--- ray/src/util/rcollate.c 2014/07/08 16:39:41 2.15 +++ ray/src/util/rcollate.c 2014/07/24 16:28:17 2.17 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rcollate.c,v 2.15 2014/07/08 16:39:41 greg Exp $"; +static const char RCSid[] = "$Id: rcollate.c,v 2.17 2014/07/24 16:28:17 greg Exp $"; #endif /* * Utility to re-order records in a binary or ASCII data file (matrix) @@ -274,6 +274,9 @@ int ni_columns = 0; /* number of input columns */ int ni_rows = 0; /* number of input rows */ int no_columns = 0; /* number of output columns */ int no_rows = 0; /* number of output rows */ +int transpose = 0; /* transpose rows & cols? */ +int i_header = 1; /* input header? */ +int o_header = 1; /* output header? */ /* check settings and assign defaults */ static int @@ -293,6 +296,12 @@ check_sizes() return(0); } } + if (transpose && (no_rows <= 0) & (no_columns <= 0)) { + if (ni_rows > 0) no_columns = ni_rows; + if (ni_columns > 0) no_rows = ni_columns; + } else if ((no_rows <= 0) & (no_columns > 0) && + !((ni_rows*ni_columns) % no_columns)) + no_rows = ni_rows*ni_columns/no_columns; if (n_comp <= 0) n_comp = 3; return(1); @@ -466,7 +475,8 @@ headline(char *s, void *p) n_comp = n; return(0); } - fputs(s, stdout); /* copy header info. */ + if (o_header) + fputs(s, stdout); /* copy header info. */ return(0); } @@ -474,9 +484,6 @@ headline(char *s, void *p) int main(int argc, char *argv[]) { - int i_header = 1; /* input header? */ - int o_header = 1; /* output header? */ - int transpose = 0; /* transpose rows & cols? */ int a; for (a = 1; a < argc && argv[a][0] == '-'; a++) @@ -587,10 +594,6 @@ main(int argc, char *argv[]) return(1); if (o_header) { /* write header */ printargs(a, argv, stdout); - if (transpose && (no_rows <= 0) & (no_columns <= 0)) { - if (ni_rows > 0) no_columns = ni_rows; - if (ni_columns > 0) no_rows = ni_columns; - } if (no_rows > 0) printf("NROWS=%d\n", no_rows); if (no_columns > 0) @@ -614,8 +617,11 @@ main(int argc, char *argv[]) } if (!do_transpose(&myMem)) return(1); - /* free_load(&myMem); */ - } else if (!do_resize(stdin)) /* just reshaping input */ + /* free_load(&myMem); about to exit, so don't bother */ + } else if (comp_size || (no_columns==ni_columns) & (no_rows==ni_rows)) { + if (!output_stream(stdin)) /* just changed header */ + return(1); + } else if (!do_resize(stdin)) /* reshaping input */ return(1); return(0); userr:
