--- ray/src/util/rcollate.c 2020/09/07 17:08:08 2.36 +++ ray/src/util/rcollate.c 2022/03/03 03:55:13 2.39 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rcollate.c,v 2.36 2020/09/07 17:08:08 greg Exp $"; +static const char RCSid[] = "$Id: rcollate.c,v 2.39 2022/03/03 03:55:13 greg Exp $"; #endif /* * Utility to re-order records in a binary or ASCII data file (matrix) @@ -29,7 +29,7 @@ typedef struct { typedef struct { int nw_rec; /* number of words per record */ - long nrecs; /* number of records we found */ + ssize_t nrecs; /* number of records we found */ char *rec[1]; /* record array (extends struct) */ } RECINDEX; @@ -87,17 +87,16 @@ load_stream(MEMLOAD *mp, FILE *fp) return(mp->len > 0); } +#if defined(_WIN32) || defined(_WIN64) + /* too difficult to fix this */ +#define load_file load_stream +#else /* load a file into memory */ static int load_file(MEMLOAD *mp, FILE *fp) { int fd; off_t skip, flen, fpos; - -#if defined(_WIN32) || defined(_WIN64) - /* too difficult to fix this */ - return load_stream(mp, fp); -#endif if (mp == NULL) return(-1); mp->mapped = NULL; @@ -112,7 +111,7 @@ load_file(MEMLOAD *mp, FILE *fp) return((int)(flen - skip)); mp->len = (size_t)(flen - skip); #ifdef MAP_FILE - if (mp->len > 1L<<20) { /* map file if > 1 MByte */ + if (mp->len >= 1L<<20) { /* map file if >= 1 MByte */ mp->mapped = mmap(NULL, flen, PROT_READ, MAP_PRIVATE, fd, 0); if (mp->mapped != MAP_FAILED) { mp->base = (char *)mp->mapped + skip; @@ -138,6 +137,7 @@ load_file(MEMLOAD *mp, FILE *fp) } return(1); } +#endif /* free a record index */ #define free_records(rp) free(rp) @@ -218,7 +218,7 @@ count_columns(const RECINDEX *rp) /* copy nth record from index to stdout */ static int -print_record(const RECINDEX *rp, long n) +print_record(const RECINDEX *rp, ssize_t n) { int words2go = rp->nw_rec; char *scp; @@ -360,10 +360,10 @@ check_sizes() } /* call to compute block input position */ -static long +static ssize_t get_block_pos(int r, int c, int blklvl[][2], int nlvls) { - long n = 0; + ssize_t n = 0; while (nlvls > 1) { int sr = r/blklvl[1][0]; @@ -379,22 +379,22 @@ get_block_pos(int r, int c, int blklvl[][2], int nlvls } /* return input offset based on array ordering and transpose option */ -static long +static ssize_t get_input_pos(int r, int c) { - long n; + ssize_t n; if (outLevels > 1) { /* block reordering */ n = get_block_pos(r, c, outArray, outLevels); if (transpose) { r = n/ni_rows; c = n - r*ni_rows; - n = (long)c*ni_columns + r; + n = (ssize_t)c*ni_columns + r; } } else if (transpose) /* transpose only */ - n = (long)c*ni_columns + r; + n = (ssize_t)c*ni_columns + r; else /* XXX should never happen! */ - n = (long)r*no_columns + c; + n = (ssize_t)r*no_columns + c; return(n); } @@ -404,7 +404,7 @@ do_reorder(const MEMLOAD *mp) { static const char tabEOL[2] = {'\t','\n'}; RECINDEX *rp = NULL; - long nrecords; + ssize_t nrecords; int i, j; /* propogate sizes */ if (ni_rows <= 0) @@ -419,7 +419,7 @@ do_reorder(const MEMLOAD *mp) ni_columns = count_columns(rp); nrecords = rp->nrecs; } else if ((ni_rows > 0) & (ni_columns > 0)) { - nrecords = ni_rows*ni_columns; + nrecords = (ssize_t)ni_rows*ni_columns; if (nrecords > mp->len/(n_comp*comp_size)) { fputs("Input too small for specified size and type\n", stderr); @@ -432,7 +432,7 @@ do_reorder(const MEMLOAD *mp) ni_rows = nrecords/ni_columns; else if ((ni_columns <= 0) & (ni_rows > 0)) ni_columns = nrecords/ni_rows; - if (nrecords != ni_rows*ni_columns) + if (nrecords != (ssize_t)ni_rows*ni_columns) goto badspec; if (transpose) { if (no_columns <= 0) @@ -456,12 +456,13 @@ do_reorder(const MEMLOAD *mp) if (o_header) { /* finish header? */ printf("NROWS=%d\n", no_rows); printf("NCOLS=%d\n", no_columns); + fputformat(fmtid, stdout); fputc('\n', stdout); } /* reorder records */ for (i = 0; i < no_rows; i++) { for (j = 0; j < no_columns; j++) { - long n = get_input_pos(i, j); + ssize_t n = get_input_pos(i, j); if (n >= nrecords) { fputs("Index past end-of-file\n", stderr); return(0); @@ -491,7 +492,7 @@ badspec: static int do_resize(FILE *fp) { - long records2go = ni_rows*ni_columns; + ssize_t records2go = ni_rows*ni_columns; int columns2go = no_columns; char word[256]; @@ -500,6 +501,7 @@ do_resize(FILE *fp) printf("NROWS=%d\n", no_rows); if (no_columns > 0) printf("NCOLS=%d\n", no_columns); + fputformat(fmtid, stdout); fputc('\n', stdout); } /* sanity checks */ @@ -728,7 +730,6 @@ main(int argc, char *argv[]) newheader("RADIANCE", stdout); printargs(a, argv, stdout); printf("NCOMP=%d\n", n_comp); - fputformat(fmtid, stdout); } if (transpose | check | (outLevels > 1) || (o_header && no_rows <= 0)) { MEMLOAD myMem; /* need to map into memory */
