Bug fixes in -o option
Additional size checks
Fixing minor issues with new -o code
Added capability to rcollate for reblocking input order for tensors
Added missing header opening line for -hi option
Fixed issue with unmapping mapped memory
Minor tweaks on last change
Fixed issues with very large file i/o
Made memory allocation in index_records less greedy
Fixed bug in allocation for reading from stream
Work-around fix for transposing ASCII input files under Windows
Simplified code a bit -- no significant change in behavior expected
Fixed issue with failure to manipulate header
Made NROWS/NCOLS more consistent with resolution string
Fixed redundant header output (bug)
Removed unnecessary address operators from function ids.
Bug fixes
Fixed bug when header is being removed from input
Fixed issue with binary data when adding or removing header
Added check for unsupported formats
Added -hi and -ho options to control input and output headers separately
Reduced number of calls to realloc() when loading from stdin
More Windows fixes (someone should come up with an acrylic version of Windows)
Fixes for Windows
Propogate output dimensions to input dimensions before checking input data
Added -w option to turn off warnings
Added error check for too little input data
Took off write ability I didn't need when mapping input file
