root/radiance/ray/src/util/rcollate.c
Revision: 2.39
Committed: Thu Mar 3 03:55:13 2022 UTC (3 years, 5 months ago) by greg
Changes since 2.38: +3 -2 lines
feat: Added float and double alignment to i/o routines for future mmap() use
2 static const char RCSid[] = "$Id: rcollate.c,v 2.38 2022/01/20 17:35:03 greg Exp $";
5 * Utility to re-order records in a binary or ASCII data file (matrix)
6 */
7
8 #include <stdlib.h>
9 #include <ctype.h>
10 #include "platform.h"
11 #include "rtio.h"
12 #include "resolu.h"
13 #if defined(_WIN32) || defined(_WIN64)
14 #undef ftello
15 #define ftello ftell
16 #undef ssize_t
17 #define ssize_t size_t
18 #else
19 #include <sys/mman.h>
20 #endif
21
22 #define MAXLEVELS 16 /* max RxC.. block pairs */
23
24 typedef struct {
25 void *mapped; /* memory-mapped pointer */
26 void *base; /* pointer to base memory */
27 size_t len; /* allocated memory length */
28 } MEMLOAD; /* file loaded/mapped into memory */
29
30 typedef struct {
31 int nw_rec; /* number of words per record */
32 ssize_t nrecs; /* number of records we found */
33 char *rec[1]; /* record array (extends struct) */
34 } RECINDEX;
35
36 int warnings = 1; /* report warnings? */
37
38 /* free loaded file */
39 static void
40 free_load(MEMLOAD *mp)
41 {
42 if (mp == NULL || (mp->base == NULL) | (mp->len <= 0))
43 return;
44 #ifdef MAP_FILE
45 if (mp->mapped)
46 munmap(mp->mapped, mp->len);
47 else
48 #endif
49 free(mp->base);
50 mp->mapped = NULL;
51 mp->base = NULL;
52 mp->len = 0;
53 }
54
55 /* load memory from an input stream, starting from current position */
56 static int
57 load_stream(MEMLOAD *mp, FILE *fp)
58 {
59 size_t alloced = 0;
60 char buf[8192];
61 size_t nr;
62
63 if (mp == NULL)
64 return(-1);
65 mp->mapped = NULL;
66 mp->base = NULL;
67 mp->len = 0;
68 if (fp == NULL)
69 return(-1);
70 while ((nr = fread(buf, 1, sizeof(buf), fp)) > 0) {
71 if (!alloced)
72 mp->base = malloc(alloced = nr);
73 else if (mp->len+nr > alloced)
74 mp->base = realloc(mp->base,
75 alloced = alloced*(2+(nr==sizeof(buf)))/2+nr);
76 if (mp->base == NULL)
77 return(-1);
78 memcpy((char *)mp->base + mp->len, buf, nr);
79 mp->len += nr;
80 }
81 if (ferror(fp)) {
82 free_load(mp);
83 return(-1);
84 }
85 if (alloced > mp->len*5/4) /* don't waste too much space */
86 mp->base = realloc(mp->base, mp->len);
87 return(mp->len > 0);
88 }
89
90 #if defined(_WIN32) || defined(_WIN64)
91 /* too difficult to fix this */
92 #define load_file load_stream
93 #else
94 /* load a file into memory */
95 static int
96 load_file(MEMLOAD *mp, FILE *fp)
97 {
98 int fd;
99 off_t skip, flen, fpos;
100 if (mp == NULL)
101 return(-1);
102 mp->mapped = NULL;
103 mp->base = NULL;
104 mp->len = 0;
105 if (fp == NULL)
106 return(-1);
107 fd = fileno(fp);
108 skip = ftello(fp);
109 flen = lseek(fd, 0, SEEK_END);
110 if (flen <= skip)
111 return((int)(flen - skip));
112 mp->len = (size_t)(flen - skip);
113 #ifdef MAP_FILE
114 if (mp->len >= 1L<<20) { /* map file if >= 1 MByte */
115 mp->mapped = mmap(NULL, flen, PROT_READ, MAP_PRIVATE, fd, 0);
116 if (mp->mapped != MAP_FAILED) {
117 mp->base = (char *)mp->mapped + skip;
118 return(1); /* mmap() success */
119 }
120 mp->mapped = NULL; /* else fall back to reading it in... */
121 }
122 #endif
123 if (lseek(fd, skip, SEEK_SET) != skip ||
124 (mp->base = malloc(mp->len)) == NULL) {
125 mp->len = 0;
126 return(-1);
127 }
128 fpos = skip;
129 while (fpos < flen) { /* read() fails if n > 2 GBytes */
130 ssize_t nread = read(fd, (char *)mp->base+(fpos-skip),
131 (flen-fpos < 1L<<24) ? flen-fpos : 1L<<24);
132 if (nread <= 0) {
133 free_load(mp);
134 return(-1);
135 }
136 fpos += nread;
137 }
138 return(1);
139 }
140 #endif
141
142 /* free a record index */
143 #define free_records(rp) free(rp)
144
145 /* compute record index */
146 static RECINDEX *
147 index_records(const MEMLOAD *mp, int nw_rec)
148 {
149 int nall = 0;
150 RECINDEX *rp;
151 char *cp, *mend;
152 int n;
153
154 if (mp == NULL || (mp->base == NULL) | (mp->len <= 0))
155 return(NULL);
156 if (nw_rec <= 0)
157 return(NULL);
158 nall = 1000;
159 rp = (RECINDEX *)malloc(sizeof(RECINDEX) + nall*sizeof(char *));
160 if (rp == NULL)
161 return(NULL);
162 rp->nw_rec = nw_rec;
163 rp->nrecs = 0;
164 cp = (char *)mp->base;
165 mend = cp + mp->len;
166 for ( ; ; ) { /* whitespace-separated words */
167 while (cp < mend && !*cp | isspace(*cp))
168 ++cp;
169 if (cp >= mend)
170 break;
171 if (rp->nrecs >= nall) {
172 nall += nall>>1; /* get more record space */
173 rp = (RECINDEX *)realloc(rp,
174 sizeof(RECINDEX) + nall*sizeof(char *));
175 if (rp == NULL)
176 return(NULL);
177 }
178 rp->rec[rp->nrecs++] = cp; /* point to first non-white */
179 n = rp->nw_rec;
180 while (++cp < mend) /* find end of record */
181 if (!*cp | isspace(*cp)) {
182 if (--n <= 0)
183 break; /* got requisite # words */
184 do { /* else find next word */
185 if (*cp == '\n') {
186 fprintf(stderr,
187 "Unexpected EOL in record!\n");
188 free_records(rp);
189 return(NULL);
190 }
191 if (++cp >= mend)
192 break;
193 } while (!*cp | isspace(*cp));
194 }
195 }
196 rp->rec[rp->nrecs] = mend; /* reallocate to save space */
197 rp = (RECINDEX *)realloc(rp,
198 sizeof(RECINDEX) + rp->nrecs*sizeof(char *));
199 return(rp);
200 }
201
202 /* count number of columns based on first EOL */
203 static int
204 count_columns(const RECINDEX *rp)
205 {
206 char *cp = rp->rec[0];
207 char *mend = rp->rec[rp->nrecs];
208 int i;
209
210 while (*cp != '\n')
211 if (++cp >= mend)
212 return(0);
213 for (i = 0; i < rp->nrecs; i++)
214 if (rp->rec[i] >= cp)
215 break;
216 return(i);
217 }
218
219 /* copy nth record from index to stdout */
220 static int
221 print_record(const RECINDEX *rp, ssize_t n)
222 {
223 int words2go = rp->nw_rec;
224 char *scp;
225
226 if ((n < 0) | (n >= rp->nrecs))
227 return(0);
228 scp = rp->rec[n];
229 do {
230 putc(*scp++, stdout);
231 if (!*scp | isspace(*scp)) {
232 if (--words2go <= 0)
233 break;
234 putc(' ', stdout); /* single space btwn. words */
235 do
236 if (++scp >= rp->rec[n+1])
237 break;
238 while (!*scp | isspace(*scp));
239 }
240 } while (scp < rp->rec[n+1]);
241 /* caller adds record sep. */
242 return(1);
243 }
244
245 /* copy a stream to stdout */
246 static int
247 output_stream(FILE *fp)
248 {
249 char buf[8192];
250 ssize_t n;
251
252 if (fp == NULL)
253 return(0);
254 fflush(stdout);
255 while ((n = fread(buf, 1, sizeof(buf), fp)) > 0)
256 if (write(fileno(stdout), buf, n) != n)
257 return(0);
258 return(!ferror(fp));
259 }
260
261 /* get next word from stream, leaving stream on EOL or start of next word */
262 static char *
263 fget_word(char buf[256], FILE *fp)
264 {
265 int c;
266 char *cp;
267 /* skip nul's and white space */
268 while (!(c = getc(fp)) || isspace(c))
269 ;
270 if (c == EOF)
271 return(NULL);
272 cp = buf;
273 do
274 *cp++ = c;
275 while ((c = getc(fp)) != EOF && !isspace(c) && cp < buf+255);
276 *cp = '\0';
277 while (isspace(c) & (c != '\n'))
278 c = getc(fp);
279 if (c != EOF)
280 ungetc(c, fp);
281 return(buf);
282 }
283
284 char *fmtid = NULL; /* format id */
285 int comp_size = 0; /* binary bytes/channel */
286 int n_comp = 0; /* components/record */
287 int ni_columns = 0; /* number of input columns */
288 int ni_rows = 0; /* number of input rows */
289 int no_columns = 0; /* number of output columns */
290 int no_rows = 0; /* number of output rows */
291 int transpose = 0; /* transpose rows & cols? */
292 int i_header = 1; /* input header? */
293 int o_header = 1; /* output header? */
294 int outArray[MAXLEVELS][2]; /* output block nesting */
295 int outLevels = 0; /* number of blocking levels */
296 int check = 0; /* force data check? */
297
298 /* parse RxCx... string */
299 static int
300 get_array(const char *spec, int blklvl[][2], int nlvls)
301 {
302 int n;
303
304 if (nlvls <= 0) {
305 fputs("Too many block levels!\n", stderr);
306 exit(1);
307 }
308 if (sscanf(spec, "%dx%d", &blklvl[0][0], &blklvl[0][1]) != 2) {
309 fputs("Bad block specification!\n", stderr);
310 exit(1);
311 }
312 while (isdigit(*spec))
313 spec++;
314 spec++; /* 'x' */
315 while (isdigit(*spec))
316 spec++;
317 if ((*spec != 'x') & (*spec != 'X')) {
318 if (*spec) {
319 fputs("Blocks must be separated by 'x' or 'X'\n", stderr);
320 exit(1);
321 }
322 return(1);
323 }
324 spec++;
325 n = get_array(spec, blklvl+1, nlvls-1);
326 if (!n)
327 return(0);
328 blklvl[0][0] *= blklvl[1][0];
329 blklvl[0][1] *= blklvl[1][1];
330 return(n+1);
331 }
332
333 /* check settings and assign defaults */
334 static int
335 check_sizes()
336 {
337 if (fmtid == NULL) {
338 fmtid = "ascii";
339 } else if (!comp_size) {
340 if (!strcmp(fmtid, "float"))
341 comp_size = sizeof(float);
342 else if (!strcmp(fmtid, "double"))
343 comp_size = sizeof(double);
344 else if (!strcmp(fmtid, "byte"))
345 comp_size = 1;
346 else if (strcmp(fmtid, "ascii")) {
347 fprintf(stderr, "Unsupported format: %s\n", fmtid);
348 return(0);
349 }
350 }
351 if (transpose && (no_rows <= 0) & (no_columns <= 0)) {
352 if (ni_rows > 0) no_columns = ni_rows;
353 if (ni_columns > 0) no_rows = ni_columns;
354 } else if ((no_rows <= 0) & (no_columns > 0) &&
355 !((ni_rows*ni_columns) % no_columns))
356 no_rows = ni_rows*ni_columns/no_columns;
357 if (n_comp <= 0)
358 n_comp = 3;
359 return(1);
360 }
361
362 /* call to compute block input position */
363 static ssize_t
364 get_block_pos(int r, int c, int blklvl[][2], int nlvls)
365 {
366 ssize_t n = 0;
367
368 while (nlvls > 1) {
369 int sr = r/blklvl[1][0];
370 int sc = c/blklvl[1][1];
371 r -= sr*blklvl[1][0];
372 c -= sc*blklvl[1][1];
373 n += sr*blklvl[1][0]*blklvl[0][1] + sc*blklvl[1][0]*blklvl[1][1];
374 blklvl++;
375 nlvls--;
376 }
377 n += r*blklvl[0][1] + c;
378 return(n);
379 }
380
381 /* return input offset based on array ordering and transpose option */
382 static ssize_t
383 get_input_pos(int r, int c)
384 {
385 ssize_t n;
386
387 if (outLevels > 1) { /* block reordering */
388 n = get_block_pos(r, c, outArray, outLevels);
389 if (transpose) {
390 r = n/ni_rows;
391 c = n - r*ni_rows;
392 n = (ssize_t)c*ni_columns + r;
393 }
394 } else if (transpose) /* transpose only */
395 n = (ssize_t)c*ni_columns + r;
396 else /* XXX should never happen! */
397 n = (ssize_t)r*no_columns + c;
398 return(n);
399 }
400
401 /* output reordered ASCII or binary data from memory */
402 static int
403 do_reorder(const MEMLOAD *mp)
404 {
405 static const char tabEOL[2] = {'\t','\n'};
406 RECINDEX *rp = NULL;
407 ssize_t nrecords;
408 int i, j;
409 /* propogate sizes */
410 if (ni_rows <= 0)
411 ni_rows = transpose ? no_columns : no_rows;
412 if (ni_columns <= 0)
413 ni_columns = transpose ? no_rows : no_columns;
414 /* get # records (& index) */
415 if (!comp_size) {
416 if ((rp = index_records(mp, n_comp)) == NULL)
417 return(0);
418 if (ni_columns <= 0)
419 ni_columns = count_columns(rp);
420 nrecords = rp->nrecs;
421 } else if ((ni_rows > 0) & (ni_columns > 0)) {
422 nrecords = (ssize_t)ni_rows*ni_columns;
423 if (nrecords > mp->len/(n_comp*comp_size)) {
424 fputs("Input too small for specified size and type\n",
425 stderr);
426 return(0);
427 }
428 } else
429 nrecords = mp->len/(n_comp*comp_size);
430 /* check sizes */
431 if ((ni_rows <= 0) & (ni_columns > 0))
432 ni_rows = nrecords/ni_columns;
433 else if ((ni_columns <= 0) & (ni_rows > 0))
434 ni_columns = nrecords/ni_rows;
435 if (nrecords != (ssize_t)ni_rows*ni_columns)
436 goto badspec;
437 if (transpose) {
438 if (no_columns <= 0)
439 no_columns = ni_rows;
440 if (no_rows <= 0)
441 no_rows = ni_columns;
442 if (outLevels <= 1 &&
443 (no_rows != ni_columns) | (no_columns != ni_rows))
444 goto badspec;
445 } else {
446 if (no_columns <= 0)
447 no_columns = ni_columns;
448 if (no_rows <= 0)
449 no_rows = ni_rows;
450 }
451 if (ni_rows*ni_columns != no_rows*no_columns) {
452 fputs("Number of input and output records do not match\n",
453 stderr);
454 return(0);
455 }
456 if (o_header) { /* finish header? */
457 printf("NROWS=%d\n", no_rows);
458 printf("NCOLS=%d\n", no_columns);
459 fputformat(fmtid, stdout);
460 fputc('\n', stdout);
461 }
462 /* reorder records */
463 for (i = 0; i < no_rows; i++) {
464 for (j = 0; j < no_columns; j++) {
465 ssize_t n = get_input_pos(i, j);
466 if (n >= nrecords) {
467 fputs("Index past end-of-file\n", stderr);
468 return(0);
469 }
470 if (rp != NULL) { /* ASCII output */
471 print_record(rp, n);
472 putc(tabEOL[j >= no_columns-1], stdout);
473 } else { /* binary output */
474 putbinary((char *)mp->base + (n_comp*comp_size)*n,
475 comp_size, n_comp, stdout);
476 }
477 }
478 if (ferror(stdout)) {
479 fprintf(stderr, "Error writing to stdout\n");
480 return(0);
481 }
482 }
483 if (rp != NULL)
484 free_records(rp);
485 return(1);
486 badspec:
487 fprintf(stderr, "Bad dimension(s)\n");
488 return(0);
489 }
490
491 /* resize ASCII stream input by ignoring EOLs between records */
492 static int
493 do_resize(FILE *fp)
494 {
495 ssize_t records2go = ni_rows*ni_columns;
496 int columns2go = no_columns;
497 char word[256];
498
499 if (o_header) { /* finish header? */
500 if (no_rows > 0)
501 printf("NROWS=%d\n", no_rows);
502 if (no_columns > 0)
503 printf("NCOLS=%d\n", no_columns);
504 fputformat(fmtid, stdout);
505 fputc('\n', stdout);
506 }
507 /* sanity checks */
508 if (comp_size || !check &
509 (no_columns == ni_columns) & (no_rows == ni_rows))
510 return(output_stream(fp)); /* no-op -- just copy */
511 if (no_columns <= 0) {
512 fprintf(stderr, "Missing -oc specification\n");
513 return(0);
514 }
515 if ((records2go <= 0) & (no_rows > 0))
516 records2go = no_rows*no_columns;
517 else if (no_rows*no_columns != records2go) {
518 fprintf(stderr,
519 "Number of input and output records disagree (%dx%d != %dx%d)\n",
520 ni_rows, ni_columns, no_rows, no_columns);
521 return(0);
522 }
523 do { /* reshape records */
524 int n;
525
526 for (n = n_comp; n--; ) {
527 if (fget_word(word, fp) == NULL) {
528 if (records2go > 0 || n < n_comp-1)
529 break;
530 goto done; /* normal EOD */
531 }
532 fputs(word, stdout);
533 if (n) { /* mid-record? */
534 int c = getc(fp);
535 if ((c == '\n') | (c == EOF))
536 break;
537 ungetc(c, fp);
538 putc(' ', stdout);
539 }
540 }
541 if (n >= 0) {
542 fprintf(stderr, "Incomplete record / unexpected EOF\n");
543 return(0);
544 }
545 if (--columns2go <= 0) { /* time to end output row? */
546 putc('\n', stdout);
547 columns2go = no_columns;
548 } else /* else separate records */
549 putc('\t', stdout);
550 } while (--records2go); /* expected EOD? */
551 done:
552 if (warnings && columns2go != no_columns)
553 fprintf(stderr, "Warning -- incomplete final row\n");
554 if (warnings && fget_word(word, fp) != NULL)
555 fprintf(stderr, "Warning -- characters beyond expected EOD\n");
556 return(1);
557 }
558
559 /* process a header line and copy to stdout */
560 static int
561 headline(char *s, void *p)
562 {
563 static char fmt[MAXFMTLEN];
564 int n;
565
566 if (formatval(fmt, s)) {
567 if (fmtid == NULL) {
568 fmtid = fmt;
569 return(0);
570 }
571 if (!strcmp(fmt, fmtid))
572 return(0);
573 fprintf(stderr, "Input format '%s' != '%s'\n", fmt, fmtid);
574 return(-1);
575 }
576 if (!strncmp(s, "NROWS=", 6)) {
577 n = atoi(s+6);
578 if ((ni_rows > 0) & (n != ni_rows)) {
579 fputs("Incorrect input row count\n", stderr);
580 return(-1);
581 }
582 ni_rows = n;
583 return(0);
584 }
585 if (!strncmp(s, "NCOLS=", 6)) {
586 n = atoi(s+6);
587 if ((ni_columns > 0) & (n != ni_columns)) {
588 fputs("Incorrect input column count\n", stderr);
589 return(-1);
590 }
591 ni_columns = n;
592 return(0);
593 }
594 if (!strncmp(s, "NCOMP=", 6)) {
595 n = atoi(s+6);
596 if ((n_comp > 0) & (n != n_comp)) {
597 fputs("Incorrect number of components\n", stderr);
598 return(-1);
599 }
600 n_comp = n;
601 return(0);
602 }
603 if (o_header)
604 fputs(s, stdout); /* copy header info. */
605 return(0);
606 }
607
608 /* main routine for converting rows/columns in data file */
609 int
610 main(int argc, char *argv[])
611 {
612 int a;
613
614 for (a = 1; a < argc && argv[a][0] == '-'; a++)
615 switch (argv[a][1]) {
616 case 'i': /* input */
617 if (argv[a][2] == 'c') /* columns */
618 ni_columns = atoi(argv[++a]);
619 else if (argv[a][2] == 'r')
620 ni_rows = atoi(argv[++a]);
621 else
622 goto userr;
623 break;
624 case 'o': /* output */
625 if (argv[a][2] == 'c') /* columns */
626 no_columns = atoi(argv[++a]);
627 else if (argv[a][2] == 'r')
628 no_rows = atoi(argv[++a]);
629 else if (argv[a][2] ||
630 !(outLevels=get_array(argv[++a], outArray, MAXLEVELS)))
631 goto userr;
632 break;
633 case 'h': /* turn off header */
634 switch (argv[a][2]) {
635 case 'i':
636 i_header = 0;
637 break;
638 case 'o':
639 o_header = 0;
640 break;
641 case '\0':
642 i_header = o_header = 0;
643 break;
644 default:
645 goto userr;
646 }
647 break;
648 case 't': /* transpose on/off */
649 transpose = !transpose;
650 break;
651 case 'f': /* format */
652 switch (argv[a][2]) {
653 case 'a': /* ASCII */
654 case 'A':
655 fmtid = "ascii";
656 comp_size = 0;
657 break;
658 case 'f': /* float */
659 case 'F':
660 fmtid = "float";
661 comp_size = sizeof(float);
662 break;
663 case 'd': /* double */
664 case 'D':
665 fmtid = "double";
666 comp_size = sizeof(double);
667 break;
668 case 'b': /* binary (bytes) */
669 case 'B':
670 fmtid = "byte";
671 comp_size = 1;
672 break;
673 default:
674 goto userr;
675 }
676 if (argv[a][3]) {
677 if (!isdigit(argv[a][3]))
678 goto userr;
679 n_comp = atoi(argv[a]+3);
680 } else
681 n_comp = 1;
682 break;
683 case 'w': /* warnings on/off */
684 warnings = !warnings;
685 break;
686 case 'c': /* force check operation */
687 check = 1;
688 break;
689 default:
690 goto userr;
691 }
692 if (a < argc-1) /* arg count OK? */
693 goto userr;
694 if (outLevels) { /* should check consistency? */
695 no_rows = outArray[0][0];
696 no_columns = outArray[0][1];
697 }
698 /* open input file? */
699 if (a == argc-1 && freopen(argv[a], "r", stdin) == NULL) {
700 fprintf(stderr, "%s: cannot open for reading\n", argv[a]);
701 return(1);
702 }
703 if (comp_size) {
704 SET_FILE_BINARY(stdin);
705 SET_FILE_BINARY(stdout);
706 }
707 /* check for no-op */
708 if (!transpose & !check & (outLevels <= 1) & (i_header == o_header) &&
709 (no_columns == ni_columns) & (no_rows == ni_rows)) {
710 if (warnings)
711 fprintf(stderr, "%s: no-op -- copying input verbatim\n",
712 argv[0]);
713 if (!output_stream(stdin))
714 return(1);
715 return(0);
716 }
717 if (i_header) { /* read header */
718 if (getheader(stdin, headline, NULL) < 0)
719 return(1);
720 if (!check_sizes())
721 return(1);
722 if (comp_size) { /* a little late... */
723 SET_FILE_BINARY(stdin);
724 SET_FILE_BINARY(stdout);
725 }
726 } else if (!check_sizes())
727 return(1);
728 if (o_header) { /* write/add to header */
729 if (!i_header)
730 newheader("RADIANCE", stdout);
731 printargs(a, argv, stdout);
732 printf("NCOMP=%d\n", n_comp);
733 }
734 if (transpose | check | (outLevels > 1) || (o_header && no_rows <= 0)) {
735 MEMLOAD myMem; /* need to map into memory */
736 if (a == argc-1) {
737 if (load_file(&myMem, stdin) <= 0) {
738 fprintf(stderr, "%s: error loading file into memory\n",
739 argv[a]);
740 return(1);
741 }
742 } else if (load_stream(&myMem, stdin) <= 0) {
743 fprintf(stderr, "%s: error loading stdin into memory\n",
744 argv[0]);
745 return(1);
746 }
747 if (!do_reorder(&myMem))
748 return(1);
749 /* free_load(&myMem); about to exit, so don't bother */
750 } else if (!do_resize(stdin)) /* just reshaping input */
751 return(1);
752 return(0);
753 userr:
754 fprintf(stderr,
755 "Usage: %s [-h[io]][-w][-c][-f[afdb][N]][-t][-ic in_col][-ir in_row][-oc out_col][-or out_row][-o RxC[xR1xC1..]] [input.dat]\n",
756 argv[0]);
757 return(1);
758 }
