--- ray/src/util/rcode_depth.c 2019/07/20 02:07:23 2.4 +++ ray/src/util/rcode_depth.c 2025/06/03 21:31:51 2.13 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rcode_depth.c,v 2.4 2019/07/20 02:07:23 greg Exp $"; +static const char RCSid[] = "$Id: rcode_depth.c,v 2.13 2025/06/03 21:31:51 greg Exp $"; #endif /* * Encode and decode depth map using 16-bit integers @@ -15,8 +15,6 @@ static const char RCSid[] = "$Id: rcode_depth.c,v 2.4 #include "fvect.h" #include "depthcodec.h" -char *progname; /* set in main() */ - enum {CV_FWD, CV_REV, CV_PTS}; @@ -27,7 +25,7 @@ usage_exit(int code) fputs("Usage: ", stderr); fputs(progname, stderr); fputs( - " [-d ref_depth/unit][-h[io]][-H[io]][-f[afd]] [input [output.dpt]]\n", + " [-d ref_depth/unit][-h[io]][-H[io]][-f[afd]][-x xr -y yr] [input [output.dpt]]\n", stderr); fputs(" Or: ", stderr); fputs(progname, stderr); @@ -45,11 +43,11 @@ encode_depths(DEPTHCODEC *dcp) long nexpected = (long)dcp->res.xr * dcp->res.yr; if (dcp->inpfmt[0]) { - if (strcasestr(dcp->inpfmt, "ascii") != NULL) + if (!strcmp(dcp->inpfmt, "ascii")) dcp->format = 'a'; - else if (strcasestr(dcp->inpfmt, "float") != NULL) + else if (!strcmp(dcp->inpfmt, "float")) dcp->format = 'f'; - else if (strcasestr(dcp->inpfmt, "double") != NULL) + else if (!strcmp(dcp->inpfmt, "double")) dcp->format = 'd'; else { fputs(dcp->inpname, stderr); @@ -59,6 +57,8 @@ encode_depths(DEPTHCODEC *dcp) return 0; } } + if (dcp->format == 'a') + SET_FILE_TEXT(dcp->finp); do { int ok = 0; @@ -71,10 +71,14 @@ encode_depths(DEPTHCODEC *dcp) break; case 'f': ok = (getbinary(&f, sizeof(f), 1, dcp->finp) == 1); + if (dcp->swapped) + swap32((char *)&f, 1); d = f; break; case 'd': ok = (getbinary(&d, sizeof(d), 1, dcp->finp) == 1); + if (dcp->swapped) + swap64((char *)&d, 1); break; } if (!ok) @@ -156,16 +160,12 @@ pixel_depths(DEPTHCODEC *dcp, int unbuf) return 0; while (scanf("%d %d", &xy[0], &xy[1]) == 2) { - - loc2pix(xy, &dcp->res, - (xy[0]+.5)/dcp->res.xr, (xy[1]+.5)/dcp->res.yr); - + loc2pix(xy, &dcp->res, xy[0]/(double)dcp->res.xr, + xy[1]/(double)dcp->res.yr); d = decode_depth_pix(dcp, xy[0], xy[1]); if (d < -FTINY) return 0; - output_depth(dcp, d); - if (unbuf && fflush(stdout) == EOF) { fputs(progname, stderr); fputs(": write error on output\n", stderr); @@ -252,10 +252,10 @@ pixel_points(DEPTHCODEC *dcp, int unbuf) } if (!check_decode_worldpos(dcp)) return 0; - + while (scanf("%d %d", &xy[0], &xy[1]) == 2) { - loc2pix(xy, &dcp->res, - (xy[0]+.5)/dcp->res.xr, (xy[1]+.5)/dcp->res.yr); + loc2pix(xy, &dcp->res, xy[0]/(double)dcp->res.xr, + xy[1]/(double)dcp->res.yr); if (get_worldpos_pix(wpos, dcp, xy[0], xy[1]) < 0) return 0; output_worldpos(dcp, wpos); @@ -277,13 +277,14 @@ pixel_points(DEPTHCODEC *dcp, int unbuf) int main(int argc, char *argv[]) { + int xres=0, yres=0; int conversion = CV_FWD; int bypixel = 0; int unbuffered = 0; DEPTHCODEC dc; int a; - - progname = argv[0]; + /* set global progname */ + fixargv0(argv[0]); set_dc_defaults(&dc); dc.hdrflags = HF_ALL; for (a = 1; a < argc && argv[a][0] == '-'; a++) @@ -350,6 +351,12 @@ main(int argc, char *argv[]) usage_exit(1); } break; + case 'x': + xres = atoi(argv[++a]); + break; + case 'y': + yres = atoi(argv[++a]); + break; case 'i': bypixel++; break; @@ -361,7 +368,12 @@ main(int argc, char *argv[]) } dc.hdrflags |= (conversion == CV_FWD) * HF_ENCODE; - if ((dc.hdrflags & (HF_RESIN|HF_RESOUT)) == HF_RESOUT) { + if ((xres > 0) & (yres > 0)) { + dc.hdrflags &= ~HF_RESIN; + dc.res.rt = PIXSTANDARD; + dc.res.xr = xres; + dc.res.yr = yres; + } else if ((dc.hdrflags & (HF_RESIN|HF_RESOUT)) == HF_RESOUT) { fputs(progname, stderr); fputs(": unknown resolution for output\n", stderr); return 1; @@ -400,9 +412,8 @@ main(int argc, char *argv[]) fputs(": cannot open for writing\n", stderr); return 1; } - SET_FILE_BINARY(dc.finp); - if ((conversion != CV_FWD) | (dc.format != 'a')) - SET_FILE_BINARY(stdout); + SET_FILE_BINARY(dc.finp); /* starting assumption */ + SET_FILE_BINARY(stdout); #ifdef getc_unlocked /* avoid stupid semaphores */ flockfile(dc.finp); flockfile(stdout); @@ -410,9 +421,17 @@ main(int argc, char *argv[]) /* read/copy header */ if (!process_dc_header(&dc, a, argv)) return 1; + + if ((conversion != CV_FWD) & (dc.format == 'a')) + SET_FILE_TEXT(stdout); /* process data */ switch (conversion) { case CV_FWD: /* distance -> depth code */ + if (!strcmp(dc.depth_unit, "1")) { + fputs(progname, stderr); + fputs(": warning - using reference depth of 1.0\n", + stderr); + } if (!encode_depths(&dc)) return 1; break;
