1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rcode_depth.c,v 2.1 2019/07/18 18:51:56 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Encode and decode depth values using 16-bit integers |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include <stdlib.h> |
11 |
#include <math.h> |
12 |
#include <ctype.h> |
13 |
#include "platform.h" |
14 |
#include "rtio.h" |
15 |
#include "fvect.h" |
16 |
#include "depthcodec.h" |
17 |
18 |
enum {CV_FWD, CV_REV, CV_PTS}; |
19 |
20 |
21 |
/* Report usage error and exit */ |
22 |
static void |
23 |
usage_exit(int code) |
24 |
25 |
fputs("Usage: ", stderr); |
26 |
fputs(progname, stderr); |
27 |
fputs( |
28 |
" [-d ref_depth/unit][-h[io]][-H[io]][-f[afd]] [input [output]]\n", |
29 |
stderr); |
30 |
fputs(" Or: ", stderr); |
31 |
32 |
fputs( |
33 |
" {-r|-p} [-i][-u][-h[io]][-H[io]][-f[afd]] [input [output]]\n", |
34 |
stderr); |
35 |
exit(code); |
36 |
37 |
38 |
39 |
/* Encode depths from input stream */ |
40 |
static int |
41 |
encode_depths(DEPTHCODEC *dcp) |
42 |
43 |
long nexpected = 0; |
44 |
45 |
if (dcp->inpfmt[0]) { |
46 |
if (strcasestr(dcp->inpfmt, "ascii") != NULL) |
47 |
dcp->format = 'a'; |
48 |
else if (strcasestr(dcp->inpfmt, "float") != NULL) |
49 |
dcp->format = 'f'; |
50 |
else if (strcasestr(dcp->inpfmt, "double") != NULL) |
51 |
dcp->format = 'd'; |
52 |
else { |
53 |
fputs(dcp->inpname, stderr); |
54 |
fputs(": unsupported input format: ", stderr); |
55 |
fputs(dcp->inpfmt, stderr); |
56 |
fputc('\n', stderr); |
57 |
return 0; |
58 |
59 |
60 |
if (dcp->hdrflags & HF_RESIN) |
61 |
nexpected = (long)dcp->res.xr * dcp->res.yr; |
62 |
do { |
63 |
int ok = 0; |
64 |
float f; |
65 |
double d; |
66 |
67 |
switch (dcp->format) { |
68 |
case 'a': |
69 |
ok = (fscanf(dcp->finp, "%lf", &d) == 1); |
70 |
break; |
71 |
case 'f': |
72 |
ok = (getbinary(&f, sizeof(f), 1, dcp->finp) == 1); |
73 |
d = f; |
74 |
break; |
75 |
case 'd': |
76 |
ok = (getbinary(&d, sizeof(d), 1, dcp->finp) == 1); |
77 |
break; |
78 |
79 |
if (!ok) |
80 |
break; |
81 |
putint(depth2code(d, dcp->refdepth), 2, stdout); |
82 |
} while (--nexpected); |
83 |
84 |
if (nexpected > 0) { |
85 |
86 |
fputs(": fewer depths than expected\n", stderr); |
87 |
return 0; |
88 |
89 |
return 1; |
90 |
91 |
92 |
93 |
/* Convert and output the given depth code to stdout */ |
94 |
static void |
95 |
output_depth(DEPTHCODEC *dcp, double d) |
96 |
97 |
float f; |
98 |
99 |
100 |
case 'a': |
101 |
printf("%.5e\n", d); |
102 |
break; |
103 |
case 'f': |
104 |
f = d; |
105 |
putbinary(&f, sizeof(f), 1, stdout); |
106 |
break; |
107 |
case 'd': |
108 |
putbinary(&d, sizeof(d), 1, stdout); |
109 |
break; |
110 |
111 |
112 |
113 |
114 |
/* Decode depths from input stream */ |
115 |
static int |
116 |
decode_depths(DEPTHCODEC *dcp) |
117 |
118 |
119 |
120 |
if (!check_decode_depths(dcp)) |
121 |
return 0; |
122 |
123 |
124 |
125 |
do { |
126 |
double d = decode_depth_next(dcp); |
127 |
if (d < -FTINY) |
128 |
break; |
129 |
output_depth(dcp, d); |
130 |
131 |
132 |
133 |
134 |
135 |
fputs(": unexpected EOF\n", stderr); |
136 |
return 0; |
137 |
138 |
return 1; |
139 |
140 |
141 |
142 |
/* Decode depths at particular pixels given on standard input */ |
143 |
static int |
144 |
pixel_depths(DEPTHCODEC *dcp, int unbuf) |
145 |
146 |
int xy[2]; |
147 |
double d; |
148 |
149 |
if (dcp->finp == stdin) { |
150 |
151 |
fputs(": <stdin> used for encoded depths\n", stderr); |
152 |
return 0; |
153 |
154 |
155 |
return 0; |
156 |
157 |
while (scanf("%d %d", &xy[0], &xy[1]) == 2) { |
158 |
loc2pix(xy, &dcp->res, |
159 |
(xy[0]+.5)/dcp->res.xr, (xy[1]+.5)/dcp->res.yr); |
160 |
d = decode_depth_pix(dcp, xy[0], xy[1]); |
161 |
if (d < -FTINY) |
162 |
return 0; |
163 |
164 |
if (unbuf && fflush(stdout) == EOF) { |
165 |
166 |
fputs(": write error on output\n", stderr); |
167 |
return 0; |
168 |
169 |
170 |
if (!feof(stdin)) { |
171 |
172 |
fputs(": non-integer as pixel index\n", stderr); |
173 |
return 0; |
174 |
175 |
return 1; |
176 |
177 |
178 |
179 |
/* Output the given world position */ |
180 |
static void |
181 |
output_worldpos(DEPTHCODEC *dcp, FVECT wpos) |
182 |
183 |
184 |
case 'a': |
185 |
fprintf(stdout, "%.5e %.5e %.5e\n", |
186 |
wpos[0], wpos[1], wpos[2]); |
187 |
break; |
188 |
#ifdef SMLFLT |
189 |
case 'f': |
190 |
putbinary(wpos, sizeof(*wpos), 3, stdout); |
191 |
break; |
192 |
case 'd': { |
193 |
double wpd[3]; |
194 |
VCOPY(wpd, wpos); |
195 |
putbinary(wpd, sizeof(*wpd), 3, stdout); |
196 |
197 |
break; |
198 |
#else |
199 |
case 'f': { |
200 |
float wpf[3]; |
201 |
VCOPY(wpf, wpos); |
202 |
putbinary(wpf, sizeof(*wpf), 3, stdout); |
203 |
204 |
break; |
205 |
case 'd': |
206 |
207 |
break; |
208 |
#endif |
209 |
210 |
211 |
212 |
213 |
/* Decode world points from input stream */ |
214 |
static int |
215 |
decode_points(DEPTHCODEC *dcp) |
216 |
217 |
long n = (long)dcp->res.xr * dcp->res.yr; |
218 |
219 |
if (!check_decode_worldpos(dcp)) |
220 |
return 0; |
221 |
222 |
while (n-- > 0) { |
223 |
FVECT wpos; |
224 |
if (decode_worldpos_next(wpos, dcp) < 0) { |
225 |
if (feof(dcp->finp)) { |
226 |
227 |
228 |
229 |
return 0; |
230 |
231 |
output_worldpos(dcp, wpos); |
232 |
233 |
return 1; |
234 |
235 |
236 |
237 |
/* Decode world points at particular pixels given on standard input */ |
238 |
static int |
239 |
pixel_points(DEPTHCODEC *dcp, int unbuf) |
240 |
241 |
int xy[2]; |
242 |
FVECT wpos; |
243 |
244 |
245 |
246 |
247 |
return 0; |
248 |
249 |
250 |
return 0; |
251 |
252 |
253 |
254 |
255 |
if (get_worldpos_pix(wpos, dcp, xy[0], xy[1]) < 0) |
256 |
return 0; |
257 |
258 |
259 |
260 |
261 |
return 0; |
262 |
263 |
264 |
265 |
266 |
267 |
return 0; |
268 |
269 |
return 1; |
270 |
271 |
272 |
273 |
int |
274 |
main(int argc, char *argv[]) |
275 |
276 |
int conversion = CV_FWD; |
277 |
int bypixel = 0; |
278 |
int unbuffered = 0; |
279 |
DEPTHCODEC dc; |
280 |
int a; |
281 |
282 |
progname = argv[0]; |
283 |
set_dc_defaults(&dc); |
284 |
dc.hdrflags = HF_ALL; |
285 |
for (a = 1; a < argc && argv[a][0] == '-'; a++) |
286 |
switch (argv[a][1]) { |
287 |
case 'd': |
288 |
strlcpy(dc.depth_unit, argv[++a], sizeof(dc.depth_unit)); |
289 |
dc.refdepth = atof(dc.depth_unit); |
290 |
if (dc.refdepth <= .0) { |
291 |
292 |
fputs(": illegal -d reference depth\n", stderr); |
293 |
return 1; |
294 |
295 |
break; |
296 |
case 'r': |
297 |
conversion = CV_REV; |
298 |
break; |
299 |
case 'p': |
300 |
conversion = CV_PTS; |
301 |
break; |
302 |
case 'f': |
303 |
switch (argv[a][2]) { |
304 |
case 'f': |
305 |
case 'd': |
306 |
case 'a': |
307 |
dc.format = argv[a][2]; |
308 |
break; |
309 |
default: |
310 |
311 |
fputs(": unsupported -f? format\n", stderr); |
312 |
usage_exit(1); |
313 |
314 |
break; |
315 |
case 'h': |
316 |
317 |
case '\0': |
318 |
dc.hdrflags &= ~(HF_HEADIN|HF_HEADOUT); |
319 |
break; |
320 |
case 'i': |
321 |
case 'I': |
322 |
dc.hdrflags &= ~HF_HEADIN; |
323 |
break; |
324 |
case 'o': |
325 |
case 'O': |
326 |
dc.hdrflags &= ~HF_HEADOUT; |
327 |
break; |
328 |
default: |
329 |
usage_exit(1); |
330 |
331 |
break; |
332 |
case 'H': |
333 |
334 |
case '\0': |
335 |
dc.hdrflags &= ~(HF_RESIN|HF_RESOUT); |
336 |
break; |
337 |
case 'i': |
338 |
case 'I': |
339 |
dc.hdrflags &= ~HF_RESIN; |
340 |
break; |
341 |
case 'o': |
342 |
case 'O': |
343 |
dc.hdrflags &= ~HF_RESOUT; |
344 |
break; |
345 |
default: |
346 |
usage_exit(1); |
347 |
348 |
break; |
349 |
case 'i': |
350 |
bypixel++; |
351 |
break; |
352 |
case 'u': |
353 |
unbuffered++; |
354 |
break; |
355 |
default: |
356 |
usage_exit(1); |
357 |
358 |
dc.hdrflags |= (conversion == CV_FWD) * HF_ENCODE; |
359 |
360 |
if ((dc.hdrflags & (HF_RESIN|HF_RESOUT)) == HF_RESOUT) { |
361 |
362 |
fputs(": unknown resolution for output\n", stderr); |
363 |
return 1; |
364 |
365 |
if (bypixel) { |
366 |
if (conversion == CV_FWD) { |
367 |
368 |
fputs(": -i only supported with -r or -p option\n", |
369 |
stderr); |
370 |
usage_exit(1); |
371 |
372 |
if (a >= argc) { |
373 |
374 |
fputs(": -i option requires input file\n", stderr); |
375 |
usage_exit(1); |
376 |
377 |
if (!(dc.hdrflags & HF_RESIN)) { |
378 |
379 |
fputs(": -i option requires input resolution\n", stderr); |
380 |
usage_exit(1); |
381 |
382 |
dc.hdrflags &= ~(HF_HEADOUT|HF_RESOUT); |
383 |
384 |
if (a < argc-2) { |
385 |
386 |
fputs(": too many file arguments\n", stderr); |
387 |
usage_exit(1); |
388 |
389 |
if (a < argc && !(dc.finp = fopen(dc.inpname=argv[a], "r"))) { |
390 |
fputs(dc.inpname, stderr); |
391 |
fputs(": cannot open for reading\n", stderr); |
392 |
return 1; |
393 |
394 |
if (a+1 < argc && !freopen(argv[a+1], "w", stdout)) { |
395 |
fputs(argv[a+1], stderr); |
396 |
fputs(": cannot open for writing\n", stderr); |
397 |
return 1; |
398 |
399 |
SET_FILE_BINARY(dc.finp); |
400 |
SET_FILE_BINARY(stdout); |
401 |
#ifdef getc_unlocked /* avoid stupid semaphores */ |
402 |
flockfile(dc.finp); |
403 |
flockfile(stdout); |
404 |
#endif |
405 |
/* read/copy header */ |
406 |
if (!process_dc_header(&dc, a, argv)) |
407 |
return 1; |
408 |
/* process data */ |
409 |
switch (conversion) { |
410 |
case CV_FWD: /* distance -> depth code */ |
411 |
if (!encode_depths(&dc)) |
412 |
return 1; |
413 |
break; |
414 |
case CV_REV: /* depth code -> distance */ |
415 |
if (!(bypixel ? pixel_depths(&dc, unbuffered) : |
416 |
decode_depths(&dc))) |
417 |
return 1; |
418 |
break; |
419 |
case CV_PTS: /* depth code -> world points */ |
420 |
if (!(bypixel ? pixel_points(&dc, unbuffered) : |
421 |
decode_points(&dc))) |
422 |
return 1; |
423 |
break; |
424 |
425 |
if (fflush(stdout) == EOF) { |
426 |
427 |
fputs(": error writing output\n", stderr); |
428 |
return 1; |
429 |
430 |
return 0; |
431 |
