root/Development/ray/src/util/rcollate.c
Revision: 2.17
Committed: Thu Jul 24 16:28:17 2014 UTC (11 years, 5 months ago) by greg
CVS Tags: rad4R2
Changes since 2.16: +6 -3 lines
Made NROWS/NCOLS more consistent with resolution string
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.17 static const char RCSid[] = "$Id: rcollate.c,v 2.16 2014/07/09 21:45:48 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Utility to re-order records in a binary or ASCII data file (matrix)
6     */
7
8     #include <stdlib.h>
9     #include <string.h>
10     #include <ctype.h>
11     #include "platform.h"
12     #include "rtio.h"
13     #include "resolu.h"
14 greg 2.7 #ifdef _WIN32
15     #undef ftello
16     #define ftello ftell
17     #undef ssize_t
18     #define ssize_t size_t
19     #else
20 greg 2.1 #include <sys/mman.h>
21     #endif
22
23     #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
24     #undef getc
25     #undef putc
26     #define getc getc_unlocked
27     #define putc putc_unlocked
28     #endif
29
30     typedef struct {
31     void *base; /* pointer to base memory */
32     size_t len; /* allocated memory length */
33     int mapped; /* memory-mapped file? */
34     } MEMLOAD; /* file loaded/mapped into memory */
35
36     typedef struct {
37     int nw_rec; /* number of words per record */
38     int nrecs; /* number of records we found */
39     char *rec[1]; /* record array (extends struct) */
40     } RECINDEX;
41
42 greg 2.4 int warnings = 1; /* report warnings? */
43
44 greg 2.1 /* free loaded file */
45     static void
46     free_load(MEMLOAD *mp)
47     {
48     if (mp == NULL || (mp->base == NULL) | (mp->len <= 0))
49     return;
50     #ifdef MAP_FILE
51     if (mp->mapped)
52     munmap(mp->base, mp->len);
53     else
54     #endif
55     free(mp->base);
56     mp->base = NULL;
57     mp->len = 0;
58     }
59
60     /* load a file into memory */
61     static int
62     load_file(MEMLOAD *mp, FILE *fp)
63     {
64     int fd;
65     off_t skip, flen;
66
67     if (mp == NULL)
68     return(-1);
69     mp->base = NULL;
70     mp->len = 0;
71     mp->mapped = 0;
72     if (fp == NULL)
73     return(-1);
74     fd = fileno(fp);
75     skip = ftello(fp);
76     flen = lseek(fd, 0, SEEK_END);
77     if (flen <= skip)
78     return((int)(flen - skip));
79     mp->len = (size_t)(flen - skip);
80     #ifdef MAP_FILE
81     if (mp->len > 1L<<20) { /* map file if > 1 MByte */
82 greg 2.2 mp->base = mmap(NULL, mp->len, PROT_READ, MAP_PRIVATE, fd, skip);
83 greg 2.1 if (mp->base != MAP_FAILED) {
84     mp->mapped = 1;
85     return(1); /* mmap() success */
86     }
87     mp->base = NULL; /* fall back to reading it in... */
88     }
89     #endif
90     if (lseek(fd, skip, SEEK_SET) != skip ||
91     (mp->base = malloc(mp->len)) == NULL) {
92     mp->len = 0;
93     return(-1);
94     }
95     if (read(fd, (char *)mp->base, mp->len) != mp->len) {
96     free_load(mp);
97     return(-1);
98     }
99     return(1);
100     }
101
102     /* load memory from an input stream, starting from current position */
103     static int
104     load_stream(MEMLOAD *mp, FILE *fp)
105     {
106 greg 2.8 size_t alloced = 0;
107 greg 2.1 char buf[8192];
108     size_t nr;
109
110     if (mp == NULL)
111     return(-1);
112     mp->base = NULL;
113     mp->len = 0;
114     mp->mapped = 0;
115     if (fp == NULL)
116     return(-1);
117     while ((nr = fread(buf, 1, sizeof(buf), fp)) > 0) {
118 greg 2.8 if (!alloced)
119 greg 2.1 mp->base = malloc(nr);
120 greg 2.8 else if (mp->len+nr > alloced)
121     mp->base = realloc(mp->base,
122     alloced = alloced*(2+(nr==sizeof(buf)))/2+nr);
123 greg 2.1 if (mp->base == NULL)
124     return(-1);
125     memcpy((char *)mp->base + mp->len, buf, nr);
126     mp->len += nr;
127     }
128     if (ferror(fp)) {
129     free_load(mp);
130     return(-1);
131     }
132 greg 2.8 if (alloced > mp->len*5/4) /* don't waste too much space */
133     mp->base = realloc(mp->base, mp->len);
134 greg 2.1 return(mp->len > 0);
135     }
136
137     /* free a record index */
138     #define free_records(rp) free(rp)
139
140     /* compute record index */
141     static RECINDEX *
142     index_records(const MEMLOAD *mp, int nw_rec)
143     {
144     RECINDEX *rp;
145     char *cp, *mend;
146     int n;
147
148     if (mp == NULL || (mp->base == NULL) | (mp->len <= 0))
149     return(NULL);
150     if (nw_rec <= 0)
151     return(NULL);
152     rp = (RECINDEX *)malloc(sizeof(RECINDEX) + mp->len/(2*nw_rec)*sizeof(char *));
153     if (rp == NULL)
154     return(NULL);
155     rp->nw_rec = nw_rec;
156     rp->nrecs = 0;
157     cp = (char *)mp->base;
158     mend = cp + mp->len;
159     for ( ; ; ) { /* whitespace-separated words */
160     while (cp < mend && !*cp | isspace(*cp))
161     ++cp;
162     if (cp >= mend)
163     break;
164     rp->rec[rp->nrecs++] = cp; /* point to first non-white */
165     n = rp->nw_rec;
166     while (++cp < mend) /* find end of record */
167     if (!*cp | isspace(*cp)) {
168     if (--n <= 0)
169     break; /* got requisite # words */
170     do { /* else find next word */
171     if (*cp == '\n') {
172     fprintf(stderr,
173     "Unexpected EOL in record!\n");
174     free_records(rp);
175     return(NULL);
176     }
177     if (++cp >= mend)
178     break;
179     } while (!*cp | isspace(*cp));
180     }
181     }
182     rp->rec[rp->nrecs] = mend; /* reallocate to save space */
183     rp = (RECINDEX *)realloc(rp,
184     sizeof(RECINDEX) + rp->nrecs*sizeof(char *));
185     return(rp);
186     }
187
188     /* count number of columns based on first EOL */
189     static int
190     count_columns(const RECINDEX *rp)
191     {
192     char *cp = rp->rec[0];
193     char *mend = rp->rec[rp->nrecs];
194     int i;
195
196     while (*cp != '\n')
197     if (++cp >= mend)
198     return(0);
199     for (i = 0; i < rp->nrecs; i++)
200     if (rp->rec[i] >= cp)
201     break;
202     return(i);
203     }
204
205     /* copy nth record from index to stdout */
206     static int
207     print_record(const RECINDEX *rp, int n)
208     {
209     int words2go = rp->nw_rec;
210     char *scp;
211
212     if ((n < 0) | (n >= rp->nrecs))
213     return(0);
214     scp = rp->rec[n];
215     do {
216     putc(*scp++, stdout);
217     if (!*scp | isspace(*scp)) {
218     if (--words2go <= 0)
219     break;
220     putc(' ', stdout); /* single space btwn. words */
221     do
222     if (++scp >= rp->rec[n+1])
223     break;
224     while (!*scp | isspace(*scp));
225     }
226     } while (scp < rp->rec[n+1]);
227     /* caller adds record sep. */
228     return(1);
229     }
230
231     /* copy a stream to stdout */
232     static int
233     output_stream(FILE *fp)
234     {
235     char buf[8192];
236     ssize_t n;
237
238     if (fp == NULL)
239     return(0);
240 greg 2.13 fflush(stdout);
241     while ((n = fread(buf, 1, sizeof(buf), fp)) > 0)
242 greg 2.1 if (write(fileno(stdout), buf, n) != n)
243     return(0);
244 greg 2.13 return(!ferror(fp));
245 greg 2.1 }
246
247     /* get next word from stream, leaving stream on EOL or start of next word */
248     static char *
249     fget_word(char buf[256], FILE *fp)
250     {
251     int c;
252     char *cp;
253     /* skip nul's and white space */
254     while (!(c = getc(fp)) || isspace(c))
255     ;
256     if (c == EOF)
257     return(NULL);
258     cp = buf;
259     do
260     *cp++ = c;
261     while ((c = getc(fp)) != EOF && !isspace(c) && cp < buf+255);
262     *cp = '\0';
263     while (isspace(c) & (c != '\n'))
264     c = getc(fp);
265     if (c != EOF)
266     ungetc(c, fp);
267     return(buf);
268     }
269
270 greg 2.9 char *fmtid = NULL; /* format id */
271     int comp_size = 0; /* binary bytes/channel */
272     int n_comp = 0; /* components/record */
273 greg 2.1 int ni_columns = 0; /* number of input columns */
274     int ni_rows = 0; /* number of input rows */
275     int no_columns = 0; /* number of output columns */
276     int no_rows = 0; /* number of output rows */
277 greg 2.16 int transpose = 0; /* transpose rows & cols? */
278     int i_header = 1; /* input header? */
279     int o_header = 1; /* output header? */
280 greg 2.1
281 greg 2.9 /* check settings and assign defaults */
282 greg 2.11 static int
283 greg 2.9 check_sizes()
284     {
285     if (fmtid == NULL) {
286     fmtid = "ascii";
287     } else if (!comp_size) {
288     if (!strcmp(fmtid, "float"))
289     comp_size = sizeof(float);
290     else if (!strcmp(fmtid, "double"))
291     comp_size = sizeof(double);
292     else if (!strcmp(fmtid, "byte"))
293     comp_size = 1;
294 greg 2.14 else if (strcmp(fmtid, "ascii")) {
295 greg 2.11 fprintf(stderr, "Unsupported format: %s\n", fmtid);
296     return(0);
297     }
298 greg 2.9 }
299 greg 2.16 if (transpose && (no_rows <= 0) & (no_columns <= 0)) {
300     if (ni_rows > 0) no_columns = ni_rows;
301     if (ni_columns > 0) no_rows = ni_columns;
302     } else if ((no_rows <= 0) & (no_columns > 0) &&
303     !((ni_rows*ni_columns) % no_columns))
304     no_rows = ni_rows*ni_columns/no_columns;
305 greg 2.9 if (n_comp <= 0)
306     n_comp = 3;
307 greg 2.11 return(1);
308 greg 2.9 }
309
310 greg 2.1 /* output transposed ASCII or binary data from memory */
311     static int
312     do_transpose(const MEMLOAD *mp)
313     {
314     static const char tabEOL[2] = {'\t','\n'};
315     RECINDEX *rp = NULL;
316     long nrecords;
317     int i, j;
318 greg 2.5 /* propogate sizes */
319     if (ni_rows <= 0)
320     ni_rows = no_columns;
321     if (ni_columns <= 0)
322     ni_columns = no_rows;
323 greg 2.1 /* get # records (& index) */
324 greg 2.9 if (!comp_size) {
325     if ((rp = index_records(mp, n_comp)) == NULL)
326 greg 2.1 return(0);
327     if (ni_columns <= 0)
328     ni_columns = count_columns(rp);
329     nrecords = rp->nrecs;
330 greg 2.3 } else if ((ni_rows > 0) & (ni_columns > 0)) {
331 greg 2.1 nrecords = ni_rows*ni_columns;
332 greg 2.9 if (nrecords > mp->len/(n_comp*comp_size)) {
333 greg 2.3 fprintf(stderr,
334     "Input too small for specified size and type\n");
335     return(0);
336     }
337     } else
338 greg 2.9 nrecords = mp->len/(n_comp*comp_size);
339 greg 2.1 /* check sizes */
340     if ((ni_rows <= 0) & (ni_columns > 0))
341     ni_rows = nrecords/ni_columns;
342     if ((ni_columns <= 0) & (ni_rows > 0))
343     ni_columns = nrecords/ni_rows;
344     if (nrecords != ni_rows*ni_columns)
345     goto badspec;
346     if (no_columns <= 0)
347     no_columns = ni_rows;
348     if (no_rows <= 0)
349     no_rows = ni_columns;
350     if ((no_rows != ni_columns) | (no_columns != ni_rows))
351     goto badspec;
352     /* transpose records */
353     for (i = 0; i < no_rows; i++) {
354     for (j = 0; j < no_columns; j++)
355     if (rp != NULL) { /* ASCII output */
356     print_record(rp, j*ni_columns + i);
357     putc(tabEOL[j >= no_columns-1], stdout);
358     } else { /* binary output */
359     fwrite((char *)mp->base +
360 greg 2.9 (n_comp*comp_size)*(j*ni_columns + i),
361     n_comp*comp_size, 1, stdout);
362 greg 2.1 }
363     if (ferror(stdout)) {
364     fprintf(stderr, "Error writing to stdout\n");
365     return(0);
366     }
367     }
368     if (rp != NULL)
369     free_records(rp);
370     return(1);
371     badspec:
372     fprintf(stderr, "Bad transpose specification -- check dimension(s)\n");
373     return(0);
374     }
375
376     /* resize ASCII stream input by ignoring EOLs between records */
377     static int
378     do_resize(FILE *fp)
379     {
380     long records2go = ni_rows*ni_columns;
381     int columns2go = no_columns;
382     char word[256];
383     /* sanity checks */
384 greg 2.12 if (comp_size)
385     return(output_stream(fp)); /* binary data -- just copy */
386 greg 2.1 if (no_columns <= 0) {
387     fprintf(stderr, "Missing -oc specification\n");
388     return(0);
389     }
390     if ((records2go <= 0) & (no_rows > 0))
391     records2go = no_rows*no_columns;
392     else if (no_rows*no_columns != records2go) {
393     fprintf(stderr,
394     "Input and output data sizes disagree (%dx%d != %dx%d)\n",
395     ni_rows, ni_columns, no_rows, no_columns);
396     return(0);
397     }
398     do { /* reshape records */
399     int n;
400
401 greg 2.9 for (n = n_comp; n--; ) {
402 greg 2.1 if (fget_word(word, fp) == NULL) {
403 greg 2.9 if (records2go > 0 || n < n_comp-1)
404 greg 2.1 break;
405     goto done; /* normal EOD */
406     }
407     fputs(word, stdout);
408     if (n) { /* mid-record? */
409     int c = getc(fp);
410     if ((c == '\n') | (c == EOF))
411     break;
412     ungetc(c, fp);
413     putc(' ', stdout);
414     }
415     }
416     if (n >= 0) {
417     fprintf(stderr, "Incomplete record / unexpected EOF\n");
418     return(0);
419     }
420     if (--columns2go <= 0) { /* time to end output row? */
421     putc('\n', stdout);
422     columns2go = no_columns;
423     } else /* else separate records */
424     putc('\t', stdout);
425     } while (--records2go); /* expected EOD? */
426     done:
427 greg 2.4 if (warnings && columns2go != no_columns)
428 greg 2.1 fprintf(stderr, "Warning -- incomplete final row\n");
429 greg 2.4 if (warnings && fget_word(word, fp) != NULL)
430     fprintf(stderr, "Warning -- characters beyond expected EOD\n");
431 greg 2.1 return(1);
432     }
433
434     /* process a header line and copy to stdout */
435     static int
436     headline(char *s, void *p)
437     {
438 greg 2.9 static char fmt[32];
439     int n;
440 greg 2.1
441     if (formatval(fmt, s)) {
442 greg 2.9 if (fmtid == NULL) {
443     fmtid = fmt;
444     return(0);
445     }
446 greg 2.1 if (!strcmp(fmt, fmtid))
447     return(0);
448     fprintf(stderr, "Input format '%s' != '%s'\n", fmt, fmtid);
449     return(-1);
450     }
451 greg 2.9 if (!strncmp(s, "NROWS=", 6)) {
452     n = atoi(s+6);
453     if ((ni_rows > 0) & (n != ni_rows)) {
454     fputs("Incorrect input row count\n", stderr);
455     return(-1);
456     }
457     ni_rows = n;
458     return(0);
459     }
460     if (!strncmp(s, "NCOLS=", 6)) {
461     n = atoi(s+6);
462     if ((ni_columns > 0) & (n != ni_columns)) {
463     fputs("Incorrect input column count\n", stderr);
464     return(-1);
465     }
466     ni_columns = n;
467     return(0);
468     }
469     if (!strncmp(s, "NCOMP=", 6)) {
470     n = atoi(s+6);
471     if ((n_comp > 0) & (n != n_comp)) {
472 greg 2.14 fputs("Incorrect number of components\n", stderr);
473 greg 2.9 return(-1);
474     }
475     n_comp = n;
476     return(0);
477     }
478 greg 2.16 if (o_header)
479     fputs(s, stdout); /* copy header info. */
480 greg 2.1 return(0);
481     }
482
483     /* main routine for converting rows/columns in data file */
484     int
485     main(int argc, char *argv[])
486     {
487 greg 2.14 int a;
488 greg 2.1
489 greg 2.14 for (a = 1; a < argc && argv[a][0] == '-'; a++)
490     switch (argv[a][1]) {
491 greg 2.1 case 'i': /* input */
492 greg 2.14 if (argv[a][2] == 'c') /* columns */
493     ni_columns = atoi(argv[++a]);
494     else if (argv[a][2] == 'r')
495     ni_rows = atoi(argv[++a]);
496 greg 2.1 else
497     goto userr;
498     break;
499     case 'o': /* output */
500 greg 2.14 if (argv[a][2] == 'c') /* columns */
501     no_columns = atoi(argv[++a]);
502     else if (argv[a][2] == 'r')
503     no_rows = atoi(argv[++a]);
504 greg 2.1 else
505     goto userr;
506     break;
507 greg 2.10 case 'h': /* turn off header */
508 greg 2.14 switch (argv[a][2]) {
509 greg 2.10 case 'i':
510     i_header = 0;
511     break;
512     case 'o':
513     o_header = 0;
514     break;
515     case '\0':
516     i_header = o_header = 0;
517     break;
518     default:
519     goto userr;
520     }
521 greg 2.1 break;
522     case 't': /* transpose on/off */
523     transpose = !transpose;
524     break;
525     case 'f': /* format */
526 greg 2.14 switch (argv[a][2]) {
527 greg 2.1 case 'a': /* ASCII */
528     case 'A':
529     fmtid = "ascii";
530 greg 2.9 comp_size = 0;
531 greg 2.1 break;
532     case 'f': /* float */
533     case 'F':
534     fmtid = "float";
535 greg 2.9 comp_size = sizeof(float);
536 greg 2.1 break;
537     case 'd': /* double */
538     case 'D':
539     fmtid = "double";
540 greg 2.9 comp_size = sizeof(double);
541 greg 2.1 break;
542     case 'b': /* binary (bytes) */
543     case 'B':
544     fmtid = "byte";
545 greg 2.9 comp_size = 1;
546 greg 2.1 break;
547     default:
548     goto userr;
549     }
550 greg 2.14 if (argv[a][3]) {
551     if (!isdigit(argv[a][3]))
552 greg 2.1 goto userr;
553 greg 2.14 n_comp = atoi(argv[a]+3);
554     } else
555     n_comp = 1;
556 greg 2.1 break;
557 greg 2.4 case 'w': /* warnings on/off */
558     warnings = !warnings;
559     break;
560 greg 2.1 default:
561     goto userr;
562     }
563 greg 2.14 if (a < argc-1) /* arg count OK? */
564 greg 2.1 goto userr;
565     /* open input file? */
566 greg 2.14 if (a == argc-1 && freopen(argv[a], "r", stdin) == NULL) {
567     fprintf(stderr, "%s: cannot open for reading\n", argv[a]);
568 greg 2.1 return(1);
569     }
570 greg 2.9 if (comp_size) {
571 greg 2.1 SET_FILE_BINARY(stdin);
572     SET_FILE_BINARY(stdout);
573     }
574     /* check for no-op */
575 greg 2.12 if (!transpose & (i_header == o_header) && (comp_size ||
576 greg 2.1 (no_columns == ni_columns) & (no_rows == ni_rows))) {
577 greg 2.4 if (warnings)
578     fprintf(stderr, "%s: no-op -- copying input verbatim\n",
579 greg 2.1 argv[0]);
580     if (!output_stream(stdin))
581     return(1);
582     return(0);
583     }
584 greg 2.10 if (i_header) { /* read header */
585 greg 2.15 if (getheader(stdin, headline, NULL) < 0)
586 greg 2.1 return(1);
587 greg 2.11 if (!check_sizes())
588     return(1);
589 greg 2.9 if (comp_size) { /* a little late... */
590     SET_FILE_BINARY(stdin);
591     SET_FILE_BINARY(stdout);
592     }
593 greg 2.11 } else if (!check_sizes())
594     return(1);
595 greg 2.10 if (o_header) { /* write header */
596 greg 2.14 printargs(a, argv, stdout);
597 greg 2.9 if (no_rows > 0)
598     printf("NROWS=%d\n", no_rows);
599     if (no_columns > 0)
600     printf("NCOLS=%d\n", no_columns);
601     printf("NCOMP=%d\n", n_comp);
602 greg 2.1 fputformat(fmtid, stdout);
603     fputc('\n', stdout); /* finish new header */
604 greg 2.10 }
605 greg 2.1 if (transpose) { /* transposing rows & columns? */
606     MEMLOAD myMem; /* need to load into memory */
607 greg 2.14 if (a == argc-1) {
608 greg 2.1 if (load_file(&myMem, stdin) <= 0) {
609     fprintf(stderr, "%s: error loading file into memory\n",
610 greg 2.14 argv[a]);
611 greg 2.1 return(1);
612     }
613     } else if (load_stream(&myMem, stdin) <= 0) {
614     fprintf(stderr, "%s: error loading stdin into memory\n",
615     argv[0]);
616     return(1);
617     }
618     if (!do_transpose(&myMem))
619     return(1);
620 greg 2.17 /* free_load(&myMem); about to exit, so don't bother */
621     } else if (comp_size || (no_columns==ni_columns) & (no_rows==ni_rows)) {
622     if (!output_stream(stdin)) /* just changed header */
623     return(1);
624     } else if (!do_resize(stdin)) /* reshaping input */
625 greg 2.1 return(1);
626     return(0);
627     userr:
628     fprintf(stderr,
629 greg 2.10 "Usage: %s [-h[io]][-w][-f[afdb][N]][-t][-ic in_col][-ir in_row][-oc out_col][-or out_row] [input.dat]\n",
630 greg 2.1 argv[0]);
631     return(1);
632     }
