--- ray/src/util/rcollate.c 2014/05/30 16:50:43 2.10 +++ ray/src/util/rcollate.c 2022/01/20 17:35:03 2.38 @@ -1,41 +1,35 @@ #ifndef lint -static const char RCSid[] = "$Id: rcollate.c,v 2.10 2014/05/30 16:50:43 greg Exp $"; +static const char RCSid[] = "$Id: rcollate.c,v 2.38 2022/01/20 17:35:03 greg Exp $"; #endif /* * Utility to re-order records in a binary or ASCII data file (matrix) */ #include -#include #include #include "platform.h" #include "rtio.h" #include "resolu.h" -#ifdef _WIN32 -#undef ftello -#define ftello ftell -#undef ssize_t -#define ssize_t size_t +#if defined(_WIN32) || defined(_WIN64) + #undef ftello + #define ftello ftell + #undef ssize_t + #define ssize_t size_t #else -#include + #include #endif -#ifdef getc_unlocked /* avoid horrendous overhead of flockfile */ -#undef getc -#undef putc -#define getc getc_unlocked -#define putc putc_unlocked -#endif +#define MAXLEVELS 16 /* max RxC.. block pairs */ typedef struct { + void *mapped; /* memory-mapped pointer */ void *base; /* pointer to base memory */ size_t len; /* allocated memory length */ - int mapped; /* memory-mapped file? */ } MEMLOAD; /* file loaded/mapped into memory */ typedef struct { int nw_rec; /* number of words per record */ - int nrecs; /* number of records we found */ + ssize_t nrecs; /* number of records we found */ char *rec[1]; /* record array (extends struct) */ } RECINDEX; @@ -49,56 +43,15 @@ free_load(MEMLOAD *mp) return; #ifdef MAP_FILE if (mp->mapped) - munmap(mp->base, mp->len); + munmap(mp->mapped, mp->len); else #endif free(mp->base); + mp->mapped = NULL; mp->base = NULL; mp->len = 0; } -/* load a file into memory */ -static int -load_file(MEMLOAD *mp, FILE *fp) -{ - int fd; - off_t skip, flen; - - if (mp == NULL) - return(-1); - mp->base = NULL; - mp->len = 0; - mp->mapped = 0; - if (fp == NULL) - return(-1); - fd = fileno(fp); - skip = ftello(fp); - flen = lseek(fd, 0, SEEK_END); - if (flen <= skip) - return((int)(flen - skip)); - mp->len = (size_t)(flen - skip); -#ifdef MAP_FILE - if (mp->len > 1L<<20) { /* map file if > 1 MByte */ - mp->base = mmap(NULL, mp->len, PROT_READ, MAP_PRIVATE, fd, skip); - if (mp->base != MAP_FAILED) { - mp->mapped = 1; - return(1); /* mmap() success */ - } - mp->base = NULL; /* fall back to reading it in... */ - } -#endif - if (lseek(fd, skip, SEEK_SET) != skip || - (mp->base = malloc(mp->len)) == NULL) { - mp->len = 0; - return(-1); - } - if (read(fd, (char *)mp->base, mp->len) != mp->len) { - free_load(mp); - return(-1); - } - return(1); -} - /* load memory from an input stream, starting from current position */ static int load_stream(MEMLOAD *mp, FILE *fp) @@ -109,14 +62,14 @@ load_stream(MEMLOAD *mp, FILE *fp) if (mp == NULL) return(-1); + mp->mapped = NULL; mp->base = NULL; mp->len = 0; - mp->mapped = 0; if (fp == NULL) return(-1); while ((nr = fread(buf, 1, sizeof(buf), fp)) > 0) { if (!alloced) - mp->base = malloc(nr); + mp->base = malloc(alloced = nr); else if (mp->len+nr > alloced) mp->base = realloc(mp->base, alloced = alloced*(2+(nr==sizeof(buf)))/2+nr); @@ -134,6 +87,58 @@ load_stream(MEMLOAD *mp, FILE *fp) return(mp->len > 0); } +#if defined(_WIN32) || defined(_WIN64) + /* too difficult to fix this */ +#define load_file load_stream +#else +/* load a file into memory */ +static int +load_file(MEMLOAD *mp, FILE *fp) +{ + int fd; + off_t skip, flen, fpos; + if (mp == NULL) + return(-1); + mp->mapped = NULL; + mp->base = NULL; + mp->len = 0; + if (fp == NULL) + return(-1); + fd = fileno(fp); + skip = ftello(fp); + flen = lseek(fd, 0, SEEK_END); + if (flen <= skip) + return((int)(flen - skip)); + mp->len = (size_t)(flen - skip); +#ifdef MAP_FILE + if (mp->len >= 1L<<20) { /* map file if >= 1 MByte */ + mp->mapped = mmap(NULL, flen, PROT_READ, MAP_PRIVATE, fd, 0); + if (mp->mapped != MAP_FAILED) { + mp->base = (char *)mp->mapped + skip; + return(1); /* mmap() success */ + } + mp->mapped = NULL; /* else fall back to reading it in... */ + } +#endif + if (lseek(fd, skip, SEEK_SET) != skip || + (mp->base = malloc(mp->len)) == NULL) { + mp->len = 0; + return(-1); + } + fpos = skip; + while (fpos < flen) { /* read() fails if n > 2 GBytes */ + ssize_t nread = read(fd, (char *)mp->base+(fpos-skip), + (flen-fpos < 1L<<24) ? flen-fpos : 1L<<24); + if (nread <= 0) { + free_load(mp); + return(-1); + } + fpos += nread; + } + return(1); +} +#endif + /* free a record index */ #define free_records(rp) free(rp) @@ -141,6 +146,7 @@ load_stream(MEMLOAD *mp, FILE *fp) static RECINDEX * index_records(const MEMLOAD *mp, int nw_rec) { + int nall = 0; RECINDEX *rp; char *cp, *mend; int n; @@ -149,7 +155,8 @@ index_records(const MEMLOAD *mp, int nw_rec) return(NULL); if (nw_rec <= 0) return(NULL); - rp = (RECINDEX *)malloc(sizeof(RECINDEX) + mp->len/(2*nw_rec)*sizeof(char *)); + nall = 1000; + rp = (RECINDEX *)malloc(sizeof(RECINDEX) + nall*sizeof(char *)); if (rp == NULL) return(NULL); rp->nw_rec = nw_rec; @@ -161,6 +168,13 @@ index_records(const MEMLOAD *mp, int nw_rec) ++cp; if (cp >= mend) break; + if (rp->nrecs >= nall) { + nall += nall>>1; /* get more record space */ + rp = (RECINDEX *)realloc(rp, + sizeof(RECINDEX) + nall*sizeof(char *)); + if (rp == NULL) + return(NULL); + } rp->rec[rp->nrecs++] = cp; /* point to first non-white */ n = rp->nw_rec; while (++cp < mend) /* find end of record */ @@ -204,7 +218,7 @@ count_columns(const RECINDEX *rp) /* copy nth record from index to stdout */ static int -print_record(const RECINDEX *rp, int n) +print_record(const RECINDEX *rp, ssize_t n) { int words2go = rp->nw_rec; char *scp; @@ -237,11 +251,11 @@ output_stream(FILE *fp) if (fp == NULL) return(0); - fflush(stdout); /* assumes nothing in input buffer */ - while ((n = read(fileno(fp), buf, sizeof(buf))) > 0) + fflush(stdout); + while ((n = fread(buf, 1, sizeof(buf), fp)) > 0) if (write(fileno(stdout), buf, n) != n) return(0); - return(n >= 0); + return(!ferror(fp)); } /* get next word from stream, leaving stream on EOL or start of next word */ @@ -274,9 +288,50 @@ int ni_columns = 0; /* number of input columns */ int ni_rows = 0; /* number of input rows */ int no_columns = 0; /* number of output columns */ int no_rows = 0; /* number of output rows */ +int transpose = 0; /* transpose rows & cols? */ +int i_header = 1; /* input header? */ +int o_header = 1; /* output header? */ +int outArray[MAXLEVELS][2]; /* output block nesting */ +int outLevels = 0; /* number of blocking levels */ +int check = 0; /* force data check? */ +/* parse RxCx... string */ +static int +get_array(const char *spec, int blklvl[][2], int nlvls) +{ + int n; + + if (nlvls <= 0) { + fputs("Too many block levels!\n", stderr); + exit(1); + } + if (sscanf(spec, "%dx%d", &blklvl[0][0], &blklvl[0][1]) != 2) { + fputs("Bad block specification!\n", stderr); + exit(1); + } + while (isdigit(*spec)) + spec++; + spec++; /* 'x' */ + while (isdigit(*spec)) + spec++; + if ((*spec != 'x') & (*spec != 'X')) { + if (*spec) { + fputs("Blocks must be separated by 'x' or 'X'\n", stderr); + exit(1); + } + return(1); + } + spec++; + n = get_array(spec, blklvl+1, nlvls-1); + if (!n) + return(0); + blklvl[0][0] *= blklvl[1][0]; + blklvl[0][1] *= blklvl[1][1]; + return(n+1); +} + /* check settings and assign defaults */ -static void +static int check_sizes() { if (fmtid == NULL) { @@ -288,24 +343,74 @@ check_sizes() comp_size = sizeof(double); else if (!strcmp(fmtid, "byte")) comp_size = 1; + else if (strcmp(fmtid, "ascii")) { + fprintf(stderr, "Unsupported format: %s\n", fmtid); + return(0); + } } + if (transpose && (no_rows <= 0) & (no_columns <= 0)) { + if (ni_rows > 0) no_columns = ni_rows; + if (ni_columns > 0) no_rows = ni_columns; + } else if ((no_rows <= 0) & (no_columns > 0) && + !((ni_rows*ni_columns) % no_columns)) + no_rows = ni_rows*ni_columns/no_columns; if (n_comp <= 0) n_comp = 3; + return(1); } -/* output transposed ASCII or binary data from memory */ +/* call to compute block input position */ +static ssize_t +get_block_pos(int r, int c, int blklvl[][2], int nlvls) +{ + ssize_t n = 0; + + while (nlvls > 1) { + int sr = r/blklvl[1][0]; + int sc = c/blklvl[1][1]; + r -= sr*blklvl[1][0]; + c -= sc*blklvl[1][1]; + n += sr*blklvl[1][0]*blklvl[0][1] + sc*blklvl[1][0]*blklvl[1][1]; + blklvl++; + nlvls--; + } + n += r*blklvl[0][1] + c; + return(n); +} + +/* return input offset based on array ordering and transpose option */ +static ssize_t +get_input_pos(int r, int c) +{ + ssize_t n; + + if (outLevels > 1) { /* block reordering */ + n = get_block_pos(r, c, outArray, outLevels); + if (transpose) { + r = n/ni_rows; + c = n - r*ni_rows; + n = (ssize_t)c*ni_columns + r; + } + } else if (transpose) /* transpose only */ + n = (ssize_t)c*ni_columns + r; + else /* XXX should never happen! */ + n = (ssize_t)r*no_columns + c; + return(n); +} + +/* output reordered ASCII or binary data from memory */ static int -do_transpose(const MEMLOAD *mp) +do_reorder(const MEMLOAD *mp) { static const char tabEOL[2] = {'\t','\n'}; RECINDEX *rp = NULL; - long nrecords; + ssize_t nrecords; int i, j; /* propogate sizes */ if (ni_rows <= 0) - ni_rows = no_columns; + ni_rows = transpose ? no_columns : no_rows; if (ni_columns <= 0) - ni_columns = no_rows; + ni_columns = transpose ? no_rows : no_columns; /* get # records (& index) */ if (!comp_size) { if ((rp = index_records(mp, n_comp)) == NULL) @@ -314,10 +419,10 @@ do_transpose(const MEMLOAD *mp) ni_columns = count_columns(rp); nrecords = rp->nrecs; } else if ((ni_rows > 0) & (ni_columns > 0)) { - nrecords = ni_rows*ni_columns; + nrecords = (ssize_t)ni_rows*ni_columns; if (nrecords > mp->len/(n_comp*comp_size)) { - fprintf(stderr, - "Input too small for specified size and type\n"); + fputs("Input too small for specified size and type\n", + stderr); return(0); } } else @@ -325,27 +430,50 @@ do_transpose(const MEMLOAD *mp) /* check sizes */ if ((ni_rows <= 0) & (ni_columns > 0)) ni_rows = nrecords/ni_columns; - if ((ni_columns <= 0) & (ni_rows > 0)) + else if ((ni_columns <= 0) & (ni_rows > 0)) ni_columns = nrecords/ni_rows; - if (nrecords != ni_rows*ni_columns) + if (nrecords != (ssize_t)ni_rows*ni_columns) goto badspec; - if (no_columns <= 0) - no_columns = ni_rows; - if (no_rows <= 0) - no_rows = ni_columns; - if ((no_rows != ni_columns) | (no_columns != ni_rows)) - goto badspec; - /* transpose records */ + if (transpose) { + if (no_columns <= 0) + no_columns = ni_rows; + if (no_rows <= 0) + no_rows = ni_columns; + if (outLevels <= 1 && + (no_rows != ni_columns) | (no_columns != ni_rows)) + goto badspec; + } else { + if (no_columns <= 0) + no_columns = ni_columns; + if (no_rows <= 0) + no_rows = ni_rows; + } + if (ni_rows*ni_columns != no_rows*no_columns) { + fputs("Number of input and output records do not match\n", + stderr); + return(0); + } + if (o_header) { /* finish header? */ + printf("NROWS=%d\n", no_rows); + printf("NCOLS=%d\n", no_columns); + fputc('\n', stdout); + } + /* reorder records */ for (i = 0; i < no_rows; i++) { - for (j = 0; j < no_columns; j++) + for (j = 0; j < no_columns; j++) { + ssize_t n = get_input_pos(i, j); + if (n >= nrecords) { + fputs("Index past end-of-file\n", stderr); + return(0); + } if (rp != NULL) { /* ASCII output */ - print_record(rp, j*ni_columns + i); + print_record(rp, n); putc(tabEOL[j >= no_columns-1], stdout); } else { /* binary output */ - fwrite((char *)mp->base + - (n_comp*comp_size)*(j*ni_columns + i), - n_comp*comp_size, 1, stdout); + putbinary((char *)mp->base + (n_comp*comp_size)*n, + comp_size, n_comp, stdout); } + } if (ferror(stdout)) { fprintf(stderr, "Error writing to stdout\n"); return(0); @@ -355,7 +483,7 @@ do_transpose(const MEMLOAD *mp) free_records(rp); return(1); badspec: - fprintf(stderr, "Bad transpose specification -- check dimension(s)\n"); + fprintf(stderr, "Bad dimension(s)\n"); return(0); } @@ -363,14 +491,21 @@ badspec: static int do_resize(FILE *fp) { - long records2go = ni_rows*ni_columns; + ssize_t records2go = ni_rows*ni_columns; int columns2go = no_columns; char word[256]; - /* sanity checks */ - if (comp_size) { - fputs("Bad call to do_resize (binary input)\n", stderr); - return(0); + + if (o_header) { /* finish header? */ + if (no_rows > 0) + printf("NROWS=%d\n", no_rows); + if (no_columns > 0) + printf("NCOLS=%d\n", no_columns); + fputc('\n', stdout); } + /* sanity checks */ + if (comp_size || !check & + (no_columns == ni_columns) & (no_rows == ni_rows)) + return(output_stream(fp)); /* no-op -- just copy */ if (no_columns <= 0) { fprintf(stderr, "Missing -oc specification\n"); return(0); @@ -379,7 +514,7 @@ do_resize(FILE *fp) records2go = no_rows*no_columns; else if (no_rows*no_columns != records2go) { fprintf(stderr, - "Input and output data sizes disagree (%dx%d != %dx%d)\n", + "Number of input and output records disagree (%dx%d != %dx%d)\n", ni_rows, ni_columns, no_rows, no_columns); return(0); } @@ -423,7 +558,7 @@ done: static int headline(char *s, void *p) { - static char fmt[32]; + static char fmt[MAXFMTLEN]; int n; if (formatval(fmt, s)) { @@ -457,13 +592,14 @@ headline(char *s, void *p) if (!strncmp(s, "NCOMP=", 6)) { n = atoi(s+6); if ((n_comp > 0) & (n != n_comp)) { - fputs("Incorrect number of components", stderr); + fputs("Incorrect number of components\n", stderr); return(-1); } n_comp = n; return(0); } - fputs(s, stdout); /* copy header info. */ + if (o_header) + fputs(s, stdout); /* copy header info. */ return(0); } @@ -471,31 +607,29 @@ headline(char *s, void *p) int main(int argc, char *argv[]) { - int i_header = 1; /* input header? */ - int o_header = 1; /* output header? */ - int transpose = 0; /* transpose rows & cols? */ - int i; + int a; - for (i = 1; i < argc && argv[i][0] == '-'; i++) - switch (argv[i][1]) { + for (a = 1; a < argc && argv[a][0] == '-'; a++) + switch (argv[a][1]) { case 'i': /* input */ - if (argv[i][2] == 'c') /* columns */ - ni_columns = atoi(argv[++i]); - else if (argv[i][2] == 'r') - ni_rows = atoi(argv[++i]); + if (argv[a][2] == 'c') /* columns */ + ni_columns = atoi(argv[++a]); + else if (argv[a][2] == 'r') + ni_rows = atoi(argv[++a]); else goto userr; break; case 'o': /* output */ - if (argv[i][2] == 'c') /* columns */ - no_columns = atoi(argv[++i]); - else if (argv[i][2] == 'r') - no_rows = atoi(argv[++i]); - else + if (argv[a][2] == 'c') /* columns */ + no_columns = atoi(argv[++a]); + else if (argv[a][2] == 'r') + no_rows = atoi(argv[++a]); + else if (argv[a][2] || + !(outLevels=get_array(argv[++a], outArray, MAXLEVELS))) goto userr; break; case 'h': /* turn off header */ - switch (argv[i][2]) { + switch (argv[a][2]) { case 'i': i_header = 0; break; @@ -513,7 +647,7 @@ main(int argc, char *argv[]) transpose = !transpose; break; case 'f': /* format */ - switch (argv[i][2]) { + switch (argv[a][2]) { case 'a': /* ASCII */ case 'A': fmtid = "ascii"; @@ -537,23 +671,31 @@ main(int argc, char *argv[]) default: goto userr; } - if (argv[i][3]) { - if (!isdigit(argv[i][3])) + if (argv[a][3]) { + if (!isdigit(argv[a][3])) goto userr; - n_comp = atoi(argv[i]+3); - } + n_comp = atoi(argv[a]+3); + } else + n_comp = 1; break; case 'w': /* warnings on/off */ warnings = !warnings; break; + case 'c': /* force check operation */ + check = 1; + break; default: goto userr; } - if (i < argc-1) /* arg count OK? */ + if (a < argc-1) /* arg count OK? */ goto userr; + if (outLevels) { /* should check consistency? */ + no_rows = outArray[0][0]; + no_columns = outArray[0][1]; + } /* open input file? */ - if (i == argc-1 && freopen(argv[i], "r", stdin) == NULL) { - fprintf(stderr, "%s: cannot open for reading\n", argv[i]); + if (a == argc-1 && freopen(argv[a], "r", stdin) == NULL) { + fprintf(stderr, "%s: cannot open for reading\n", argv[a]); return(1); } if (comp_size) { @@ -561,8 +703,8 @@ main(int argc, char *argv[]) SET_FILE_BINARY(stdout); } /* check for no-op */ - if (!transpose && (comp_size || - (no_columns == ni_columns) & (no_rows == ni_rows))) { + if (!transpose & !check & (outLevels <= 1) & (i_header == o_header) && + (no_columns == ni_columns) & (no_rows == ni_rows)) { if (warnings) fprintf(stderr, "%s: no-op -- copying input verbatim\n", argv[0]); @@ -571,35 +713,29 @@ main(int argc, char *argv[]) return(0); } if (i_header) { /* read header */ - if (getheader(stdin, &headline, NULL) < 0) + if (getheader(stdin, headline, NULL) < 0) return(1); - check_sizes(); + if (!check_sizes()) + return(1); if (comp_size) { /* a little late... */ SET_FILE_BINARY(stdin); SET_FILE_BINARY(stdout); } - } else - check_sizes(); - if (o_header) { /* write header */ - printargs(argc, argv, stdout); - if (transpose && (no_rows <= 0) & (no_columns <= 0)) { - if (ni_rows > 0) no_columns = ni_rows; - if (ni_columns > 0) no_rows = ni_columns; - } - if (no_rows > 0) - printf("NROWS=%d\n", no_rows); - if (no_columns > 0) - printf("NCOLS=%d\n", no_columns); + } else if (!check_sizes()) + return(1); + if (o_header) { /* write/add to header */ + if (!i_header) + newheader("RADIANCE", stdout); + printargs(a, argv, stdout); printf("NCOMP=%d\n", n_comp); fputformat(fmtid, stdout); - fputc('\n', stdout); /* finish new header */ } - if (transpose) { /* transposing rows & columns? */ - MEMLOAD myMem; /* need to load into memory */ - if (i == argc-1) { + if (transpose | check | (outLevels > 1) || (o_header && no_rows <= 0)) { + MEMLOAD myMem; /* need to map into memory */ + if (a == argc-1) { if (load_file(&myMem, stdin) <= 0) { fprintf(stderr, "%s: error loading file into memory\n", - argv[i]); + argv[a]); return(1); } } else if (load_stream(&myMem, stdin) <= 0) { @@ -607,15 +743,15 @@ main(int argc, char *argv[]) argv[0]); return(1); } - if (!do_transpose(&myMem)) + if (!do_reorder(&myMem)) return(1); - /* free_load(&myMem); */ + /* free_load(&myMem); about to exit, so don't bother */ } else if (!do_resize(stdin)) /* just reshaping input */ return(1); return(0); userr: fprintf(stderr, -"Usage: %s [-h[io]][-w][-f[afdb][N]][-t][-ic in_col][-ir in_row][-oc out_col][-or out_row] [input.dat]\n", +"Usage: %s [-h[io]][-w][-c][-f[afdb][N]][-t][-ic in_col][-ir in_row][-oc out_col][-or out_row][-o RxC[xR1xC1..]] [input.dat]\n", argv[0]); return(1); }
