root/radiance/ray/src/util/rcollate.c
Revision: 2.4
Committed: Fri Sep 6 21:34:39 2013 UTC (11 years, 7 months ago) by greg
Changes since 2.3: +12 -6 lines
Added -w option to turn off warnings
2 static const char RCSid[] = "$Id: rcollate.c,v 2.3 2013/09/05 18:47:12 greg Exp $";
5 * Utility to re-order records in a binary or ASCII data file (matrix)
6 */
7
8 #include <stdlib.h>
9 #include <unistd.h>
10 #include <string.h>
11 #include <ctype.h>
12 #include "platform.h"
13 #include "rtio.h"
14 #include "resolu.h"
15 #ifndef _WIN32
16 #include <sys/mman.h>
17 #endif
18
19 #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
20 #undef getc
21 #undef putc
22 #define getc getc_unlocked
23 #define putc putc_unlocked
24 #endif
25
26 typedef struct {
27 void *base; /* pointer to base memory */
28 size_t len; /* allocated memory length */
29 int mapped; /* memory-mapped file? */
30 } MEMLOAD; /* file loaded/mapped into memory */
31
32 typedef struct {
33 int nw_rec; /* number of words per record */
34 int nrecs; /* number of records we found */
35 char *rec[1]; /* record array (extends struct) */
36 } RECINDEX;
37
38 int warnings = 1; /* report warnings? */
39
40 /* free loaded file */
41 static void
42 free_load(MEMLOAD *mp)
43 {
44 if (mp == NULL || (mp->base == NULL) | (mp->len <= 0))
45 return;
46 #ifdef MAP_FILE
47 if (mp->mapped)
48 munmap(mp->base, mp->len);
49 else
50 #endif
51 free(mp->base);
52 mp->base = NULL;
53 mp->len = 0;
54 }
55
56 /* load a file into memory */
57 static int
58 load_file(MEMLOAD *mp, FILE *fp)
59 {
60 int fd;
61 off_t skip, flen;
62
63 if (mp == NULL)
64 return(-1);
65 mp->base = NULL;
66 mp->len = 0;
67 mp->mapped = 0;
68 if (fp == NULL)
69 return(-1);
70 fd = fileno(fp);
71 skip = ftello(fp);
72 flen = lseek(fd, 0, SEEK_END);
73 if (flen <= skip)
74 return((int)(flen - skip));
75 mp->len = (size_t)(flen - skip);
76 #ifdef MAP_FILE
77 if (mp->len > 1L<<20) { /* map file if > 1 MByte */
78 mp->base = mmap(NULL, mp->len, PROT_READ, MAP_PRIVATE, fd, skip);
79 if (mp->base != MAP_FAILED) {
80 mp->mapped = 1;
81 return(1); /* mmap() success */
82 }
83 mp->base = NULL; /* fall back to reading it in... */
84 }
85 #endif
86 if (lseek(fd, skip, SEEK_SET) != skip ||
87 (mp->base = malloc(mp->len)) == NULL) {
88 mp->len = 0;
89 return(-1);
90 }
91 if (read(fd, (char *)mp->base, mp->len) != mp->len) {
92 free_load(mp);
93 return(-1);
94 }
95 return(1);
96 }
97
98 /* load memory from an input stream, starting from current position */
99 static int
100 load_stream(MEMLOAD *mp, FILE *fp)
101 {
102 char buf[8192];
103 size_t nr;
104
105 if (mp == NULL)
106 return(-1);
107 mp->base = NULL;
108 mp->len = 0;
109 mp->mapped = 0;
110 if (fp == NULL)
111 return(-1);
112 while ((nr = fread(buf, 1, sizeof(buf), fp)) > 0) {
113 if (!mp->len)
114 mp->base = malloc(nr);
115 else
116 mp->base = realloc(mp->base, mp->len+nr);
117 if (mp->base == NULL)
118 return(-1);
119 memcpy((char *)mp->base + mp->len, buf, nr);
120 mp->len += nr;
121 }
122 if (ferror(fp)) {
123 free_load(mp);
124 return(-1);
125 }
126 return(mp->len > 0);
127 }
128
129 /* free a record index */
130 #define free_records(rp) free(rp)
131
132 /* compute record index */
133 static RECINDEX *
134 index_records(const MEMLOAD *mp, int nw_rec)
135 {
136 RECINDEX *rp;
137 char *cp, *mend;
138 int n;
139
140 if (mp == NULL || (mp->base == NULL) | (mp->len <= 0))
141 return(NULL);
142 if (nw_rec <= 0)
143 return(NULL);
144 rp = (RECINDEX *)malloc(sizeof(RECINDEX) + mp->len/(2*nw_rec)*sizeof(char *));
145 if (rp == NULL)
146 return(NULL);
147 rp->nw_rec = nw_rec;
148 rp->nrecs = 0;
149 cp = (char *)mp->base;
150 mend = cp + mp->len;
151 for ( ; ; ) { /* whitespace-separated words */
152 while (cp < mend && !*cp | isspace(*cp))
153 ++cp;
154 if (cp >= mend)
155 break;
156 rp->rec[rp->nrecs++] = cp; /* point to first non-white */
157 n = rp->nw_rec;
158 while (++cp < mend) /* find end of record */
159 if (!*cp | isspace(*cp)) {
160 if (--n <= 0)
161 break; /* got requisite # words */
162 do { /* else find next word */
163 if (*cp == '\n') {
164 fprintf(stderr,
165 "Unexpected EOL in record!\n");
166 free_records(rp);
167 return(NULL);
168 }
169 if (++cp >= mend)
170 break;
171 } while (!*cp | isspace(*cp));
172 }
173 }
174 rp->rec[rp->nrecs] = mend; /* reallocate to save space */
175 rp = (RECINDEX *)realloc(rp,
176 sizeof(RECINDEX) + rp->nrecs*sizeof(char *));
177 return(rp);
178 }
179
180 /* count number of columns based on first EOL */
181 static int
182 count_columns(const RECINDEX *rp)
183 {
184 char *cp = rp->rec[0];
185 char *mend = rp->rec[rp->nrecs];
186 int i;
187
188 while (*cp != '\n')
189 if (++cp >= mend)
190 return(0);
191 for (i = 0; i < rp->nrecs; i++)
192 if (rp->rec[i] >= cp)
193 break;
194 return(i);
195 }
196
197 /* copy nth record from index to stdout */
198 static int
199 print_record(const RECINDEX *rp, int n)
200 {
201 int words2go = rp->nw_rec;
202 char *scp;
203
204 if ((n < 0) | (n >= rp->nrecs))
205 return(0);
206 scp = rp->rec[n];
207 do {
208 putc(*scp++, stdout);
209 if (!*scp | isspace(*scp)) {
210 if (--words2go <= 0)
211 break;
212 putc(' ', stdout); /* single space btwn. words */
213 do
214 if (++scp >= rp->rec[n+1])
215 break;
216 while (!*scp | isspace(*scp));
217 }
218 } while (scp < rp->rec[n+1]);
219 /* caller adds record sep. */
220 return(1);
221 }
222
223 /* copy a stream to stdout */
224 static int
225 output_stream(FILE *fp)
226 {
227 char buf[8192];
228 ssize_t n;
229
230 if (fp == NULL)
231 return(0);
232 fflush(stdout); /* assumes nothing in input buffer */
233 while ((n = read(fileno(fp), buf, sizeof(buf))) > 0)
234 if (write(fileno(stdout), buf, n) != n)
235 return(0);
236 return(n >= 0);
237 }
238
239 /* get next word from stream, leaving stream on EOL or start of next word */
240 static char *
241 fget_word(char buf[256], FILE *fp)
242 {
243 int c;
244 char *cp;
245 /* skip nul's and white space */
246 while (!(c = getc(fp)) || isspace(c))
247 ;
248 if (c == EOF)
249 return(NULL);
250 cp = buf;
251 do
252 *cp++ = c;
253 while ((c = getc(fp)) != EOF && !isspace(c) && cp < buf+255);
254 *cp = '\0';
255 while (isspace(c) & (c != '\n'))
256 c = getc(fp);
257 if (c != EOF)
258 ungetc(c, fp);
259 return(buf);
260 }
261
262 char *fmtid = "ascii"; /* format id */
263 int record_width = 3; /* words/record (<0 binary) */
264 int ni_columns = 0; /* number of input columns */
265 int ni_rows = 0; /* number of input rows */
266 int no_columns = 0; /* number of output columns */
267 int no_rows = 0; /* number of output rows */
268
269 /* output transposed ASCII or binary data from memory */
270 static int
271 do_transpose(const MEMLOAD *mp)
272 {
273 static const char tabEOL[2] = {'\t','\n'};
274 RECINDEX *rp = NULL;
275 long nrecords;
276 int i, j;
277 /* get # records (& index) */
278 if (record_width > 0) {
279 if ((rp = index_records(mp, record_width)) == NULL)
280 return(0);
281 if (ni_columns <= 0)
282 ni_columns = count_columns(rp);
283 nrecords = rp->nrecs;
284 } else if ((ni_rows > 0) & (ni_columns > 0)) {
285 nrecords = ni_rows*ni_columns;
286 if (nrecords > mp->len / -record_width) {
287 fprintf(stderr,
288 "Input too small for specified size and type\n");
289 return(0);
290 }
291 } else
292 nrecords = mp->len / -record_width;
293 /* check sizes */
294 if (ni_rows <= 0)
295 ni_rows = no_columns;
296 if (ni_columns <= 0)
297 ni_columns = no_rows;
298 if ((ni_rows <= 0) & (ni_columns > 0))
299 ni_rows = nrecords/ni_columns;
300 if ((ni_columns <= 0) & (ni_rows > 0))
301 ni_columns = nrecords/ni_rows;
302 if (nrecords != ni_rows*ni_columns)
303 goto badspec;
304 if (no_columns <= 0)
305 no_columns = ni_rows;
306 if (no_rows <= 0)
307 no_rows = ni_columns;
308 if ((no_rows != ni_columns) | (no_columns != ni_rows))
309 goto badspec;
310 /* transpose records */
311 for (i = 0; i < no_rows; i++) {
312 for (j = 0; j < no_columns; j++)
313 if (rp != NULL) { /* ASCII output */
314 print_record(rp, j*ni_columns + i);
315 putc(tabEOL[j >= no_columns-1], stdout);
316 } else { /* binary output */
317 fwrite((char *)mp->base +
318 -record_width*(j*ni_columns + i),
319 -record_width, 1, stdout);
320 }
321 if (ferror(stdout)) {
322 fprintf(stderr, "Error writing to stdout\n");
323 return(0);
324 }
325 }
326 if (rp != NULL)
327 free_records(rp);
328 return(1);
329 badspec:
330 fprintf(stderr, "Bad transpose specification -- check dimension(s)\n");
331 return(0);
332 }
333
334 /* resize ASCII stream input by ignoring EOLs between records */
335 static int
336 do_resize(FILE *fp)
337 {
338 long records2go = ni_rows*ni_columns;
339 int columns2go = no_columns;
340 char word[256];
341 /* sanity checks */
342 if (record_width <= 0) {
343 fprintf(stderr, "Bad call to do_resize (record_width = %d)\n",
344 record_width);
345 return(0);
346 }
347 if (no_columns <= 0) {
348 fprintf(stderr, "Missing -oc specification\n");
349 return(0);
350 }
351 if ((records2go <= 0) & (no_rows > 0))
352 records2go = no_rows*no_columns;
353 else if (no_rows*no_columns != records2go) {
354 fprintf(stderr,
355 "Input and output data sizes disagree (%dx%d != %dx%d)\n",
356 ni_rows, ni_columns, no_rows, no_columns);
357 return(0);
358 }
359 do { /* reshape records */
360 int n;
361
362 for (n = record_width; n--; ) {
363 if (fget_word(word, fp) == NULL) {
364 if (records2go > 0 || n < record_width-1)
365 break;
366 goto done; /* normal EOD */
367 }
368 fputs(word, stdout);
369 if (n) { /* mid-record? */
370 int c = getc(fp);
371 if ((c == '\n') | (c == EOF))
372 break;
373 ungetc(c, fp);
374 putc(' ', stdout);
375 }
376 }
377 if (n >= 0) {
378 fprintf(stderr, "Incomplete record / unexpected EOF\n");
379 return(0);
380 }
381 if (--columns2go <= 0) { /* time to end output row? */
382 putc('\n', stdout);
383 columns2go = no_columns;
384 } else /* else separate records */
385 putc('\t', stdout);
386 } while (--records2go); /* expected EOD? */
387 done:
388 if (warnings && columns2go != no_columns)
389 fprintf(stderr, "Warning -- incomplete final row\n");
390 if (warnings && fget_word(word, fp) != NULL)
391 fprintf(stderr, "Warning -- characters beyond expected EOD\n");
392 return(1);
393 }
394
395 /* process a header line and copy to stdout */
396 static int
397 headline(char *s, void *p)
398 {
399 char fmt[32];
400
401 if (formatval(fmt, s)) {
402 if (!strcmp(fmt, fmtid))
403 return(0);
404 fprintf(stderr, "Input format '%s' != '%s'\n", fmt, fmtid);
405 return(-1);
406 }
407 fputs(s, stdout); /* copy header info. */
408 return(0);
409 }
410
411 /* main routine for converting rows/columns in data file */
412 int
413 main(int argc, char *argv[])
414 {
415 int do_header = 1; /* header i/o? */
416 int transpose = 0; /* transpose rows & cols? */
417 int i;
418
419 for (i = 1; i < argc && argv[i][0] == '-'; i++)
420 switch (argv[i][1]) {
421 case 'i': /* input */
422 if (argv[i][2] == 'c') /* columns */
423 ni_columns = atoi(argv[++i]);
424 else if (argv[i][2] == 'r')
425 ni_rows = atoi(argv[++i]);
426 else
427 goto userr;
428 break;
429 case 'o': /* output */
430 if (argv[i][2] == 'c') /* columns */
431 no_columns = atoi(argv[++i]);
432 else if (argv[i][2] == 'r')
433 no_rows = atoi(argv[++i]);
434 else
435 goto userr;
436 break;
437 case 'h': /* header on/off */
438 do_header = !do_header;
439 break;
440 case 't': /* transpose on/off */
441 transpose = !transpose;
442 break;
443 case 'f': /* format */
444 switch (argv[i][2]) {
445 case 'a': /* ASCII */
446 case 'A':
447 fmtid = "ascii";
448 record_width = 1;
449 break;
450 case 'f': /* float */
451 case 'F':
452 fmtid = "float";
453 record_width = -(int)sizeof(float);
454 break;
455 case 'd': /* double */
456 case 'D':
457 fmtid = "double";
458 record_width = -(int)sizeof(double);
459 break;
460 case 'b': /* binary (bytes) */
461 case 'B':
462 fmtid = "byte";
463 record_width = -1;
464 break;
465 default:
466 goto userr;
467 }
468 if (argv[i][3]) {
469 if (!isdigit(argv[i][3]))
470 goto userr;
471 record_width *= atoi(argv[i]+3);
472 }
473 break;
474 case 'w': /* warnings on/off */
475 warnings = !warnings;
476 break;
477 default:
478 goto userr;
479 }
480 if (!record_width)
481 goto userr;
482 if (i < argc-1) /* arg count OK? */
483 goto userr;
484 /* open input file? */
485 if (i == argc-1 && freopen(argv[i], "r", stdin) == NULL) {
486 fprintf(stderr, "%s: cannot open for reading\n", argv[i]);
487 return(1);
488 }
489 if (record_width < 0) {
490 SET_FILE_BINARY(stdin);
491 SET_FILE_BINARY(stdout);
492 }
493 /* check for no-op */
494 if (!transpose && (record_width < 0 ||
495 (no_columns == ni_columns) & (no_rows == ni_rows))) {
496 if (warnings)
497 fprintf(stderr, "%s: no-op -- copying input verbatim\n",
498 argv[0]);
499 if (!output_stream(stdin))
500 return(1);
501 return(0);
502 }
503 if (do_header) { /* read/write header */
504 if (getheader(stdin, &headline, NULL) < 0)
505 return(1);
506 printargs(argc, argv, stdout);
507 fputformat(fmtid, stdout);
508 fputc('\n', stdout); /* finish new header */
509 }
510 if (transpose) { /* transposing rows & columns? */
511 MEMLOAD myMem; /* need to load into memory */
512 if (i == argc-1) {
513 if (load_file(&myMem, stdin) <= 0) {
514 fprintf(stderr, "%s: error loading file into memory\n",
515 argv[i]);
516 return(1);
517 }
518 } else if (load_stream(&myMem, stdin) <= 0) {
519 fprintf(stderr, "%s: error loading stdin into memory\n",
520 argv[0]);
521 return(1);
522 }
523 if (!do_transpose(&myMem))
524 return(1);
525 /* free_load(&myMem); */
526 } else if (!do_resize(stdin)) /* just reshaping input */
527 return(1);
528 return(0);
529 userr:
530 fprintf(stderr,
531 "Usage: %s [-h][-w][-f[afdb][N]][-t][-ic in_col][-ir in_row][-oc out_col][-or out_row] [input.dat]\n",
532 argv[0]);
533 return(1);
534 }
