--- ray/src/util/rcollate.c 2015/06/16 19:06:29 2.20 +++ ray/src/util/rcollate.c 2018/08/02 18:33:50 2.26 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rcollate.c,v 2.20 2015/06/16 19:06:29 greg Exp $"; +static const char RCSid[] = "$Id: rcollate.c,v 2.26 2018/08/02 18:33:50 greg Exp $"; #endif /* * Utility to re-order records in a binary or ASCII data file (matrix) @@ -11,22 +11,15 @@ static const char RCSid[] = "$Id: rcollate.c,v 2.20 20 #include "platform.h" #include "rtio.h" #include "resolu.h" -#ifdef _WIN32 -#undef ftello -#define ftello ftell -#undef ssize_t -#define ssize_t size_t +#if defined(_WIN32) || defined(_WIN64) + #undef ftello + #define ftello ftell + #undef ssize_t + #define ssize_t size_t #else -#include + #include #endif -#ifdef getc_unlocked /* avoid horrendous overhead of flockfile */ -#undef getc -#undef putc -#define getc getc_unlocked -#define putc putc_unlocked -#endif - typedef struct { void *base; /* pointer to base memory */ size_t len; /* allocated memory length */ @@ -74,7 +67,7 @@ load_stream(MEMLOAD *mp, FILE *fp) return(-1); while ((nr = fread(buf, 1, sizeof(buf), fp)) > 0) { if (!alloced) - mp->base = malloc(nr); + mp->base = malloc(alloced = nr); else if (mp->len+nr > alloced) mp->base = realloc(mp->base, alloced = alloced*(2+(nr==sizeof(buf)))/2+nr); @@ -99,7 +92,8 @@ load_file(MEMLOAD *mp, FILE *fp) int fd; off_t skip, flen; -#ifdef _WIN32 /* too difficult to fix this */ +#if defined(_WIN32) || defined(_WIN64) + /* too difficult to fix this */ return load_stream(mp, fp); #endif if (mp == NULL) @@ -144,6 +138,7 @@ load_file(MEMLOAD *mp, FILE *fp) static RECINDEX * index_records(const MEMLOAD *mp, int nw_rec) { + int nall = 0; RECINDEX *rp; char *cp, *mend; int n; @@ -152,7 +147,8 @@ index_records(const MEMLOAD *mp, int nw_rec) return(NULL); if (nw_rec <= 0) return(NULL); - rp = (RECINDEX *)malloc(sizeof(RECINDEX) + mp->len/(2*nw_rec)*sizeof(char *)); + nall = 1000; + rp = (RECINDEX *)malloc(sizeof(RECINDEX) + nall*sizeof(char *)); if (rp == NULL) return(NULL); rp->nw_rec = nw_rec; @@ -164,6 +160,13 @@ index_records(const MEMLOAD *mp, int nw_rec) ++cp; if (cp >= mend) break; + if (rp->nrecs >= nall) { + nall += nall>>1; /* get more record space */ + rp = (RECINDEX *)realloc(rp, + sizeof(RECINDEX) + nall*sizeof(char *)); + if (rp == NULL) + return(NULL); + } rp->rec[rp->nrecs++] = cp; /* point to first non-white */ n = rp->nw_rec; while (++cp < mend) /* find end of record */ @@ -359,9 +362,9 @@ do_transpose(const MEMLOAD *mp) print_record(rp, j*ni_columns + i); putc(tabEOL[j >= no_columns-1], stdout); } else { /* binary output */ - fwrite((char *)mp->base + + putbinary((char *)mp->base + (n_comp*comp_size)*(j*ni_columns + i), - n_comp*comp_size, 1, stdout); + comp_size, n_comp, stdout); } if (ferror(stdout)) { fprintf(stderr, "Error writing to stdout\n"); @@ -438,7 +441,7 @@ done: static int headline(char *s, void *p) { - static char fmt[32]; + static char fmt[MAXFMTLEN]; int n; if (formatval(fmt, s)) {
