--- ray/src/util/rcode_ident.c 2019/07/23 17:20:20 2.3 +++ ray/src/util/rcode_ident.c 2019/07/26 17:45:23 2.8 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rcode_ident.c,v 2.3 2019/07/23 17:20:20 greg Exp $"; +static const char RCSid[] = "$Id: rcode_ident.c,v 2.8 2019/07/26 17:45:23 greg Exp $"; #endif /* * Create or read identifier index map @@ -73,9 +73,7 @@ scan_ident(char ident[MAXIDLEN], FILE *fp) static int headline(char *s, void *p) { - extern const char FMTSTR[]; - - if (strstr(s, FMTSTR) == s) + if (isformat(s)) return 0; fputs(s, stdout); @@ -91,7 +89,7 @@ create_index(const char *fname, int hdrflags, int ndxb char **idmap; int idmlen; int nextID = 0; - LUTAB hashtab = LU_SINIT(free,NULL); + LUTAB hashtab; RESOLU rs; long n; int ndx; @@ -134,6 +132,10 @@ create_index(const char *fname, int hdrflags, int ndxb fputs(": unsupported bits/pixel\n", stderr); return 0; } + memset(&hashtab, 0, sizeof(hashtab)); + hashtab.hashf = lu_shash; + hashtab.keycmp = strcmp; + hashtab.freek = free; if (!idmap || !lu_init(&hashtab, idmlen)) goto memerr; fputc('\n', stdout); /* end of info header */ @@ -210,7 +212,7 @@ memerr: } -/* print out table IDs */ +/* print out ID table */ void print_IDs(IDMAP *idmp) { @@ -218,9 +220,12 @@ print_IDs(IDMAP *idmp) printf("============ %d IDs ============\n", idmp->nids); - for (i = 0; i < idmp->nids; i++) - puts(mapID(idmp, i)); - + for (i = 0; i < idmp->nids; i++) { + fputs(mapID(idmp, i), stdout); + putchar(sepc); + } + if (sepc != '\n') + fputc('\n', stdout); puts("============= END ============="); } @@ -230,7 +235,7 @@ int decode_select(const char *fname, int hdrflags) { IDMAP *idmp = idmap_ropen(fname, hdrflags); - int x, y; + int i, j; if (!idmp) return 0; @@ -244,25 +249,25 @@ decode_select(const char *fname, int hdrflags) idmap_close(idmp); return 0; } - while (scanf("%d %d", &x, &y) == 2) { - x = idmap_seek(idmp, x, idmp->res.yr-1 - y); - if (!x) { + while (scanf("%d %d", &i, &j) == 2) { + i = idmap_seek(idmp, i, idmp->res.yr-1 - j); + if (!i) { fputs(progname, stderr); fputs(": warning - pixel index is off map\n", stderr); continue; } - if (x > 0) - x = idmap_next_i(idmp); - if (x < 0) { + if (i > 0) + i = idmap_next_i(idmp); + if (i < 0) { fputs(fname, stderr); fputs(": read/seek error in decode_select()\n", stderr); idmap_close(idmp); return 0; } if (numeric) { - printf("%d", x); + printf("%d", i); } else { - const char *id = mapID(idmp, x); + const char *id = mapID(idmp, i); if (!id) { fputs(fname, stderr); fputs(": bad ID index in file\n", stderr); @@ -304,7 +309,7 @@ decode_all(const char *fname, int hdrflags) print_IDs(idmp); for (n = idmp->res.xr*idmp->res.yr; n-- > 0; ) { - int ndx = idmap_next_i(idmp); + const int ndx = idmap_next_i(idmp); if (ndx < 0) { fputs(fname, stderr); fputs(": unexpected EOF\n", stderr); @@ -314,7 +319,7 @@ decode_all(const char *fname, int hdrflags) if (numeric) { printf("%d", ndx); } else { - const char *id = idmap_next(idmp); + const char *id = mapID(idmp, ndx); if (!id) { fputs(fname, stderr); fputs(": bad ID index in file\n", stderr);
