--- ray/src/util/rcollate.c 2014/09/18 00:12:42 2.19 +++ ray/src/util/rcollate.c 2019/02/05 17:13:00 2.30 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rcollate.c,v 2.19 2014/09/18 00:12:42 greg Exp $"; +static const char RCSid[] = "$Id: rcollate.c,v 2.30 2019/02/05 17:13:00 greg Exp $"; #endif /* * Utility to re-order records in a binary or ASCII data file (matrix) @@ -11,26 +11,19 @@ static const char RCSid[] = "$Id: rcollate.c,v 2.19 20 #include "platform.h" #include "rtio.h" #include "resolu.h" -#ifdef _WIN32 -#undef ftello -#define ftello ftell -#undef ssize_t -#define ssize_t size_t +#if defined(_WIN32) || defined(_WIN64) + #undef ftello + #define ftello ftell + #undef ssize_t + #define ssize_t size_t #else -#include + #include #endif -#ifdef getc_unlocked /* avoid horrendous overhead of flockfile */ -#undef getc -#undef putc -#define getc getc_unlocked -#define putc putc_unlocked -#endif - typedef struct { + void *mapped; /* memory-mapped pointer */ void *base; /* pointer to base memory */ size_t len; /* allocated memory length */ - int mapped; /* memory-mapped file? */ } MEMLOAD; /* file loaded/mapped into memory */ typedef struct { @@ -49,56 +42,15 @@ free_load(MEMLOAD *mp) return; #ifdef MAP_FILE if (mp->mapped) - munmap(mp->base, mp->len); + munmap(mp->mapped, mp->len); else #endif free(mp->base); + mp->mapped = NULL; mp->base = NULL; mp->len = 0; } -/* load a file into memory */ -static int -load_file(MEMLOAD *mp, FILE *fp) -{ - int fd; - off_t skip, flen; - - if (mp == NULL) - return(-1); - mp->base = NULL; - mp->len = 0; - mp->mapped = 0; - if (fp == NULL) - return(-1); - fd = fileno(fp); - skip = ftello(fp); - flen = lseek(fd, 0, SEEK_END); - if (flen <= skip) - return((int)(flen - skip)); - mp->len = (size_t)(flen - skip); -#ifdef MAP_FILE - if (mp->len > 1L<<20) { /* map file if > 1 MByte */ - mp->base = mmap(NULL, mp->len, PROT_READ, MAP_PRIVATE, fd, skip); - if (mp->base != MAP_FAILED) { - mp->mapped = 1; - return(1); /* mmap() success */ - } - mp->base = NULL; /* fall back to reading it in... */ - } -#endif - if (lseek(fd, skip, SEEK_SET) != skip || - (mp->base = malloc(mp->len)) == NULL) { - mp->len = 0; - return(-1); - } - if (read(fd, (char *)mp->base, mp->len) != mp->len) { - free_load(mp); - return(-1); - } - return(1); -} - /* load memory from an input stream, starting from current position */ static int load_stream(MEMLOAD *mp, FILE *fp) @@ -109,14 +61,14 @@ load_stream(MEMLOAD *mp, FILE *fp) if (mp == NULL) return(-1); + mp->mapped = NULL; mp->base = NULL; mp->len = 0; - mp->mapped = 0; if (fp == NULL) return(-1); while ((nr = fread(buf, 1, sizeof(buf), fp)) > 0) { if (!alloced) - mp->base = malloc(nr); + mp->base = malloc(alloced = nr); else if (mp->len+nr > alloced) mp->base = realloc(mp->base, alloced = alloced*(2+(nr==sizeof(buf)))/2+nr); @@ -134,6 +86,58 @@ load_stream(MEMLOAD *mp, FILE *fp) return(mp->len > 0); } +/* load a file into memory */ +static int +load_file(MEMLOAD *mp, FILE *fp) +{ + int fd; + off_t skip, flen, fpos; + +#if defined(_WIN32) || defined(_WIN64) + /* too difficult to fix this */ + return load_stream(mp, fp); +#endif + if (mp == NULL) + return(-1); + mp->mapped = NULL; + mp->base = NULL; + mp->len = 0; + if (fp == NULL) + return(-1); + fd = fileno(fp); + skip = ftello(fp); + flen = lseek(fd, 0, SEEK_END); + if (flen <= skip) + return((int)(flen - skip)); + mp->len = (size_t)(flen - skip); +#ifdef MAP_FILE + if (mp->len > 1L<<20) { /* map file if > 1 MByte */ + mp->mapped = mmap(NULL, flen, PROT_READ, MAP_PRIVATE, fd, 0); + if (mp->mapped != MAP_FAILED) { + mp->base = (char *)mp->mapped + skip; + return(1); /* mmap() success */ + } + mp->mapped = NULL; /* else fall back to reading it in... */ + } +#endif + if (lseek(fd, skip, SEEK_SET) != skip || + (mp->base = malloc(mp->len)) == NULL) { + mp->len = 0; + return(-1); + } + fpos = skip; + while (fpos < flen) { /* read() fails if n > 2 GBytes */ + ssize_t nread = read(fd, (char *)mp->base+(fpos-skip), + (flen-fpos < 1L<<24) ? flen-fpos : 1L<<24); + if (nread <= 0) { + free_load(mp); + return(-1); + } + fpos += nread; + } + return(1); +} + /* free a record index */ #define free_records(rp) free(rp) @@ -141,6 +145,7 @@ load_stream(MEMLOAD *mp, FILE *fp) static RECINDEX * index_records(const MEMLOAD *mp, int nw_rec) { + int nall = 0; RECINDEX *rp; char *cp, *mend; int n; @@ -149,7 +154,8 @@ index_records(const MEMLOAD *mp, int nw_rec) return(NULL); if (nw_rec <= 0) return(NULL); - rp = (RECINDEX *)malloc(sizeof(RECINDEX) + mp->len/(2*nw_rec)*sizeof(char *)); + nall = 1000; + rp = (RECINDEX *)malloc(sizeof(RECINDEX) + nall*sizeof(char *)); if (rp == NULL) return(NULL); rp->nw_rec = nw_rec; @@ -161,6 +167,13 @@ index_records(const MEMLOAD *mp, int nw_rec) ++cp; if (cp >= mend) break; + if (rp->nrecs >= nall) { + nall += nall>>1; /* get more record space */ + rp = (RECINDEX *)realloc(rp, + sizeof(RECINDEX) + nall*sizeof(char *)); + if (rp == NULL) + return(NULL); + } rp->rec[rp->nrecs++] = cp; /* point to first non-white */ n = rp->nw_rec; while (++cp < mend) /* find end of record */ @@ -356,9 +369,9 @@ do_transpose(const MEMLOAD *mp) print_record(rp, j*ni_columns + i); putc(tabEOL[j >= no_columns-1], stdout); } else { /* binary output */ - fwrite((char *)mp->base + - (n_comp*comp_size)*(j*ni_columns + i), - n_comp*comp_size, 1, stdout); + putbinary((char *)mp->base + + (size_t)(n_comp*comp_size)*(j*ni_columns + i), + comp_size, n_comp, stdout); } if (ferror(stdout)) { fprintf(stderr, "Error writing to stdout\n"); @@ -435,7 +448,7 @@ done: static int headline(char *s, void *p) { - static char fmt[32]; + static char fmt[MAXFMTLEN]; int n; if (formatval(fmt, s)) { @@ -592,7 +605,9 @@ main(int argc, char *argv[]) } } else if (!check_sizes()) return(1); - if (o_header) { /* write header */ + if (o_header) { /* write/add to header */ + if (!i_header) + newheader("RADIANCE", stdout); printargs(a, argv, stdout); if (no_rows > 0) printf("NROWS=%d\n", no_rows);
