--- ray/src/util/rcollate.c 2018/10/18 22:59:48 2.27 +++ ray/src/util/rcollate.c 2018/10/20 15:02:51 2.29 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rcollate.c,v 2.27 2018/10/18 22:59:48 greg Exp $"; +static const char RCSid[] = "$Id: rcollate.c,v 2.29 2018/10/20 15:02:51 greg Exp $"; #endif /* * Utility to re-order records in a binary or ASCII data file (matrix) @@ -21,9 +21,9 @@ static const char RCSid[] = "$Id: rcollate.c,v 2.27 20 #endif typedef struct { + void *mapped; /* memory-mapped pointer */ void *base; /* pointer to base memory */ size_t len; /* allocated memory length */ - int mapped; /* memory-mapped file? */ } MEMLOAD; /* file loaded/mapped into memory */ typedef struct { @@ -42,10 +42,11 @@ free_load(MEMLOAD *mp) return; #ifdef MAP_FILE if (mp->mapped) - munmap(mp->base, mp->len); + munmap(mp->mapped, mp->len); else #endif free(mp->base); + mp->mapped = NULL; mp->base = NULL; mp->len = 0; } @@ -60,9 +61,9 @@ load_stream(MEMLOAD *mp, FILE *fp) if (mp == NULL) return(-1); + mp->mapped = NULL; mp->base = NULL; mp->len = 0; - mp->mapped = 0; if (fp == NULL) return(-1); while ((nr = fread(buf, 1, sizeof(buf), fp)) > 0) { @@ -90,7 +91,7 @@ static int load_file(MEMLOAD *mp, FILE *fp) { int fd; - off_t skip, flen, skipped; + off_t skip, flen, fpos; #if defined(_WIN32) || defined(_WIN64) /* too difficult to fix this */ @@ -98,9 +99,9 @@ load_file(MEMLOAD *mp, FILE *fp) #endif if (mp == NULL) return(-1); + mp->mapped = NULL; mp->base = NULL; mp->len = 0; - mp->mapped = 0; if (fp == NULL) return(-1); fd = fileno(fp); @@ -111,13 +112,12 @@ load_file(MEMLOAD *mp, FILE *fp) mp->len = (size_t)(flen - skip); #ifdef MAP_FILE if (mp->len > 1L<<20) { /* map file if > 1 MByte */ - mp->base = mmap(NULL, flen, PROT_READ, MAP_PRIVATE, fd, 0); - if (mp->base != MAP_FAILED) { - mp->base = (char *)mp->base + skip; - mp->mapped = 1; + mp->mapped = mmap(NULL, flen, PROT_READ, MAP_PRIVATE, fd, 0); + if (mp->mapped != MAP_FAILED) { + mp->base = (char *)mp->mapped + skip; return(1); /* mmap() success */ } - mp->base = NULL; /* fall back to reading it in... */ + mp->mapped = NULL; /* else fall back to reading it in... */ } #endif if (lseek(fd, skip, SEEK_SET) != skip || @@ -125,15 +125,15 @@ load_file(MEMLOAD *mp, FILE *fp) mp->len = 0; return(-1); } - skipped = skip; /* read() fails on really big buffers */ - while (skipped < flen) { - ssize_t nread = read(fd, (char *)mp->base+(skipped-skip), - (flen-skipped <= 1L<<30) ? flen-skipped : 1L<<30); + fpos = skip; + while (fpos < flen) { /* read() fails if n > 2 GBytes */ + ssize_t nread = read(fd, (char *)mp->base+(fpos-skip), + (flen-fpos < 1L<<24) ? flen-fpos : 1L<<24); if (nread <= 0) { free_load(mp); return(-1); } - skipped += nread; + fpos += nread; } return(1); } @@ -370,7 +370,7 @@ do_transpose(const MEMLOAD *mp) putc(tabEOL[j >= no_columns-1], stdout); } else { /* binary output */ putbinary((char *)mp->base + - (unsigned long)(n_comp*comp_size)*(j*ni_columns + i), + (size_t)(n_comp*comp_size)*(j*ni_columns + i), comp_size, n_comp, stdout); } if (ferror(stdout)) {
