--- ray/src/util/rcollate.c 2014/05/30 18:24:06 2.13 +++ ray/src/util/rcollate.c 2016/03/04 00:21:21 2.22 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rcollate.c,v 2.13 2014/05/30 18:24:06 greg Exp $"; +static const char RCSid[] = "$Id: rcollate.c,v 2.22 2016/03/04 00:21:21 greg Exp $"; #endif /* * Utility to re-order records in a binary or ASCII data file (matrix) @@ -20,13 +20,6 @@ static const char RCSid[] = "$Id: rcollate.c,v 2.13 20 #include #endif -#ifdef getc_unlocked /* avoid horrendous overhead of flockfile */ -#undef getc -#undef putc -#define getc getc_unlocked -#define putc putc_unlocked -#endif - typedef struct { void *base; /* pointer to base memory */ size_t len; /* allocated memory length */ @@ -57,6 +50,41 @@ free_load(MEMLOAD *mp) mp->len = 0; } +/* load memory from an input stream, starting from current position */ +static int +load_stream(MEMLOAD *mp, FILE *fp) +{ + size_t alloced = 0; + char buf[8192]; + size_t nr; + + if (mp == NULL) + return(-1); + mp->base = NULL; + mp->len = 0; + mp->mapped = 0; + if (fp == NULL) + return(-1); + while ((nr = fread(buf, 1, sizeof(buf), fp)) > 0) { + if (!alloced) + mp->base = malloc(alloced = nr); + else if (mp->len+nr > alloced) + mp->base = realloc(mp->base, + alloced = alloced*(2+(nr==sizeof(buf)))/2+nr); + if (mp->base == NULL) + return(-1); + memcpy((char *)mp->base + mp->len, buf, nr); + mp->len += nr; + } + if (ferror(fp)) { + free_load(mp); + return(-1); + } + if (alloced > mp->len*5/4) /* don't waste too much space */ + mp->base = realloc(mp->base, mp->len); + return(mp->len > 0); +} + /* load a file into memory */ static int load_file(MEMLOAD *mp, FILE *fp) @@ -64,6 +92,9 @@ load_file(MEMLOAD *mp, FILE *fp) int fd; off_t skip, flen; +#ifdef _WIN32 /* too difficult to fix this */ + return load_stream(mp, fp); +#endif if (mp == NULL) return(-1); mp->base = NULL; @@ -99,41 +130,6 @@ load_file(MEMLOAD *mp, FILE *fp) return(1); } -/* load memory from an input stream, starting from current position */ -static int -load_stream(MEMLOAD *mp, FILE *fp) -{ - size_t alloced = 0; - char buf[8192]; - size_t nr; - - if (mp == NULL) - return(-1); - mp->base = NULL; - mp->len = 0; - mp->mapped = 0; - if (fp == NULL) - return(-1); - while ((nr = fread(buf, 1, sizeof(buf), fp)) > 0) { - if (!alloced) - mp->base = malloc(nr); - else if (mp->len+nr > alloced) - mp->base = realloc(mp->base, - alloced = alloced*(2+(nr==sizeof(buf)))/2+nr); - if (mp->base == NULL) - return(-1); - memcpy((char *)mp->base + mp->len, buf, nr); - mp->len += nr; - } - if (ferror(fp)) { - free_load(mp); - return(-1); - } - if (alloced > mp->len*5/4) /* don't waste too much space */ - mp->base = realloc(mp->base, mp->len); - return(mp->len > 0); -} - /* free a record index */ #define free_records(rp) free(rp) @@ -274,6 +270,9 @@ int ni_columns = 0; /* number of input columns */ int ni_rows = 0; /* number of input rows */ int no_columns = 0; /* number of output columns */ int no_rows = 0; /* number of output rows */ +int transpose = 0; /* transpose rows & cols? */ +int i_header = 1; /* input header? */ +int o_header = 1; /* output header? */ /* check settings and assign defaults */ static int @@ -288,11 +287,17 @@ check_sizes() comp_size = sizeof(double); else if (!strcmp(fmtid, "byte")) comp_size = 1; - else { + else if (strcmp(fmtid, "ascii")) { fprintf(stderr, "Unsupported format: %s\n", fmtid); return(0); } } + if (transpose && (no_rows <= 0) & (no_columns <= 0)) { + if (ni_rows > 0) no_columns = ni_rows; + if (ni_columns > 0) no_rows = ni_columns; + } else if ((no_rows <= 0) & (no_columns > 0) && + !((ni_rows*ni_columns) % no_columns)) + no_rows = ni_rows*ni_columns/no_columns; if (n_comp <= 0) n_comp = 3; return(1); @@ -372,8 +377,8 @@ do_resize(FILE *fp) int columns2go = no_columns; char word[256]; /* sanity checks */ - if (comp_size) - return(output_stream(fp)); /* binary data -- just copy */ + if (comp_size || (no_columns == ni_columns) & (no_rows == ni_rows)) + return(output_stream(fp)); /* no-op -- just copy */ if (no_columns <= 0) { fprintf(stderr, "Missing -oc specification\n"); return(0); @@ -460,13 +465,14 @@ headline(char *s, void *p) if (!strncmp(s, "NCOMP=", 6)) { n = atoi(s+6); if ((n_comp > 0) & (n != n_comp)) { - fputs("Incorrect number of components", stderr); + fputs("Incorrect number of components\n", stderr); return(-1); } n_comp = n; return(0); } - fputs(s, stdout); /* copy header info. */ + if (o_header) + fputs(s, stdout); /* copy header info. */ return(0); } @@ -474,31 +480,28 @@ headline(char *s, void *p) int main(int argc, char *argv[]) { - int i_header = 1; /* input header? */ - int o_header = 1; /* output header? */ - int transpose = 0; /* transpose rows & cols? */ - int i; + int a; - for (i = 1; i < argc && argv[i][0] == '-'; i++) - switch (argv[i][1]) { + for (a = 1; a < argc && argv[a][0] == '-'; a++) + switch (argv[a][1]) { case 'i': /* input */ - if (argv[i][2] == 'c') /* columns */ - ni_columns = atoi(argv[++i]); - else if (argv[i][2] == 'r') - ni_rows = atoi(argv[++i]); + if (argv[a][2] == 'c') /* columns */ + ni_columns = atoi(argv[++a]); + else if (argv[a][2] == 'r') + ni_rows = atoi(argv[++a]); else goto userr; break; case 'o': /* output */ - if (argv[i][2] == 'c') /* columns */ - no_columns = atoi(argv[++i]); - else if (argv[i][2] == 'r') - no_rows = atoi(argv[++i]); + if (argv[a][2] == 'c') /* columns */ + no_columns = atoi(argv[++a]); + else if (argv[a][2] == 'r') + no_rows = atoi(argv[++a]); else goto userr; break; case 'h': /* turn off header */ - switch (argv[i][2]) { + switch (argv[a][2]) { case 'i': i_header = 0; break; @@ -516,7 +519,7 @@ main(int argc, char *argv[]) transpose = !transpose; break; case 'f': /* format */ - switch (argv[i][2]) { + switch (argv[a][2]) { case 'a': /* ASCII */ case 'A': fmtid = "ascii"; @@ -540,11 +543,12 @@ main(int argc, char *argv[]) default: goto userr; } - if (argv[i][3]) { - if (!isdigit(argv[i][3])) + if (argv[a][3]) { + if (!isdigit(argv[a][3])) goto userr; - n_comp = atoi(argv[i]+3); - } + n_comp = atoi(argv[a]+3); + } else + n_comp = 1; break; case 'w': /* warnings on/off */ warnings = !warnings; @@ -552,11 +556,11 @@ main(int argc, char *argv[]) default: goto userr; } - if (i < argc-1) /* arg count OK? */ + if (a < argc-1) /* arg count OK? */ goto userr; /* open input file? */ - if (i == argc-1 && freopen(argv[i], "r", stdin) == NULL) { - fprintf(stderr, "%s: cannot open for reading\n", argv[i]); + if (a == argc-1 && freopen(argv[a], "r", stdin) == NULL) { + fprintf(stderr, "%s: cannot open for reading\n", argv[a]); return(1); } if (comp_size) { @@ -564,8 +568,8 @@ main(int argc, char *argv[]) SET_FILE_BINARY(stdout); } /* check for no-op */ - if (!transpose & (i_header == o_header) && (comp_size || - (no_columns == ni_columns) & (no_rows == ni_rows))) { + if (!transpose & (i_header == o_header) && + (no_columns == ni_columns) & (no_rows == ni_rows)) { if (warnings) fprintf(stderr, "%s: no-op -- copying input verbatim\n", argv[0]); @@ -574,7 +578,7 @@ main(int argc, char *argv[]) return(0); } if (i_header) { /* read header */ - if (getheader(stdin, &headline, NULL) < 0) + if (getheader(stdin, headline, NULL) < 0) return(1); if (!check_sizes()) return(1); @@ -585,11 +589,7 @@ main(int argc, char *argv[]) } else if (!check_sizes()) return(1); if (o_header) { /* write header */ - printargs(argc, argv, stdout); - if (transpose && (no_rows <= 0) & (no_columns <= 0)) { - if (ni_rows > 0) no_columns = ni_rows; - if (ni_columns > 0) no_rows = ni_columns; - } + printargs(a, argv, stdout); if (no_rows > 0) printf("NROWS=%d\n", no_rows); if (no_columns > 0) @@ -599,11 +599,11 @@ main(int argc, char *argv[]) fputc('\n', stdout); /* finish new header */ } if (transpose) { /* transposing rows & columns? */ - MEMLOAD myMem; /* need to load into memory */ - if (i == argc-1) { + MEMLOAD myMem; /* need to map into memory */ + if (a == argc-1) { if (load_file(&myMem, stdin) <= 0) { fprintf(stderr, "%s: error loading file into memory\n", - argv[i]); + argv[a]); return(1); } } else if (load_stream(&myMem, stdin) <= 0) { @@ -613,8 +613,8 @@ main(int argc, char *argv[]) } if (!do_transpose(&myMem)) return(1); - /* free_load(&myMem); */ - } else if (!do_resize(stdin)) /* just reshaping input */ + /* free_load(&myMem); about to exit, so don't bother */ + } else if (!do_resize(stdin)) /* reshaping input */ return(1); return(0); userr:
