--- ray/src/util/rcode_depth.c 2019/11/13 18:17:05 2.7 +++ ray/src/util/rcode_depth.c 2020/07/20 15:53:30 2.11 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rcode_depth.c,v 2.7 2019/11/13 18:17:05 greg Exp $"; +static const char RCSid[] = "$Id: rcode_depth.c,v 2.11 2020/07/20 15:53:30 greg Exp $"; #endif /* * Encode and decode depth map using 16-bit integers @@ -27,7 +27,7 @@ usage_exit(int code) fputs("Usage: ", stderr); fputs(progname, stderr); fputs( - " [-d ref_depth/unit][-h[io]][-H[io]][-f[afd]] [input [output.dpt]]\n", + " [-d ref_depth/unit][-h[io]][-H[io]][-f[afd]][-x xr -y yr] [input [output.dpt]]\n", stderr); fputs(" Or: ", stderr); fputs(progname, stderr); @@ -45,11 +45,11 @@ encode_depths(DEPTHCODEC *dcp) long nexpected = (long)dcp->res.xr * dcp->res.yr; if (dcp->inpfmt[0]) { - if (strstr(dcp->inpfmt, "ascii") != NULL) + if (!strcmp(dcp->inpfmt, "ascii")) dcp->format = 'a'; - else if (strstr(dcp->inpfmt, "float") != NULL) + else if (!strcmp(dcp->inpfmt, "float")) dcp->format = 'f'; - else if (strstr(dcp->inpfmt, "double") != NULL) + else if (!strcmp(dcp->inpfmt, "double")) dcp->format = 'd'; else { fputs(dcp->inpname, stderr); @@ -59,6 +59,8 @@ encode_depths(DEPTHCODEC *dcp) return 0; } } + if (dcp->format == 'a') + SET_FILE_TEXT(dcp->finp); do { int ok = 0; @@ -256,7 +258,7 @@ pixel_points(DEPTHCODEC *dcp, int unbuf) } if (!check_decode_worldpos(dcp)) return 0; - + while (scanf("%d %d", &xy[0], &xy[1]) == 2) { loc2pix(xy, &dcp->res, (xy[0]+.5)/dcp->res.xr, (xy[1]+.5)/dcp->res.yr); @@ -416,9 +418,8 @@ main(int argc, char *argv[]) fputs(": cannot open for writing\n", stderr); return 1; } - SET_FILE_BINARY(dc.finp); - if ((conversion != CV_FWD) | (dc.format != 'a')) - SET_FILE_BINARY(stdout); + SET_FILE_BINARY(dc.finp); /* starting assumption */ + SET_FILE_BINARY(stdout); #ifdef getc_unlocked /* avoid stupid semaphores */ flockfile(dc.finp); flockfile(stdout); @@ -426,9 +427,17 @@ main(int argc, char *argv[]) /* read/copy header */ if (!process_dc_header(&dc, a, argv)) return 1; + + if ((conversion != CV_FWD) & (dc.format == 'a')) + SET_FILE_TEXT(stdout); /* process data */ switch (conversion) { case CV_FWD: /* distance -> depth code */ + if (!strcmp(dc.depth_unit, "1")) { + fputs(progname, stderr); + fputs(": warning - using reference depth of 1.0\n", + stderr); + } if (!encode_depths(&dc)) return 1; break;
