| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rcollate.c,v 2.20 2015/06/16 19:06:29 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Utility to re-order records in a binary or ASCII data file (matrix)
| 6 |
| 7 |
| 8 |
#include <stdlib.h>
| 9 |
#include <string.h>
| 10 |
#include <ctype.h>
| 11 |
#include "platform.h"
| 12 |
#include "rtio.h"
| 13 |
#include "resolu.h"
| 14 |
#ifdef _WIN32
| 15 |
#undef ftello
| 16 |
#define ftello ftell
| 17 |
#undef ssize_t
| 18 |
#define ssize_t size_t
| 19 |
#else
| 20 |
#include <sys/mman.h>
| 21 |
#endif
| 22 |
| 23 |
#ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
| 24 |
#undef getc
| 25 |
#undef putc
| 26 |
#define getc getc_unlocked
| 27 |
#define putc putc_unlocked
| 28 |
#endif
| 29 |
| 30 |
typedef struct {
| 31 |
void *base; /* pointer to base memory */
| 32 |
size_t len; /* allocated memory length */
| 33 |
int mapped; /* memory-mapped file? */
| 34 |
} MEMLOAD; /* file loaded/mapped into memory */
| 35 |
| 36 |
typedef struct {
| 37 |
int nw_rec; /* number of words per record */
| 38 |
int nrecs; /* number of records we found */
| 39 |
char *rec[1]; /* record array (extends struct) */
| 40 |
} RECINDEX;
| 41 |
| 42 |
int warnings = 1; /* report warnings? */
| 43 |
| 44 |
/* free loaded file */
| 45 |
static void
| 46 |
free_load(MEMLOAD *mp)
| 47 |
| 48 |
if (mp == NULL || (mp->base == NULL) | (mp->len <= 0))
| 49 |
return;
| 50 |
#ifdef MAP_FILE
| 51 |
if (mp->mapped)
| 52 |
munmap(mp->base, mp->len);
| 53 |
else
| 54 |
#endif
| 55 |
free(mp->base);
| 56 |
mp->base = NULL;
| 57 |
mp->len = 0;
| 58 |
| 59 |
| 60 |
/* load memory from an input stream, starting from current position */
| 61 |
static int
| 62 |
load_stream(MEMLOAD *mp, FILE *fp)
| 63 |
| 64 |
size_t alloced = 0;
| 65 |
char buf[8192];
| 66 |
size_t nr;
| 67 |
| 68 |
if (mp == NULL)
| 69 |
return(-1);
| 70 |
mp->base = NULL;
| 71 |
mp->len = 0;
| 72 |
mp->mapped = 0;
| 73 |
if (fp == NULL)
| 74 |
return(-1);
| 75 |
while ((nr = fread(buf, 1, sizeof(buf), fp)) > 0) {
| 76 |
if (!alloced)
| 77 |
mp->base = malloc(alloced = nr);
| 78 |
else if (mp->len+nr > alloced)
| 79 |
mp->base = realloc(mp->base,
| 80 |
alloced = alloced*(2+(nr==sizeof(buf)))/2+nr);
| 81 |
if (mp->base == NULL)
| 82 |
return(-1);
| 83 |
memcpy((char *)mp->base + mp->len, buf, nr);
| 84 |
mp->len += nr;
| 85 |
| 86 |
if (ferror(fp)) {
| 87 |
free_load(mp);
| 88 |
return(-1);
| 89 |
| 90 |
if (alloced > mp->len*5/4) /* don't waste too much space */
| 91 |
mp->base = realloc(mp->base, mp->len);
| 92 |
return(mp->len > 0);
| 93 |
| 94 |
| 95 |
/* load a file into memory */
| 96 |
static int
| 97 |
load_file(MEMLOAD *mp, FILE *fp)
| 98 |
| 99 |
int fd;
| 100 |
off_t skip, flen;
| 101 |
| 102 |
#ifdef _WIN32 /* too difficult to fix this */
| 103 |
return load_stream(mp, fp);
| 104 |
#endif
| 105 |
if (mp == NULL)
| 106 |
return(-1);
| 107 |
mp->base = NULL;
| 108 |
mp->len = 0;
| 109 |
mp->mapped = 0;
| 110 |
if (fp == NULL)
| 111 |
return(-1);
| 112 |
fd = fileno(fp);
| 113 |
skip = ftello(fp);
| 114 |
flen = lseek(fd, 0, SEEK_END);
| 115 |
if (flen <= skip)
| 116 |
return((int)(flen - skip));
| 117 |
mp->len = (size_t)(flen - skip);
| 118 |
#ifdef MAP_FILE
| 119 |
if (mp->len > 1L<<20) { /* map file if > 1 MByte */
| 120 |
mp->base = mmap(NULL, mp->len, PROT_READ, MAP_PRIVATE, fd, skip);
| 121 |
if (mp->base != MAP_FAILED) {
| 122 |
mp->mapped = 1;
| 123 |
return(1); /* mmap() success */
| 124 |
| 125 |
mp->base = NULL; /* fall back to reading it in... */
| 126 |
| 127 |
#endif
| 128 |
if (lseek(fd, skip, SEEK_SET) != skip ||
| 129 |
(mp->base = malloc(mp->len)) == NULL) {
| 130 |
mp->len = 0;
| 131 |
return(-1);
| 132 |
| 133 |
if (read(fd, (char *)mp->base, mp->len) != mp->len) {
| 134 |
free_load(mp);
| 135 |
return(-1);
| 136 |
| 137 |
return(1);
| 138 |
| 139 |
| 140 |
/* free a record index */
| 141 |
#define free_records(rp) free(rp)
| 142 |
| 143 |
/* compute record index */
| 144 |
static RECINDEX *
| 145 |
index_records(const MEMLOAD *mp, int nw_rec)
| 146 |
| 147 |
RECINDEX *rp;
| 148 |
char *cp, *mend;
| 149 |
int n;
| 150 |
| 151 |
| 152 |
return(NULL);
| 153 |
if (nw_rec <= 0)
| 154 |
return(NULL);
| 155 |
rp = (RECINDEX *)malloc(sizeof(RECINDEX) + mp->len/(2*nw_rec)*sizeof(char *));
| 156 |
if (rp == NULL)
| 157 |
return(NULL);
| 158 |
rp->nw_rec = nw_rec;
| 159 |
rp->nrecs = 0;
| 160 |
cp = (char *)mp->base;
| 161 |
mend = cp + mp->len;
| 162 |
for ( ; ; ) { /* whitespace-separated words */
| 163 |
while (cp < mend && !*cp | isspace(*cp))
| 164 |
++cp;
| 165 |
if (cp >= mend)
| 166 |
break;
| 167 |
rp->rec[rp->nrecs++] = cp; /* point to first non-white */
| 168 |
n = rp->nw_rec;
| 169 |
while (++cp < mend) /* find end of record */
| 170 |
if (!*cp | isspace(*cp)) {
| 171 |
if (--n <= 0)
| 172 |
break; /* got requisite # words */
| 173 |
do { /* else find next word */
| 174 |
if (*cp == '\n') {
| 175 |
fprintf(stderr,
| 176 |
"Unexpected EOL in record!\n");
| 177 |
free_records(rp);
| 178 |
return(NULL);
| 179 |
| 180 |
if (++cp >= mend)
| 181 |
break;
| 182 |
} while (!*cp | isspace(*cp));
| 183 |
| 184 |
| 185 |
rp->rec[rp->nrecs] = mend; /* reallocate to save space */
| 186 |
rp = (RECINDEX *)realloc(rp,
| 187 |
sizeof(RECINDEX) + rp->nrecs*sizeof(char *));
| 188 |
return(rp);
| 189 |
| 190 |
| 191 |
/* count number of columns based on first EOL */
| 192 |
static int
| 193 |
count_columns(const RECINDEX *rp)
| 194 |
| 195 |
char *cp = rp->rec[0];
| 196 |
char *mend = rp->rec[rp->nrecs];
| 197 |
int i;
| 198 |
| 199 |
while (*cp != '\n')
| 200 |
if (++cp >= mend)
| 201 |
return(0);
| 202 |
for (i = 0; i < rp->nrecs; i++)
| 203 |
if (rp->rec[i] >= cp)
| 204 |
break;
| 205 |
return(i);
| 206 |
| 207 |
| 208 |
/* copy nth record from index to stdout */
| 209 |
static int
| 210 |
print_record(const RECINDEX *rp, int n)
| 211 |
| 212 |
int words2go = rp->nw_rec;
| 213 |
char *scp;
| 214 |
| 215 |
if ((n < 0) | (n >= rp->nrecs))
| 216 |
return(0);
| 217 |
scp = rp->rec[n];
| 218 |
do {
| 219 |
putc(*scp++, stdout);
| 220 |
if (!*scp | isspace(*scp)) {
| 221 |
if (--words2go <= 0)
| 222 |
break;
| 223 |
putc(' ', stdout); /* single space btwn. words */
| 224 |
do
| 225 |
if (++scp >= rp->rec[n+1])
| 226 |
break;
| 227 |
while (!*scp | isspace(*scp));
| 228 |
| 229 |
} while (scp < rp->rec[n+1]);
| 230 |
/* caller adds record sep. */
| 231 |
return(1);
| 232 |
| 233 |
| 234 |
/* copy a stream to stdout */
| 235 |
static int
| 236 |
output_stream(FILE *fp)
| 237 |
| 238 |
char buf[8192];
| 239 |
ssize_t n;
| 240 |
| 241 |
if (fp == NULL)
| 242 |
return(0);
| 243 |
fflush(stdout);
| 244 |
while ((n = fread(buf, 1, sizeof(buf), fp)) > 0)
| 245 |
if (write(fileno(stdout), buf, n) != n)
| 246 |
return(0);
| 247 |
return(!ferror(fp));
| 248 |
| 249 |
| 250 |
/* get next word from stream, leaving stream on EOL or start of next word */
| 251 |
static char *
| 252 |
fget_word(char buf[256], FILE *fp)
| 253 |
| 254 |
int c;
| 255 |
char *cp;
| 256 |
/* skip nul's and white space */
| 257 |
while (!(c = getc(fp)) || isspace(c))
| 258 |
| 259 |
if (c == EOF)
| 260 |
return(NULL);
| 261 |
cp = buf;
| 262 |
do
| 263 |
*cp++ = c;
| 264 |
while ((c = getc(fp)) != EOF && !isspace(c) && cp < buf+255);
| 265 |
*cp = '\0';
| 266 |
while (isspace(c) & (c != '\n'))
| 267 |
c = getc(fp);
| 268 |
if (c != EOF)
| 269 |
ungetc(c, fp);
| 270 |
return(buf);
| 271 |
| 272 |
| 273 |
char *fmtid = NULL; /* format id */
| 274 |
int comp_size = 0; /* binary bytes/channel */
| 275 |
int n_comp = 0; /* components/record */
| 276 |
int ni_columns = 0; /* number of input columns */
| 277 |
int ni_rows = 0; /* number of input rows */
| 278 |
int no_columns = 0; /* number of output columns */
| 279 |
int no_rows = 0; /* number of output rows */
| 280 |
int transpose = 0; /* transpose rows & cols? */
| 281 |
int i_header = 1; /* input header? */
| 282 |
int o_header = 1; /* output header? */
| 283 |
| 284 |
/* check settings and assign defaults */
| 285 |
static int
| 286 |
check_sizes()
| 287 |
| 288 |
if (fmtid == NULL) {
| 289 |
fmtid = "ascii";
| 290 |
} else if (!comp_size) {
| 291 |
if (!strcmp(fmtid, "float"))
| 292 |
comp_size = sizeof(float);
| 293 |
else if (!strcmp(fmtid, "double"))
| 294 |
comp_size = sizeof(double);
| 295 |
else if (!strcmp(fmtid, "byte"))
| 296 |
comp_size = 1;
| 297 |
else if (strcmp(fmtid, "ascii")) {
| 298 |
fprintf(stderr, "Unsupported format: %s\n", fmtid);
| 299 |
return(0);
| 300 |
| 301 |
| 302 |
if (transpose && (no_rows <= 0) & (no_columns <= 0)) {
| 303 |
if (ni_rows > 0) no_columns = ni_rows;
| 304 |
if (ni_columns > 0) no_rows = ni_columns;
| 305 |
} else if ((no_rows <= 0) & (no_columns > 0) &&
| 306 |
!((ni_rows*ni_columns) % no_columns))
| 307 |
no_rows = ni_rows*ni_columns/no_columns;
| 308 |
if (n_comp <= 0)
| 309 |
n_comp = 3;
| 310 |
return(1);
| 311 |
| 312 |
| 313 |
/* output transposed ASCII or binary data from memory */
| 314 |
static int
| 315 |
do_transpose(const MEMLOAD *mp)
| 316 |
| 317 |
static const char tabEOL[2] = {'\t','\n'};
| 318 |
RECINDEX *rp = NULL;
| 319 |
long nrecords;
| 320 |
int i, j;
| 321 |
/* propogate sizes */
| 322 |
if (ni_rows <= 0)
| 323 |
ni_rows = no_columns;
| 324 |
if (ni_columns <= 0)
| 325 |
ni_columns = no_rows;
| 326 |
/* get # records (& index) */
| 327 |
if (!comp_size) {
| 328 |
if ((rp = index_records(mp, n_comp)) == NULL)
| 329 |
return(0);
| 330 |
| 331 |
ni_columns = count_columns(rp);
| 332 |
nrecords = rp->nrecs;
| 333 |
} else if ((ni_rows > 0) & (ni_columns > 0)) {
| 334 |
nrecords = ni_rows*ni_columns;
| 335 |
if (nrecords > mp->len/(n_comp*comp_size)) {
| 336 |
fprintf(stderr,
| 337 |
"Input too small for specified size and type\n");
| 338 |
return(0);
| 339 |
| 340 |
} else
| 341 |
nrecords = mp->len/(n_comp*comp_size);
| 342 |
/* check sizes */
| 343 |
if ((ni_rows <= 0) & (ni_columns > 0))
| 344 |
ni_rows = nrecords/ni_columns;
| 345 |
if ((ni_columns <= 0) & (ni_rows > 0))
| 346 |
ni_columns = nrecords/ni_rows;
| 347 |
if (nrecords != ni_rows*ni_columns)
| 348 |
goto badspec;
| 349 |
if (no_columns <= 0)
| 350 |
| 351 |
if (no_rows <= 0)
| 352 |
| 353 |
if ((no_rows != ni_columns) | (no_columns != ni_rows))
| 354 |
goto badspec;
| 355 |
/* transpose records */
| 356 |
for (i = 0; i < no_rows; i++) {
| 357 |
for (j = 0; j < no_columns; j++)
| 358 |
if (rp != NULL) { /* ASCII output */
| 359 |
print_record(rp, j*ni_columns + i);
| 360 |
putc(tabEOL[j >= no_columns-1], stdout);
| 361 |
} else { /* binary output */
| 362 |
fwrite((char *)mp->base +
| 363 |
(n_comp*comp_size)*(j*ni_columns + i),
| 364 |
n_comp*comp_size, 1, stdout);
| 365 |
| 366 |
if (ferror(stdout)) {
| 367 |
fprintf(stderr, "Error writing to stdout\n");
| 368 |
return(0);
| 369 |
| 370 |
| 371 |
if (rp != NULL)
| 372 |
free_records(rp);
| 373 |
return(1);
| 374 |
badspec:
| 375 |
fprintf(stderr, "Bad transpose specification -- check dimension(s)\n");
| 376 |
return(0);
| 377 |
| 378 |
| 379 |
/* resize ASCII stream input by ignoring EOLs between records */
| 380 |
static int
| 381 |
do_resize(FILE *fp)
| 382 |
| 383 |
long records2go = ni_rows*ni_columns;
| 384 |
int columns2go = no_columns;
| 385 |
char word[256];
| 386 |
/* sanity checks */
| 387 |
if (comp_size || (no_columns == ni_columns) & (no_rows == ni_rows))
| 388 |
return(output_stream(fp)); /* no-op -- just copy */
| 389 |
if (no_columns <= 0) {
| 390 |
fprintf(stderr, "Missing -oc specification\n");
| 391 |
return(0);
| 392 |
| 393 |
if ((records2go <= 0) & (no_rows > 0))
| 394 |
records2go = no_rows*no_columns;
| 395 |
else if (no_rows*no_columns != records2go) {
| 396 |
fprintf(stderr,
| 397 |
"Input and output data sizes disagree (%dx%d != %dx%d)\n",
| 398 |
ni_rows, ni_columns, no_rows, no_columns);
| 399 |
return(0);
| 400 |
| 401 |
do { /* reshape records */
| 402 |
int n;
| 403 |
| 404 |
for (n = n_comp; n--; ) {
| 405 |
if (fget_word(word, fp) == NULL) {
| 406 |
if (records2go > 0 || n < n_comp-1)
| 407 |
break;
| 408 |
goto done; /* normal EOD */
| 409 |
| 410 |
fputs(word, stdout);
| 411 |
if (n) { /* mid-record? */
| 412 |
int c = getc(fp);
| 413 |
if ((c == '\n') | (c == EOF))
| 414 |
break;
| 415 |
ungetc(c, fp);
| 416 |
putc(' ', stdout);
| 417 |
| 418 |
| 419 |
if (n >= 0) {
| 420 |
fprintf(stderr, "Incomplete record / unexpected EOF\n");
| 421 |
return(0);
| 422 |
| 423 |
if (--columns2go <= 0) { /* time to end output row? */
| 424 |
putc('\n', stdout);
| 425 |
| 426 |
} else /* else separate records */
| 427 |
putc('\t', stdout);
| 428 |
} while (--records2go); /* expected EOD? */
| 429 |
done:
| 430 |
if (warnings && columns2go != no_columns)
| 431 |
fprintf(stderr, "Warning -- incomplete final row\n");
| 432 |
if (warnings && fget_word(word, fp) != NULL)
| 433 |
fprintf(stderr, "Warning -- characters beyond expected EOD\n");
| 434 |
return(1);
| 435 |
| 436 |
| 437 |
/* process a header line and copy to stdout */
| 438 |
static int
| 439 |
headline(char *s, void *p)
| 440 |
| 441 |
static char fmt[32];
| 442 |
int n;
| 443 |
| 444 |
if (formatval(fmt, s)) {
| 445 |
| 446 |
fmtid = fmt;
| 447 |
return(0);
| 448 |
| 449 |
if (!strcmp(fmt, fmtid))
| 450 |
return(0);
| 451 |
fprintf(stderr, "Input format '%s' != '%s'\n", fmt, fmtid);
| 452 |
return(-1);
| 453 |
| 454 |
if (!strncmp(s, "NROWS=", 6)) {
| 455 |
n = atoi(s+6);
| 456 |
if ((ni_rows > 0) & (n != ni_rows)) {
| 457 |
fputs("Incorrect input row count\n", stderr);
| 458 |
return(-1);
| 459 |
| 460 |
ni_rows = n;
| 461 |
return(0);
| 462 |
| 463 |
if (!strncmp(s, "NCOLS=", 6)) {
| 464 |
n = atoi(s+6);
| 465 |
if ((ni_columns > 0) & (n != ni_columns)) {
| 466 |
fputs("Incorrect input column count\n", stderr);
| 467 |
return(-1);
| 468 |
| 469 |
ni_columns = n;
| 470 |
return(0);
| 471 |
| 472 |
if (!strncmp(s, "NCOMP=", 6)) {
| 473 |
n = atoi(s+6);
| 474 |
if ((n_comp > 0) & (n != n_comp)) {
| 475 |
fputs("Incorrect number of components\n", stderr);
| 476 |
return(-1);
| 477 |
| 478 |
n_comp = n;
| 479 |
return(0);
| 480 |
| 481 |
if (o_header)
| 482 |
fputs(s, stdout); /* copy header info. */
| 483 |
return(0);
| 484 |
| 485 |
| 486 |
/* main routine for converting rows/columns in data file */
| 487 |
int
| 488 |
main(int argc, char *argv[])
| 489 |
| 490 |
int a;
| 491 |
| 492 |
for (a = 1; a < argc && argv[a][0] == '-'; a++)
| 493 |
switch (argv[a][1]) {
| 494 |
case 'i': /* input */
| 495 |
if (argv[a][2] == 'c') /* columns */
| 496 |
ni_columns = atoi(argv[++a]);
| 497 |
else if (argv[a][2] == 'r')
| 498 |
ni_rows = atoi(argv[++a]);
| 499 |
else
| 500 |
goto userr;
| 501 |
break;
| 502 |
case 'o': /* output */
| 503 |
| 504 |
no_columns = atoi(argv[++a]);
| 505 |
| 506 |
no_rows = atoi(argv[++a]);
| 507 |
else
| 508 |
goto userr;
| 509 |
break;
| 510 |
case 'h': /* turn off header */
| 511 |
switch (argv[a][2]) {
| 512 |
case 'i':
| 513 |
i_header = 0;
| 514 |
break;
| 515 |
case 'o':
| 516 |
o_header = 0;
| 517 |
break;
| 518 |
case '\0':
| 519 |
i_header = o_header = 0;
| 520 |
break;
| 521 |
default:
| 522 |
goto userr;
| 523 |
| 524 |
break;
| 525 |
case 't': /* transpose on/off */
| 526 |
transpose = !transpose;
| 527 |
break;
| 528 |
case 'f': /* format */
| 529 |
| 530 |
case 'a': /* ASCII */
| 531 |
case 'A':
| 532 |
fmtid = "ascii";
| 533 |
comp_size = 0;
| 534 |
break;
| 535 |
case 'f': /* float */
| 536 |
case 'F':
| 537 |
fmtid = "float";
| 538 |
| 539 |
break;
| 540 |
case 'd': /* double */
| 541 |
case 'D':
| 542 |
fmtid = "double";
| 543 |
| 544 |
break;
| 545 |
case 'b': /* binary (bytes) */
| 546 |
case 'B':
| 547 |
fmtid = "byte";
| 548 |
comp_size = 1;
| 549 |
break;
| 550 |
default:
| 551 |
goto userr;
| 552 |
| 553 |
if (argv[a][3]) {
| 554 |
if (!isdigit(argv[a][3]))
| 555 |
goto userr;
| 556 |
n_comp = atoi(argv[a]+3);
| 557 |
} else
| 558 |
n_comp = 1;
| 559 |
break;
| 560 |
case 'w': /* warnings on/off */
| 561 |
warnings = !warnings;
| 562 |
break;
| 563 |
default:
| 564 |
goto userr;
| 565 |
| 566 |
if (a < argc-1) /* arg count OK? */
| 567 |
goto userr;
| 568 |
/* open input file? */
| 569 |
if (a == argc-1 && freopen(argv[a], "r", stdin) == NULL) {
| 570 |
fprintf(stderr, "%s: cannot open for reading\n", argv[a]);
| 571 |
return(1);
| 572 |
| 573 |
if (comp_size) {
| 574 |
SET_FILE_BINARY(stdin);
| 575 |
SET_FILE_BINARY(stdout);
| 576 |
| 577 |
/* check for no-op */
| 578 |
if (!transpose & (i_header == o_header) &&
| 579 |
(no_columns == ni_columns) & (no_rows == ni_rows)) {
| 580 |
if (warnings)
| 581 |
fprintf(stderr, "%s: no-op -- copying input verbatim\n",
| 582 |
argv[0]);
| 583 |
if (!output_stream(stdin))
| 584 |
return(1);
| 585 |
return(0);
| 586 |
| 587 |
if (i_header) { /* read header */
| 588 |
if (getheader(stdin, headline, NULL) < 0)
| 589 |
return(1);
| 590 |
if (!check_sizes())
| 591 |
return(1);
| 592 |
if (comp_size) { /* a little late... */
| 593 |
| 594 |
| 595 |
| 596 |
} else if (!check_sizes())
| 597 |
return(1);
| 598 |
if (o_header) { /* write header */
| 599 |
printargs(a, argv, stdout);
| 600 |
if (no_rows > 0)
| 601 |
printf("NROWS=%d\n", no_rows);
| 602 |
if (no_columns > 0)
| 603 |
printf("NCOLS=%d\n", no_columns);
| 604 |
printf("NCOMP=%d\n", n_comp);
| 605 |
fputformat(fmtid, stdout);
| 606 |
fputc('\n', stdout); /* finish new header */
| 607 |
| 608 |
if (transpose) { /* transposing rows & columns? */
| 609 |
MEMLOAD myMem; /* need to map into memory */
| 610 |
if (a == argc-1) {
| 611 |
if (load_file(&myMem, stdin) <= 0) {
| 612 |
fprintf(stderr, "%s: error loading file into memory\n",
| 613 |
argv[a]);
| 614 |
return(1);
| 615 |
| 616 |
} else if (load_stream(&myMem, stdin) <= 0) {
| 617 |
fprintf(stderr, "%s: error loading stdin into memory\n",
| 618 |
argv[0]);
| 619 |
return(1);
| 620 |
| 621 |
if (!do_transpose(&myMem))
| 622 |
return(1);
| 623 |
/* free_load(&myMem); about to exit, so don't bother */
| 624 |
} else if (!do_resize(stdin)) /* reshaping input */
| 625 |
return(1);
| 626 |
return(0);
| 627 |
userr:
| 628 |
fprintf(stderr,
| 629 |
"Usage: %s [-h[io]][-w][-f[afdb][N]][-t][-ic in_col][-ir in_row][-oc out_col][-or out_row] [input.dat]\n",
| 630 |
argv[0]);
| 631 |
return(1);
| 632 |
