| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rcode_depth.c,v 2.4 2019/07/20 02:07:23 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Encode and decode depth map using 16-bit integers
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include <stdlib.h>
| 11 |
#include <math.h>
| 12 |
#include <ctype.h>
| 13 |
#include "platform.h"
| 14 |
#include "rtio.h"
| 15 |
#include "fvect.h"
| 16 |
#include "depthcodec.h"
| 17 |
| 18 |
char *progname; /* set in main() */
| 19 |
| 20 |
enum {CV_FWD, CV_REV, CV_PTS};
| 21 |
| 22 |
| 23 |
/* Report usage error and exit */
| 24 |
static void
| 25 |
usage_exit(int code)
| 26 |
| 27 |
fputs("Usage: ", stderr);
| 28 |
fputs(progname, stderr);
| 29 |
fputs(
| 30 |
" [-d ref_depth/unit][-h[io]][-H[io]][-f[afd]] [input [output.dpt]]\n",
| 31 |
stderr);
| 32 |
fputs(" Or: ", stderr);
| 33 |
| 34 |
fputs(
| 35 |
" {-r|-p} [-i][-u][-h[io]][-H[io]][-f[afd]] [input.dpt [output]]\n",
| 36 |
stderr);
| 37 |
exit(code);
| 38 |
| 39 |
| 40 |
| 41 |
/* Encode depths from input stream */
| 42 |
static int
| 43 |
encode_depths(DEPTHCODEC *dcp)
| 44 |
| 45 |
long nexpected = (long)dcp->res.xr * dcp->res.yr;
| 46 |
| 47 |
if (dcp->inpfmt[0]) {
| 48 |
if (strstr(dcp->inpfmt, "ascii") != NULL)
| 49 |
dcp->format = 'a';
| 50 |
else if (strstr(dcp->inpfmt, "float") != NULL)
| 51 |
dcp->format = 'f';
| 52 |
else if (strstr(dcp->inpfmt, "double") != NULL)
| 53 |
dcp->format = 'd';
| 54 |
else {
| 55 |
fputs(dcp->inpname, stderr);
| 56 |
fputs(": unsupported input format: ", stderr);
| 57 |
fputs(dcp->inpfmt, stderr);
| 58 |
fputc('\n', stderr);
| 59 |
return 0;
| 60 |
| 61 |
| 62 |
| 63 |
do {
| 64 |
int ok = 0;
| 65 |
float f;
| 66 |
double d;
| 67 |
| 68 |
switch (dcp->format) {
| 69 |
case 'a':
| 70 |
ok = (fscanf(dcp->finp, "%lf", &d) == 1);
| 71 |
break;
| 72 |
case 'f':
| 73 |
ok = (getbinary(&f, sizeof(f), 1, dcp->finp) == 1);
| 74 |
d = f;
| 75 |
break;
| 76 |
case 'd':
| 77 |
ok = (getbinary(&d, sizeof(d), 1, dcp->finp) == 1);
| 78 |
break;
| 79 |
| 80 |
if (!ok)
| 81 |
break;
| 82 |
| 83 |
putint(depth2code(d, dcp->refdepth), 2, stdout);
| 84 |
| 85 |
} while (--nexpected);
| 86 |
| 87 |
if (nexpected > 0) {
| 88 |
| 89 |
fputs(": fewer depths than expected\n", stderr);
| 90 |
return 0;
| 91 |
| 92 |
return 1;
| 93 |
| 94 |
| 95 |
| 96 |
/* Convert and output the given depth to stdout */
| 97 |
static void
| 98 |
output_depth(DEPTHCODEC *dcp, double d)
| 99 |
| 100 |
float f;
| 101 |
| 102 |
| 103 |
case 'a':
| 104 |
printf("%.5e\n", d);
| 105 |
break;
| 106 |
case 'f':
| 107 |
f = d;
| 108 |
putbinary(&f, sizeof(f), 1, stdout);
| 109 |
break;
| 110 |
case 'd':
| 111 |
putbinary(&d, sizeof(d), 1, stdout);
| 112 |
break;
| 113 |
| 114 |
| 115 |
| 116 |
| 117 |
/* Decode depths from input stream */
| 118 |
static int
| 119 |
decode_depths(DEPTHCODEC *dcp)
| 120 |
| 121 |
| 122 |
| 123 |
if (!check_decode_depths(dcp))
| 124 |
return 0;
| 125 |
| 126 |
do {
| 127 |
double d = decode_depth_next(dcp);
| 128 |
if (d < -FTINY)
| 129 |
break;
| 130 |
output_depth(dcp, d);
| 131 |
| 132 |
| 133 |
| 134 |
| 135 |
| 136 |
fputs(": unexpected EOF\n", stderr);
| 137 |
return 0;
| 138 |
| 139 |
return 1;
| 140 |
| 141 |
| 142 |
| 143 |
/* Decode depths at particular pixels given on standard input */
| 144 |
static int
| 145 |
pixel_depths(DEPTHCODEC *dcp, int unbuf)
| 146 |
| 147 |
int xy[2];
| 148 |
double d;
| 149 |
| 150 |
if (dcp->finp == stdin) {
| 151 |
| 152 |
fputs(": <stdin> used for encoded depths\n", stderr);
| 153 |
return 0;
| 154 |
| 155 |
| 156 |
return 0;
| 157 |
| 158 |
while (scanf("%d %d", &xy[0], &xy[1]) == 2) {
| 159 |
| 160 |
loc2pix(xy, &dcp->res,
| 161 |
(xy[0]+.5)/dcp->res.xr, (xy[1]+.5)/dcp->res.yr);
| 162 |
| 163 |
d = decode_depth_pix(dcp, xy[0], xy[1]);
| 164 |
if (d < -FTINY)
| 165 |
return 0;
| 166 |
| 167 |
| 168 |
| 169 |
if (unbuf && fflush(stdout) == EOF) {
| 170 |
| 171 |
fputs(": write error on output\n", stderr);
| 172 |
return 0;
| 173 |
| 174 |
| 175 |
if (!feof(stdin)) {
| 176 |
| 177 |
fputs(": non-integer as pixel index\n", stderr);
| 178 |
return 0;
| 179 |
| 180 |
return 1;
| 181 |
| 182 |
| 183 |
| 184 |
/* Output the given world position to stdout */
| 185 |
static void
| 186 |
output_worldpos(DEPTHCODEC *dcp, FVECT wpos)
| 187 |
| 188 |
| 189 |
case 'a':
| 190 |
printf("%.5e %.5e %.5e\n", wpos[0], wpos[1], wpos[2]);
| 191 |
break;
| 192 |
#ifdef SMLFLT
| 193 |
case 'f':
| 194 |
putbinary(wpos, sizeof(*wpos), 3, stdout);
| 195 |
break;
| 196 |
case 'd': {
| 197 |
double wpd[3];
| 198 |
VCOPY(wpd, wpos);
| 199 |
putbinary(wpd, sizeof(*wpd), 3, stdout);
| 200 |
| 201 |
break;
| 202 |
#else
| 203 |
case 'f': {
| 204 |
float wpf[3];
| 205 |
VCOPY(wpf, wpos);
| 206 |
putbinary(wpf, sizeof(*wpf), 3, stdout);
| 207 |
| 208 |
break;
| 209 |
case 'd':
| 210 |
| 211 |
break;
| 212 |
#endif
| 213 |
| 214 |
| 215 |
| 216 |
| 217 |
/* Decode world points from input stream */
| 218 |
static int
| 219 |
decode_points(DEPTHCODEC *dcp)
| 220 |
| 221 |
long n = (long)dcp->res.xr * dcp->res.yr;
| 222 |
| 223 |
if (!check_decode_worldpos(dcp))
| 224 |
return 0;
| 225 |
| 226 |
while (n-- > 0) {
| 227 |
FVECT wpos;
| 228 |
if (decode_worldpos_next(wpos, dcp) < 0) {
| 229 |
if (feof(dcp->finp)) {
| 230 |
| 231 |
| 232 |
| 233 |
return 0;
| 234 |
| 235 |
output_worldpos(dcp, wpos);
| 236 |
| 237 |
return 1;
| 238 |
| 239 |
| 240 |
| 241 |
/* Decode world points at particular pixels given on standard input */
| 242 |
static int
| 243 |
pixel_points(DEPTHCODEC *dcp, int unbuf)
| 244 |
| 245 |
int xy[2];
| 246 |
FVECT wpos;
| 247 |
| 248 |
| 249 |
| 250 |
| 251 |
return 0;
| 252 |
| 253 |
| 254 |
return 0;
| 255 |
| 256 |
| 257 |
| 258 |
| 259 |
if (get_worldpos_pix(wpos, dcp, xy[0], xy[1]) < 0)
| 260 |
return 0;
| 261 |
| 262 |
| 263 |
| 264 |
| 265 |
return 0;
| 266 |
| 267 |
| 268 |
if (!feof(stdin)) {
| 269 |
| 270 |
| 271 |
return 0;
| 272 |
| 273 |
return 1;
| 274 |
| 275 |
| 276 |
| 277 |
int
| 278 |
main(int argc, char *argv[])
| 279 |
| 280 |
int conversion = CV_FWD;
| 281 |
int bypixel = 0;
| 282 |
int unbuffered = 0;
| 283 |
DEPTHCODEC dc;
| 284 |
int a;
| 285 |
| 286 |
progname = argv[0];
| 287 |
set_dc_defaults(&dc);
| 288 |
dc.hdrflags = HF_ALL;
| 289 |
for (a = 1; a < argc && argv[a][0] == '-'; a++)
| 290 |
switch (argv[a][1]) {
| 291 |
case 'd':
| 292 |
strlcpy(dc.depth_unit, argv[++a], sizeof(dc.depth_unit));
| 293 |
dc.refdepth = atof(dc.depth_unit);
| 294 |
if (dc.refdepth <= .0) {
| 295 |
| 296 |
fputs(": illegal -d reference depth\n", stderr);
| 297 |
return 1;
| 298 |
| 299 |
break;
| 300 |
case 'r':
| 301 |
conversion = CV_REV;
| 302 |
break;
| 303 |
case 'p':
| 304 |
conversion = CV_PTS;
| 305 |
break;
| 306 |
case 'f':
| 307 |
switch (argv[a][2]) {
| 308 |
case 'f':
| 309 |
case 'd':
| 310 |
case 'a':
| 311 |
dc.format = argv[a][2];
| 312 |
break;
| 313 |
default:
| 314 |
| 315 |
fputs(": unsupported -f? format\n", stderr);
| 316 |
usage_exit(1);
| 317 |
| 318 |
break;
| 319 |
case 'h':
| 320 |
| 321 |
case '\0':
| 322 |
dc.hdrflags &= ~(HF_HEADIN|HF_HEADOUT);
| 323 |
break;
| 324 |
case 'i':
| 325 |
case 'I':
| 326 |
dc.hdrflags &= ~HF_HEADIN;
| 327 |
break;
| 328 |
case 'o':
| 329 |
case 'O':
| 330 |
dc.hdrflags &= ~HF_HEADOUT;
| 331 |
break;
| 332 |
default:
| 333 |
usage_exit(1);
| 334 |
| 335 |
break;
| 336 |
case 'H':
| 337 |
| 338 |
case '\0':
| 339 |
dc.hdrflags &= ~(HF_RESIN|HF_RESOUT);
| 340 |
break;
| 341 |
case 'i':
| 342 |
case 'I':
| 343 |
dc.hdrflags &= ~HF_RESIN;
| 344 |
break;
| 345 |
case 'o':
| 346 |
case 'O':
| 347 |
dc.hdrflags &= ~HF_RESOUT;
| 348 |
break;
| 349 |
default:
| 350 |
usage_exit(1);
| 351 |
| 352 |
break;
| 353 |
case 'i':
| 354 |
bypixel++;
| 355 |
break;
| 356 |
case 'u':
| 357 |
unbuffered++;
| 358 |
break;
| 359 |
default:
| 360 |
usage_exit(1);
| 361 |
| 362 |
dc.hdrflags |= (conversion == CV_FWD) * HF_ENCODE;
| 363 |
| 364 |
if ((dc.hdrflags & (HF_RESIN|HF_RESOUT)) == HF_RESOUT) {
| 365 |
| 366 |
fputs(": unknown resolution for output\n", stderr);
| 367 |
return 1;
| 368 |
| 369 |
if (bypixel) {
| 370 |
if (conversion == CV_FWD) {
| 371 |
| 372 |
fputs(": -i only supported with -r or -p option\n",
| 373 |
stderr);
| 374 |
usage_exit(1);
| 375 |
| 376 |
if (a >= argc) {
| 377 |
| 378 |
fputs(": -i option requires input file\n", stderr);
| 379 |
usage_exit(1);
| 380 |
| 381 |
if (!(dc.hdrflags & HF_RESIN)) {
| 382 |
| 383 |
fputs(": -i option requires input resolution\n", stderr);
| 384 |
usage_exit(1);
| 385 |
| 386 |
| 387 |
| 388 |
if (a < argc-2) {
| 389 |
| 390 |
fputs(": too many file arguments\n", stderr);
| 391 |
usage_exit(1);
| 392 |
| 393 |
if (a < argc && !(dc.finp = fopen(dc.inpname=argv[a], "r"))) {
| 394 |
fputs(dc.inpname, stderr);
| 395 |
fputs(": cannot open for reading\n", stderr);
| 396 |
return 1;
| 397 |
| 398 |
if (a+1 < argc && !freopen(argv[a+1], "w", stdout)) {
| 399 |
fputs(argv[a+1], stderr);
| 400 |
fputs(": cannot open for writing\n", stderr);
| 401 |
return 1;
| 402 |
| 403 |
SET_FILE_BINARY(dc.finp);
| 404 |
if ((conversion != CV_FWD) | (dc.format != 'a'))
| 405 |
SET_FILE_BINARY(stdout);
| 406 |
#ifdef getc_unlocked /* avoid stupid semaphores */
| 407 |
flockfile(dc.finp);
| 408 |
flockfile(stdout);
| 409 |
#endif
| 410 |
/* read/copy header */
| 411 |
if (!process_dc_header(&dc, a, argv))
| 412 |
return 1;
| 413 |
/* process data */
| 414 |
switch (conversion) {
| 415 |
case CV_FWD: /* distance -> depth code */
| 416 |
if (!encode_depths(&dc))
| 417 |
return 1;
| 418 |
break;
| 419 |
case CV_REV: /* depth code -> distance */
| 420 |
if (!(bypixel ? pixel_depths(&dc, unbuffered) :
| 421 |
decode_depths(&dc)))
| 422 |
return 1;
| 423 |
break;
| 424 |
case CV_PTS: /* depth code -> world points */
| 425 |
if (!(bypixel ? pixel_points(&dc, unbuffered) :
| 426 |
decode_points(&dc)))
| 427 |
return 1;
| 428 |
break;
| 429 |
| 430 |
if (fflush(stdout) == EOF) {
| 431 |
| 432 |
fputs(": error writing output\n", stderr);
| 433 |
return 1;
| 434 |
| 435 |
return 0;
| 436 |
