--- ray/src/util/rcode_depth.c 2019/08/13 16:31:35 2.5 +++ ray/src/util/rcode_depth.c 2019/11/13 18:17:05 2.7 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rcode_depth.c,v 2.5 2019/08/13 16:31:35 greg Exp $"; +static const char RCSid[] = "$Id: rcode_depth.c,v 2.7 2019/11/13 18:17:05 greg Exp $"; #endif /* * Encode and decode depth map using 16-bit integers @@ -71,10 +71,14 @@ encode_depths(DEPTHCODEC *dcp) break; case 'f': ok = (getbinary(&f, sizeof(f), 1, dcp->finp) == 1); + if (dcp->swapped) + swap32((char *)&f, 1); d = f; break; case 'd': ok = (getbinary(&d, sizeof(d), 1, dcp->finp) == 1); + if (dcp->swapped) + swap64((char *)&d, 1); break; } if (!ok) @@ -277,6 +281,7 @@ pixel_points(DEPTHCODEC *dcp, int unbuf) int main(int argc, char *argv[]) { + int xres=0, yres=0; int conversion = CV_FWD; int bypixel = 0; int unbuffered = 0; @@ -350,6 +355,12 @@ main(int argc, char *argv[]) usage_exit(1); } break; + case 'x': + xres = atoi(argv[++a]); + break; + case 'y': + yres = atoi(argv[++a]); + break; case 'i': bypixel++; break; @@ -361,7 +372,12 @@ main(int argc, char *argv[]) } dc.hdrflags |= (conversion == CV_FWD) * HF_ENCODE; - if ((dc.hdrflags & (HF_RESIN|HF_RESOUT)) == HF_RESOUT) { + if ((xres > 0) & (yres > 0)) { + dc.hdrflags &= ~HF_RESIN; + dc.res.rt = PIXSTANDARD; + dc.res.xr = xres; + dc.res.yr = yres; + } else if ((dc.hdrflags & (HF_RESIN|HF_RESOUT)) == HF_RESOUT) { fputs(progname, stderr); fputs(": unknown resolution for output\n", stderr); return 1;
