root/radiance/ray/src/util/rcode_depth.c
Revision 2.13 - (view) (download) (annotate) - [selected]
Tue Jun 3 21:31:51 2025 UTC (5 weeks, 3 days ago) by greg
Changes since 2.12: +3 -5 lines
Diff to previous 2.12
Thu Jun 30 00:16:49 2022 UTC (3 years ago) by greg
Changes since 2.11: +5 -9 lines
fix(rcode_depth): Pixels with -i option were off by 1
Mon Jul 20 15:53:30 2020 UTC (4 years, 11 months ago) by greg
Changes since 2.10: +9 -5 lines
fix(rcode_depth, rcode_norm): TEXT/BINARY mode was mishandled for Windows
Wed Feb 12 01:13:01 2020 UTC (5 years, 4 months ago) by greg
Simplified input type check
Tue Feb 11 18:15:23 2020 UTC (5 years, 5 months ago) by greg
Changes since 2.8: +6 -1 lines
Added warning about default reference depth on forward conversion
Wed Nov 13 18:20:47 2019 UTC (5 years, 7 months ago) by greg
Fixed usage statement corresponding to previous addition
Wed Nov 13 18:17:05 2019 UTC (5 years, 7 months ago) by greg
Changes since 2.6: +14 -2 lines
Added -x and -y options to add resolution information when not in input
Wed Aug 14 21:00:14 2019 UTC (5 years, 10 months ago) by greg
Changes since 2.5: +5 -1 lines
Added byte order to gendaymtx, rsplit, dctimestep, rcode_depth, and rcode_normal
Tue Aug 13 16:31:35 2019 UTC (5 years, 10 months ago) by greg
Changes since 2.4: +4 -4 lines
Windows cleaning (thanks to Nathaniel Jones for pointing out errors)
Sat Jul 20 02:07:23 2019 UTC (5 years, 11 months ago) by greg
Changes since 2.3: +4 -4 lines
Created man pages for rcode_depth, rcode_ident, and rcode_norm
Fri Jul 19 01:24:33 2019 UTC (5 years, 11 months ago) by greg
Changes since 2.2: +19 -14 lines
Minor fixes
Thu Jul 18 19:13:44 2019 UTC (5 years, 11 months ago) by greg
Following convention of leaving file names off in header command line detail
Thu Jul 18 18:51:56 2019 UTC (5 years, 11 months ago) by greg
Diff to selected 2.13
