root/radiance/ray/src/util/rcollate.c
Revision: 2.1
Committed: Thu Sep 5 17:53:23 2013 UTC (10 years, 8 months ago) by greg
5 * Utility to re-order records in a binary or ASCII data file (matrix)
6 */
7
8 #include <stdlib.h>
9 #include <unistd.h>
10 #include <string.h>
11 #include <ctype.h>
12 #include "platform.h"
13 #include "rtio.h"
14 #include "resolu.h"
15 #ifndef _WIN32
16 #include <sys/mman.h>
17 #endif
18
19 #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
20 #undef getc
21 #undef putc
22 #define getc getc_unlocked
23 #define putc putc_unlocked
24 #endif
25
26 typedef struct {
27 void *base; /* pointer to base memory */
28 size_t len; /* allocated memory length */
29 int mapped; /* memory-mapped file? */
30 } MEMLOAD; /* file loaded/mapped into memory */
31
32 typedef struct {
33 int nw_rec; /* number of words per record */
34 int nrecs; /* number of records we found */
35 char *rec[1]; /* record array (extends struct) */
36 } RECINDEX;
37
38 /* free loaded file */
39 static void
40 free_load(MEMLOAD *mp)
41 {
42 if (mp == NULL || (mp->base == NULL) | (mp->len <= 0))
43 return;
44 #ifdef MAP_FILE
45 if (mp->mapped)
46 munmap(mp->base, mp->len);
47 else
48 #endif
49 free(mp->base);
50 mp->base = NULL;
51 mp->len = 0;
52 }
53
54 /* load a file into memory */
55 static int
56 load_file(MEMLOAD *mp, FILE *fp)
57 {
58 int fd;
59 off_t skip, flen;
60
61 if (mp == NULL)
62 return(-1);
63 mp->base = NULL;
64 mp->len = 0;
65 mp->mapped = 0;
66 if (fp == NULL)
67 return(-1);
68 fd = fileno(fp);
69 skip = ftello(fp);
70 flen = lseek(fd, 0, SEEK_END);
71 if (flen <= skip)
72 return((int)(flen - skip));
73 mp->len = (size_t)(flen - skip);
74 #ifdef MAP_FILE
75 if (mp->len > 1L<<20) { /* map file if > 1 MByte */
76 mp->base = mmap(NULL, mp->len, PROT_READ|PROT_WRITE,
77 MAP_PRIVATE, fd, skip);
78 if (mp->base != MAP_FAILED) {
79 mp->mapped = 1;
80 return(1); /* mmap() success */
81 }
82 mp->base = NULL; /* fall back to reading it in... */
83 }
84 #endif
85 if (lseek(fd, skip, SEEK_SET) != skip ||
86 (mp->base = malloc(mp->len)) == NULL) {
87 mp->len = 0;
88 return(-1);
89 }
90 if (read(fd, (char *)mp->base, mp->len) != mp->len) {
91 free_load(mp);
92 return(-1);
93 }
94 return(1);
95 }
96
97 /* load memory from an input stream, starting from current position */
98 static int
99 load_stream(MEMLOAD *mp, FILE *fp)
100 {
101 char buf[8192];
102 size_t nr;
103
104 if (mp == NULL)
105 return(-1);
106 mp->base = NULL;
107 mp->len = 0;
108 mp->mapped = 0;
109 if (fp == NULL)
110 return(-1);
111 while ((nr = fread(buf, 1, sizeof(buf), fp)) > 0) {
112 if (!mp->len)
113 mp->base = malloc(nr);
114 else
115 mp->base = realloc(mp->base, mp->len+nr);
116 if (mp->base == NULL)
117 return(-1);
118 memcpy((char *)mp->base + mp->len, buf, nr);
119 mp->len += nr;
120 }
121 if (ferror(fp)) {
122 free_load(mp);
123 return(-1);
124 }
125 return(mp->len > 0);
126 }
127
128 /* free a record index */
129 #define free_records(rp) free(rp)
130
131 /* compute record index */
132 static RECINDEX *
133 index_records(const MEMLOAD *mp, int nw_rec)
134 {
135 RECINDEX *rp;
136 char *cp, *mend;
137 int n;
138
139 if (mp == NULL || (mp->base == NULL) | (mp->len <= 0))
140 return(NULL);
141 if (nw_rec <= 0)
142 return(NULL);
143 rp = (RECINDEX *)malloc(sizeof(RECINDEX) + mp->len/(2*nw_rec)*sizeof(char *));
144 if (rp == NULL)
145 return(NULL);
146 rp->nw_rec = nw_rec;
147 rp->nrecs = 0;
148 cp = (char *)mp->base;
149 mend = cp + mp->len;
150 for ( ; ; ) { /* whitespace-separated words */
151 while (cp < mend && !*cp | isspace(*cp))
152 ++cp;
153 if (cp >= mend)
154 break;
155 rp->rec[rp->nrecs++] = cp; /* point to first non-white */
156 n = rp->nw_rec;
157 while (++cp < mend) /* find end of record */
158 if (!*cp | isspace(*cp)) {
159 if (--n <= 0)
160 break; /* got requisite # words */
161 do { /* else find next word */
162 if (*cp == '\n') {
163 fprintf(stderr,
164 "Unexpected EOL in record!\n");
165 free_records(rp);
166 return(NULL);
167 }
168 if (++cp >= mend)
169 break;
170 } while (!*cp | isspace(*cp));
171 }
172 }
173 rp->rec[rp->nrecs] = mend; /* reallocate to save space */
174 rp = (RECINDEX *)realloc(rp,
175 sizeof(RECINDEX) + rp->nrecs*sizeof(char *));
176 return(rp);
177 }
178
179 /* count number of columns based on first EOL */
180 static int
181 count_columns(const RECINDEX *rp)
182 {
183 char *cp = rp->rec[0];
184 char *mend = rp->rec[rp->nrecs];
185 int i;
186
187 while (*cp != '\n')
188 if (++cp >= mend)
189 return(0);
190 for (i = 0; i < rp->nrecs; i++)
191 if (rp->rec[i] >= cp)
192 break;
193 return(i);
194 }
195
196 /* copy nth record from index to stdout */
197 static int
198 print_record(const RECINDEX *rp, int n)
199 {
200 int words2go = rp->nw_rec;
201 char *scp;
202
203 if ((n < 0) | (n >= rp->nrecs))
204 return(0);
205 scp = rp->rec[n];
206 do {
207 putc(*scp++, stdout);
208 if (!*scp | isspace(*scp)) {
209 if (--words2go <= 0)
210 break;
211 putc(' ', stdout); /* single space btwn. words */
212 do
213 if (++scp >= rp->rec[n+1])
214 break;
215 while (!*scp | isspace(*scp));
216 }
217 } while (scp < rp->rec[n+1]);
218 /* caller adds record sep. */
219 return(1);
220 }
221
222 /* copy a stream to stdout */
223 static int
224 output_stream(FILE *fp)
225 {
226 char buf[8192];
227 ssize_t n;
228
229 if (fp == NULL)
230 return(0);
231 fflush(stdout); /* assumes nothing in input buffer */
232 while ((n = read(fileno(fp), buf, sizeof(buf))) > 0)
233 if (write(fileno(stdout), buf, n) != n)
234 return(0);
235 return(n >= 0);
236 }
237
238 /* get next word from stream, leaving stream on EOL or start of next word */
239 static char *
240 fget_word(char buf[256], FILE *fp)
241 {
242 int c;
243 char *cp;
244 /* skip nul's and white space */
245 while (!(c = getc(fp)) || isspace(c))
246 ;
247 if (c == EOF)
248 return(NULL);
249 cp = buf;
250 do
251 *cp++ = c;
252 while ((c = getc(fp)) != EOF && !isspace(c) && cp < buf+255);
253 *cp = '\0';
254 while (isspace(c) & (c != '\n'))
255 c = getc(fp);
256 if (c != EOF)
257 ungetc(c, fp);
258 return(buf);
259 }
260
261 char *fmtid = "ascii"; /* format id */
262 int record_width = 3; /* words/record (<0 binary) */
263 int ni_columns = 0; /* number of input columns */
264 int ni_rows = 0; /* number of input rows */
265 int no_columns = 0; /* number of output columns */
266 int no_rows = 0; /* number of output rows */
267
268 /* output transposed ASCII or binary data from memory */
269 static int
270 do_transpose(const MEMLOAD *mp)
271 {
272 static const char tabEOL[2] = {'\t','\n'};
273 RECINDEX *rp = NULL;
274 long nrecords;
275 int i, j;
276 /* get # records (& index) */
277 if (record_width > 0) {
278 if ((rp = index_records(mp, record_width)) == NULL)
279 return(0);
280 if (ni_columns <= 0)
281 ni_columns = count_columns(rp);
282 nrecords = rp->nrecs;
283 } else if ((ni_rows > 0) & (ni_columns > 0))
284 nrecords = ni_rows*ni_columns;
285 else
286 nrecords = mp->len / -record_width;
287 /* check sizes */
288 if (ni_rows <= 0)
289 ni_rows = no_columns;
290 if (ni_columns <= 0)
291 ni_columns = no_rows;
292 if ((ni_rows <= 0) & (ni_columns > 0))
293 ni_rows = nrecords/ni_columns;
294 if ((ni_columns <= 0) & (ni_rows > 0))
295 ni_columns = nrecords/ni_rows;
296 if (nrecords != ni_rows*ni_columns)
297 goto badspec;
298 if (no_columns <= 0)
299 no_columns = ni_rows;
300 if (no_rows <= 0)
301 no_rows = ni_columns;
302 if ((no_rows != ni_columns) | (no_columns != ni_rows))
303 goto badspec;
304 /* transpose records */
305 for (i = 0; i < no_rows; i++) {
306 for (j = 0; j < no_columns; j++)
307 if (rp != NULL) { /* ASCII output */
308 print_record(rp, j*ni_columns + i);
309 putc(tabEOL[j >= no_columns-1], stdout);
310 } else { /* binary output */
311 fwrite((char *)mp->base +
312 -record_width*(j*ni_columns + i),
313 -record_width, 1, stdout);
314 }
315 if (ferror(stdout)) {
316 fprintf(stderr, "Error writing to stdout\n");
317 return(0);
318 }
319 }
320 if (rp != NULL)
321 free_records(rp);
322 return(1);
323 badspec:
324 fprintf(stderr, "Bad transpose specification -- check dimension(s)\n");
325 return(0);
326 }
327
328 /* resize ASCII stream input by ignoring EOLs between records */
329 static int
330 do_resize(FILE *fp)
331 {
332 long records2go = ni_rows*ni_columns;
333 int columns2go = no_columns;
334 char word[256];
335 /* sanity checks */
336 if (record_width <= 0) {
337 fprintf(stderr, "Bad call to do_resize (record_width = %d)\n",
338 record_width);
339 return(0);
340 }
341 if (no_columns <= 0) {
342 fprintf(stderr, "Missing -oc specification\n");
343 return(0);
344 }
345 if ((records2go <= 0) & (no_rows > 0))
346 records2go = no_rows*no_columns;
347 else if (no_rows*no_columns != records2go) {
348 fprintf(stderr,
349 "Input and output data sizes disagree (%dx%d != %dx%d)\n",
350 ni_rows, ni_columns, no_rows, no_columns);
351 return(0);
352 }
353 do { /* reshape records */
354 int n;
355
356 for (n = record_width; n--; ) {
357 if (fget_word(word, fp) == NULL) {
358 if (records2go > 0 || n < record_width-1)
359 break;
360 goto done; /* normal EOD */
361 }
362 fputs(word, stdout);
363 if (n) { /* mid-record? */
364 int c = getc(fp);
365 if ((c == '\n') | (c == EOF))
366 break;
367 ungetc(c, fp);
368 putc(' ', stdout);
369 }
370 }
371 if (n >= 0) {
372 fprintf(stderr, "Incomplete record / unexpected EOF\n");
373 return(0);
374 }
375 if (--columns2go <= 0) { /* time to end output row? */
376 putc('\n', stdout);
377 columns2go = no_columns;
378 } else /* else separate records */
379 putc('\t', stdout);
380 } while (--records2go); /* expected EOD? */
381 done:
382 if (columns2go != no_columns)
383 fprintf(stderr, "Warning -- incomplete final row\n");
384 if (fget_word(word, fp) != NULL)
385 fprintf(stderr, "Warning -- data beyond expected EOF\n");
386 return(1);
387 }
388
389 /* process a header line and copy to stdout */
390 static int
391 headline(char *s, void *p)
392 {
393 char fmt[32];
394
395 if (formatval(fmt, s)) {
396 if (!strcmp(fmt, fmtid))
397 return(0);
398 fprintf(stderr, "Input format '%s' != '%s'\n", fmt, fmtid);
399 return(-1);
400 }
401 fputs(s, stdout); /* copy header info. */
402 return(0);
403 }
404
405 /* main routine for converting rows/columns in data file */
406 int
407 main(int argc, char *argv[])
408 {
409 int do_header = 1; /* header i/o? */
410 int transpose = 0; /* transpose rows & cols? */
411 int i;
412
413 for (i = 1; i < argc && argv[i][0] == '-'; i++)
414 switch (argv[i][1]) {
415 case 'i': /* input */
416 if (argv[i][2] == 'c') /* columns */
417 ni_columns = atoi(argv[++i]);
418 else if (argv[i][2] == 'r')
419 ni_rows = atoi(argv[++i]);
420 else
421 goto userr;
422 break;
423 case 'o': /* output */
424 if (argv[i][2] == 'c') /* columns */
425 no_columns = atoi(argv[++i]);
426 else if (argv[i][2] == 'r')
427 no_rows = atoi(argv[++i]);
428 else
429 goto userr;
430 break;
431 case 'h': /* header on/off */
432 do_header = !do_header;
433 break;
434 case 't': /* transpose on/off */
435 transpose = !transpose;
436 break;
437 case 'f': /* format */
438 switch (argv[i][2]) {
439 case 'a': /* ASCII */
440 case 'A':
441 fmtid = "ascii";
442 record_width = 1;
443 break;
444 case 'f': /* float */
445 case 'F':
446 fmtid = "float";
447 record_width = -(int)sizeof(float);
448 break;
449 case 'd': /* double */
450 case 'D':
451 fmtid = "double";
452 record_width = -(int)sizeof(double);
453 break;
454 case 'b': /* binary (bytes) */
455 case 'B':
456 fmtid = "byte";
457 record_width = -1;
458 break;
459 default:
460 goto userr;
461 }
462 if (argv[i][3]) {
463 if (!isdigit(argv[i][3]))
464 goto userr;
465 record_width *= atoi(argv[i]+3);
466 }
467 break;
468 default:
469 goto userr;
470 }
471 if (!record_width)
472 goto userr;
473 if (i < argc-1) /* arg count OK? */
474 goto userr;
475 /* open input file? */
476 if (i == argc-1 && freopen(argv[i], "r", stdin) == NULL) {
477 fprintf(stderr, "%s: cannot open for reading\n", argv[i]);
478 return(1);
479 }
480 if (record_width < 0) {
481 SET_FILE_BINARY(stdin);
482 SET_FILE_BINARY(stdout);
483 }
484 /* check for no-op */
485 if (!transpose && (record_width < 0 ||
486 (no_columns == ni_columns) & (no_rows == ni_rows))) {
487 fprintf(stderr, "%s: no-op -- copying input verbatim\n",
488 argv[0]);
489 if (!output_stream(stdin))
490 return(1);
491 return(0);
492 }
493 if (do_header) { /* read/write header */
494 if (getheader(stdin, &headline, NULL) < 0)
495 return(1);
496 printargs(argc, argv, stdout);
497 fputformat(fmtid, stdout);
498 fputc('\n', stdout); /* finish new header */
499 }
500 if (transpose) { /* transposing rows & columns? */
501 MEMLOAD myMem; /* need to load into memory */
502 if (i == argc-1) {
503 if (load_file(&myMem, stdin) <= 0) {
504 fprintf(stderr, "%s: error loading file into memory\n",
505 argv[i]);
506 return(1);
507 }
508 } else if (load_stream(&myMem, stdin) <= 0) {
509 fprintf(stderr, "%s: error loading stdin into memory\n",
510 argv[0]);
511 return(1);
512 }
513 if (!do_transpose(&myMem))
514 return(1);
515 /* free_load(&myMem); */
516 } else if (!do_resize(stdin)) /* just reshaping input */
517 return(1);
518 return(0);
519 userr:
520 fprintf(stderr,
521 "Usage: %s [-h][-f[afdb][N]][-t][-ic in_col][-ir in_row][-oc out_col][-or out_row] [input.dat]\n",
522 argv[0]);
523 return(1);
524 }
