root/radiance/ray/src/util/rcode_ident.c
Fri Jul 26 18:38:39 2019 UTC (4 years, 9 months ago) by greg
Added HF_STDERR to control stderr output
Fri Jul 26 17:45:23 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.7: +2 -4 lines
Switched to more standard method of detecting format line
Wed Jul 24 17:50:32 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.6: +7 -4 lines
Use separation character for ID table output
Wed Jul 24 00:25:51 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.5: +12 -12 lines
Cosmetic improvements
Wed Jul 24 00:17:22 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.4: +6 -2 lines
Removed automatic array initialization of hash table
Tue Jul 23 17:23:25 2019 UTC (4 years, 9 months ago) by greg
Fixed goof in last change
Tue Jul 23 17:20:20 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.2: +66 -13 lines
Added -l and -n options to rcode_ident
Fri Jul 19 22:57:12 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.1: +8 -3 lines
Fixed issue with -x and -y option still expecting resolution string
Fri Jul 19 22:25:03 2019 UTC (4 years, 9 months ago) by greg
Diff to selected 2.7
