| 1 | #ifndef lint |
| 2 | static const char RCSid[] = "$Id: rcollate.c,v 2.17 2014/07/24 16:28:17 greg Exp $"; |
| 3 | #endif |
| 4 | /* |
| 5 | * Utility to re-order records in a binary or ASCII data file (matrix) |
| 6 | */ |
| 7 |  |
| 8 | #include <stdlib.h> |
| 9 | #include <string.h> |
| 10 | #include <ctype.h> |
| 11 | #include "platform.h" |
| 12 | #include "rtio.h" |
| 13 | #include "resolu.h" |
| 14 | #ifdef _WIN32 |
| 15 | #undef ftello |
| 16 | #define ftello  ftell |
| 17 | #undef ssize_t |
| 18 | #define ssize_t size_t |
| 19 | #else |
| 20 | #include <sys/mman.h> |
| 21 | #endif |
| 22 |  |
| 23 | #ifdef getc_unlocked            /* avoid horrendous overhead of flockfile */ |
| 24 | #undef getc |
| 25 | #undef putc |
| 26 | #define getc    getc_unlocked |
| 27 | #define putc    putc_unlocked |
| 28 | #endif |
| 29 |  |
| 30 | typedef struct { |
| 31 | void    *base;          /* pointer to base memory */ |
| 32 | size_t  len;            /* allocated memory length */ |
| 33 | int     mapped;         /* memory-mapped file? */ |
| 34 | } MEMLOAD;              /* file loaded/mapped into memory */ |
| 35 |  |
| 36 | typedef struct { |
| 37 | int     nw_rec;         /* number of words per record */ |
| 38 | int     nrecs;          /* number of records we found */ |
| 39 | char    *rec[1];        /* record array (extends struct) */ |
| 40 | } RECINDEX; |
| 41 |  |
| 42 | int             warnings = 1;   /* report warnings? */ |
| 43 |  |
| 44 | /* free loaded file */ |
| 45 | static void |
| 46 | free_load(MEMLOAD *mp) |
| 47 | { |
| 48 | if (mp == NULL || (mp->base == NULL) | (mp->len <= 0)) |
| 49 | return; |
| 50 | #ifdef MAP_FILE |
| 51 | if (mp->mapped) |
| 52 | munmap(mp->base, mp->len); |
| 53 | else |
| 54 | #endif |
| 55 | free(mp->base); |
| 56 | mp->base = NULL; |
| 57 | mp->len = 0; |
| 58 | } |
| 59 |  |
| 60 | /* load a file into memory */ |
| 61 | static int |
| 62 | load_file(MEMLOAD *mp, FILE *fp) |
| 63 | { |
| 64 | int     fd; |
| 65 | off_t   skip, flen; |
| 66 |  |
| 67 | if (mp == NULL) |
| 68 | return(-1); |
| 69 | mp->base = NULL; |
| 70 | mp->len = 0; |
| 71 | mp->mapped = 0; |
| 72 | if (fp == NULL) |
| 73 | return(-1); |
| 74 | fd = fileno(fp); |
| 75 | skip = ftello(fp); |
| 76 | flen = lseek(fd, 0, SEEK_END); |
| 77 | if (flen <= skip) |
| 78 | return((int)(flen - skip)); |
| 79 | mp->len = (size_t)(flen - skip); |
| 80 | #ifdef MAP_FILE |
| 81 | if (mp->len > 1L<<20) {         /* map file if > 1 MByte */ |
| 82 | mp->base = mmap(NULL, mp->len, PROT_READ, MAP_PRIVATE, fd, skip); |
| 83 | if (mp->base != MAP_FAILED) { |
| 84 | mp->mapped = 1; |
| 85 | return(1);      /* mmap() success */ |
| 86 | } |
| 87 | mp->base = NULL;        /* fall back to reading it in... */ |
| 88 | } |
| 89 | #endif |
| 90 | if (lseek(fd, skip, SEEK_SET) != skip || |
| 91 | (mp->base = malloc(mp->len)) == NULL) { |
| 92 | mp->len = 0; |
| 93 | return(-1); |
| 94 | } |
| 95 | if (read(fd, (char *)mp->base, mp->len) != mp->len) { |
| 96 | free_load(mp); |
| 97 | return(-1); |
| 98 | } |
| 99 | return(1); |
| 100 | } |
| 101 |  |
| 102 | /* load memory from an input stream, starting from current position */ |
| 103 | static int |
| 104 | load_stream(MEMLOAD *mp, FILE *fp) |
| 105 | { |
| 106 | size_t  alloced = 0; |
| 107 | char    buf[8192]; |
| 108 | size_t  nr; |
| 109 |  |
| 110 | if (mp == NULL) |
| 111 | return(-1); |
| 112 | mp->base = NULL; |
| 113 | mp->len = 0; |
| 114 | mp->mapped = 0; |
| 115 | if (fp == NULL) |
| 116 | return(-1); |
| 117 | while ((nr = fread(buf, 1, sizeof(buf), fp)) > 0) { |
| 118 | if (!alloced) |
| 119 | mp->base = malloc(nr); |
| 120 | else if (mp->len+nr > alloced) |
| 121 | mp->base = realloc(mp->base, |
| 122 | alloced = alloced*(2+(nr==sizeof(buf)))/2+nr); |
| 123 | if (mp->base == NULL) |
| 124 | return(-1); |
| 125 | memcpy((char *)mp->base + mp->len, buf, nr); |
| 126 | mp->len += nr; |
| 127 | } |
| 128 | if (ferror(fp)) { |
| 129 | free_load(mp); |
| 130 | return(-1); |
| 131 | } |
| 132 | if (alloced > mp->len*5/4)      /* don't waste too much space */ |
| 133 | mp->base = realloc(mp->base, mp->len); |
| 134 | return(mp->len > 0); |
| 135 | } |
| 136 |  |
| 137 | /* free a record index */ |
| 138 | #define free_records(rp)        free(rp) |
| 139 |  |
| 140 | /* compute record index */ |
| 141 | static RECINDEX * |
| 142 | index_records(const MEMLOAD *mp, int nw_rec) |
| 143 | { |
| 144 | RECINDEX        *rp; |
| 145 | char            *cp, *mend; |
| 146 | int             n; |
| 147 |  |
| 148 | if (mp == NULL || (mp->base == NULL) | (mp->len <= 0)) |
| 149 | return(NULL); |
| 150 | if (nw_rec <= 0) |
| 151 | return(NULL); |
| 152 | rp = (RECINDEX *)malloc(sizeof(RECINDEX) + mp->len/(2*nw_rec)*sizeof(char *)); |
| 153 | if (rp == NULL) |
| 154 | return(NULL); |
| 155 | rp->nw_rec = nw_rec; |
| 156 | rp->nrecs = 0; |
| 157 | cp = (char *)mp->base; |
| 158 | mend = cp + mp->len; |
| 159 | for ( ; ; ) {                           /* whitespace-separated words */ |
| 160 | while (cp < mend && !*cp | isspace(*cp)) |
| 161 | ++cp; |
| 162 | if (cp >= mend) |
| 163 | break; |
| 164 | rp->rec[rp->nrecs++] = cp;      /* point to first non-white */ |
| 165 | n = rp->nw_rec; |
| 166 | while (++cp < mend)             /* find end of record */ |
| 167 | if (!*cp | isspace(*cp)) { |
| 168 | if (--n <= 0) |
| 169 | break;  /* got requisite # words */ |
| 170 | do {            /* else find next word */ |
| 171 | if (*cp == '\n') { |
| 172 | fprintf(stderr, |
| 173 | "Unexpected EOL in record!\n"); |
| 174 | free_records(rp); |
| 175 | return(NULL); |
| 176 | } |
| 177 | if (++cp >= mend) |
| 178 | break; |
| 179 | } while (!*cp | isspace(*cp)); |
| 180 | } |
| 181 | } |
| 182 | rp->rec[rp->nrecs] = mend;              /* reallocate to save space */ |
| 183 | rp = (RECINDEX *)realloc(rp, |
| 184 | sizeof(RECINDEX) + rp->nrecs*sizeof(char *)); |
| 185 | return(rp); |
| 186 | } |
| 187 |  |
| 188 | /* count number of columns based on first EOL */ |
| 189 | static int |
| 190 | count_columns(const RECINDEX *rp) |
| 191 | { |
| 192 | char    *cp = rp->rec[0]; |
| 193 | char    *mend = rp->rec[rp->nrecs]; |
| 194 | int     i; |
| 195 |  |
| 196 | while (*cp != '\n') |
| 197 | if (++cp >= mend) |
| 198 | return(0); |
| 199 | for (i = 0; i < rp->nrecs; i++) |
| 200 | if (rp->rec[i] >= cp) |
| 201 | break; |
| 202 | return(i); |
| 203 | } |
| 204 |  |
| 205 | /* copy nth record from index to stdout */ |
| 206 | static int |
| 207 | print_record(const RECINDEX *rp, int n) |
| 208 | { |
| 209 | int     words2go = rp->nw_rec; |
| 210 | char    *scp; |
| 211 |  |
| 212 | if ((n < 0) | (n >= rp->nrecs)) |
| 213 | return(0); |
| 214 | scp = rp->rec[n]; |
| 215 | do { |
| 216 | putc(*scp++, stdout); |
| 217 | if (!*scp | isspace(*scp)) { |
| 218 | if (--words2go <= 0) |
| 219 | break; |
| 220 | putc(' ', stdout);      /* single space btwn. words */ |
| 221 | do |
| 222 | if (++scp >= rp->rec[n+1]) |
| 223 | break; |
| 224 | while (!*scp | isspace(*scp)); |
| 225 | } |
| 226 | } while (scp < rp->rec[n+1]); |
| 227 | /* caller adds record sep. */ |
| 228 | return(1); |
| 229 | } |
| 230 |  |
| 231 | /* copy a stream to stdout */ |
| 232 | static int |
| 233 | output_stream(FILE *fp) |
| 234 | { |
| 235 | char    buf[8192]; |
| 236 | ssize_t n; |
| 237 |  |
| 238 | if (fp == NULL) |
| 239 | return(0); |
| 240 | fflush(stdout); |
| 241 | while ((n = fread(buf, 1, sizeof(buf), fp)) > 0) |
| 242 | if (write(fileno(stdout), buf, n) != n) |
| 243 | return(0); |
| 244 | return(!ferror(fp)); |
| 245 | } |
| 246 |  |
| 247 | /* get next word from stream, leaving stream on EOL or start of next word */ |
| 248 | static char * |
| 249 | fget_word(char buf[256], FILE *fp) |
| 250 | { |
| 251 | int     c; |
| 252 | char    *cp; |
| 253 | /* skip nul's and white space */ |
| 254 | while (!(c = getc(fp)) || isspace(c)) |
| 255 | ; |
| 256 | if (c == EOF) |
| 257 | return(NULL); |
| 258 | cp = buf; |
| 259 | do |
| 260 | *cp++ = c; |
| 261 | while ((c = getc(fp)) != EOF && !isspace(c) && cp < buf+255); |
| 262 | *cp = '\0'; |
| 263 | while (isspace(c) & (c != '\n')) |
| 264 | c = getc(fp); |
| 265 | if (c != EOF) |
| 266 | ungetc(c, fp); |
| 267 | return(buf); |
| 268 | } |
| 269 |  |
| 270 | char            *fmtid = NULL;                  /* format id */ |
| 271 | int             comp_size = 0;                  /* binary bytes/channel */ |
| 272 | int             n_comp = 0;                     /* components/record */ |
| 273 | int             ni_columns = 0;                 /* number of input columns */ |
| 274 | int             ni_rows = 0;                    /* number of input rows */ |
| 275 | int             no_columns = 0;                 /* number of output columns */ |
| 276 | int             no_rows = 0;                    /* number of output rows */ |
| 277 | int             transpose = 0;                  /* transpose rows & cols? */ |
| 278 | int             i_header = 1;                   /* input header? */ |
| 279 | int             o_header = 1;                   /* output header? */ |
| 280 |  |
| 281 | /* check settings and assign defaults */ |
| 282 | static int |
| 283 | check_sizes() |
| 284 | { |
| 285 | if (fmtid == NULL) { |
| 286 | fmtid = "ascii"; |
| 287 | } else if (!comp_size) { |
| 288 | if (!strcmp(fmtid, "float")) |
| 289 | comp_size = sizeof(float); |
| 290 | else if (!strcmp(fmtid, "double")) |
| 291 | comp_size = sizeof(double); |
| 292 | else if (!strcmp(fmtid, "byte")) |
| 293 | comp_size = 1; |
| 294 | else if (strcmp(fmtid, "ascii")) { |
| 295 | fprintf(stderr, "Unsupported format: %s\n", fmtid); |
| 296 | return(0); |
| 297 | } |
| 298 | } |
| 299 | if (transpose && (no_rows <= 0) & (no_columns <= 0)) { |
| 300 | if (ni_rows > 0) no_columns = ni_rows; |
| 301 | if (ni_columns > 0) no_rows = ni_columns; |
| 302 | } else if ((no_rows <= 0) & (no_columns > 0) && |
| 303 | !((ni_rows*ni_columns) % no_columns)) |
| 304 | no_rows = ni_rows*ni_columns/no_columns; |
| 305 | if (n_comp <= 0) |
| 306 | n_comp = 3; |
| 307 | return(1); |
| 308 | } |
| 309 |  |
| 310 | /* output transposed ASCII or binary data from memory */ |
| 311 | static int |
| 312 | do_transpose(const MEMLOAD *mp) |
| 313 | { |
| 314 | static const char       tabEOL[2] = {'\t','\n'}; |
| 315 | RECINDEX                *rp = NULL; |
| 316 | long                    nrecords; |
| 317 | int                     i, j; |
| 318 | /* propogate sizes */ |
| 319 | if (ni_rows <= 0) |
| 320 | ni_rows = no_columns; |
| 321 | if (ni_columns <= 0) |
| 322 | ni_columns = no_rows; |
| 323 | /* get # records (& index) */ |
| 324 | if (!comp_size) { |
| 325 | if ((rp = index_records(mp, n_comp)) == NULL) |
| 326 | return(0); |
| 327 | if (ni_columns <= 0) |
| 328 | ni_columns = count_columns(rp); |
| 329 | nrecords = rp->nrecs; |
| 330 | } else if ((ni_rows > 0) & (ni_columns > 0)) { |
| 331 | nrecords = ni_rows*ni_columns; |
| 332 | if (nrecords > mp->len/(n_comp*comp_size)) { |
| 333 | fprintf(stderr, |
| 334 | "Input too small for specified size and type\n"); |
| 335 | return(0); |
| 336 | } |
| 337 | } else |
| 338 | nrecords = mp->len/(n_comp*comp_size); |
| 339 | /* check sizes */ |
| 340 | if ((ni_rows <= 0) & (ni_columns > 0)) |
| 341 | ni_rows = nrecords/ni_columns; |
| 342 | if ((ni_columns <= 0) & (ni_rows > 0)) |
| 343 | ni_columns = nrecords/ni_rows; |
| 344 | if (nrecords != ni_rows*ni_columns) |
| 345 | goto badspec; |
| 346 | if (no_columns <= 0) |
| 347 | no_columns = ni_rows; |
| 348 | if (no_rows <= 0) |
| 349 | no_rows = ni_columns; |
| 350 | if ((no_rows != ni_columns) | (no_columns != ni_rows)) |
| 351 | goto badspec; |
| 352 | /* transpose records */ |
| 353 | for (i = 0; i < no_rows; i++) { |
| 354 | for (j = 0; j < no_columns; j++) |
| 355 | if (rp != NULL) {               /* ASCII output */ |
| 356 | print_record(rp, j*ni_columns + i); |
| 357 | putc(tabEOL[j >= no_columns-1], stdout); |
| 358 | } else {                        /* binary output */ |
| 359 | fwrite((char *)mp->base + |
| 360 | (n_comp*comp_size)*(j*ni_columns + i), |
| 361 | n_comp*comp_size, 1, stdout); |
| 362 | } |
| 363 | if (ferror(stdout)) { |
| 364 | fprintf(stderr, "Error writing to stdout\n"); |
| 365 | return(0); |
| 366 | } |
| 367 | } |
| 368 | if (rp != NULL) |
| 369 | free_records(rp); |
| 370 | return(1); |
| 371 | badspec: |
| 372 | fprintf(stderr, "Bad transpose specification -- check dimension(s)\n"); |
| 373 | return(0); |
| 374 | } |
| 375 |  |
| 376 | /* resize ASCII stream input by ignoring EOLs between records */ |
| 377 | static int |
| 378 | do_resize(FILE *fp) |
| 379 | { |
| 380 | long    records2go = ni_rows*ni_columns; |
| 381 | int     columns2go = no_columns; |
| 382 | char    word[256]; |
| 383 | /* sanity checks */ |
| 384 | if (comp_size) |
| 385 | return(output_stream(fp));      /* binary data -- just copy */ |
| 386 | if (no_columns <= 0) { |
| 387 | fprintf(stderr, "Missing -oc specification\n"); |
| 388 | return(0); |
| 389 | } |
| 390 | if ((records2go <= 0) & (no_rows > 0)) |
| 391 | records2go = no_rows*no_columns; |
| 392 | else if (no_rows*no_columns != records2go) { |
| 393 | fprintf(stderr, |
| 394 | "Input and output data sizes disagree (%dx%d != %dx%d)\n", |
| 395 | ni_rows, ni_columns, no_rows, no_columns); |
| 396 | return(0); |
| 397 | } |
| 398 | do {                                    /* reshape records */ |
| 399 | int     n; |
| 400 |  |
| 401 | for (n = n_comp; n--; ) { |
| 402 | if (fget_word(word, fp) == NULL) { |
| 403 | if (records2go > 0 || n < n_comp-1) |
| 404 | break; |
| 405 | goto done;      /* normal EOD */ |
| 406 | } |
| 407 | fputs(word, stdout); |
| 408 | if (n) {                /* mid-record? */ |
| 409 | int     c = getc(fp); |
| 410 | if ((c == '\n') | (c == EOF)) |
| 411 | break; |
| 412 | ungetc(c, fp); |
| 413 | putc(' ', stdout); |
| 414 | } |
| 415 | } |
| 416 | if (n >= 0) { |
| 417 | fprintf(stderr, "Incomplete record / unexpected EOF\n"); |
| 418 | return(0); |
| 419 | } |
| 420 | if (--columns2go <= 0) {        /* time to end output row? */ |
| 421 | putc('\n', stdout); |
| 422 | columns2go = no_columns; |
| 423 | } else                          /* else separate records */ |
| 424 | putc('\t', stdout); |
| 425 | } while (--records2go);                 /* expected EOD? */ |
| 426 | done: |
| 427 | if (warnings && columns2go != no_columns) |
| 428 | fprintf(stderr, "Warning -- incomplete final row\n"); |
| 429 | if (warnings && fget_word(word, fp) != NULL) |
| 430 | fprintf(stderr, "Warning -- characters beyond expected EOD\n"); |
| 431 | return(1); |
| 432 | } |
| 433 |  |
| 434 | /* process a header line and copy to stdout */ |
| 435 | static int |
| 436 | headline(char *s, void *p) |
| 437 | { |
| 438 | static char     fmt[32]; |
| 439 | int             n; |
| 440 |  |
| 441 | if (formatval(fmt, s)) { |
| 442 | if (fmtid == NULL) { |
| 443 | fmtid = fmt; |
| 444 | return(0); |
| 445 | } |
| 446 | if (!strcmp(fmt, fmtid)) |
| 447 | return(0); |
| 448 | fprintf(stderr, "Input format '%s' != '%s'\n", fmt, fmtid); |
| 449 | return(-1); |
| 450 | } |
| 451 | if (!strncmp(s, "NROWS=", 6)) { |
| 452 | n = atoi(s+6); |
| 453 | if ((ni_rows > 0) & (n != ni_rows)) { |
| 454 | fputs("Incorrect input row count\n", stderr); |
| 455 | return(-1); |
| 456 | } |
| 457 | ni_rows = n; |
| 458 | return(0); |
| 459 | } |
| 460 | if (!strncmp(s, "NCOLS=", 6)) { |
| 461 | n = atoi(s+6); |
| 462 | if ((ni_columns > 0) & (n != ni_columns)) { |
| 463 | fputs("Incorrect input column count\n", stderr); |
| 464 | return(-1); |
| 465 | } |
| 466 | ni_columns = n; |
| 467 | return(0); |
| 468 | } |
| 469 | if (!strncmp(s, "NCOMP=", 6)) { |
| 470 | n = atoi(s+6); |
| 471 | if ((n_comp > 0) & (n != n_comp)) { |
| 472 | fputs("Incorrect number of components\n", stderr); |
| 473 | return(-1); |
| 474 | } |
| 475 | n_comp = n; |
| 476 | return(0); |
| 477 | } |
| 478 | if (o_header) |
| 479 | fputs(s, stdout);               /* copy header info. */ |
| 480 | return(0); |
| 481 | } |
| 482 |  |
| 483 | /* main routine for converting rows/columns in data file */ |
| 484 | int |
| 485 | main(int argc, char *argv[]) |
| 486 | { |
| 487 | int     a; |
| 488 |  |
| 489 | for (a = 1; a < argc && argv[a][0] == '-'; a++) |
| 490 | switch (argv[a][1]) { |
| 491 | case 'i':                       /* input */ |
| 492 | if (argv[a][2] == 'c')  /* columns */ |
| 493 | ni_columns = atoi(argv[++a]); |
| 494 | else if (argv[a][2] == 'r') |
| 495 | ni_rows = atoi(argv[++a]); |
| 496 | else |
| 497 | goto userr; |
| 498 | break; |
| 499 | case 'o':                       /* output */ |
| 500 | if (argv[a][2] == 'c')  /* columns */ |
| 501 | no_columns = atoi(argv[++a]); |
| 502 | else if (argv[a][2] == 'r') |
| 503 | no_rows = atoi(argv[++a]); |
| 504 | else |
| 505 | goto userr; |
| 506 | break; |
| 507 | case 'h':                       /* turn off header */ |
| 508 | switch (argv[a][2]) { |
| 509 | case 'i': |
| 510 | i_header = 0; |
| 511 | break; |
| 512 | case 'o': |
| 513 | o_header = 0; |
| 514 | break; |
| 515 | case '\0': |
| 516 | i_header = o_header = 0; |
| 517 | break; |
| 518 | default: |
| 519 | goto userr; |
| 520 | } |
| 521 | break; |
| 522 | case 't':                       /* transpose on/off */ |
| 523 | transpose = !transpose; |
| 524 | break; |
| 525 | case 'f':                       /* format */ |
| 526 | switch (argv[a][2]) { |
| 527 | case 'a':               /* ASCII */ |
| 528 | case 'A': |
| 529 | fmtid = "ascii"; |
| 530 | comp_size = 0; |
| 531 | break; |
| 532 | case 'f':               /* float */ |
| 533 | case 'F': |
| 534 | fmtid = "float"; |
| 535 | comp_size = sizeof(float); |
| 536 | break; |
| 537 | case 'd':               /* double */ |
| 538 | case 'D': |
| 539 | fmtid = "double"; |
| 540 | comp_size = sizeof(double); |
| 541 | break; |
| 542 | case 'b':               /* binary (bytes) */ |
| 543 | case 'B': |
| 544 | fmtid = "byte"; |
| 545 | comp_size = 1; |
| 546 | break; |
| 547 | default: |
| 548 | goto userr; |
| 549 | } |
| 550 | if (argv[a][3]) { |
| 551 | if (!isdigit(argv[a][3])) |
| 552 | goto userr; |
| 553 | n_comp = atoi(argv[a]+3); |
| 554 | } else |
| 555 | n_comp = 1; |
| 556 | break; |
| 557 | case 'w':                       /* warnings on/off */ |
| 558 | warnings = !warnings; |
| 559 | break; |
| 560 | default: |
| 561 | goto userr; |
| 562 | } |
| 563 | if (a < argc-1)                         /* arg count OK? */ |
| 564 | goto userr; |
| 565 | /* open input file? */ |
| 566 | if (a == argc-1 && freopen(argv[a], "r", stdin) == NULL) { |
| 567 | fprintf(stderr, "%s: cannot open for reading\n", argv[a]); |
| 568 | return(1); |
| 569 | } |
| 570 | if (comp_size) { |
| 571 | SET_FILE_BINARY(stdin); |
| 572 | SET_FILE_BINARY(stdout); |
| 573 | } |
| 574 | /* check for no-op */ |
| 575 | if (!transpose & !i_header & !o_header && (comp_size || |
| 576 | (no_columns == ni_columns) & (no_rows == ni_rows))) { |
| 577 | if (warnings) |
| 578 | fprintf(stderr, "%s: no-op -- copying input verbatim\n", |
| 579 | argv[0]); |
| 580 | if (!output_stream(stdin)) |
| 581 | return(1); |
| 582 | return(0); |
| 583 | } |
| 584 | if (i_header) {                         /* read header */ |
| 585 | if (getheader(stdin, headline, NULL) < 0) |
| 586 | return(1); |
| 587 | if (!check_sizes()) |
| 588 | return(1); |
| 589 | if (comp_size) {                /* a little late... */ |
| 590 | SET_FILE_BINARY(stdin); |
| 591 | SET_FILE_BINARY(stdout); |
| 592 | } |
| 593 | } else if (!check_sizes()) |
| 594 | return(1); |
| 595 | if (o_header) {                         /* write header */ |
| 596 | printargs(a, argv, stdout); |
| 597 | if (no_rows > 0) |
| 598 | printf("NROWS=%d\n", no_rows); |
| 599 | if (no_columns > 0) |
| 600 | printf("NCOLS=%d\n", no_columns); |
| 601 | printf("NCOMP=%d\n", n_comp); |
| 602 | fputformat(fmtid, stdout); |
| 603 | fputc('\n', stdout);            /* finish new header */ |
| 604 | } |
| 605 | if (transpose) {                        /* transposing rows & columns? */ |
| 606 | MEMLOAD myMem;                  /* need to load into memory */ |
| 607 | if (a == argc-1) { |
| 608 | if (load_file(&myMem, stdin) <= 0) { |
| 609 | fprintf(stderr, "%s: error loading file into memory\n", |
| 610 | argv[a]); |
| 611 | return(1); |
| 612 | } |
| 613 | } else if (load_stream(&myMem, stdin) <= 0) { |
| 614 | fprintf(stderr, "%s: error loading stdin into memory\n", |
| 615 | argv[0]); |
| 616 | return(1); |
| 617 | } |
| 618 | if (!do_transpose(&myMem)) |
| 619 | return(1); |
| 620 | /* free_load(&myMem);   about to exit, so don't bother */ |
| 621 | } else if (comp_size || (no_columns==ni_columns) & (no_rows==ni_rows)) { |
| 622 | if (!output_stream(stdin))      /* just changed header */ |
| 623 | return(1); |
| 624 | } else if (!do_resize(stdin))           /* reshaping input */ |
| 625 | return(1); |
| 626 | return(0); |
| 627 | userr: |
| 628 | fprintf(stderr, |
| 629 | "Usage: %s [-h[io]][-w][-f[afdb][N]][-t][-ic in_col][-ir in_row][-oc out_col][-or out_row] [input.dat]\n", |
| 630 | argv[0]); |
| 631 | return(1); |
| 632 | } |
