root/radiance/ray/src/util/rcode_ident.c
Revision: 2.4
Committed: Tue Jul 23 17:23:25 2019 UTC (4 years, 10 months ago) by greg
Fixed goof in last change
2 static const char RCSid[] = "$Id: rcode_ident.c,v 2.3 2019/07/23 17:20:20 greg Exp $";
5 * Create or read identifier index map
6 *
7 */
8
9 #include <stdlib.h>
10 #include <ctype.h>
11 #include "rtio.h"
12 #include "platform.h"
13 #include "lookup.h"
14 #include "idmap.h"
15
16 #ifndef MAXIDLEN
17 #define MAXIDLEN 256 /* longest ID length supported */
18 #endif
19
20 #define HF_TABLOUT 0x100 /* output ID table after header */
21
22 char *progname; /* global argv[0] */
23
24 static int unbuffered = 0;
25 static int numeric = 0;
26 static int sepc = '\n';
27
28
29 /* Report usage error and exit */
30 static void
31 usage_exit(int code)
32 {
33 fputs("Usage: ", stderr);
34 fputs(progname, stderr);
35 fputs(" [-8|-16|-24][-h][-tS][-x xr -y yr] [input.txt [output.idx]]\n",
36 stderr);
37 fputs(" Or: ", stderr);
38 fputs(progname, stderr);
39 fputs(" -r [-i][-u][-h][-H][-l][-n][-tS] input.idx [output.txt]\n",
40 stderr);
41 exit(code);
42 }
43
44
45 /* read identifier from input, trimming white space on either end */
46 static int
47 scan_ident(char ident[MAXIDLEN], FILE *fp)
48 {
49 char *cp = ident;
50 int c;
51
52 while ((c = getc(fp)) != EOF) {
53 if (cp == ident && isspace(c))
54 continue;
55 if (c == sepc) {
56 while (cp > ident && isspace(cp[-1]))
57 cp--;
58 *cp = '\0';
59 return cp - ident; /* return string length */
60 }
61 if (cp - ident >= MAXIDLEN-1) {
62 fputs(progname, stderr);
63 fputs(": identifier too long in scan_ident()\n", stderr);
64 return -1;
65 }
66 *cp++ = c;
67 }
68 return -1;
69 }
70
71
72 /* elide format from header lines */
73 static int
74 headline(char *s, void *p)
75 {
76 extern const char FMTSTR[];
77
78 if (strstr(s, FMTSTR) == s)
79 return 0;
80
81 fputs(s, stdout);
82 return 1;
83 }
84
85
86 /* Create an identifier index from the given input file (stdin if NULL) */
87 int
88 create_index(const char *fname, int hdrflags, int ndxbytes, int xres, int yres)
89 {
90 FILE *fp = stdin;
91 char **idmap;
92 int idmlen;
93 int nextID = 0;
94 LUTAB hashtab = LU_SINIT(free,NULL);
95 RESOLU rs;
96 long n;
97 int ndx;
98 /* open file if not stdin */
99 if (!fname)
100 fname = "<stdin>";
101 else if (!(fp = fopen(fname, "r"))) {
102 fputs(fname, stderr);
103 fputs(": cannot open for input\n", stderr);
104 return 0;
105 }
106 #ifdef getc_unlocked /* avoid stupid semaphores */
107 flockfile(fp);
108 #endif
109 /* load/copy header */
110 if (hdrflags & HF_HEADOUT && getheader(fp, headline, NULL) < 0) {
111 fputs(fname, stderr);
112 fputs(": bad header or wrong input format\n", stderr);
113 fclose(fp);
114 return 0;
115 }
116 if (!(hdrflags & HF_HEADOUT))
117 newheader("RADIANCE", stdout);
118 /* finish & allocate ID table */
119 switch (ndxbytes) {
120 case 1:
121 fputformat(IDMAP8FMT, stdout);
122 idmap = (char **)malloc((idmlen=256)*sizeof(char *));
123 break;
124 case 2:
125 fputformat(IDMAP16FMT, stdout);
126 idmap = (char **)malloc((idmlen=4096)*sizeof(char *));
127 break;
128 case 3:
129 fputformat(IDMAP24FMT, stdout);
130 idmap = (char **)malloc((idmlen=1L<<17)*sizeof(char *));
131 break;
132 default:
133 fputs(progname, stderr);
134 fputs(": unsupported bits/pixel\n", stderr);
135 return 0;
136 }
137 if (!idmap || !lu_init(&hashtab, idmlen))
138 goto memerr;
139 fputc('\n', stdout); /* end of info header */
140
141 rs.rt = PIXSTANDARD; /* get/write map resolution */
142 if (hdrflags & HF_RESOUT) {
143 if (!fgetsresolu(&rs, fp)) {
144 fputs(fname, stderr);
145 fputs(": bad resolution string\n", stderr);
146 return 0;
147 }
148 } else if (((rs.xr = xres) <= 0) | ((rs.yr = yres) <= 0)) {
149 fputs(fname, stderr);
150 fputs(": missing/illegal resolution\n", stderr);
151 return 0;
152 }
153 fputsresolu(&rs, stdout);
154 /* read/assign/write each ID */
155 for (n = (long)rs.xr*rs.yr; n-- > 0; ) {
156 LUENT *lep;
157 char ident[MAXIDLEN];
158 int len = scan_ident(ident, fp);
159 if (len < 0) {
160 if (feof(fp)) {
161 fputs(fname, stderr);
162 fputs(": unexpected EOF\n", stderr);
163 }
164 return 0;
165 }
166 lep = lu_find(&hashtab, ident);
167 if (!lep->key) { /* new entry */
168 if (nextID >= 1<<(ndxbytes<<3)) {
169 fputs(progname, stderr);
170 fputs(
171 ": too many unique identifiers for index size\n",
172 stderr);
173 return 0;
174 }
175 if (nextID >= idmlen) { /* reallocate? */
176 idmlen += idmlen>>2; /* +25% growth */
177 idmap = (char **)realloc(idmap, idmlen);
178 if (!idmap)
179 goto memerr;
180 }
181 lep->key = (char *)malloc(len+1);
182 if (!lep->key)
183 goto memerr;
184 idmap[nextID] = strcpy(lep->key, ident);
185 lep->data = (char *)nextID++;
186 }
187 /* write this id index */
188 putint((int)lep->data, ndxbytes, stdout);
189 }
190 while ((ndx = getc(fp)) != EOF) /* verify we got them all */
191 if (!isspace(ndx)) {
192 fputs(fname, stderr);
193 fputs(": warning - non-white characters past end\n",
194 stderr);
195 break;
196 }
197 if (fp != stdin) /* done with input */
198 fclose(fp);
199 for (ndx = 0; ndx < nextID; ndx++) { /* append string table */
200 fputs(idmap[ndx], stdout);
201 putchar('\0'); /* nul-terminated IDs */
202 }
203 free(idmap); /* clean up */
204 lu_done(&hashtab);
205 return 1;
206 memerr:
207 fputs(progname, stderr);
208 fputs(": out of memory!\n", stderr);
209 return 0;
210 }
211
212
213 /* print out table IDs */
214 void
215 print_IDs(IDMAP *idmp)
216 {
217 int i;
218
219 printf("============ %d IDs ============\n", idmp->nids);
220
221 for (i = 0; i < idmp->nids; i++)
222 puts(mapID(idmp, i));
223
224 puts("============= END =============");
225 }
226
227
228 /* Load selected pixels from identifier index file */
229 int
230 decode_select(const char *fname, int hdrflags)
231 {
232 IDMAP *idmp = idmap_ropen(fname, hdrflags);
233 int x, y;
234
235 if (!idmp)
236 return 0;
237
238 if (hdrflags & HF_TABLOUT)
239 print_IDs(idmp);
240
241 if (idmp->res.rt != PIXSTANDARD) {
242 fputs(progname, stderr);
243 fputs(": can only handle standard pixel ordering\n", stderr);
244 idmap_close(idmp);
245 return 0;
246 }
247 while (scanf("%d %d", &x, &y) == 2) {
248 x = idmap_seek(idmp, x, idmp->res.yr-1 - y);
249 if (!x) {
250 fputs(progname, stderr);
251 fputs(": warning - pixel index is off map\n", stderr);
252 continue;
253 }
254 if (x > 0)
255 x = idmap_next_i(idmp);
256 if (x < 0) {
257 fputs(fname, stderr);
258 fputs(": read/seek error in decode_select()\n", stderr);
259 idmap_close(idmp);
260 return 0;
261 }
262 if (numeric) {
263 printf("%d", x);
264 } else {
265 const char *id = mapID(idmp, x);
266 if (!id) {
267 fputs(fname, stderr);
268 fputs(": bad ID index in file\n", stderr);
269 idmap_close(idmp);
270 return 0;
271 }
272 fputs(id, stdout);
273 }
274 putchar(sepc);
275 if (unbuffered && fflush(stdout) == EOF) {
276 fputs(progname, stderr);
277 fputs(": write error on output\n", stderr);
278 idmap_close(idmp);
279 return 0;
280 }
281 }
282 idmap_close(idmp);
283
284 if (!feof(stdin)) {
285 fputs(progname, stderr);
286 fputs(": non-numeric input for pixel index\n", stderr);
287 return 0;
288 }
289 return 1;
290 }
291
292
293 /* Load and convert identifier index file to ASCII */
294 int
295 decode_all(const char *fname, int hdrflags)
296 {
297 IDMAP *idmp = idmap_ropen(fname, hdrflags);
298 long n;
299
300 if (!idmp)
301 return 0;
302
303 if (hdrflags & HF_TABLOUT)
304 print_IDs(idmp);
305
306 for (n = idmp->res.xr*idmp->res.yr; n-- > 0; ) {
307 int ndx = idmap_next_i(idmp);
308 if (ndx < 0) {
309 fputs(fname, stderr);
310 fputs(": unexpected EOF\n", stderr);
311 idmap_close(idmp);
312 return 0;
313 }
314 if (numeric) {
315 printf("%d", ndx);
316 } else {
317 const char *id = mapID(idmp, ndx);
318 if (!id) {
319 fputs(fname, stderr);
320 fputs(": bad ID index in file\n", stderr);
321 idmap_close(idmp);
322 return 0;
323 }
324 fputs(id, stdout);
325 }
326 putchar(sepc);
327 }
328 idmap_close(idmp);
329 return 1;
330 }
331
332
333 int
334 main(int argc, char *argv[])
335 {
336 char *inpfname = NULL;
337 int reverse = 0;
338 int bypixel = 0;
339 int hdrflags = HF_HEADOUT|HF_RESOUT;
340 int xres=0, yres=0;
341 int ndxbytes = 2;
342 int a;
343
344 progname = argv[0];
345 for (a = 1; a < argc && argv[a][0] == '-'; a++)
346 switch (argv[a][1]) {
347 case 'r':
348 reverse++;
349 break;
350 case 'i':
351 bypixel++;
352 break;
353 case 'u':
354 unbuffered++;
355 break;
356 case 'n':
357 numeric++;
358 break;
359 case 'l':
360 hdrflags |= HF_TABLOUT;
361 break;
362 case 'h':
363 hdrflags &= ~HF_HEADOUT;
364 break;
365 case 'H':
366 hdrflags &= ~HF_RESOUT;
367 break;
368 case 't':
369 if (!(sepc = argv[a][2]))
370 sepc = '\n';
371 break;
372 case 'x':
373 xres = atoi(argv[++a]);
374 break;
375 case 'y':
376 yres = atoi(argv[++a]);
377 break;
378 case '8':
379 case '1':
380 case '2':
381 switch (atoi(argv[a]+1)) {
382 case 8:
383 ndxbytes = 1;
384 break;
385 case 16:
386 ndxbytes = 2;
387 break;
388 case 24:
389 ndxbytes = 3;
390 break;
391 default:
392 usage_exit(1);
393 }
394 break;
395 default:
396 usage_exit(1);
397 }
398 if ((xres > 0) & (yres > 0)) /* user specified resolution? */
399 hdrflags &= ~HF_RESOUT;
400 if (reverse && a >= argc) {
401 fputs(progname, stderr);
402 fputs(": -r option requires named input file\n", stderr);
403 return 1;
404 }
405 if (a < argc-2) {
406 fputs(progname, stderr);
407 fputs(": too many file arguments\n", stderr);
408 return 1;
409 }
410 if (a < argc)
411 inpfname = argv[a];
412 if (a+1 < argc && !freopen(argv[a+1], "w", stdout)) {
413 fputs(argv[a+1], stderr);
414 fputs(": cannot open output\n", stderr);
415 return 1;
416 }
417 if (!reverse)
418 SET_FILE_BINARY(stdout);
419 #ifdef getc_unlocked /* avoid stupid semaphores */
420 flockfile(stdout);
421 #endif
422 if (reverse) {
423 if (!(bypixel ? decode_select(inpfname, hdrflags) :
424 decode_all(inpfname, hdrflags)))
425 return 1;
426 } else if (!create_index(inpfname, hdrflags, ndxbytes, xres, yres))
427 return 1;
428
429 if (fflush(stdout) == EOF) {
430 fputs(progname, stderr);
431 fputs(": error writing output\n", stderr);
432 return 1;
433 }
434 return 0;
435 }
