root/radiance/ray/src/util/rcollate.c
Sat Dec 28 18:05:14 2019 UTC (4 years, 4 months ago) by greg
Changes since 2.34: +1 -2 lines
Diff to previous 2.34 , to selected 2.23
Fri Nov 8 22:12:33 2019 UTC (4 years, 6 months ago) by greg
Changes since 2.33: +6 -5 lines
Diff to previous 2.33 , to selected 2.23
Bug fixes in -o option
Fri Nov 8 16:36:36 2019 UTC (4 years, 6 months ago) by greg
Changes since 2.32: +17 -3 lines
Diff to previous 2.32 , to selected 2.23
Additional size checks
Fri Nov 8 05:39:05 2019 UTC (4 years, 6 months ago) by greg
Changes since 2.31: +2 -9 lines
Diff to previous 2.31 , to selected 2.23
Fixing minor issues with new -o code
Fri Nov 8 02:10:38 2019 UTC (4 years, 6 months ago) by greg
Changes since 2.30: +115 -22 lines
Diff to previous 2.30 , to selected 2.23
Added capability to rcollate for reblocking input order for tensors
Tue Feb 5 17:13:00 2019 UTC (5 years, 3 months ago) by greg
Changes since 2.29: +4 -2 lines
Diff to previous 2.29 , to selected 2.23
Added missing header opening line for -hi option
Sat Oct 20 15:02:51 2018 UTC (5 years, 7 months ago) by greg
Changes since 2.28: +10 -10 lines
Diff to previous 2.28 , to selected 2.23
Fixed issue with unmapping mapped memory
Fri Oct 19 16:53:37 2018 UTC (5 years, 7 months ago) by greg
Changes since 2.27: +9 -9 lines
Diff to previous 2.27 , to selected 2.23
Minor tweaks on last change
Thu Oct 18 22:59:48 2018 UTC (5 years, 7 months ago) by greg
Changes since 2.26: +14 -7 lines
Diff to previous 2.26 , to selected 2.23
Fixed issues with very large file i/o
Thu Aug 2 18:33:50 2018 UTC (5 years, 9 months ago) by greg
Diff to previous 2.25 , to selected 2.23
Thu Aug 18 00:52:48 2016 UTC (7 years, 9 months ago) by greg
Changes since 2.24: +3 -3 lines
Diff to previous 2.24 , to selected 2.23
Sat Apr 16 00:42:16 2016 UTC (8 years, 1 month ago) by greg
Changes since 2.23: +11 -2 lines
Diff to previous 2.23
Made memory allocation in index_records less greedy
Changes since 2.22: +9 -8 lines
Diff to previous 2.22
Fri Mar 4 00:21:21 2016 UTC (8 years, 2 months ago) by greg
Changes since 2.21: +1 -8 lines
Tue Jun 16 20:35:56 2015 UTC (8 years, 11 months ago) by greg
Fixed bug in allocation for reading from stream
Tue Jun 16 19:06:29 2015 UTC (8 years, 11 months ago) by greg
Changes since 2.19: +39 -36 lines
Work-around fix for transposing ASCII input files under Windows
Thu Sep 18 00:12:42 2014 UTC (9 years, 8 months ago) by greg
CVS Tags: rad4R2P2
Changes since 2.18: +6 -9 lines
Simplified code a bit -- no significant change in behavior expected
Fri Aug 1 18:21:04 2014 UTC (9 years, 9 months ago) by greg
CVS Tags: rad4R2P1
Fixed issue with failure to manipulate header
Thu Jul 24 16:28:17 2014 UTC (9 years, 9 months ago) by greg
CVS Tags: rad4R2
Changes since 2.16: +6 -3 lines
Made NROWS/NCOLS more consistent with resolution string
Wed Jul 9 21:45:48 2014 UTC (9 years, 10 months ago) by greg
Changes since 2.15: +12 -9 lines
Fixed redundant header output (bug)
Tue Jul 8 16:39:41 2014 UTC (9 years, 10 months ago) by greg
Removed unnecessary address operators from function ids.
Sat May 31 19:21:21 2014 UTC (9 years, 11 months ago) by greg
Changes since 2.13: +27 -26 lines
Bug fixes
Fri May 30 18:24:06 2014 UTC (9 years, 11 months ago) by greg
Fixed bug when header is being removed from input
Fri May 30 18:10:20 2014 UTC (9 years, 11 months ago) by greg
Changes since 2.11: +4 -6 lines
Fixed issue with binary data when adding or removing header
Fri May 30 17:29:28 2014 UTC (9 years, 11 months ago) by greg
Changes since 2.10: +11 -5 lines
Added check for unsupported formats
Fri May 30 16:50:43 2014 UTC (9 years, 11 months ago) by greg
Changes since 2.9: +23 -8 lines
Added -hi and -ho options to control input and output headers separately
Fri May 30 00:00:54 2014 UTC (9 years, 11 months ago) by greg
Changes since 2.8: +88 -25 lines
Fri Feb 21 13:49:00 2014 UTC (10 years, 3 months ago) by greg
Reduced number of calls to realloc() when loading from stdin
Mon Nov 18 22:02:12 2013 UTC (10 years, 6 months ago) by greg
Changes since 2.6: +7 -2 lines
More Windows fixes (someone should come up with an acrylic version of Windows)
Mon Nov 18 18:07:16 2013 UTC (10 years, 6 months ago) by greg
Changes since 2.5: +1 -2 lines
Fixes for Windows
Fri Sep 6 21:43:29 2013 UTC (10 years, 8 months ago) by greg
Changes since 2.4: +6 -5 lines
Propogate output dimensions to input dimensions before checking input data
Fri Sep 6 21:34:39 2013 UTC (10 years, 8 months ago) by greg
Changes since 2.3: +12 -6 lines
Added -w option to turn off warnings
Thu Sep 5 18:47:12 2013 UTC (10 years, 8 months ago) by greg
Added error check for too little input data
Thu Sep 5 18:30:58 2013 UTC (10 years, 8 months ago) by greg
Changes since 2.1: +2 -3 lines
Took off write ability I didn't need when mapping input file
Thu Sep 5 17:53:23 2013 UTC (10 years, 8 months ago) by greg
Diff to selected 2.23
