; /* point to first non-white */
165 n = rp->nw_rec;
166 while (++cp < mend) /* find end of record */
167 if (!*cp | isspace(*cp)) {
168 if (--n <= 0)
169 break; /* got requisite # words */
170 do { /* else find next word */
171 if (*cp == '\n') {
172 fprintf(stderr,
173 "Unexpected EOL in record!\n");
174 free_records(rp);
175 return(NULL);
176 }
177 if (++cp >= mend)
178 break;
179 } while (!*cp | isspace(*cp));
180 }
181 }
182 rp->rec[rp->nrecs] = mend; /* reallocate to save space */
183 rp = (RECINDEX *)realloc(rp,
184 sizeof(RECINDEX) + rp->nrecs*sizeof(char *));
185 return(rp);
186 }
187
188 /* count number of columns based on first EOL */
189 static int
190 count_columns(const RECINDEX *rp)
191 {
192 char *cp = rp->rec[0];
193 char *mend = rp->rec[rp->nrecs];
194 int i;
195
196 while (*cp != '\n')
197 if (++cp >= mend)
198 return(0);
199 for (i = 0; i < rp->nrecs; i++)
200 if (rp->rec[i] >= cp)
201 break;
202 return(i);
203 }
204
205 /* copy nth record from index to stdout */
206 static int
207 print_record(const RECINDEX *rp, int n)
208 {
209 int words2go = rp->nw_rec;
210 char *scp;
211
212 if ((n < 0) | (n >= rp->nrecs))
213 return(0);
214 scp = rp->rec[n];
215 do {
216 putc(*scp++, stdout);
217 if (!*scp | isspace(*scp)) {
218 if (--words2go <= 0)
219 break;
220 putc(' ', stdout); /* single space btwn. words */
221 do
222 if (++scp >= rp->rec[n+1])
223 break;
224 while (!*scp | isspace(*scp));
225 }
226 } while (scp < rp->rec[n+1]);
227 /* caller adds record sep. */
228 return(1);
229 }
230
231 /* copy a stream to stdout */
232 static int
233 output_stream(FILE *fp)
234 {
235 char buf[8192];
236 ssize_t n;
237
238 if (fp == NULL)
239 return(0);
240 fflush(stdout); /* assumes nothing in input buffer */
241 while ((n = read(fileno(fp), buf, sizeof(buf))) > 0)
242 if (write(fileno(stdout), buf, n) != n)
243 return(0);
244 return(n >= 0);
245 }
246
247 /* get next word from stream, leaving stream on EOL or start of next word */
248 static char *
249 fget_word(char buf[256], FILE *fp)
250 {
251 int c;
252 char *cp;
253 /* skip nul's and white space */
254 while (!(c = getc(fp)) || isspace(c))
255 ;
256 if (c == EOF)
257 return(NULL);
258 cp = buf;
259 do
260 *cp++ = c;
261 while ((c = getc(fp)) != EOF && !isspace(c) && cp < buf+255);
262 *cp = '\0';
263 while (isspace(c) & (c != '\n'))
264 c = getc(fp);
265 if (c != EOF)
266 ungetc(c, fp);
267 return(buf);
268 }
269
270 char *fmtid = "ascii"; /* format id */
271 int record_width = 3; /* words/record (<0 binary) */
272 int ni_columns = 0; /* number of input columns */
273 int ni_rows = 0; /* number of input rows */
274 int no_columns = 0; /* number of output columns */
275 int no_rows = 0; /* number of output rows */
276
277 /* output transposed ASCII or binary data from memory */
278 static int
279 do_transpose(const MEMLOAD *mp)
280 {
281 static const char tabEOL[2] = {'\t','\n'};
282 RECINDEX *rp = NULL;
283 long nrecords;
284 int i, j;
285 /* propogate sizes */
286 if (ni_rows <= 0)
287 ni_rows = no_columns;
288 if (ni_columns <= 0)
289 ni_columns = no_rows;
290 /* get # records (& index) */
291 if (record_width > 0) {
292 if ((rp = index_records(mp, record_width)) == NULL)
293 return(0);
294 if (ni_columns <= 0)
295 ni_columns = count_columns(rp);
296 nrecords = rp->nrecs;
297 } else if ((ni_rows > 0) & (ni_columns > 0)) {
298 nrecords = ni_rows*ni_columns;
299 if (nrecords > mp->len / -record_width) {
300 fprintf(stderr,
301 "Input too small for specified size and type\n");
302 return(0);
303 }
304 } else
305 nrecords = mp->len / -record_width;
306 /* check sizes */
307 if ((ni_rows <= 0) & (ni_columns > 0))
308 ni_rows = nrecords/ni_columns;
309 if ((ni_columns <= 0) & (ni_rows > 0))
310 ni_columns = nrecords/ni_rows;
311 if (nrecords != ni_rows*ni_columns)
312 goto badspec;
313 if (no_columns <= 0)
314 no_columns = ni_rows;
315 if (no_rows <= 0)
316 no_rows = ni_columns;
317 if ((no_rows != ni_columns) | (no_columns != ni_rows))
318 goto badspec;
319 /* transpose records */
320 for (i = 0; i < no_rows; i++) {
321 for (j = 0; j < no_columns; j++)
322 if (rp != NULL) { /* ASCII output */
323 print_record(rp, j*ni_columns + i);
324 putc(tabEOL[j >= no_columns-1], stdout);
325 } else { /* binary output */
326 fwrite((char *)mp->base +
327 -record_width*(j*ni_columns + i),
328 -record_width, 1, stdout);
329 }
330 if (ferror(stdout)) {
331 fprintf(stderr, "Error writing to stdout\n");
332 return(0);
333 }
334 }
335 if (rp != NULL)
336 free_records(rp);
337 return(1);
338 badspec:
339 fprintf(stderr, "Bad transpose specification -- check dimension(s)\n");
340 return(0);
341 }
342
343 /* resize ASCII stream input by ignoring EOLs between records */
344 static int
345 do_resize(FILE *fp)
346 {
347 long records2go = ni_rows*ni_columns;
348 int columns2go = no_columns;
349 char word[256];
350 /* sanity checks */
351 if (record_width <= 0) {
352 fprintf(stderr, "Bad call to do_resize (record_width = %d)\n",
353 record_width);
354 return(0);
355 }
356 if (no_columns <= 0) {
357 fprintf(stderr, "Missing -oc specification\n");
358 return(0);
359 }
360 if ((records2go <= 0) & (no_rows > 0))
361 records2go = no_rows*no_columns;
362 else if (no_rows*no_columns != records2go) {
363 fprintf(stderr,
364 "Input and output data sizes disagree (%dx%d != %dx%d)\n",
365 ni_rows, ni_columns, no_rows, no_columns);
366 return(0);
367 }
368 do { /* reshape records */
369 int n;
370
371 for (n = record_width; n--; ) {
372 if (fget_word(word, fp) == NULL) {
373 if (records2go > 0 || n < record_width-1)
374 break;
375 goto done; /* normal EOD */
376 }
377 fputs(word, stdout);
378 if (n) { /* mid-record? */
379 int c = getc(fp);
380 if ((c == '\n') | (c == EOF))
381 break;
382 ungetc(c, fp);
383 putc(' ', stdout);
384 }
385 }
386 if (n >= 0) {
387 fprintf(stderr, "Incomplete record / unexpected EOF\n");
388 return(0);
389 }
390 if (--columns2go <= 0) { /* time to end output row? */
391 putc('\n', stdout);
392 columns2go = no_columns;
393 } else /* else separate records */
394 putc('\t', stdout);
395 } while (--records2go); /* expected EOD? */
396 done:
397 if (warnings && columns2go != no_columns)
398 fprintf(stderr, "Warning -- incomplete final row\n");
399 if (warnings && fget_word(word, fp) != NULL)
400 fprintf(stderr, "Warning -- characters beyond expected EOD\n");
401 return(1);
402 }
403
404 /* process a header line and copy to stdout */
405 static int
406 headline(char *s, void *p)
407 {
408 char fmt[32];
409
410 if (formatval(fmt, s)) {
411 if (!strcmp(fmt, fmtid))
412 return(0);
413 fprintf(stderr, "Input format '%s' != '%s'\n", fmt, fmtid);
414 return(-1);
415 }
416 fputs(s, stdout); /* copy header info. */
417 return(0);
418 }
419
420 /* main routine for converting rows/columns in data file */
421 int
422 main(int argc, char *argv[])
423 {
424 int do_header = 1; /* header i/o? */
425 int transpose = 0; /* transpose rows & cols? */
426 int i;
427
428 for (i = 1; i < argc && argv[i][0] == '-'; i++)
429 switch (argv[i][1]) {
430 case 'i': /* input */
431 if (argv[i][2] == 'c') /* columns */
432 ni_columns = atoi(argv[++i]);
433 else if (argv[i][2] == 'r')
434 ni_rows = atoi(argv[++i]);
435 else
436 goto userr;
437 break;
438 case 'o': /* output */
439 if (argv[i][2] == 'c') /* columns */
440 no_columns = atoi(argv[++i]);
441 else if (argv[i][2] == 'r')
442 no_rows = atoi(argv[++i]);
443 else
444 goto userr;
445 break;
446 case 'h': /* header on/off */
447 do_header = !do_header;
448 break;
449 case 't': /* transpose on/off */
450 transpose = !transpose;
451 break;
452 case 'f': /* format */
453 switch (argv[i][2]) {
454 case 'a': /* ASCII */
455 case 'A':
456 fmtid = "ascii";
457 record_width = 1;
458 break;
459 case 'f': /* float */
460 case 'F':
461 fmtid = "float";
462 record_width = -(int)sizeof(float);
463 break;
464 case 'd': /* double */
465 case 'D':
466 fmtid = "double";
467 record_width = -(int)sizeof(double);
468 break;
469 case 'b': /* binary (bytes) */
470 case 'B':
471 fmtid = "byte";
472 record_width = -1;
473 break;
474 default:
475 goto userr;
476 }
477 if (argv[i][3]) {
478 if (!isdigit(argv[i][3]))
479 goto userr;
480 record_width *= atoi(argv[i]+3);
481 }
482 break;
483 case 'w': /* warnings on/off */
484 warnings = !warnings;
485 break;
486 default:
487 goto userr;
488 }
489 if (!record_width)
490 goto userr;
491 if (i < argc-1) /* arg count OK? */
492 goto userr;
493 /* open input file? */
494 if (i == argc-1 && freopen(argv[i], "r", stdin) == NULL) {
495 fprintf(stderr, "%s: cannot open for reading\n", argv[i]);
496 return(1);
497 }
498 if (record_width < 0) {
499 SET_FILE_BINARY(stdin);
500 SET_FILE_BINARY(stdout);
501 }
502 /* check for no-op */
503 if (!transpose && (record_width < 0 ||
504 (no_columns == ni_columns) & (no_rows == ni_rows))) {
505 if (warnings)
506 fprintf(stderr, "%s: no-op -- copying input verbatim\n",
507 argv[0]);
508 if (!output_stream(stdin))
509 return(1);
510 return(0);
511 }
512 if (do_header) { /* read/write header */
513 if (getheader(stdin, &headline, NULL) < 0)
514 return(1);
515 printargs(argc, argv, stdout);
516 fputformat(fmtid, stdout);
517 fputc('\n', stdout); /* finish new header */
518 }
519 if (transpose) { /* transposing rows & columns? */
520 MEMLOAD myMem; /* need to load into memory */
521 if (i == argc-1) {
522 if (load_file(&myMem, stdin) <= 0) {
523 fprintf(stderr, "%s: error loading file into memory\n",
524 argv[i]);
525 return(1);
526 }
527 } else if (load_stream(&myMem, stdin) <= 0) {
528 fprintf(stderr, "%s: error loading stdin into memory\n",
529 argv[0]);
530 return(1);
531 }
532 if (!do_transpose(&myMem))
533 return(1);
534 /* free_load(&myMem); */
535 } else if (!do_resize(stdin)) /* just reshaping input */
536 return(1);
537 return(0);
538 userr:
539 fprintf(stderr,
540 "Usage: %s [-h][-w][-f[afdb][N]][-t][-ic in_col][-ir in_row][-oc out_col][-or out_row] [input.dat]\n",
541 argv[0]);
542 return(1);
543 }
