1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rcode_depth.c,v 2.11 2020/07/20 15:53:30 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Encode and decode depth map using 16-bit integers |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include <stdlib.h> |
11 |
#include <math.h> |
12 |
#include <ctype.h> |
13 |
#include "platform.h" |
14 |
#include "rtio.h" |
15 |
#include "fvect.h" |
16 |
#include "depthcodec.h" |
17 |
18 |
char *progname; /* set in main() */ |
19 |
20 |
enum {CV_FWD, CV_REV, CV_PTS}; |
21 |
22 |
23 |
/* Report usage error and exit */ |
24 |
static void |
25 |
usage_exit(int code) |
26 |
27 |
fputs("Usage: ", stderr); |
28 |
fputs(progname, stderr); |
29 |
fputs( |
30 |
" [-d ref_depth/unit][-h[io]][-H[io]][-f[afd]][-x xr -y yr] [input [output.dpt]]\n", |
31 |
stderr); |
32 |
fputs(" Or: ", stderr); |
33 |
34 |
fputs( |
35 |
" {-r|-p} [-i][-u][-h[io]][-H[io]][-f[afd]] [input.dpt [output]]\n", |
36 |
stderr); |
37 |
exit(code); |
38 |
39 |
40 |
41 |
/* Encode depths from input stream */ |
42 |
static int |
43 |
encode_depths(DEPTHCODEC *dcp) |
44 |
45 |
long nexpected = (long)dcp->res.xr * dcp->res.yr; |
46 |
47 |
if (dcp->inpfmt[0]) { |
48 |
if (!strcmp(dcp->inpfmt, "ascii")) |
49 |
dcp->format = 'a'; |
50 |
else if (!strcmp(dcp->inpfmt, "float")) |
51 |
dcp->format = 'f'; |
52 |
else if (!strcmp(dcp->inpfmt, "double")) |
53 |
dcp->format = 'd'; |
54 |
else { |
55 |
fputs(dcp->inpname, stderr); |
56 |
fputs(": unsupported input format: ", stderr); |
57 |
fputs(dcp->inpfmt, stderr); |
58 |
fputc('\n', stderr); |
59 |
return 0; |
60 |
61 |
62 |
if (dcp->format == 'a') |
63 |
SET_FILE_TEXT(dcp->finp); |
64 |
65 |
do { |
66 |
int ok = 0; |
67 |
float f; |
68 |
double d; |
69 |
70 |
switch (dcp->format) { |
71 |
case 'a': |
72 |
ok = (fscanf(dcp->finp, "%lf", &d) == 1); |
73 |
break; |
74 |
case 'f': |
75 |
ok = (getbinary(&f, sizeof(f), 1, dcp->finp) == 1); |
76 |
if (dcp->swapped) |
77 |
swap32((char *)&f, 1); |
78 |
d = f; |
79 |
break; |
80 |
case 'd': |
81 |
ok = (getbinary(&d, sizeof(d), 1, dcp->finp) == 1); |
82 |
if (dcp->swapped) |
83 |
swap64((char *)&d, 1); |
84 |
break; |
85 |
86 |
if (!ok) |
87 |
break; |
88 |
89 |
putint(depth2code(d, dcp->refdepth), 2, stdout); |
90 |
91 |
} while (--nexpected); |
92 |
93 |
if (nexpected > 0) { |
94 |
95 |
fputs(": fewer depths than expected\n", stderr); |
96 |
return 0; |
97 |
98 |
return 1; |
99 |
100 |
101 |
102 |
/* Convert and output the given depth to stdout */ |
103 |
static void |
104 |
output_depth(DEPTHCODEC *dcp, double d) |
105 |
106 |
float f; |
107 |
108 |
109 |
case 'a': |
110 |
printf("%.5e\n", d); |
111 |
break; |
112 |
case 'f': |
113 |
f = d; |
114 |
putbinary(&f, sizeof(f), 1, stdout); |
115 |
break; |
116 |
case 'd': |
117 |
putbinary(&d, sizeof(d), 1, stdout); |
118 |
break; |
119 |
120 |
121 |
122 |
123 |
/* Decode depths from input stream */ |
124 |
static int |
125 |
decode_depths(DEPTHCODEC *dcp) |
126 |
127 |
128 |
129 |
if (!check_decode_depths(dcp)) |
130 |
return 0; |
131 |
132 |
do { |
133 |
double d = decode_depth_next(dcp); |
134 |
if (d < -FTINY) |
135 |
break; |
136 |
output_depth(dcp, d); |
137 |
138 |
139 |
140 |
141 |
142 |
fputs(": unexpected EOF\n", stderr); |
143 |
return 0; |
144 |
145 |
return 1; |
146 |
147 |
148 |
149 |
/* Decode depths at particular pixels given on standard input */ |
150 |
static int |
151 |
pixel_depths(DEPTHCODEC *dcp, int unbuf) |
152 |
153 |
int xy[2]; |
154 |
double d; |
155 |
156 |
if (dcp->finp == stdin) { |
157 |
158 |
fputs(": <stdin> used for encoded depths\n", stderr); |
159 |
return 0; |
160 |
161 |
162 |
return 0; |
163 |
164 |
while (scanf("%d %d", &xy[0], &xy[1]) == 2) { |
165 |
loc2pix(xy, &dcp->res, xy[0]/(double)dcp->res.xr, |
166 |
xy[1]/(double)dcp->res.yr); |
167 |
d = decode_depth_pix(dcp, xy[0], xy[1]); |
168 |
if (d < -FTINY) |
169 |
return 0; |
170 |
171 |
if (unbuf && fflush(stdout) == EOF) { |
172 |
173 |
fputs(": write error on output\n", stderr); |
174 |
return 0; |
175 |
176 |
177 |
if (!feof(stdin)) { |
178 |
179 |
fputs(": non-integer as pixel index\n", stderr); |
180 |
return 0; |
181 |
182 |
return 1; |
183 |
184 |
185 |
186 |
/* Output the given world position to stdout */ |
187 |
static void |
188 |
output_worldpos(DEPTHCODEC *dcp, FVECT wpos) |
189 |
190 |
191 |
case 'a': |
192 |
printf("%.5e %.5e %.5e\n", wpos[0], wpos[1], wpos[2]); |
193 |
break; |
194 |
#ifdef SMLFLT |
195 |
case 'f': |
196 |
putbinary(wpos, sizeof(*wpos), 3, stdout); |
197 |
break; |
198 |
case 'd': { |
199 |
double wpd[3]; |
200 |
VCOPY(wpd, wpos); |
201 |
putbinary(wpd, sizeof(*wpd), 3, stdout); |
202 |
203 |
break; |
204 |
#else |
205 |
case 'f': { |
206 |
float wpf[3]; |
207 |
VCOPY(wpf, wpos); |
208 |
putbinary(wpf, sizeof(*wpf), 3, stdout); |
209 |
210 |
break; |
211 |
case 'd': |
212 |
213 |
break; |
214 |
#endif |
215 |
216 |
217 |
218 |
219 |
/* Decode world points from input stream */ |
220 |
static int |
221 |
decode_points(DEPTHCODEC *dcp) |
222 |
223 |
long n = (long)dcp->res.xr * dcp->res.yr; |
224 |
225 |
if (!check_decode_worldpos(dcp)) |
226 |
return 0; |
227 |
228 |
while (n-- > 0) { |
229 |
FVECT wpos; |
230 |
if (decode_worldpos_next(wpos, dcp) < 0) { |
231 |
if (feof(dcp->finp)) { |
232 |
233 |
234 |
235 |
return 0; |
236 |
237 |
output_worldpos(dcp, wpos); |
238 |
239 |
return 1; |
240 |
241 |
242 |
243 |
/* Decode world points at particular pixels given on standard input */ |
244 |
static int |
245 |
pixel_points(DEPTHCODEC *dcp, int unbuf) |
246 |
247 |
int xy[2]; |
248 |
FVECT wpos; |
249 |
250 |
251 |
252 |
253 |
return 0; |
254 |
255 |
256 |
return 0; |
257 |
258 |
259 |
260 |
261 |
if (get_worldpos_pix(wpos, dcp, xy[0], xy[1]) < 0) |
262 |
return 0; |
263 |
264 |
265 |
266 |
267 |
return 0; |
268 |
269 |
270 |
271 |
272 |
273 |
return 0; |
274 |
275 |
return 1; |
276 |
277 |
278 |
279 |
int |
280 |
main(int argc, char *argv[]) |
281 |
282 |
int xres=0, yres=0; |
283 |
int conversion = CV_FWD; |
284 |
int bypixel = 0; |
285 |
int unbuffered = 0; |
286 |
DEPTHCODEC dc; |
287 |
int a; |
288 |
289 |
progname = argv[0]; |
290 |
set_dc_defaults(&dc); |
291 |
dc.hdrflags = HF_ALL; |
292 |
for (a = 1; a < argc && argv[a][0] == '-'; a++) |
293 |
switch (argv[a][1]) { |
294 |
case 'd': |
295 |
strlcpy(dc.depth_unit, argv[++a], sizeof(dc.depth_unit)); |
296 |
dc.refdepth = atof(dc.depth_unit); |
297 |
if (dc.refdepth <= .0) { |
298 |
299 |
fputs(": illegal -d reference depth\n", stderr); |
300 |
return 1; |
301 |
302 |
break; |
303 |
case 'r': |
304 |
conversion = CV_REV; |
305 |
break; |
306 |
case 'p': |
307 |
conversion = CV_PTS; |
308 |
break; |
309 |
case 'f': |
310 |
switch (argv[a][2]) { |
311 |
case 'f': |
312 |
case 'd': |
313 |
case 'a': |
314 |
dc.format = argv[a][2]; |
315 |
break; |
316 |
default: |
317 |
318 |
fputs(": unsupported -f? format\n", stderr); |
319 |
usage_exit(1); |
320 |
321 |
break; |
322 |
case 'h': |
323 |
324 |
case '\0': |
325 |
dc.hdrflags &= ~(HF_HEADIN|HF_HEADOUT); |
326 |
break; |
327 |
case 'i': |
328 |
case 'I': |
329 |
dc.hdrflags &= ~HF_HEADIN; |
330 |
break; |
331 |
case 'o': |
332 |
case 'O': |
333 |
dc.hdrflags &= ~HF_HEADOUT; |
334 |
break; |
335 |
default: |
336 |
usage_exit(1); |
337 |
338 |
break; |
339 |
case 'H': |
340 |
341 |
case '\0': |
342 |
dc.hdrflags &= ~(HF_RESIN|HF_RESOUT); |
343 |
break; |
344 |
case 'i': |
345 |
case 'I': |
346 |
dc.hdrflags &= ~HF_RESIN; |
347 |
break; |
348 |
case 'o': |
349 |
case 'O': |
350 |
dc.hdrflags &= ~HF_RESOUT; |
351 |
break; |
352 |
default: |
353 |
usage_exit(1); |
354 |
355 |
break; |
356 |
case 'x': |
357 |
xres = atoi(argv[++a]); |
358 |
break; |
359 |
case 'y': |
360 |
yres = atoi(argv[++a]); |
361 |
break; |
362 |
case 'i': |
363 |
bypixel++; |
364 |
break; |
365 |
case 'u': |
366 |
unbuffered++; |
367 |
break; |
368 |
default: |
369 |
usage_exit(1); |
370 |
371 |
dc.hdrflags |= (conversion == CV_FWD) * HF_ENCODE; |
372 |
373 |
if ((xres > 0) & (yres > 0)) { |
374 |
375 |
dc.res.rt = PIXSTANDARD; |
376 |
dc.res.xr = xres; |
377 |
dc.res.yr = yres; |
378 |
} else if ((dc.hdrflags & (HF_RESIN|HF_RESOUT)) == HF_RESOUT) { |
379 |
380 |
fputs(": unknown resolution for output\n", stderr); |
381 |
return 1; |
382 |
383 |
if (bypixel) { |
384 |
if (conversion == CV_FWD) { |
385 |
386 |
fputs(": -i only supported with -r or -p option\n", |
387 |
stderr); |
388 |
usage_exit(1); |
389 |
390 |
if (a >= argc) { |
391 |
392 |
fputs(": -i option requires input file\n", stderr); |
393 |
usage_exit(1); |
394 |
395 |
if (!(dc.hdrflags & HF_RESIN)) { |
396 |
397 |
fputs(": -i option requires input resolution\n", stderr); |
398 |
usage_exit(1); |
399 |
400 |
401 |
402 |
if (a < argc-2) { |
403 |
404 |
fputs(": too many file arguments\n", stderr); |
405 |
usage_exit(1); |
406 |
407 |
if (a < argc && !(dc.finp = fopen(dc.inpname=argv[a], "r"))) { |
408 |
fputs(dc.inpname, stderr); |
409 |
fputs(": cannot open for reading\n", stderr); |
410 |
return 1; |
411 |
412 |
if (a+1 < argc && !freopen(argv[a+1], "w", stdout)) { |
413 |
fputs(argv[a+1], stderr); |
414 |
fputs(": cannot open for writing\n", stderr); |
415 |
return 1; |
416 |
417 |
SET_FILE_BINARY(dc.finp); /* starting assumption */ |
418 |
SET_FILE_BINARY(stdout); |
419 |
#ifdef getc_unlocked /* avoid stupid semaphores */ |
420 |
flockfile(dc.finp); |
421 |
flockfile(stdout); |
422 |
#endif |
423 |
/* read/copy header */ |
424 |
if (!process_dc_header(&dc, a, argv)) |
425 |
return 1; |
426 |
427 |
if ((conversion != CV_FWD) & (dc.format == 'a')) |
428 |
SET_FILE_TEXT(stdout); |
429 |
/* process data */ |
430 |
switch (conversion) { |
431 |
case CV_FWD: /* distance -> depth code */ |
432 |
if (!strcmp(dc.depth_unit, "1")) { |
433 |
434 |
fputs(": warning - using reference depth of 1.0\n", |
435 |
stderr); |
436 |
437 |
if (!encode_depths(&dc)) |
438 |
return 1; |
439 |
break; |
440 |
case CV_REV: /* depth code -> distance */ |
441 |
if (!(bypixel ? pixel_depths(&dc, unbuffered) : |
442 |
decode_depths(&dc))) |
443 |
return 1; |
444 |
break; |
445 |
case CV_PTS: /* depth code -> world points */ |
446 |
if (!(bypixel ? pixel_points(&dc, unbuffered) : |
447 |
decode_points(&dc))) |
448 |
return 1; |
449 |
break; |
450 |
451 |
if (fflush(stdout) == EOF) { |
452 |
453 |
fputs(": error writing output\n", stderr); |
454 |
return 1; |
455 |
456 |
return 0; |
457 |
