--- ray/src/util/rcode_norm.c 2019/11/13 18:20:47 2.6 +++ ray/src/util/rcode_norm.c 2025/06/04 22:34:27 2.11 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rcode_norm.c,v 2.6 2019/11/13 18:20:47 greg Exp $"; +static const char RCSid[] = "$Id: rcode_norm.c,v 2.11 2025/06/04 22:34:27 greg Exp $"; #endif /* * Encode and decode surface normal map using 32-bit integers @@ -9,13 +9,12 @@ static const char RCSid[] = "$Id: rcode_norm.c,v 2.6 2 #include #include "platform.h" +#include "paths.h" #include "rtio.h" #include "rtmath.h" #include "normcodec.h" -char *progname; /* set in main() */ - /* Report usage error and exit */ static void usage_exit(int code) @@ -38,11 +37,11 @@ encode_normals(NORMCODEC *ncp) long nexpected = (long)ncp->res.xr * ncp->res.yr; if (ncp->inpfmt[0]) { - if (strstr(ncp->inpfmt, "ascii") != NULL) + if (!strcmp(ncp->inpfmt, "ascii")) ncp->format = 'a'; - else if (strstr(ncp->inpfmt, "float") != NULL) + else if (!strcmp(ncp->inpfmt, "float")) ncp->format = 'f'; - else if (strstr(ncp->inpfmt, "double") != NULL) + else if (!strcmp(ncp->inpfmt, "double")) ncp->format = 'd'; else { fputs(ncp->inpname, stderr); @@ -52,6 +51,8 @@ encode_normals(NORMCODEC *ncp) return 0; } } + if (ncp->format == 'a') + SET_FILE_TEXT(ncp->finp); do { int ok = 0; @@ -189,6 +190,7 @@ pixel_normals(NORMCODEC *ncp, int unbuf) fputs(": can only handle standard pixel ordering\n", stderr); return 0; } + while (scanf("%d %d", &x, &y) == 2) { y = ncp->res.yr-1 - y; @@ -222,8 +224,8 @@ main(int argc, char *argv[]) int unbuffered = 0; NORMCODEC nc; int a; - - progname = argv[0]; + /* set global progname */ + fixargv0(argv[0]); set_nc_defaults(&nc); nc.hdrflags = HF_ALL; for (a = 1; a < argc && argv[a][0] == '-'; a++) @@ -339,9 +341,8 @@ main(int argc, char *argv[]) fputs(": cannot open for writing\n", stderr); return 1; } - SET_FILE_BINARY(nc.finp); - if (reverse || nc.format != 'a') - SET_FILE_BINARY(stdout); + SET_FILE_BINARY(nc.finp); /* starting assumption */ + SET_FILE_BINARY(stdout); #ifdef getc_unlocked /* avoid stupid semaphores */ flockfile(nc.finp); flockfile(stdout); @@ -349,6 +350,9 @@ main(int argc, char *argv[]) /* read/copy header */ if (!process_nc_header(&nc, a, argv)) return 1; + + if (reverse && nc.format == 'a') + SET_FILE_TEXT(stdout); /* process data */ if (!reverse) { if (!encode_normals(&nc))
