--- ray/src/util/rcode_norm.c 2019/07/20 02:07:23 2.2 +++ ray/src/util/rcode_norm.c 2020/07/24 16:00:10 2.9 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rcode_norm.c,v 2.2 2019/07/20 02:07:23 greg Exp $"; +static const char RCSid[] = "$Id: rcode_norm.c,v 2.9 2020/07/24 16:00:10 greg Exp $"; #endif /* * Encode and decode surface normal map using 32-bit integers @@ -22,7 +22,7 @@ usage_exit(int code) { fputs("Usage: ", stderr); fputs(progname, stderr); - fputs(" [-h[io]][-H[io]][-f[afd]] [input [output.nrm]]\n", stderr); + fputs(" [-h[io]][-H[io]][-f[afd]][-x xr -y yr] [input [output.nrm]]\n", stderr); fputs(" Or: ", stderr); fputs(progname, stderr); fputs(" -r [-i][-u][-h[io]][-H[io]][-f[afd]] [input.nrm [output]]\n", @@ -38,11 +38,11 @@ encode_normals(NORMCODEC *ncp) long nexpected = (long)ncp->res.xr * ncp->res.yr; if (ncp->inpfmt[0]) { - if (strcasestr(ncp->inpfmt, "ascii") != NULL) + if (!strcmp(ncp->inpfmt, "ascii")) ncp->format = 'a'; - else if (strcasestr(ncp->inpfmt, "float") != NULL) + else if (!strcmp(ncp->inpfmt, "float")) ncp->format = 'f'; - else if (strcasestr(ncp->inpfmt, "double") != NULL) + else if (!strcmp(ncp->inpfmt, "double")) ncp->format = 'd'; else { fputs(ncp->inpname, stderr); @@ -52,6 +52,8 @@ encode_normals(NORMCODEC *ncp) return 0; } } + if (ncp->format == 'a') + SET_FILE_TEXT(ncp->finp); do { int ok = 0; @@ -65,24 +67,30 @@ encode_normals(NORMCODEC *ncp) #ifdef SMLFLT case 'f': ok = (getbinary(nrm, sizeof(*nrm), 3, ncp->finp) == 3); + if (ncp->swapped) + swap32((char *)nrm, 3); break; case 'd': { - double nrmd[3]; - ok = (getbinary(nrmd, sizeof(*nrmd), - 3, ncp->finp) == 3); - if (ok) VCOPY(nrm, nrmd); - } - break; + double nrmd[3]; + ok = (getbinary(nrmd, sizeof(*nrmd), + 3, ncp->finp) == 3); + if (ncp->swapped) + swap64((char *)nrmd, 3); + if (ok) VCOPY(nrm, nrmd); + } break; #else case 'f': { - float nrmf[3]; - ok = (getbinary(nrmf, sizeof(*nrmf), - 3, ncp->finp) == 3); - if (ok) VCOPY(nrm, nrmf); - } - break; + float nrmf[3]; + ok = (getbinary(nrmf, sizeof(*nrmf), + 3, ncp->finp) == 3); + if (ncp->swapped) + swap32((char *)nrmf, 3); + if (ok) VCOPY(nrm, nrmf); + } break; case 'd': ok = (getbinary(nrm, sizeof(*nrm), 3, ncp->finp) == 3); + if (ncp->swapped) + swap64((char *)nrm, 3); break; #endif } @@ -183,6 +191,7 @@ pixel_normals(NORMCODEC *ncp, int unbuf) fputs(": can only handle standard pixel ordering\n", stderr); return 0; } + while (scanf("%d %d", &x, &y) == 2) { y = ncp->res.yr-1 - y; @@ -210,6 +219,7 @@ pixel_normals(NORMCODEC *ncp, int unbuf) int main(int argc, char *argv[]) { + int xres=0, yres=0; int reverse = 0; int bypixel = 0; int unbuffered = 0; @@ -271,6 +281,12 @@ main(int argc, char *argv[]) usage_exit(1); } break; + case 'x': + xres = atoi(argv[++a]); + break; + case 'y': + yres = atoi(argv[++a]); + break; case 'i': bypixel++; break; @@ -282,7 +298,12 @@ main(int argc, char *argv[]) } nc.hdrflags |= !reverse * HF_ENCODE; - if ((nc.hdrflags & (HF_RESIN|HF_RESOUT)) == HF_RESOUT) { + if ((xres > 0) & (yres > 0)) { + nc.hdrflags &= ~HF_RESIN; + nc.res.rt = PIXSTANDARD; + nc.res.xr = xres; + nc.res.yr = yres; + } else if ((nc.hdrflags & (HF_RESIN|HF_RESOUT)) == HF_RESOUT) { fputs(progname, stderr); fputs(": unknown resolution for output\n", stderr); return 1; @@ -321,9 +342,8 @@ main(int argc, char *argv[]) fputs(": cannot open for writing\n", stderr); return 1; } - SET_FILE_BINARY(nc.finp); - if (reverse || nc.format != 'a') - SET_FILE_BINARY(stdout); + SET_FILE_BINARY(nc.finp); /* starting assumption */ + SET_FILE_BINARY(stdout); #ifdef getc_unlocked /* avoid stupid semaphores */ flockfile(nc.finp); flockfile(stdout); @@ -331,6 +351,9 @@ main(int argc, char *argv[]) /* read/copy header */ if (!process_nc_header(&nc, a, argv)) return 1; + + if (reverse && nc.format == 'a') + SET_FILE_TEXT(stdout); /* process data */ if (!reverse) { if (!encode_normals(&nc))
