1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rcode_norm.c,v 2.1 2019/07/19 02:18:44 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Encode and decode surface normal map using 32-bit integers |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include <stdlib.h> |
11 |
#include "platform.h" |
12 |
#include "rtio.h" |
13 |
#include "rtmath.h" |
14 |
#include "normcodec.h" |
15 |
16 |
char *progname; /* set in main() */ |
17 |
18 |
19 |
/* Report usage error and exit */ |
20 |
static void |
21 |
usage_exit(int code) |
22 |
23 |
fputs("Usage: ", stderr); |
24 |
fputs(progname, stderr); |
25 |
fputs(" [-h[io]][-H[io]][-f[afd]] [input [output.nrm]]\n", stderr); |
26 |
fputs(" Or: ", stderr); |
27 |
28 |
fputs(" -r [-i][-u][-h[io]][-H[io]][-f[afd]] [input.nrm [output]]\n", |
29 |
stderr); |
30 |
exit(code); |
31 |
32 |
33 |
34 |
/* Encode normals from input stream */ |
35 |
static int |
36 |
encode_normals(NORMCODEC *ncp) |
37 |
38 |
long nexpected = (long)ncp->res.xr * ncp->res.yr; |
39 |
40 |
if (ncp->inpfmt[0]) { |
41 |
if (strcasestr(ncp->inpfmt, "ascii") != NULL) |
42 |
ncp->format = 'a'; |
43 |
else if (strcasestr(ncp->inpfmt, "float") != NULL) |
44 |
ncp->format = 'f'; |
45 |
else if (strcasestr(ncp->inpfmt, "double") != NULL) |
46 |
ncp->format = 'd'; |
47 |
else { |
48 |
fputs(ncp->inpname, stderr); |
49 |
fputs(": unsupported input format: ", stderr); |
50 |
fputs(ncp->inpfmt, stderr); |
51 |
fputc('\n', stderr); |
52 |
return 0; |
53 |
54 |
55 |
56 |
do { |
57 |
int ok = 0; |
58 |
FVECT nrm; |
59 |
60 |
switch (ncp->format) { |
61 |
case 'a': |
62 |
ok = (fscanf(ncp->finp, FVFORMAT, |
63 |
&nrm[0], &nrm[1], &nrm[2]) == 3); |
64 |
break; |
65 |
#ifdef SMLFLT |
66 |
case 'f': |
67 |
ok = (getbinary(nrm, sizeof(*nrm), 3, ncp->finp) == 3); |
68 |
break; |
69 |
case 'd': { |
70 |
double nrmd[3]; |
71 |
ok = (getbinary(nrmd, sizeof(*nrmd), |
72 |
73 |
if (ok) VCOPY(nrm, nrmd); |
74 |
75 |
break; |
76 |
#else |
77 |
case 'f': { |
78 |
float nrmf[3]; |
79 |
ok = (getbinary(nrmf, sizeof(*nrmf), |
80 |
81 |
if (ok) VCOPY(nrm, nrmf); |
82 |
83 |
break; |
84 |
case 'd': |
85 |
86 |
break; |
87 |
#endif |
88 |
89 |
if (!ok) |
90 |
break; |
91 |
92 |
normalize(nrm); |
93 |
putint(encodedir(nrm), 4, stdout); |
94 |
95 |
} while (--nexpected); |
96 |
97 |
if (nexpected > 0) { |
98 |
99 |
fputs(": fewer normals than expected\n", stderr); |
100 |
return 0; |
101 |
102 |
return 1; |
103 |
104 |
105 |
106 |
/* Output the given normal to stdout */ |
107 |
static void |
108 |
output_normal(NORMCODEC *ncp, FVECT nrm) |
109 |
110 |
111 |
case 'a': |
112 |
printf("%.9f %.9f %.9f\n", nrm[0], nrm[1], nrm[2]); |
113 |
break; |
114 |
#ifdef SMLFLT |
115 |
case 'f': |
116 |
putbinary(nrm, sizeof(*nrm), 3, stdout); |
117 |
break; |
118 |
case 'd': { |
119 |
double nrmd[3]; |
120 |
VCOPY(nrmd, nrm); |
121 |
putbinary(nrmd, sizeof(*nrmd), 3, stdout); |
122 |
123 |
break; |
124 |
#else |
125 |
case 'f': { |
126 |
float nrmf[3]; |
127 |
VCOPY(nrmf, nrm); |
128 |
putbinary(nrmf, sizeof(*nrmf), 3, stdout); |
129 |
130 |
break; |
131 |
case 'd': |
132 |
133 |
break; |
134 |
#endif |
135 |
136 |
137 |
138 |
139 |
/* Decode normals from input stream */ |
140 |
static int |
141 |
decode_normals(NORMCODEC *ncp) |
142 |
143 |
144 |
145 |
if (!check_decode_normals(ncp)) |
146 |
return 0; |
147 |
148 |
do { |
149 |
FVECT nrm; |
150 |
151 |
if (decode_normal_next(nrm, ncp) < 0) |
152 |
break; |
153 |
154 |
output_normal(ncp, nrm); |
155 |
156 |
157 |
158 |
159 |
160 |
fputs(": unexpected EOF\n", stderr); |
161 |
return 0; |
162 |
163 |
return 1; |
164 |
165 |
166 |
167 |
/* Decode normals at particular pixels given on standard input */ |
168 |
static int |
169 |
pixel_normals(NORMCODEC *ncp, int unbuf) |
170 |
171 |
int x, y; |
172 |
FVECT nrm; |
173 |
174 |
if (ncp->finp == stdin) { |
175 |
176 |
fputs(": <stdin> used for encoded normals\n", stderr); |
177 |
return 0; |
178 |
179 |
180 |
return 0; |
181 |
if (ncp->res.rt != PIXSTANDARD) { |
182 |
183 |
fputs(": can only handle standard pixel ordering\n", stderr); |
184 |
return 0; |
185 |
186 |
while (scanf("%d %d", &x, &y) == 2) { |
187 |
188 |
y = ncp->res.yr-1 - y; |
189 |
190 |
if (decode_normal_pix(nrm, ncp, x, y) < 0) |
191 |
return 0; |
192 |
193 |
194 |
195 |
if (unbuf && fflush(stdout) == EOF) { |
196 |
197 |
fputs(": write error on output\n", stderr); |
198 |
return 0; |
199 |
200 |
201 |
if (!feof(stdin)) { |
202 |
203 |
fputs(": non-integer as pixel index\n", stderr); |
204 |
return 0; |
205 |
206 |
return 1; |
207 |
208 |
209 |
210 |
int |
211 |
main(int argc, char *argv[]) |
212 |
213 |
int reverse = 0; |
214 |
int bypixel = 0; |
215 |
int unbuffered = 0; |
216 |
NORMCODEC nc; |
217 |
int a; |
218 |
219 |
progname = argv[0]; |
220 |
set_nc_defaults(&nc); |
221 |
nc.hdrflags = HF_ALL; |
222 |
for (a = 1; a < argc && argv[a][0] == '-'; a++) |
223 |
switch (argv[a][1]) { |
224 |
case 'r': |
225 |
reverse++; |
226 |
break; |
227 |
case 'f': |
228 |
switch (argv[a][2]) { |
229 |
case 'f': |
230 |
case 'd': |
231 |
case 'a': |
232 |
nc.format = argv[a][2]; |
233 |
break; |
234 |
default: |
235 |
236 |
fputs(": unsupported -f? format\n", stderr); |
237 |
usage_exit(1); |
238 |
239 |
break; |
240 |
case 'h': |
241 |
242 |
case '\0': |
243 |
nc.hdrflags &= ~(HF_HEADIN|HF_HEADOUT); |
244 |
break; |
245 |
case 'i': |
246 |
case 'I': |
247 |
nc.hdrflags &= ~HF_HEADIN; |
248 |
break; |
249 |
case 'o': |
250 |
case 'O': |
251 |
nc.hdrflags &= ~HF_HEADOUT; |
252 |
break; |
253 |
default: |
254 |
usage_exit(1); |
255 |
256 |
break; |
257 |
case 'H': |
258 |
259 |
case '\0': |
260 |
nc.hdrflags &= ~(HF_RESIN|HF_RESOUT); |
261 |
break; |
262 |
case 'i': |
263 |
case 'I': |
264 |
nc.hdrflags &= ~HF_RESIN; |
265 |
break; |
266 |
case 'o': |
267 |
case 'O': |
268 |
nc.hdrflags &= ~HF_RESOUT; |
269 |
break; |
270 |
default: |
271 |
usage_exit(1); |
272 |
273 |
break; |
274 |
case 'i': |
275 |
bypixel++; |
276 |
break; |
277 |
case 'u': |
278 |
unbuffered++; |
279 |
break; |
280 |
default: |
281 |
usage_exit(1); |
282 |
283 |
nc.hdrflags |= !reverse * HF_ENCODE; |
284 |
285 |
if ((nc.hdrflags & (HF_RESIN|HF_RESOUT)) == HF_RESOUT) { |
286 |
287 |
fputs(": unknown resolution for output\n", stderr); |
288 |
return 1; |
289 |
290 |
if (bypixel) { |
291 |
if (!reverse) { |
292 |
293 |
fputs(": -i only supported with -r option\n", |
294 |
stderr); |
295 |
usage_exit(1); |
296 |
297 |
if (a >= argc) { |
298 |
299 |
fputs(": -i option requires input file\n", stderr); |
300 |
usage_exit(1); |
301 |
302 |
if (!(nc.hdrflags & HF_RESIN)) { |
303 |
304 |
fputs(": -i option requires input resolution\n", stderr); |
305 |
usage_exit(1); |
306 |
307 |
308 |
309 |
if (a < argc-2) { |
310 |
311 |
fputs(": too many file arguments\n", stderr); |
312 |
usage_exit(1); |
313 |
314 |
if (a < argc && !(nc.finp = fopen(nc.inpname=argv[a], "r"))) { |
315 |
fputs(nc.inpname, stderr); |
316 |
fputs(": cannot open for reading\n", stderr); |
317 |
return 1; |
318 |
319 |
if (a+1 < argc && !freopen(argv[a+1], "w", stdout)) { |
320 |
fputs(argv[a+1], stderr); |
321 |
fputs(": cannot open for writing\n", stderr); |
322 |
return 1; |
323 |
324 |
SET_FILE_BINARY(nc.finp); |
325 |
if (reverse || nc.format != 'a') |
326 |
SET_FILE_BINARY(stdout); |
327 |
#ifdef getc_unlocked /* avoid stupid semaphores */ |
328 |
flockfile(nc.finp); |
329 |
flockfile(stdout); |
330 |
#endif |
331 |
/* read/copy header */ |
332 |
if (!process_nc_header(&nc, a, argv)) |
333 |
return 1; |
334 |
/* process data */ |
335 |
if (!reverse) { |
336 |
if (!encode_normals(&nc)) |
337 |
return 1; |
338 |
} else if (bypixel) { |
339 |
if (!pixel_normals(&nc, unbuffered)) |
340 |
return 1; |
341 |
} else if (!decode_normals(&nc)) |
342 |
return 1; |
343 |
344 |
if (fflush(stdout) == EOF) { |
345 |
346 |
fputs(": error writing output\n", stderr); |
347 |
return 1; |
348 |
349 |
return 0; |
350 |
