root/radiance/ray/src/util/rcollate.c
Revision: 2.3
Committed: Thu Sep 5 18:47:12 2013 UTC (11 years, 8 months ago) by greg
Added error check for too little input data
2 static const char RCSid[] = "$Id: rcollate.c,v 2.2 2013/09/05 18:30:58 greg Exp $";
5 * Utility to re-order records in a binary or ASCII data file (matrix)
6 */
7
8 #include <stdlib.h>
9 #include <unistd.h>
10 #include <string.h>
11 #include <ctype.h>
12 #include "platform.h"
13 #include "rtio.h"
14 #include "resolu.h"
15 #ifndef _WIN32
16 #include <sys/mman.h>
17 #endif
18
19 #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
20 #undef getc
21 #undef putc
22 #define getc getc_unlocked
23 #define putc putc_unlocked
24 #endif
25
26 typedef struct {
27 void *base; /* pointer to base memory */
28 size_t len; /* allocated memory length */
29 int mapped; /* memory-mapped file? */
30 } MEMLOAD; /* file loaded/mapped into memory */
31
32 typedef struct {
33 int nw_rec; /* number of words per record */
34 int nrecs; /* number of records we found */
35 char *rec[1]; /* record array (extends struct) */
36 } RECINDEX;
37
38 /* free loaded file */
39 static void
40 free_load(MEMLOAD *mp)
41 {
42 if (mp == NULL || (mp->base == NULL) | (mp->len <= 0))
43 return;
44 #ifdef MAP_FILE
45 if (mp->mapped)
46 munmap(mp->base, mp->len);
47 else
48 #endif
49 free(mp->base);
50 mp->base = NULL;
51 mp->len = 0;
52 }
53
54 /* load a file into memory */
55 static int
56 load_file(MEMLOAD *mp, FILE *fp)
57 {
58 int fd;
59 off_t skip, flen;
60
61 if (mp == NULL)
62 return(-1);
63 mp->base = NULL;
64 mp->len = 0;
65 mp->mapped = 0;
66 if (fp == NULL)
67 return(-1);
68 fd = fileno(fp);
69 skip = ftello(fp);
70 flen = lseek(fd, 0, SEEK_END);
71 if (flen <= skip)
72 return((int)(flen - skip));
73 mp->len = (size_t)(flen - skip);
74 #ifdef MAP_FILE
75 if (mp->len > 1L<<20) { /* map file if > 1 MByte */
76 mp->base = mmap(NULL, mp->len, PROT_READ, MAP_PRIVATE, fd, skip);
77 if (mp->base != MAP_FAILED) {
78 mp->mapped = 1;
79 return(1); /* mmap() success */
80 }
81 mp->base = NULL; /* fall back to reading it in... */
82 }
83 #endif
84 if (lseek(fd, skip, SEEK_SET) != skip ||
85 (mp->base = malloc(mp->len)) == NULL) {
86 mp->len = 0;
87 return(-1);
88 }
89 if (read(fd, (char *)mp->base, mp->len) != mp->len) {
90 free_load(mp);
91 return(-1);
92 }
93 return(1);
94 }
95
96 /* load memory from an input stream, starting from current position */
97 static int
98 load_stream(MEMLOAD *mp, FILE *fp)
99 {
100 char buf[8192];
101 size_t nr;
102
103 if (mp == NULL)
104 return(-1);
105 mp->base = NULL;
106 mp->len = 0;
107 mp->mapped = 0;
108 if (fp == NULL)
109 return(-1);
110 while ((nr = fread(buf, 1, sizeof(buf), fp)) > 0) {
111 if (!mp->len)
112 mp->base = malloc(nr);
113 else
114 mp->base = realloc(mp->base, mp->len+nr);
115 if (mp->base == NULL)
116 return(-1);
117 memcpy((char *)mp->base + mp->len, buf, nr);
118 mp->len += nr;
119 }
120 if (ferror(fp)) {
121 free_load(mp);
122 return(-1);
123 }
124 return(mp->len > 0);
125 }
126
127 /* free a record index */
128 #define free_records(rp) free(rp)
129
130 /* compute record index */
131 static RECINDEX *
132 index_records(const MEMLOAD *mp, int nw_rec)
133 {
134 RECINDEX *rp;
135 char *cp, *mend;
136 int n;
137
138 if (mp == NULL || (mp->base == NULL) | (mp->len <= 0))
139 return(NULL);
140 if (nw_rec <= 0)
141 return(NULL);
142 rp = (RECINDEX *)malloc(sizeof(RECINDEX) + mp->len/(2*nw_rec)*sizeof(char *));
143 if (rp == NULL)
144 return(NULL);
145 rp->nw_rec = nw_rec;
146 rp->nrecs = 0;
147 cp = (char *)mp->base;
148 mend = cp + mp->len;
149 for ( ; ; ) { /* whitespace-separated words */
150 while (cp < mend && !*cp | isspace(*cp))
151 ++cp;
152 if (cp >= mend)
153 break;
154 rp->rec[rp->nrecs++] = cp; /* point to first non-white */
155 n = rp->nw_rec;
156 while (++cp < mend) /* find end of record */
157 if (!*cp | isspace(*cp)) {
158 if (--n <= 0)
159 break; /* got requisite # words */
160 do { /* else find next word */
161 if (*cp == '\n') {
162 fprintf(stderr,
163 "Unexpected EOL in record!\n");
164 free_records(rp);
165 return(NULL);
166 }
167 if (++cp >= mend)
168 break;
169 } while (!*cp | isspace(*cp));
170 }
171 }
172 rp->rec[rp->nrecs] = mend; /* reallocate to save space */
173 rp = (RECINDEX *)realloc(rp,
174 sizeof(RECINDEX) + rp->nrecs*sizeof(char *));
175 return(rp);
176 }
177
178 /* count number of columns based on first EOL */
179 static int
180 count_columns(const RECINDEX *rp)
181 {
182 char *cp = rp->rec[0];
183 char *mend = rp->rec[rp->nrecs];
184 int i;
185
186 while (*cp != '\n')
187 if (++cp >= mend)
188 return(0);
189 for (i = 0; i < rp->nrecs; i++)
190 if (rp->rec[i] >= cp)
191 break;
192 return(i);
193 }
194
195 /* copy nth record from index to stdout */
196 static int
197 print_record(const RECINDEX *rp, int n)
198 {
199 int words2go = rp->nw_rec;
200 char *scp;
201
202 if ((n < 0) | (n >= rp->nrecs))
203 return(0);
204 scp = rp->rec[n];
205 do {
206 putc(*scp++, stdout);
207 if (!*scp | isspace(*scp)) {
208 if (--words2go <= 0)
209 break;
210 putc(' ', stdout); /* single space btwn. words */
211 do
212 if (++scp >= rp->rec[n+1])
213 break;
214 while (!*scp | isspace(*scp));
215 }
216 } while (scp < rp->rec[n+1]);
217 /* caller adds record sep. */
218 return(1);
219 }
220
221 /* copy a stream to stdout */
222 static int
223 output_stream(FILE *fp)
224 {
225 char buf[8192];
226 ssize_t n;
227
228 if (fp == NULL)
229 return(0);
230 fflush(stdout); /* assumes nothing in input buffer */
231 while ((n = read(fileno(fp), buf, sizeof(buf))) > 0)
232 if (write(fileno(stdout), buf, n) != n)
233 return(0);
234 return(n >= 0);
235 }
236
237 /* get next word from stream, leaving stream on EOL or start of next word */
238 static char *
239 fget_word(char buf[256], FILE *fp)
240 {
241 int c;
242 char *cp;
243 /* skip nul's and white space */
244 while (!(c = getc(fp)) || isspace(c))
245 ;
246 if (c == EOF)
247 return(NULL);
248 cp = buf;
249 do
250 *cp++ = c;
251 while ((c = getc(fp)) != EOF && !isspace(c) && cp < buf+255);
252 *cp = '\0';
253 while (isspace(c) & (c != '\n'))
254 c = getc(fp);
255 if (c != EOF)
256 ungetc(c, fp);
257 return(buf);
258 }
259
260 char *fmtid = "ascii"; /* format id */
261 int record_width = 3; /* words/record (<0 binary) */
262 int ni_columns = 0; /* number of input columns */
263 int ni_rows = 0; /* number of input rows */
264 int no_columns = 0; /* number of output columns */
265 int no_rows = 0; /* number of output rows */
266
267 /* output transposed ASCII or binary data from memory */
268 static int
269 do_transpose(const MEMLOAD *mp)
270 {
271 static const char tabEOL[2] = {'\t','\n'};
272 RECINDEX *rp = NULL;
273 long nrecords;
274 int i, j;
275 /* get # records (& index) */
276 if (record_width > 0) {
277 if ((rp = index_records(mp, record_width)) == NULL)
278 return(0);
279 if (ni_columns <= 0)
280 ni_columns = count_columns(rp);
281 nrecords = rp->nrecs;
282 } else if ((ni_rows > 0) & (ni_columns > 0)) {
283 nrecords = ni_rows*ni_columns;
284 if (nrecords > mp->len / -record_width) {
285 fprintf(stderr,
286 "Input too small for specified size and type\n");
287 return(0);
288 }
289 } else
290 nrecords = mp->len / -record_width;
291 /* check sizes */
292 if (ni_rows <= 0)
293 ni_rows = no_columns;
294 if (ni_columns <= 0)
295 ni_columns = no_rows;
296 if ((ni_rows <= 0) & (ni_columns > 0))
297 ni_rows = nrecords/ni_columns;
298 if ((ni_columns <= 0) & (ni_rows > 0))
299 ni_columns = nrecords/ni_rows;
300 if (nrecords != ni_rows*ni_columns)
301 goto badspec;
302 if (no_columns <= 0)
303 no_columns = ni_rows;
304 if (no_rows <= 0)
305 no_rows = ni_columns;
306 if ((no_rows != ni_columns) | (no_columns != ni_rows))
307 goto badspec;
308 /* transpose records */
309 for (i = 0; i < no_rows; i++) {
310 for (j = 0; j < no_columns; j++)
311 if (rp != NULL) { /* ASCII output */
312 print_record(rp, j*ni_columns + i);
313 putc(tabEOL[j >= no_columns-1], stdout);
314 } else { /* binary output */
315 fwrite((char *)mp->base +
316 -record_width*(j*ni_columns + i),
317 -record_width, 1, stdout);
318 }
319 if (ferror(stdout)) {
320 fprintf(stderr, "Error writing to stdout\n");
321 return(0);
322 }
323 }
324 if (rp != NULL)
325 free_records(rp);
326 return(1);
327 badspec:
328 fprintf(stderr, "Bad transpose specification -- check dimension(s)\n");
329 return(0);
330 }
331
332 /* resize ASCII stream input by ignoring EOLs between records */
333 static int
334 do_resize(FILE *fp)
335 {
336 long records2go = ni_rows*ni_columns;
337 int columns2go = no_columns;
338 char word[256];
339 /* sanity checks */
340 if (record_width <= 0) {
341 fprintf(stderr, "Bad call to do_resize (record_width = %d)\n",
342 record_width);
343 return(0);
344 }
345 if (no_columns <= 0) {
346 fprintf(stderr, "Missing -oc specification\n");
347 return(0);
348 }
349 if ((records2go <= 0) & (no_rows > 0))
350 records2go = no_rows*no_columns;
351 else if (no_rows*no_columns != records2go) {
352 fprintf(stderr,
353 "Input and output data sizes disagree (%dx%d != %dx%d)\n",
354 ni_rows, ni_columns, no_rows, no_columns);
355 return(0);
356 }
357 do { /* reshape records */
358 int n;
359
360 for (n = record_width; n--; ) {
361 if (fget_word(word, fp) == NULL) {
362 if (records2go > 0 || n < record_width-1)
363 break;
364 goto done; /* normal EOD */
365 }
366 fputs(word, stdout);
367 if (n) { /* mid-record? */
368 int c = getc(fp);
369 if ((c == '\n') | (c == EOF))
370 break;
371 ungetc(c, fp);
372 putc(' ', stdout);
373 }
374 }
375 if (n >= 0) {
376 fprintf(stderr, "Incomplete record / unexpected EOF\n");
377 return(0);
378 }
379 if (--columns2go <= 0) { /* time to end output row? */
380 putc('\n', stdout);
381 columns2go = no_columns;
382 } else /* else separate records */
383 putc('\t', stdout);
384 } while (--records2go); /* expected EOD? */
385 done:
386 if (columns2go != no_columns)
387 fprintf(stderr, "Warning -- incomplete final row\n");
388 if (fget_word(word, fp) != NULL)
389 fprintf(stderr, "Warning -- data beyond expected EOF\n");
390 return(1);
391 }
392
393 /* process a header line and copy to stdout */
394 static int
395 headline(char *s, void *p)
396 {
397 char fmt[32];
398
399 if (formatval(fmt, s)) {
400 if (!strcmp(fmt, fmtid))
401 return(0);
402 fprintf(stderr, "Input format '%s' != '%s'\n", fmt, fmtid);
403 return(-1);
404 }
405 fputs(s, stdout); /* copy header info. */
406 return(0);
407 }
408
409 /* main routine for converting rows/columns in data file */
410 int
411 main(int argc, char *argv[])
412 {
413 int do_header = 1; /* header i/o? */
414 int transpose = 0; /* transpose rows & cols? */
415 int i;
416
417 for (i = 1; i < argc && argv[i][0] == '-'; i++)
418 switch (argv[i][1]) {
419 case 'i': /* input */
420 if (argv[i][2] == 'c') /* columns */
421 ni_columns = atoi(argv[++i]);
422 else if (argv[i][2] == 'r')
423 ni_rows = atoi(argv[++i]);
424 else
425 goto userr;
426 break;
427 case 'o': /* output */
428 if (argv[i][2] == 'c') /* columns */
429 no_columns = atoi(argv[++i]);
430 else if (argv[i][2] == 'r')
431 no_rows = atoi(argv[++i]);
432 else
433 goto userr;
434 break;
435 case 'h': /* header on/off */
436 do_header = !do_header;
437 break;
438 case 't': /* transpose on/off */
439 transpose = !transpose;
440 break;
441 case 'f': /* format */
442 switch (argv[i][2]) {
443 case 'a': /* ASCII */
444 case 'A':
445 fmtid = "ascii";
446 record_width = 1;
447 break;
448 case 'f': /* float */
449 case 'F':
450 fmtid = "float";
451 record_width = -(int)sizeof(float);
452 break;
453 case 'd': /* double */
454 case 'D':
455 fmtid = "double";
456 record_width = -(int)sizeof(double);
457 break;
458 case 'b': /* binary (bytes) */
459 case 'B':
460 fmtid = "byte";
461 record_width = -1;
462 break;
463 default:
464 goto userr;
465 }
466 if (argv[i][3]) {
467 if (!isdigit(argv[i][3]))
468 goto userr;
469 record_width *= atoi(argv[i]+3);
470 }
471 break;
472 default:
473 goto userr;
474 }
475 if (!record_width)
476 goto userr;
477 if (i < argc-1) /* arg count OK? */
478 goto userr;
479 /* open input file? */
480 if (i == argc-1 && freopen(argv[i], "r", stdin) == NULL) {
481 fprintf(stderr, "%s: cannot open for reading\n", argv[i]);
482 return(1);
483 }
484 if (record_width < 0) {
485 SET_FILE_BINARY(stdin);
486 SET_FILE_BINARY(stdout);
487 }
488 /* check for no-op */
489 if (!transpose && (record_width < 0 ||
490 (no_columns == ni_columns) & (no_rows == ni_rows))) {
491 fprintf(stderr, "%s: no-op -- copying input verbatim\n",
492 argv[0]);
493 if (!output_stream(stdin))
494 return(1);
495 return(0);
496 }
497 if (do_header) { /* read/write header */
498 if (getheader(stdin, &headline, NULL) < 0)
499 return(1);
500 printargs(argc, argv, stdout);
501 fputformat(fmtid, stdout);
502 fputc('\n', stdout); /* finish new header */
503 }
504 if (transpose) { /* transposing rows & columns? */
505 MEMLOAD myMem; /* need to load into memory */
506 if (i == argc-1) {
507 if (load_file(&myMem, stdin) <= 0) {
508 fprintf(stderr, "%s: error loading file into memory\n",
509 argv[i]);
510 return(1);
511 }
512 } else if (load_stream(&myMem, stdin) <= 0) {
513 fprintf(stderr, "%s: error loading stdin into memory\n",
514 argv[0]);
515 return(1);
516 }
517 if (!do_transpose(&myMem))
518 return(1);
519 /* free_load(&myMem); */
520 } else if (!do_resize(stdin)) /* just reshaping input */
521 return(1);
522 return(0);
523 userr:
524 fprintf(stderr,
525 "Usage: %s [-h][-f[afdb][N]][-t][-ic in_col][-ir in_row][-oc out_col][-or out_row] [input.dat]\n",
526 argv[0]);
527 return(1);
528 }
