--- ray/src/util/rcollate.c 2013/09/06 21:43:29 2.5 +++ ray/src/util/rcollate.c 2014/05/30 16:50:43 2.10 @@ -1,18 +1,22 @@ #ifndef lint -static const char RCSid[] = "$Id: rcollate.c,v 2.5 2013/09/06 21:43:29 greg Exp $"; +static const char RCSid[] = "$Id: rcollate.c,v 2.10 2014/05/30 16:50:43 greg Exp $"; #endif /* * Utility to re-order records in a binary or ASCII data file (matrix) */ #include -#include #include #include #include "platform.h" #include "rtio.h" #include "resolu.h" -#ifndef _WIN32 +#ifdef _WIN32 +#undef ftello +#define ftello ftell +#undef ssize_t +#define ssize_t size_t +#else #include #endif @@ -99,6 +103,7 @@ load_file(MEMLOAD *mp, FILE *fp) static int load_stream(MEMLOAD *mp, FILE *fp) { + size_t alloced = 0; char buf[8192]; size_t nr; @@ -110,10 +115,11 @@ load_stream(MEMLOAD *mp, FILE *fp) if (fp == NULL) return(-1); while ((nr = fread(buf, 1, sizeof(buf), fp)) > 0) { - if (!mp->len) + if (!alloced) mp->base = malloc(nr); - else - mp->base = realloc(mp->base, mp->len+nr); + else if (mp->len+nr > alloced) + mp->base = realloc(mp->base, + alloced = alloced*(2+(nr==sizeof(buf)))/2+nr); if (mp->base == NULL) return(-1); memcpy((char *)mp->base + mp->len, buf, nr); @@ -123,6 +129,8 @@ load_stream(MEMLOAD *mp, FILE *fp) free_load(mp); return(-1); } + if (alloced > mp->len*5/4) /* don't waste too much space */ + mp->base = realloc(mp->base, mp->len); return(mp->len > 0); } @@ -259,13 +267,32 @@ fget_word(char buf[256], FILE *fp) return(buf); } -char *fmtid = "ascii"; /* format id */ -int record_width = 3; /* words/record (<0 binary) */ +char *fmtid = NULL; /* format id */ +int comp_size = 0; /* binary bytes/channel */ +int n_comp = 0; /* components/record */ int ni_columns = 0; /* number of input columns */ int ni_rows = 0; /* number of input rows */ int no_columns = 0; /* number of output columns */ int no_rows = 0; /* number of output rows */ +/* check settings and assign defaults */ +static void +check_sizes() +{ + if (fmtid == NULL) { + fmtid = "ascii"; + } else if (!comp_size) { + if (!strcmp(fmtid, "float")) + comp_size = sizeof(float); + else if (!strcmp(fmtid, "double")) + comp_size = sizeof(double); + else if (!strcmp(fmtid, "byte")) + comp_size = 1; + } + if (n_comp <= 0) + n_comp = 3; +} + /* output transposed ASCII or binary data from memory */ static int do_transpose(const MEMLOAD *mp) @@ -280,21 +307,21 @@ do_transpose(const MEMLOAD *mp) if (ni_columns <= 0) ni_columns = no_rows; /* get # records (& index) */ - if (record_width > 0) { - if ((rp = index_records(mp, record_width)) == NULL) + if (!comp_size) { + if ((rp = index_records(mp, n_comp)) == NULL) return(0); if (ni_columns <= 0) ni_columns = count_columns(rp); nrecords = rp->nrecs; } else if ((ni_rows > 0) & (ni_columns > 0)) { nrecords = ni_rows*ni_columns; - if (nrecords > mp->len / -record_width) { + if (nrecords > mp->len/(n_comp*comp_size)) { fprintf(stderr, "Input too small for specified size and type\n"); return(0); } } else - nrecords = mp->len / -record_width; + nrecords = mp->len/(n_comp*comp_size); /* check sizes */ if ((ni_rows <= 0) & (ni_columns > 0)) ni_rows = nrecords/ni_columns; @@ -316,8 +343,8 @@ do_transpose(const MEMLOAD *mp) putc(tabEOL[j >= no_columns-1], stdout); } else { /* binary output */ fwrite((char *)mp->base + - -record_width*(j*ni_columns + i), - -record_width, 1, stdout); + (n_comp*comp_size)*(j*ni_columns + i), + n_comp*comp_size, 1, stdout); } if (ferror(stdout)) { fprintf(stderr, "Error writing to stdout\n"); @@ -340,9 +367,8 @@ do_resize(FILE *fp) int columns2go = no_columns; char word[256]; /* sanity checks */ - if (record_width <= 0) { - fprintf(stderr, "Bad call to do_resize (record_width = %d)\n", - record_width); + if (comp_size) { + fputs("Bad call to do_resize (binary input)\n", stderr); return(0); } if (no_columns <= 0) { @@ -360,9 +386,9 @@ do_resize(FILE *fp) do { /* reshape records */ int n; - for (n = record_width; n--; ) { + for (n = n_comp; n--; ) { if (fget_word(word, fp) == NULL) { - if (records2go > 0 || n < record_width-1) + if (records2go > 0 || n < n_comp-1) break; goto done; /* normal EOD */ } @@ -397,14 +423,46 @@ done: static int headline(char *s, void *p) { - char fmt[32]; + static char fmt[32]; + int n; if (formatval(fmt, s)) { + if (fmtid == NULL) { + fmtid = fmt; + return(0); + } if (!strcmp(fmt, fmtid)) return(0); fprintf(stderr, "Input format '%s' != '%s'\n", fmt, fmtid); return(-1); } + if (!strncmp(s, "NROWS=", 6)) { + n = atoi(s+6); + if ((ni_rows > 0) & (n != ni_rows)) { + fputs("Incorrect input row count\n", stderr); + return(-1); + } + ni_rows = n; + return(0); + } + if (!strncmp(s, "NCOLS=", 6)) { + n = atoi(s+6); + if ((ni_columns > 0) & (n != ni_columns)) { + fputs("Incorrect input column count\n", stderr); + return(-1); + } + ni_columns = n; + return(0); + } + if (!strncmp(s, "NCOMP=", 6)) { + n = atoi(s+6); + if ((n_comp > 0) & (n != n_comp)) { + fputs("Incorrect number of components", stderr); + return(-1); + } + n_comp = n; + return(0); + } fputs(s, stdout); /* copy header info. */ return(0); } @@ -413,7 +471,8 @@ headline(char *s, void *p) int main(int argc, char *argv[]) { - int do_header = 1; /* header i/o? */ + int i_header = 1; /* input header? */ + int o_header = 1; /* output header? */ int transpose = 0; /* transpose rows & cols? */ int i; @@ -435,8 +494,20 @@ main(int argc, char *argv[]) else goto userr; break; - case 'h': /* header on/off */ - do_header = !do_header; + case 'h': /* turn off header */ + switch (argv[i][2]) { + case 'i': + i_header = 0; + break; + case 'o': + o_header = 0; + break; + case '\0': + i_header = o_header = 0; + break; + default: + goto userr; + } break; case 't': /* transpose on/off */ transpose = !transpose; @@ -446,22 +517,22 @@ main(int argc, char *argv[]) case 'a': /* ASCII */ case 'A': fmtid = "ascii"; - record_width = 1; + comp_size = 0; break; case 'f': /* float */ case 'F': fmtid = "float"; - record_width = -(int)sizeof(float); + comp_size = sizeof(float); break; case 'd': /* double */ case 'D': fmtid = "double"; - record_width = -(int)sizeof(double); + comp_size = sizeof(double); break; case 'b': /* binary (bytes) */ case 'B': fmtid = "byte"; - record_width = -1; + comp_size = 1; break; default: goto userr; @@ -469,7 +540,7 @@ main(int argc, char *argv[]) if (argv[i][3]) { if (!isdigit(argv[i][3])) goto userr; - record_width *= atoi(argv[i]+3); + n_comp = atoi(argv[i]+3); } break; case 'w': /* warnings on/off */ @@ -478,8 +549,6 @@ main(int argc, char *argv[]) default: goto userr; } - if (!record_width) - goto userr; if (i < argc-1) /* arg count OK? */ goto userr; /* open input file? */ @@ -487,12 +556,12 @@ main(int argc, char *argv[]) fprintf(stderr, "%s: cannot open for reading\n", argv[i]); return(1); } - if (record_width < 0) { + if (comp_size) { SET_FILE_BINARY(stdin); SET_FILE_BINARY(stdout); } /* check for no-op */ - if (!transpose && (record_width < 0 || + if (!transpose && (comp_size || (no_columns == ni_columns) & (no_rows == ni_rows))) { if (warnings) fprintf(stderr, "%s: no-op -- copying input verbatim\n", @@ -501,10 +570,27 @@ main(int argc, char *argv[]) return(1); return(0); } - if (do_header) { /* read/write header */ + if (i_header) { /* read header */ if (getheader(stdin, &headline, NULL) < 0) return(1); + check_sizes(); + if (comp_size) { /* a little late... */ + SET_FILE_BINARY(stdin); + SET_FILE_BINARY(stdout); + } + } else + check_sizes(); + if (o_header) { /* write header */ printargs(argc, argv, stdout); + if (transpose && (no_rows <= 0) & (no_columns <= 0)) { + if (ni_rows > 0) no_columns = ni_rows; + if (ni_columns > 0) no_rows = ni_columns; + } + if (no_rows > 0) + printf("NROWS=%d\n", no_rows); + if (no_columns > 0) + printf("NCOLS=%d\n", no_columns); + printf("NCOMP=%d\n", n_comp); fputformat(fmtid, stdout); fputc('\n', stdout); /* finish new header */ } @@ -529,7 +615,7 @@ main(int argc, char *argv[]) return(0); userr: fprintf(stderr, -"Usage: %s [-h][-w][-f[afdb][N]][-t][-ic in_col][-ir in_row][-oc out_col][-or out_row] [input.dat]\n", +"Usage: %s [-h[io]][-w][-f[afdb][N]][-t][-ic in_col][-ir in_row][-oc out_col][-or out_row] [input.dat]\n", argv[0]); return(1); }
