root/radiance/ray/src/util/rcollate.c
Revision: 2.46
Committed: Wed Jun 5 21:56:53 2024 UTC (12 months ago) by greg
perf(getinfo,rcollate): Removed unnecessary call to fileno() that used semaphore
2 static const char RCSid[] = "$Id: rcollate.c,v 2.45 2024/01/26 00:47:17 greg Exp $";
5 * Utility to re-order records in a binary or ASCII data file (matrix)
6 */
7
8 #include <stdlib.h>
9 #include <ctype.h>
10 #include "platform.h"
11 #include "rtio.h"
12 #include "resolu.h"
13 #if defined(_WIN32) || defined(_WIN64)
14 #undef ftello
15 #define ftello ftell
16 #undef ssize_t
17 #define ssize_t size_t
18 #else
19 #include <sys/mman.h>
20 #endif
21
22 #define MAXLEVELS 16 /* max RxC.. block pairs */
23
24 typedef struct {
25 void *mapped; /* memory-mapped pointer */
26 void *base; /* pointer to base memory */
27 size_t len; /* allocated memory length */
28 } MEMLOAD; /* file loaded/mapped into memory */
29
30 typedef struct {
31 int nw_rec; /* number of words per record */
32 size_t nrecs; /* number of records we found */
33 char *rec[1]; /* record array (extends struct) */
34 } RECINDEX;
35
36 int warnings = 1; /* report warnings? */
37
38 char *fmtid = NULL; /* format id */
39 int comp_size = 0; /* binary bytes/channel */
40 int n_comp = 0; /* components/record */
41 int ni_columns = 0; /* number of input columns */
42 int ni_rows = 0; /* number of input rows */
43 int no_columns = 0; /* number of output columns */
44 int no_rows = 0; /* number of output rows */
45 int transpose = 0; /* transpose rows & cols? */
46 int i_header = 1; /* input header? */
47 int o_header = 1; /* output header? */
48 int outArray[MAXLEVELS][2]; /* output block nesting */
49 int outLevels = 0; /* number of blocking levels */
50 int check = 0; /* force data check? */
51
52 /* free loaded file */
53 static void
54 free_load(MEMLOAD *mp)
55 {
56 if (mp == NULL || (mp->base == NULL) | (mp->len <= 0))
57 return;
58 #ifdef MAP_FILE
59 if (mp->mapped)
60 munmap(mp->mapped, mp->len);
61 else
62 #endif
63 free(mp->base);
64 mp->mapped = NULL;
65 mp->base = NULL;
66 mp->len = 0;
67 }
68
69 /* load memory from an input stream, starting from current position */
70 static int
71 load_stream(MEMLOAD *mp, FILE *fp)
72 {
73 size_t alloced = 0;
74 char buf[8192];
75 size_t nr;
76
77 if (mp == NULL)
78 return(-1);
79 mp->mapped = NULL;
80 mp->base = NULL;
81 mp->len = 0;
82 if (fp == NULL)
83 return(-1);
84 while ((nr = fread(buf, 1, sizeof(buf), fp)) > 0) {
85 if (!alloced)
86 mp->base = malloc(alloced = nr);
87 else if (mp->len+nr > alloced)
88 mp->base = realloc(mp->base,
89 alloced = alloced*(2+(nr==sizeof(buf)))/2+nr);
90 if (mp->base == NULL)
91 return(-1);
92 memcpy((char *)mp->base + mp->len, buf, nr);
93 mp->len += nr;
94 }
95 if (ferror(fp)) {
96 free_load(mp);
97 return(-1);
98 }
99 if (alloced > mp->len*5/4) /* don't waste too much space */
100 mp->base = realloc(mp->base, mp->len);
101 return(mp->len > 0);
102 }
103
104 #if defined(_WIN32) || defined(_WIN64)
105 /* too difficult to fix this */
106 #define load_file load_stream
107 #else
108 /* load a file into memory */
109 static int
110 load_file(MEMLOAD *mp, FILE *fp)
111 {
112 int fd;
113 off_t skip, flen, fpos;
114 if (mp == NULL)
115 return(-1);
116 mp->mapped = NULL;
117 mp->base = NULL;
118 mp->len = 0;
119 if (fp == NULL)
120 return(-1);
121 fd = fileno(fp);
122 skip = ftello(fp);
123 flen = lseek(fd, 0, SEEK_END);
124 if (flen <= skip)
125 return((int)(flen - skip));
126 mp->len = (size_t)(flen - skip);
127 #ifdef MAP_FILE
128 if (mp->len >= 1L<<20) { /* map file if >= 1 MByte */
129 mp->mapped = mmap(NULL, flen, PROT_READ, MAP_PRIVATE, fd, 0);
130 if (mp->mapped != MAP_FAILED) {
131 mp->base = (char *)mp->mapped + skip;
132 return(1); /* mmap() success */
133 }
134 mp->mapped = NULL; /* else fall back to reading it in... */
135 }
136 #endif
137 if (lseek(fd, skip, SEEK_SET) != skip ||
138 (mp->base = malloc(mp->len)) == NULL) {
139 mp->len = 0;
140 return(-1);
141 }
142 fpos = skip;
143 while (fpos < flen) { /* read() fails if n > 2 GBytes */
144 ssize_t nread = read(fd, (char *)mp->base+(fpos-skip),
145 (flen-fpos < 1L<<24) ? flen-fpos : 1L<<24);
146 if (nread <= 0) {
147 free_load(mp);
148 return(-1);
149 }
150 fpos += nread;
151 }
152 return(1);
153 }
154 #endif
155
156 /* free a record index */
157 #define free_records(rp) free(rp)
158
159 /* compute record index */
160 static RECINDEX *
161 index_records(const MEMLOAD *mp, int nw_rec)
162 {
163 int nall = 0;
164 RECINDEX *rp;
165 char *cp, *mend;
166 int n;
167
168 if (mp == NULL || (mp->base == NULL) | (mp->len <= 0))
169 return(NULL);
170 if (nw_rec <= 0)
171 return(NULL);
172 nall = 1000;
173 rp = (RECINDEX *)malloc(sizeof(RECINDEX) + nall*sizeof(char *));
174 if (rp == NULL)
175 return(NULL);
176 rp->nw_rec = nw_rec;
177 rp->nrecs = 0;
178 cp = (char *)mp->base;
179 mend = cp + mp->len;
180 for ( ; ; ) { /* whitespace-separated words */
181 while (cp < mend && !*cp | isspace(*cp))
182 ++cp;
183 if (cp >= mend)
184 break;
185 if (rp->nrecs >= nall) {
186 nall += nall>>1; /* get more record space */
187 rp = (RECINDEX *)realloc(rp,
188 sizeof(RECINDEX) + nall*sizeof(char *));
189 if (rp == NULL)
190 return(NULL);
191 }
192 rp->rec[rp->nrecs++] = cp; /* point to first non-white */
193 n = rp->nw_rec;
194 while (++cp < mend) /* find end of record */
195 if (!*cp | isspace(*cp)) {
196 if (--n <= 0)
197 break; /* got requisite # words */
198 do { /* else find next word */
199 if (*cp == '\n') {
200 fputs("Unexpected EOL in record!\n", stderr);
201 free_records(rp);
202 return(NULL);
203 }
204 if (++cp >= mend)
205 break;
206 } while (!*cp | isspace(*cp));
207 }
208 }
209 rp->rec[rp->nrecs] = mend; /* reallocate to save space */
210 rp = (RECINDEX *)realloc(rp,
211 sizeof(RECINDEX) + rp->nrecs*sizeof(char *));
212 return(rp);
213 }
214
215 /* count number of columns based on first EOL */
216 static int
217 count_columns(const RECINDEX *rp)
218 {
219 char *cp = rp->rec[0];
220 char *mend = rp->rec[rp->nrecs];
221 int i;
222
223 while (*cp != '\n')
224 if (++cp >= mend)
225 return(0);
226 for (i = 0; i < rp->nrecs; i++)
227 if (rp->rec[i] >= cp)
228 break;
229 return(i);
230 }
231
232 /* copy nth record from index to stdout */
233 static int
234 print_record(const RECINDEX *rp, size_t n)
235 {
236 static char delims[] = " \t\n\r\f";
237 int words2go = rp->nw_rec;
238 char *scp;
239
240 if (n >= rp->nrecs)
241 return(0);
242 scp = rp->rec[n];
243
244 if (check && !isfltd(scp, delims))
245 goto formerr;
246 do {
247 putc(*scp++, stdout);
248 if (!*scp | isspace(*scp)) {
249 if (--words2go <= 0)
250 break;
251 putc(' ', stdout); /* single space btwn. words */
252 do
253 if (++scp >= rp->rec[n+1])
254 break;
255 while (!*scp | isspace(*scp));
256
257 if (check && !isfltd(scp, delims))
258 goto formerr;
259 }
260 } while (scp < rp->rec[n+1]);
261 /* caller adds record sep. */
262 return(1);
263 formerr:
264 fputs("Badly formed number: ", stderr);
265 while (*scp && !isspace(*scp))
266 fputc(*scp++, stderr);
267 fputc('\n', stderr);
268 return(0);
269 }
270
271 /* copy a stream to stdout, return bytes written or 0 on error */
272 static size_t
273 output_stream(FILE *fp)
274 {
275 size_t ntot = 0;
276 char buf[8192];
277 size_t n;
278
279 if (fp == NULL)
280 return(0);
281 fflush(stdout);
282 while ((n = fread(buf, 1, sizeof(buf), fp)) > 0) {
283 if (write(1, buf, n) != n)
284 return(0);
285 ntot += n;
286 }
287 return(!ferror(fp) * ntot);
288 }
289
290 /* get next word from stream, leaving stream on EOL or start of next word */
291 static char *
292 fget_word(char buf[256], FILE *fp)
293 {
294 int c;
295 char *cp;
296 /* skip nul's and white space */
297 while (!(c = getc(fp)) || isspace(c))
298 ;
299 if (c == EOF)
300 return(NULL);
301 cp = buf;
302 do
303 *cp++ = c;
304 while ((c = getc(fp)) != EOF && !isspace(c) && cp < buf+255);
305 *cp = '\0';
306 while (isspace(c) & (c != '\n'))
307 c = getc(fp);
308 if (c != EOF)
309 ungetc(c, fp);
310 return(buf);
311 }
312
313 /* parse RxCx... string */
314 static int
315 get_array(const char *spec, int blklvl[][2], int nlvls)
316 {
317 int n;
318
319 if (nlvls <= 0) {
320 fputs("Too many block levels!\n", stderr);
321 exit(1);
322 }
323 if (sscanf(spec, "%dx%d", &blklvl[0][0], &blklvl[0][1]) != 2) {
324 fputs("Bad block specification!\n", stderr);
325 exit(1);
326 }
327 while (isdigit(*spec))
328 spec++;
329 spec++; /* 'x' */
330 while (isdigit(*spec))
331 spec++;
332 if ((*spec != 'x') & (*spec != 'X')) {
333 if (*spec) {
334 fputs("Blocks must be separated by 'x' or 'X'\n", stderr);
335 exit(1);
336 }
337 return(1);
338 }
339 spec++;
340 n = get_array(spec, blklvl+1, nlvls-1);
341 if (!n)
342 return(0);
343 blklvl[0][0] *= blklvl[1][0];
344 blklvl[0][1] *= blklvl[1][1];
345 return(n+1);
346 }
347
348 /* check settings and assign defaults */
349 static int
350 check_sizes()
351 {
352 if (fmtid == NULL) {
353 fmtid = "ascii";
354 } else if (!comp_size) {
355 if (!strcmp(fmtid, "float"))
356 comp_size = sizeof(float);
357 else if (!strcmp(fmtid, "double"))
358 comp_size = sizeof(double);
359 else if (!strcmp(fmtid, "byte"))
360 comp_size = 1;
361 else if (strcmp(fmtid, "ascii")) {
362 fprintf(stderr, "Unsupported format: %s\n", fmtid);
363 return(0);
364 }
365 }
366 if (transpose && (no_rows <= 0) & (no_columns <= 0)) {
367 if (ni_rows > 0) no_columns = ni_rows;
368 if (ni_columns > 0) no_rows = ni_columns;
369 } else {
370 if (no_columns <= 0)
371 no_columns = ni_columns;
372 if ((no_rows <= 0) & (no_columns > 0) &&
373 !((ni_rows*ni_columns) % no_columns))
374 no_rows = ni_rows*ni_columns/no_columns;
375 }
376 if (n_comp <= 0)
377 n_comp = 3;
378 return(1);
379 }
380
381 /* call to compute block input position */
382 static size_t
383 get_block_pos(int r, int c, int blklvl[][2], int nlvls)
384 {
385 size_t n = 0;
386
387 while (nlvls > 1) {
388 int sr = r/blklvl[1][0];
389 int sc = c/blklvl[1][1];
390 r -= sr*blklvl[1][0];
391 c -= sc*blklvl[1][1];
392 n += sr*blklvl[1][0]*blklvl[0][1] + sc*blklvl[1][0]*blklvl[1][1];
393 blklvl++;
394 nlvls--;
395 }
396 n += r*blklvl[0][1] + c;
397 return(n);
398 }
399
400 /* return input offset based on array ordering and transpose option */
401 static size_t
402 get_input_pos(int r, int c)
403 {
404 size_t n;
405
406 if (outLevels > 1) { /* block reordering */
407 n = get_block_pos(r, c, outArray, outLevels);
408 if (transpose) {
409 r = n/ni_rows;
410 c = n - r*ni_rows;
411 n = (size_t)c*ni_columns + r;
412 }
413 } else if (transpose) /* transpose only */
414 n = (size_t)c*ni_columns + r;
415 else /* XXX should never happen! */
416 n = (size_t)r*no_columns + c;
417 return(n);
418 }
419
420 /* output reordered ASCII or binary data from memory */
421 static int
422 do_reorder(const MEMLOAD *mp)
423 {
424 static const char tabEOL[2] = {'\t','\n'};
425 RECINDEX *rp = NULL;
426 size_t nrecords;
427 int i, j;
428 /* propogate sizes */
429 if (ni_rows <= 0)
430 ni_rows = transpose ? no_columns : no_rows;
431 if (ni_columns <= 0)
432 ni_columns = transpose ? no_rows : no_columns;
433 /* get # records (& index) */
434 if (!comp_size) {
435 if ((rp = index_records(mp, n_comp)) == NULL)
436 return(0);
437 if (ni_columns <= 0)
438 ni_columns = count_columns(rp);
439 nrecords = rp->nrecs;
440 } else if ((ni_rows > 0) & (ni_columns > 0)) {
441 nrecords = (size_t)ni_rows*ni_columns;
442 if (nrecords > mp->len/(n_comp*comp_size)) {
443 fputs("Input too small for specified size and type\n",
444 stderr);
445 return(0);
446 }
447 } else
448 nrecords = mp->len/(n_comp*comp_size);
449 /* check sizes */
450 if ((ni_rows <= 0) & (ni_columns > 0))
451 ni_rows = nrecords/ni_columns;
452 else if ((ni_columns <= 0) & (ni_rows > 0))
453 ni_columns = nrecords/ni_rows;
454 if (nrecords != (size_t)ni_rows*ni_columns)
455 goto badspec;
456 if (transpose) {
457 if (no_columns <= 0)
458 no_columns = ni_rows;
459 if (no_rows <= 0)
460 no_rows = ni_columns;
461 if (outLevels <= 1 &&
462 (no_rows != ni_columns) | (no_columns != ni_rows))
463 goto badspec;
464 } else {
465 if (no_columns <= 0)
466 no_columns = ni_columns;
467 if (no_rows <= 0)
468 no_rows = ni_rows;
469 }
470 if (ni_rows*ni_columns != no_rows*no_columns) {
471 fputs("Number of input and output records do not match\n",
472 stderr);
473 return(0);
474 }
475 if (o_header) { /* finish header? */
476 printf("NROWS=%d\n", no_rows);
477 printf("NCOLS=%d\n", no_columns);
478 fputformat(fmtid, stdout);
479 fputc('\n', stdout);
480 }
481 /* reorder records */
482 for (i = 0; i < no_rows; i++) {
483 for (j = 0; j < no_columns; j++) {
484 size_t n = get_input_pos(i, j);
485 if (n >= nrecords) {
486 fputs("Index past end-of-file\n", stderr);
487 return(0);
488 }
489 if (rp != NULL) { /* ASCII output */
490 if (!print_record(rp, n))
491 return(0);
492 putc(tabEOL[j >= no_columns-1], stdout);
493 } else { /* binary output */
494 putbinary((char *)mp->base + (n_comp*comp_size)*n,
495 comp_size, n_comp, stdout);
496 }
497 }
498 if (ferror(stdout)) {
499 fputs("Error writing to stdout\n", stderr);
500 return(0);
501 }
502 }
503 if (rp != NULL)
504 free_records(rp);
505 return(1);
506 badspec:
507 fputs("Bad dimension(s)\n", stderr);
508 return(0);
509 }
510
511 /* resize stream input by ignoring EOLs between ASCII records */
512 static int
513 do_resize(FILE *fp)
514 {
515 size_t records2go = ni_rows*ni_columns;
516 int columns2go = no_columns;
517 char word[256];
518
519 if (o_header) { /* finish header? */
520 if (no_rows > 0)
521 printf("NROWS=%d\n", no_rows);
522 if (no_columns > 0)
523 printf("NCOLS=%d\n", no_columns);
524 fputformat(fmtid, stdout);
525 fputc('\n', stdout);
526 }
527 if (comp_size) { /* just copy binary data? */
528 size_t nwritten = output_stream(fp);
529 if ((no_rows > 0) & (no_columns > 0) &&
530 nwritten != (size_t)no_rows*no_columns*n_comp*comp_size) {
531 if (check) {
532 fputs("Incorrect binary file size\n", stderr);
533 return(0); /* fatal if check is true */
534 }
535 if (warnings)
536 fputs("Warning -- unexpected binary file size\n", stderr);
537 }
538 return(nwritten > 0);
539 } /* else straight ASCII data copy? */
540 if (!check & (no_columns == ni_columns) & (no_rows == ni_rows))
541 return(output_stream(fp) > 0);
542 /* need to reshape (& check?) input */
543 if (no_columns <= 0) {
544 fputs("Missing -oc specification\n", stderr);
545 return(0);
546 }
547 if ((records2go <= 0) & (no_rows > 0))
548 records2go = no_rows*no_columns;
549 else if (no_rows*no_columns != records2go) {
550 fprintf(stderr,
551 "Number of input and output records disagree (%dx%d != %dx%d)\n",
552 ni_rows, ni_columns, no_rows, no_columns);
553 return(0);
554 }
555 do { /* reshape records */
556 int n = n_comp;
557 while (n--) {
558 if (fget_word(word, fp) == NULL) {
559 if ((records2go > 0) | (n < n_comp-1))
560 break;
561 goto done; /* normal EOD */
562 }
563 if (check && !isflt(word)) {
564 fputs("Badly formed number: ", stderr);
565 fputs(word, stderr);
566 fputc('\n', stderr);
567 return(0);
568 }
569 fputs(word, stdout);
570 if (n) { /* mid-record? */
571 int c = getc(fp);
572 if ((c == '\n') | (c == EOF))
573 break;
574 ungetc(c, fp);
575 putc(' ', stdout);
576 }
577 }
578 if (n >= 0) {
579 fputs("Incomplete record / unexpected EOF\n", stderr);
580 return(0);
581 }
582 if (--columns2go <= 0) { /* time to end output row? */
583 putc('\n', stdout);
584 columns2go = no_columns;
585 } else /* else separate records */
586 putc('\t', stdout);
587 } while (--records2go); /* expected EOD? */
588 done:
589 if (columns2go != no_columns) {
590 if (check) {
591 fputs("Incomplete final row\n", stderr);
592 return(0);
593 }
594 if (warnings)
595 fputs("Warning -- incomplete final row\n", stderr);
596 }
597 if (fget_word(word, fp) != NULL) {
598 if (check) {
599 fputs("Characters beyond expected EOD\n", stderr);
600 return(0);
601 }
602 if (warnings)
603 fputs("Warning -- characters beyond expected EOD\n", stderr);
604 }
605 return(1);
606 }
607
608 /* process a header line and copy to stdout */
609 static int
610 headline(char *s, void *p)
611 {
612 static char fmt[MAXFMTLEN];
613 int n;
614
615 if (formatval(fmt, s)) {
616 if (fmtid == fmt) return(0);
617 if (fmtid == NULL) {
618 fmtid = fmt;
619 return(0);
620 }
621 if (!check & (comp_size == 1) & (n_comp > 1))
622 return(0); /* byte exception - skip check */
623 if (!strcmp(fmt, fmtid))
624 return(0);
625 fprintf(stderr, "Input format '%s' != '%s'\n", fmt, fmtid);
626 return(-1);
627 }
628 if (!strncmp(s, "NROWS=", 6)) {
629 n = atoi(s+6);
630 if ((ni_rows > 0) & (n != ni_rows)) {
631 fputs("Incorrect input row count\n", stderr);
632 return(-1);
633 }
634 ni_rows = n;
635 return(0);
636 }
637 if (!strncmp(s, "NCOLS=", 6)) {
638 n = atoi(s+6);
639 if ((ni_columns > 0) & (n != ni_columns)) {
640 fputs("Incorrect input column count\n", stderr);
641 return(-1);
642 }
643 ni_columns = n;
644 return(0);
645 }
646 if (!strncmp(s, "NCOMP=", 6)) {
647 if (!check & (comp_size == 1) & (n_comp > 1))
648 return(0); /* byte exception - ignore */
649 n = atoi(s+6);
650 if ((n_comp > 0) & (n != n_comp)) {
651 fputs("Incorrect number of components\n", stderr);
652 return(-1);
653 }
654 n_comp = n;
655 return(0);
656 }
657 if (o_header)
658 fputs(s, stdout); /* copy header info. */
659 return(0);
660 }
661
662 /* main routine for converting rows/columns in data file */
663 int
664 main(int argc, char *argv[])
665 {
666 int a;
667
668 for (a = 1; a < argc && argv[a][0] == '-'; a++)
669 switch (argv[a][1]) {
670 case 'i': /* input */
671 if (argv[a][2] == 'c') /* columns */
672 ni_columns = atoi(argv[++a]);
673 else if (argv[a][2] == 'r')
674 ni_rows = atoi(argv[++a]);
675 else
676 goto userr;
677 break;
678 case 'o': /* output */
679 if (argv[a][2] == 'c') /* columns */
680 no_columns = atoi(argv[++a]);
681 else if (argv[a][2] == 'r')
682 no_rows = atoi(argv[++a]);
683 else if (argv[a][2] ||
684 !(outLevels=get_array(argv[++a], outArray, MAXLEVELS)))
685 goto userr;
686 break;
687 case 'h': /* turn off header */
688 switch (argv[a][2]) {
689 case 'i':
690 i_header = 0;
691 break;
692 case 'o':
693 o_header = 0;
694 break;
695 case '\0':
696 i_header = o_header = 0;
697 break;
698 default:
699 goto userr;
700 }
701 break;
702 case 't': /* transpose on/off */
703 transpose = !transpose;
704 break;
705 case 'f': /* format */
706 switch (argv[a][2]) {
707 case 'a': /* ASCII */
708 case 'A':
709 fmtid = "ascii";
710 comp_size = 0;
711 break;
712 case 'f': /* float */
713 case 'F':
714 fmtid = "float";
715 comp_size = sizeof(float);
716 break;
717 case 'd': /* double */
718 case 'D':
719 fmtid = "double";
720 comp_size = sizeof(double);
721 break;
722 case 'b': /* binary (bytes) */
723 case 'B':
724 fmtid = "byte";
725 comp_size = 1;
726 break;
727 default:
728 goto userr;
729 }
730 if (argv[a][3]) {
731 if (!isdigit(argv[a][3]))
732 goto userr;
733 n_comp = atoi(argv[a]+3);
734 } else
735 n_comp = 1;
736 break;
737 case 'w': /* warnings on/off */
738 warnings = !warnings;
739 break;
740 case 'c': /* force check operation */
741 check = 1;
742 break;
743 default:
744 goto userr;
745 }
746 if (a < argc-1) /* arg count OK? */
747 goto userr;
748 if (outLevels) { /* should check consistency? */
749 no_rows = outArray[0][0];
750 no_columns = outArray[0][1];
751 }
752 /* open input file? */
753 if (a == argc-1 && freopen(argv[a], "rb", stdin) == NULL) {
754 fprintf(stderr, "%s: cannot open for reading\n", argv[a]);
755 return(1);
756 } else
757 SET_FILE_BINARY(stdin);
758 SET_FILE_BINARY(stdout);
759 #ifdef getc_unlocked /* avoid stupid semaphores */
760 flockfile(stdin);
761 flockfile(stdout);
762 #endif
763 /* check for no-op */
764 if (!transpose & !check & (outLevels <= 1) & (i_header == o_header) &&
765 (no_columns == ni_columns) & (no_rows == ni_rows)) {
766 if (warnings)
767 fprintf(stderr, "%s: no-op -- copying input verbatim\n",
768 argv[0]);
769 return(!output_stream(stdin));
770 }
771 /* read input header? */
772 if (i_header && getheader(stdin, headline, NULL) < 0)
773 return(1);
774 if (!check_sizes()) /* adjust sizes */
775 return(1);
776 if (o_header) { /* add to output header? */
777 if (!i_header)
778 newheader("RADIANCE", stdout);
779 printargs(a, argv, stdout);
780 printf("NCOMP=%d\n", n_comp);
781 }
782 if (!comp_size) { /* a little late, here... */
783 SET_FILE_TEXT(stdin);
784 SET_FILE_TEXT(stdout);
785 }
786 if (transpose | (outLevels > 1) || (o_header && no_rows <= 0)) {
787 MEMLOAD myMem; /* need to map into memory */
788 if (a == argc-1) {
789 if (load_file(&myMem, stdin) <= 0) {
790 fprintf(stderr, "%s: error loading file into memory\n",
791 argv[a]);
792 return(1);
793 }
794 } else if (load_stream(&myMem, stdin) <= 0) {
795 fprintf(stderr, "%s: error loading stdin into memory\n",
796 argv[0]);
797 return(1);
798 }
799 if (!do_reorder(&myMem))
800 return(1);
801 /* free_load(&myMem); about to exit, so don't bother */
802 } else if (!do_resize(stdin)) /* just reshaping input */
803 return(1);
804 return(0);
805 userr:
806 fprintf(stderr,
807 "Usage: %s [-h[io]][-w][-c][-f[afdb][N]][-t][-ic in_col][-ir in_row][-oc out_col][-or out_row][-o RxC[xR1xC1..]] [input.dat]\n",
808 argv[0]);
809 return(1);
810 }
