1 |
greg |
2.1 |
#ifndef lint |
2 |
greg |
2.11 |
static const char RCSid[] = "$Id: rcode_norm.c,v 2.10 2025/06/03 21:31:51 greg Exp $"; |
3 |
greg |
2.1 |
#endif |
4 |
5 |
* Encode and decode surface normal map using 32-bit integers |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include <stdlib.h> |
11 |
#include "platform.h" |
12 |
greg |
2.11 |
#include "paths.h" |
13 |
greg |
2.1 |
#include "rtio.h" |
14 |
#include "rtmath.h" |
15 |
#include "normcodec.h" |
16 |
17 |
18 |
/* Report usage error and exit */ |
19 |
static void |
20 |
usage_exit(int code) |
21 |
22 |
fputs("Usage: ", stderr); |
23 |
fputs(progname, stderr); |
24 |
greg |
2.6 |
fputs(" [-h[io]][-H[io]][-f[afd]][-x xr -y yr] [input [output.nrm]]\n", stderr); |
25 |
greg |
2.1 |
fputs(" Or: ", stderr); |
26 |
27 |
greg |
2.2 |
fputs(" -r [-i][-u][-h[io]][-H[io]][-f[afd]] [input.nrm [output]]\n", |
28 |
greg |
2.1 |
stderr); |
29 |
exit(code); |
30 |
31 |
32 |
33 |
/* Encode normals from input stream */ |
34 |
static int |
35 |
encode_normals(NORMCODEC *ncp) |
36 |
37 |
long nexpected = (long)ncp->res.xr * ncp->res.yr; |
38 |
39 |
if (ncp->inpfmt[0]) { |
40 |
greg |
2.7 |
if (!strcmp(ncp->inpfmt, "ascii")) |
41 |
greg |
2.1 |
ncp->format = 'a'; |
42 |
greg |
2.7 |
else if (!strcmp(ncp->inpfmt, "float")) |
43 |
greg |
2.1 |
ncp->format = 'f'; |
44 |
greg |
2.7 |
else if (!strcmp(ncp->inpfmt, "double")) |
45 |
greg |
2.1 |
ncp->format = 'd'; |
46 |
else { |
47 |
fputs(ncp->inpname, stderr); |
48 |
fputs(": unsupported input format: ", stderr); |
49 |
fputs(ncp->inpfmt, stderr); |
50 |
fputc('\n', stderr); |
51 |
return 0; |
52 |
53 |
54 |
greg |
2.8 |
if (ncp->format == 'a') |
55 |
SET_FILE_TEXT(ncp->finp); |
56 |
greg |
2.1 |
57 |
do { |
58 |
int ok = 0; |
59 |
FVECT nrm; |
60 |
61 |
switch (ncp->format) { |
62 |
case 'a': |
63 |
ok = (fscanf(ncp->finp, FVFORMAT, |
64 |
&nrm[0], &nrm[1], &nrm[2]) == 3); |
65 |
break; |
66 |
#ifdef SMLFLT |
67 |
case 'f': |
68 |
ok = (getbinary(nrm, sizeof(*nrm), 3, ncp->finp) == 3); |
69 |
greg |
2.4 |
if (ncp->swapped) |
70 |
swap32((char *)nrm, 3); |
71 |
greg |
2.1 |
break; |
72 |
case 'd': { |
73 |
greg |
2.4 |
double nrmd[3]; |
74 |
ok = (getbinary(nrmd, sizeof(*nrmd), |
75 |
76 |
if (ncp->swapped) |
77 |
swap64((char *)nrmd, 3); |
78 |
if (ok) VCOPY(nrm, nrmd); |
79 |
} break; |
80 |
greg |
2.1 |
#else |
81 |
case 'f': { |
82 |
greg |
2.4 |
float nrmf[3]; |
83 |
ok = (getbinary(nrmf, sizeof(*nrmf), |
84 |
85 |
if (ncp->swapped) |
86 |
swap32((char *)nrmf, 3); |
87 |
if (ok) VCOPY(nrm, nrmf); |
88 |
} break; |
89 |
greg |
2.1 |
case 'd': |
90 |
91 |
greg |
2.4 |
if (ncp->swapped) |
92 |
swap64((char *)nrm, 3); |
93 |
greg |
2.1 |
break; |
94 |
#endif |
95 |
96 |
if (!ok) |
97 |
break; |
98 |
99 |
normalize(nrm); |
100 |
putint(encodedir(nrm), 4, stdout); |
101 |
102 |
} while (--nexpected); |
103 |
104 |
if (nexpected > 0) { |
105 |
106 |
fputs(": fewer normals than expected\n", stderr); |
107 |
return 0; |
108 |
109 |
return 1; |
110 |
111 |
112 |
113 |
/* Output the given normal to stdout */ |
114 |
static void |
115 |
output_normal(NORMCODEC *ncp, FVECT nrm) |
116 |
117 |
118 |
case 'a': |
119 |
printf("%.9f %.9f %.9f\n", nrm[0], nrm[1], nrm[2]); |
120 |
break; |
121 |
#ifdef SMLFLT |
122 |
case 'f': |
123 |
putbinary(nrm, sizeof(*nrm), 3, stdout); |
124 |
break; |
125 |
case 'd': { |
126 |
double nrmd[3]; |
127 |
VCOPY(nrmd, nrm); |
128 |
putbinary(nrmd, sizeof(*nrmd), 3, stdout); |
129 |
130 |
break; |
131 |
#else |
132 |
case 'f': { |
133 |
float nrmf[3]; |
134 |
VCOPY(nrmf, nrm); |
135 |
putbinary(nrmf, sizeof(*nrmf), 3, stdout); |
136 |
137 |
break; |
138 |
case 'd': |
139 |
140 |
break; |
141 |
#endif |
142 |
143 |
144 |
145 |
146 |
/* Decode normals from input stream */ |
147 |
static int |
148 |
decode_normals(NORMCODEC *ncp) |
149 |
150 |
151 |
152 |
if (!check_decode_normals(ncp)) |
153 |
return 0; |
154 |
155 |
do { |
156 |
FVECT nrm; |
157 |
158 |
if (decode_normal_next(nrm, ncp) < 0) |
159 |
break; |
160 |
161 |
output_normal(ncp, nrm); |
162 |
163 |
164 |
165 |
166 |
167 |
fputs(": unexpected EOF\n", stderr); |
168 |
return 0; |
169 |
170 |
return 1; |
171 |
172 |
173 |
174 |
/* Decode normals at particular pixels given on standard input */ |
175 |
static int |
176 |
pixel_normals(NORMCODEC *ncp, int unbuf) |
177 |
178 |
int x, y; |
179 |
FVECT nrm; |
180 |
181 |
if (ncp->finp == stdin) { |
182 |
183 |
fputs(": <stdin> used for encoded normals\n", stderr); |
184 |
return 0; |
185 |
186 |
187 |
return 0; |
188 |
if (ncp->res.rt != PIXSTANDARD) { |
189 |
190 |
fputs(": can only handle standard pixel ordering\n", stderr); |
191 |
return 0; |
192 |
193 |
greg |
2.8 |
194 |
greg |
2.1 |
while (scanf("%d %d", &x, &y) == 2) { |
195 |
196 |
y = ncp->res.yr-1 - y; |
197 |
198 |
if (decode_normal_pix(nrm, ncp, x, y) < 0) |
199 |
return 0; |
200 |
201 |
202 |
203 |
if (unbuf && fflush(stdout) == EOF) { |
204 |
205 |
fputs(": write error on output\n", stderr); |
206 |
return 0; |
207 |
208 |
209 |
if (!feof(stdin)) { |
210 |
211 |
fputs(": non-integer as pixel index\n", stderr); |
212 |
return 0; |
213 |
214 |
return 1; |
215 |
216 |
217 |
218 |
int |
219 |
main(int argc, char *argv[]) |
220 |
221 |
greg |
2.5 |
int xres=0, yres=0; |
222 |
greg |
2.1 |
int reverse = 0; |
223 |
int bypixel = 0; |
224 |
int unbuffered = 0; |
225 |
NORMCODEC nc; |
226 |
int a; |
227 |
greg |
2.10 |
/* set global progname */ |
228 |
fixargv0(argv[0]); |
229 |
greg |
2.1 |
set_nc_defaults(&nc); |
230 |
nc.hdrflags = HF_ALL; |
231 |
for (a = 1; a < argc && argv[a][0] == '-'; a++) |
232 |
switch (argv[a][1]) { |
233 |
case 'r': |
234 |
reverse++; |
235 |
break; |
236 |
case 'f': |
237 |
switch (argv[a][2]) { |
238 |
case 'f': |
239 |
case 'd': |
240 |
case 'a': |
241 |
nc.format = argv[a][2]; |
242 |
break; |
243 |
default: |
244 |
245 |
fputs(": unsupported -f? format\n", stderr); |
246 |
usage_exit(1); |
247 |
248 |
break; |
249 |
case 'h': |
250 |
251 |
case '\0': |
252 |
nc.hdrflags &= ~(HF_HEADIN|HF_HEADOUT); |
253 |
break; |
254 |
case 'i': |
255 |
case 'I': |
256 |
nc.hdrflags &= ~HF_HEADIN; |
257 |
break; |
258 |
case 'o': |
259 |
case 'O': |
260 |
nc.hdrflags &= ~HF_HEADOUT; |
261 |
break; |
262 |
default: |
263 |
usage_exit(1); |
264 |
265 |
break; |
266 |
case 'H': |
267 |
268 |
case '\0': |
269 |
nc.hdrflags &= ~(HF_RESIN|HF_RESOUT); |
270 |
break; |
271 |
case 'i': |
272 |
case 'I': |
273 |
nc.hdrflags &= ~HF_RESIN; |
274 |
break; |
275 |
case 'o': |
276 |
case 'O': |
277 |
nc.hdrflags &= ~HF_RESOUT; |
278 |
break; |
279 |
default: |
280 |
usage_exit(1); |
281 |
282 |
break; |
283 |
greg |
2.5 |
case 'x': |
284 |
xres = atoi(argv[++a]); |
285 |
break; |
286 |
case 'y': |
287 |
yres = atoi(argv[++a]); |
288 |
break; |
289 |
greg |
2.1 |
case 'i': |
290 |
bypixel++; |
291 |
break; |
292 |
case 'u': |
293 |
unbuffered++; |
294 |
break; |
295 |
default: |
296 |
usage_exit(1); |
297 |
298 |
nc.hdrflags |= !reverse * HF_ENCODE; |
299 |
300 |
greg |
2.5 |
if ((xres > 0) & (yres > 0)) { |
301 |
302 |
nc.res.rt = PIXSTANDARD; |
303 |
nc.res.xr = xres; |
304 |
nc.res.yr = yres; |
305 |
} else if ((nc.hdrflags & (HF_RESIN|HF_RESOUT)) == HF_RESOUT) { |
306 |
greg |
2.1 |
307 |
fputs(": unknown resolution for output\n", stderr); |
308 |
return 1; |
309 |
310 |
if (bypixel) { |
311 |
if (!reverse) { |
312 |
313 |
fputs(": -i only supported with -r option\n", |
314 |
stderr); |
315 |
usage_exit(1); |
316 |
317 |
if (a >= argc) { |
318 |
319 |
fputs(": -i option requires input file\n", stderr); |
320 |
usage_exit(1); |
321 |
322 |
if (!(nc.hdrflags & HF_RESIN)) { |
323 |
324 |
fputs(": -i option requires input resolution\n", stderr); |
325 |
usage_exit(1); |
326 |
327 |
greg |
2.2 |
328 |
greg |
2.1 |
329 |
if (a < argc-2) { |
330 |
331 |
fputs(": too many file arguments\n", stderr); |
332 |
usage_exit(1); |
333 |
334 |
if (a < argc && !(nc.finp = fopen(nc.inpname=argv[a], "r"))) { |
335 |
fputs(nc.inpname, stderr); |
336 |
fputs(": cannot open for reading\n", stderr); |
337 |
return 1; |
338 |
339 |
if (a+1 < argc && !freopen(argv[a+1], "w", stdout)) { |
340 |
fputs(argv[a+1], stderr); |
341 |
fputs(": cannot open for writing\n", stderr); |
342 |
return 1; |
343 |
344 |
greg |
2.9 |
SET_FILE_BINARY(nc.finp); /* starting assumption */ |
345 |
greg |
2.8 |
SET_FILE_BINARY(stdout); |
346 |
greg |
2.1 |
#ifdef getc_unlocked /* avoid stupid semaphores */ |
347 |
flockfile(nc.finp); |
348 |
flockfile(stdout); |
349 |
#endif |
350 |
/* read/copy header */ |
351 |
if (!process_nc_header(&nc, a, argv)) |
352 |
return 1; |
353 |
greg |
2.8 |
354 |
if (reverse && nc.format == 'a') |
355 |
SET_FILE_TEXT(stdout); |
356 |
greg |
2.1 |
/* process data */ |
357 |
if (!reverse) { |
358 |
if (!encode_normals(&nc)) |
359 |
return 1; |
360 |
} else if (bypixel) { |
361 |
if (!pixel_normals(&nc, unbuffered)) |
362 |
return 1; |
363 |
} else if (!decode_normals(&nc)) |
364 |
return 1; |
365 |
366 |
if (fflush(stdout) == EOF) { |
367 |
368 |
fputs(": error writing output\n", stderr); |
369 |
return 1; |
370 |
371 |
return 0; |
372 |
