--- ray/src/util/rcode_norm.c 2019/07/20 02:07:23 2.2 +++ ray/src/util/rcode_norm.c 2019/08/14 21:00:14 2.4 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rcode_norm.c,v 2.2 2019/07/20 02:07:23 greg Exp $"; +static const char RCSid[] = "$Id: rcode_norm.c,v 2.4 2019/08/14 21:00:14 greg Exp $"; #endif /* * Encode and decode surface normal map using 32-bit integers @@ -38,11 +38,11 @@ encode_normals(NORMCODEC *ncp) long nexpected = (long)ncp->res.xr * ncp->res.yr; if (ncp->inpfmt[0]) { - if (strcasestr(ncp->inpfmt, "ascii") != NULL) + if (strstr(ncp->inpfmt, "ascii") != NULL) ncp->format = 'a'; - else if (strcasestr(ncp->inpfmt, "float") != NULL) + else if (strstr(ncp->inpfmt, "float") != NULL) ncp->format = 'f'; - else if (strcasestr(ncp->inpfmt, "double") != NULL) + else if (strstr(ncp->inpfmt, "double") != NULL) ncp->format = 'd'; else { fputs(ncp->inpname, stderr); @@ -65,24 +65,30 @@ encode_normals(NORMCODEC *ncp) #ifdef SMLFLT case 'f': ok = (getbinary(nrm, sizeof(*nrm), 3, ncp->finp) == 3); + if (ncp->swapped) + swap32((char *)nrm, 3); break; case 'd': { - double nrmd[3]; - ok = (getbinary(nrmd, sizeof(*nrmd), - 3, ncp->finp) == 3); - if (ok) VCOPY(nrm, nrmd); - } - break; + double nrmd[3]; + ok = (getbinary(nrmd, sizeof(*nrmd), + 3, ncp->finp) == 3); + if (ncp->swapped) + swap64((char *)nrmd, 3); + if (ok) VCOPY(nrm, nrmd); + } break; #else case 'f': { - float nrmf[3]; - ok = (getbinary(nrmf, sizeof(*nrmf), - 3, ncp->finp) == 3); - if (ok) VCOPY(nrm, nrmf); - } - break; + float nrmf[3]; + ok = (getbinary(nrmf, sizeof(*nrmf), + 3, ncp->finp) == 3); + if (ncp->swapped) + swap32((char *)nrmf, 3); + if (ok) VCOPY(nrm, nrmf); + } break; case 'd': ok = (getbinary(nrm, sizeof(*nrm), 3, ncp->finp) == 3); + if (ncp->swapped) + swap64((char *)nrm, 3); break; #endif }
