root/radiance/ray/src/util/rcode_norm.c
Sat Jun 7 05:09:46 2025 UTC (8 weeks, 2 days ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.11: +1 -2 lines
Wed Jun 4 22:34:27 2025 UTC (2 months ago) by greg
fix: Fixed reference to fixargv0()
Tue Jun 3 21:31:51 2025 UTC (2 months ago) by greg
Changes since 2.9: +3 -5 lines
Fri Jul 24 16:00:10 2020 UTC (5 years ago) by greg
CVS Tags: rad5R3, rad5R4
fix(rcode_norm): typo in change for Windows
Mon Jul 20 15:53:30 2020 UTC (5 years ago) by greg
Changes since 2.7: +9 -4 lines
fix(rcode_depth, rcode_norm): TEXT/BINARY mode was mishandled for Windows
Wed Feb 12 01:13:01 2020 UTC (5 years, 5 months ago) by greg
Simplified input type check
Wed Nov 13 18:20:47 2019 UTC (5 years, 8 months ago) by greg
Fixed usage statement corresponding to previous addition
Wed Nov 13 18:17:05 2019 UTC (5 years, 8 months ago) by greg
Changes since 2.4: +14 -2 lines
Added -x and -y options to add resolution information when not in input
Wed Aug 14 21:00:14 2019 UTC (5 years, 11 months ago) by greg
Changes since 2.3: +19 -13 lines
Added byte order to gendaymtx, rsplit, dctimestep, rcode_depth, and rcode_normal
Tue Aug 13 16:31:35 2019 UTC (5 years, 11 months ago) by greg
Windows cleaning (thanks to Nathaniel Jones for pointing out errors)
Sat Jul 20 02:07:23 2019 UTC (6 years ago) by greg
Changes since 2.1: +4 -4 lines
Created man pages for rcode_depth, rcode_ident, and rcode_norm
Fri Jul 19 02:18:44 2019 UTC (6 years ago) by greg
