root/radiance/ray/src/util/rcollate.c
Thu Sep 18 00:12:42 2014 UTC (9 years, 7 months ago) by greg
CVS Tags: rad4R2P2
Changes since 2.18: +6 -9 lines
Diff to previous 2.18 , to selected 2.5
Simplified code a bit -- no significant change in behavior expected
Fri Aug 1 18:21:04 2014 UTC (9 years, 9 months ago) by greg
CVS Tags: rad4R2P1
Diff to previous 2.17 , to selected 2.5
Fixed issue with failure to manipulate header
Thu Jul 24 16:28:17 2014 UTC (9 years, 9 months ago) by greg
CVS Tags: rad4R2
Changes since 2.16: +6 -3 lines
Diff to previous 2.16 , to selected 2.5
Made NROWS/NCOLS more consistent with resolution string
Wed Jul 9 21:45:48 2014 UTC (9 years, 9 months ago) by greg
Changes since 2.15: +12 -9 lines
Diff to previous 2.15 , to selected 2.5
Fixed redundant header output (bug)
Tue Jul 8 16:39:41 2014 UTC (9 years, 9 months ago) by greg
Removed unnecessary address operators from function ids.
Sat May 31 19:21:21 2014 UTC (9 years, 11 months ago) by greg
Changes since 2.13: +27 -26 lines
Bug fixes
Fri May 30 18:24:06 2014 UTC (9 years, 11 months ago) by greg
Fixed bug when header is being removed from input
Fri May 30 18:10:20 2014 UTC (9 years, 11 months ago) by greg
Changes since 2.11: +4 -6 lines
Fixed issue with binary data when adding or removing header
Fri May 30 17:29:28 2014 UTC (9 years, 11 months ago) by greg
Changes since 2.10: +11 -5 lines
Added check for unsupported formats
Fri May 30 16:50:43 2014 UTC (9 years, 11 months ago) by greg
Changes since 2.9: +23 -8 lines
Added -hi and -ho options to control input and output headers separately
Fri May 30 00:00:54 2014 UTC (9 years, 11 months ago) by greg
Changes since 2.8: +88 -25 lines
Fri Feb 21 13:49:00 2014 UTC (10 years, 2 months ago) by greg
Reduced number of calls to realloc() when loading from stdin
Mon Nov 18 22:02:12 2013 UTC (10 years, 5 months ago) by greg
Changes since 2.6: +7 -2 lines
More Windows fixes (someone should come up with an acrylic version of Windows)
Mon Nov 18 18:07:16 2013 UTC (10 years, 5 months ago) by greg
Changes since 2.5: +1 -2 lines
Fixes for Windows
Fri Sep 6 21:43:29 2013 UTC (10 years, 7 months ago) by greg
Changes since 2.4: +6 -5 lines
Propogate output dimensions to input dimensions before checking input data
Fri Sep 6 21:34:39 2013 UTC (10 years, 7 months ago) by greg
Changes since 2.3: +12 -6 lines
Added -w option to turn off warnings
Thu Sep 5 18:47:12 2013 UTC (10 years, 7 months ago) by greg
Added error check for too little input data
Thu Sep 5 18:30:58 2013 UTC (10 years, 7 months ago) by greg
Changes since 2.1: +2 -3 lines
Took off write ability I didn't need when mapping input file
Thu Sep 5 17:53:23 2013 UTC (10 years, 7 months ago) by greg
Diff to selected 2.5
