--- ray/src/util/rcode_depth.c 2020/02/12 01:13:01 2.10 +++ ray/src/util/rcode_depth.c 2020/07/20 15:53:30 2.11 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rcode_depth.c,v 2.10 2020/02/12 01:13:01 greg Exp $"; +static const char RCSid[] = "$Id: rcode_depth.c,v 2.11 2020/07/20 15:53:30 greg Exp $"; #endif /* * Encode and decode depth map using 16-bit integers @@ -59,6 +59,8 @@ encode_depths(DEPTHCODEC *dcp) return 0; } } + if (dcp->format == 'a') + SET_FILE_TEXT(dcp->finp); do { int ok = 0; @@ -256,7 +258,7 @@ pixel_points(DEPTHCODEC *dcp, int unbuf) } if (!check_decode_worldpos(dcp)) return 0; - + while (scanf("%d %d", &xy[0], &xy[1]) == 2) { loc2pix(xy, &dcp->res, (xy[0]+.5)/dcp->res.xr, (xy[1]+.5)/dcp->res.yr); @@ -416,9 +418,8 @@ main(int argc, char *argv[]) fputs(": cannot open for writing\n", stderr); return 1; } - SET_FILE_BINARY(dc.finp); - if ((conversion != CV_FWD) | (dc.format != 'a')) - SET_FILE_BINARY(stdout); + SET_FILE_BINARY(dc.finp); /* starting assumption */ + SET_FILE_BINARY(stdout); #ifdef getc_unlocked /* avoid stupid semaphores */ flockfile(dc.finp); flockfile(stdout); @@ -426,6 +427,9 @@ main(int argc, char *argv[]) /* read/copy header */ if (!process_dc_header(&dc, a, argv)) return 1; + + if ((conversion != CV_FWD) & (dc.format == 'a')) + SET_FILE_TEXT(stdout); /* process data */ switch (conversion) { case CV_FWD: /* distance -> depth code */
