--- ray/src/util/rcode_norm.c 2019/11/13 18:17:05 2.5 +++ ray/src/util/rcode_norm.c 2025/06/07 05:09:46 2.12 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rcode_norm.c,v 2.5 2019/11/13 18:17:05 greg Exp $"; +static const char RCSid[] = "$Id: rcode_norm.c,v 2.12 2025/06/07 05:09:46 greg Exp $"; #endif /* * Encode and decode surface normal map using 32-bit integers @@ -13,16 +13,14 @@ static const char RCSid[] = "$Id: rcode_norm.c,v 2.5 2 #include "rtmath.h" #include "normcodec.h" -char *progname; /* set in main() */ - /* Report usage error and exit */ static void usage_exit(int code) { fputs("Usage: ", stderr); fputs(progname, stderr); - fputs(" [-h[io]][-H[io]][-f[afd]] [input [output.nrm]]\n", stderr); + fputs(" [-h[io]][-H[io]][-f[afd]][-x xr -y yr] [input [output.nrm]]\n", stderr); fputs(" Or: ", stderr); fputs(progname, stderr); fputs(" -r [-i][-u][-h[io]][-H[io]][-f[afd]] [input.nrm [output]]\n", @@ -38,11 +36,11 @@ encode_normals(NORMCODEC *ncp) long nexpected = (long)ncp->res.xr * ncp->res.yr; if (ncp->inpfmt[0]) { - if (strstr(ncp->inpfmt, "ascii") != NULL) + if (!strcmp(ncp->inpfmt, "ascii")) ncp->format = 'a'; - else if (strstr(ncp->inpfmt, "float") != NULL) + else if (!strcmp(ncp->inpfmt, "float")) ncp->format = 'f'; - else if (strstr(ncp->inpfmt, "double") != NULL) + else if (!strcmp(ncp->inpfmt, "double")) ncp->format = 'd'; else { fputs(ncp->inpname, stderr); @@ -52,6 +50,8 @@ encode_normals(NORMCODEC *ncp) return 0; } } + if (ncp->format == 'a') + SET_FILE_TEXT(ncp->finp); do { int ok = 0; @@ -189,6 +189,7 @@ pixel_normals(NORMCODEC *ncp, int unbuf) fputs(": can only handle standard pixel ordering\n", stderr); return 0; } + while (scanf("%d %d", &x, &y) == 2) { y = ncp->res.yr-1 - y; @@ -222,8 +223,8 @@ main(int argc, char *argv[]) int unbuffered = 0; NORMCODEC nc; int a; - - progname = argv[0]; + /* set global progname */ + fixargv0(argv[0]); set_nc_defaults(&nc); nc.hdrflags = HF_ALL; for (a = 1; a < argc && argv[a][0] == '-'; a++) @@ -339,9 +340,8 @@ main(int argc, char *argv[]) fputs(": cannot open for writing\n", stderr); return 1; } - SET_FILE_BINARY(nc.finp); - if (reverse || nc.format != 'a') - SET_FILE_BINARY(stdout); + SET_FILE_BINARY(nc.finp); /* starting assumption */ + SET_FILE_BINARY(stdout); #ifdef getc_unlocked /* avoid stupid semaphores */ flockfile(nc.finp); flockfile(stdout); @@ -349,6 +349,9 @@ main(int argc, char *argv[]) /* read/copy header */ if (!process_nc_header(&nc, a, argv)) return 1; + + if (reverse && nc.format == 'a') + SET_FILE_TEXT(stdout); /* process data */ if (!reverse) { if (!encode_normals(&nc))
