root/Development/ray/src/util/rcode_depth.c
Revision: 2.13
Committed: Tue Jun 3 21:31:51 2025 UTC (6 months, 2 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.12: +3 -5 lines
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.13 static const char RCSid[] = "$Id: rcode_depth.c,v 2.12 2022/06/30 00:16:49 greg Exp $";
3 greg 2.1 #endif
4     /*
5 greg 2.3 * Encode and decode depth map using 16-bit integers
6 greg 2.1 */
7
8     #include "copyright.h"
9
10     #include <stdlib.h>
11     #include <math.h>
12     #include <ctype.h>
13     #include "platform.h"
14     #include "rtio.h"
15     #include "fvect.h"
16     #include "depthcodec.h"
17
18     enum {CV_FWD, CV_REV, CV_PTS};
19
20
21     /* Report usage error and exit */
22     static void
23     usage_exit(int code)
24     {
25     fputs("Usage: ", stderr);
26     fputs(progname, stderr);
27     fputs(
28 greg 2.8 " [-d ref_depth/unit][-h[io]][-H[io]][-f[afd]][-x xr -y yr] [input [output.dpt]]\n",
29 greg 2.1 stderr);
30     fputs(" Or: ", stderr);
31     fputs(progname, stderr);
32     fputs(
33 greg 2.4 " {-r|-p} [-i][-u][-h[io]][-H[io]][-f[afd]] [input.dpt [output]]\n",
34 greg 2.1 stderr);
35     exit(code);
36     }
37
38
39     /* Encode depths from input stream */
40     static int
41     encode_depths(DEPTHCODEC *dcp)
42     {
43 greg 2.3 long nexpected = (long)dcp->res.xr * dcp->res.yr;
44 greg 2.1
45     if (dcp->inpfmt[0]) {
46 greg 2.10 if (!strcmp(dcp->inpfmt, "ascii"))
47 greg 2.1 dcp->format = 'a';
48 greg 2.10 else if (!strcmp(dcp->inpfmt, "float"))
49 greg 2.1 dcp->format = 'f';
50 greg 2.10 else if (!strcmp(dcp->inpfmt, "double"))
51 greg 2.1 dcp->format = 'd';
52     else {
53     fputs(dcp->inpname, stderr);
54     fputs(": unsupported input format: ", stderr);
55     fputs(dcp->inpfmt, stderr);
56     fputc('\n', stderr);
57     return 0;
58     }
59     }
60 greg 2.11 if (dcp->format == 'a')
61     SET_FILE_TEXT(dcp->finp);
62 greg 2.3
63 greg 2.1 do {
64     int ok = 0;
65     float f;
66     double d;
67
68     switch (dcp->format) {
69     case 'a':
70     ok = (fscanf(dcp->finp, "%lf", &d) == 1);
71     break;
72     case 'f':
73     ok = (getbinary(&f, sizeof(f), 1, dcp->finp) == 1);
74 greg 2.6 if (dcp->swapped)
75     swap32((char *)&f, 1);
76 greg 2.1 d = f;
77     break;
78     case 'd':
79     ok = (getbinary(&d, sizeof(d), 1, dcp->finp) == 1);
80 greg 2.6 if (dcp->swapped)
81     swap64((char *)&d, 1);
82 greg 2.1 break;
83     }
84     if (!ok)
85     break;
86 greg 2.3
87 greg 2.1 putint(depth2code(d, dcp->refdepth), 2, stdout);
88 greg 2.3
89 greg 2.1 } while (--nexpected);
90
91     if (nexpected > 0) {
92     fputs(dcp->inpname, stderr);
93     fputs(": fewer depths than expected\n", stderr);
94     return 0;
95     }
96     return 1;
97     }
98
99
100 greg 2.3 /* Convert and output the given depth to stdout */
101 greg 2.1 static void
102     output_depth(DEPTHCODEC *dcp, double d)
103     {
104     float f;
105
106     switch (dcp->format) {
107     case 'a':
108     printf("%.5e\n", d);
109     break;
110     case 'f':
111     f = d;
112     putbinary(&f, sizeof(f), 1, stdout);
113     break;
114     case 'd':
115     putbinary(&d, sizeof(d), 1, stdout);
116     break;
117     }
118     }
119
120
121     /* Decode depths from input stream */
122     static int
123     decode_depths(DEPTHCODEC *dcp)
124     {
125 greg 2.3 long nexpected = (long)dcp->res.xr * dcp->res.yr;
126 greg 2.1
127     if (!check_decode_depths(dcp))
128     return 0;
129
130     do {
131 greg 2.3 double d = decode_depth_next(dcp);
132 greg 2.1 if (d < -FTINY)
133     break;
134     output_depth(dcp, d);
135
136     } while (--nexpected);
137
138     if (nexpected > 0) {
139     fputs(dcp->inpname, stderr);
140     fputs(": unexpected EOF\n", stderr);
141     return 0;
142     }
143     return 1;
144     }
145
146
147     /* Decode depths at particular pixels given on standard input */
148     static int
149     pixel_depths(DEPTHCODEC *dcp, int unbuf)
150     {
151     int xy[2];
152     double d;
153
154     if (dcp->finp == stdin) {
155     fputs(progname, stderr);
156     fputs(": <stdin> used for encoded depths\n", stderr);
157     return 0;
158     }
159     if (!check_decode_depths(dcp))
160     return 0;
161
162     while (scanf("%d %d", &xy[0], &xy[1]) == 2) {
163 greg 2.12 loc2pix(xy, &dcp->res, xy[0]/(double)dcp->res.xr,
164     xy[1]/(double)dcp->res.yr);
165 greg 2.1 d = decode_depth_pix(dcp, xy[0], xy[1]);
166     if (d < -FTINY)
167     return 0;
168     output_depth(dcp, d);
169     if (unbuf && fflush(stdout) == EOF) {
170     fputs(progname, stderr);
171     fputs(": write error on output\n", stderr);
172     return 0;
173     }
174     }
175     if (!feof(stdin)) {
176     fputs(progname, stderr);
177     fputs(": non-integer as pixel index\n", stderr);
178     return 0;
179     }
180     return 1;
181     }
182
183
184 greg 2.3 /* Output the given world position to stdout */
185 greg 2.1 static void
186     output_worldpos(DEPTHCODEC *dcp, FVECT wpos)
187     {
188     switch (dcp->format) {
189     case 'a':
190 greg 2.3 printf("%.5e %.5e %.5e\n", wpos[0], wpos[1], wpos[2]);
191 greg 2.1 break;
192     #ifdef SMLFLT
193     case 'f':
194     putbinary(wpos, sizeof(*wpos), 3, stdout);
195     break;
196     case 'd': {
197     double wpd[3];
198     VCOPY(wpd, wpos);
199     putbinary(wpd, sizeof(*wpd), 3, stdout);
200     }
201     break;
202     #else
203     case 'f': {
204     float wpf[3];
205     VCOPY(wpf, wpos);
206     putbinary(wpf, sizeof(*wpf), 3, stdout);
207     }
208     break;
209     case 'd':
210     putbinary(wpos, sizeof(*wpos), 3, stdout);
211     break;
212     #endif
213     }
214     }
215
216
217     /* Decode world points from input stream */
218     static int
219     decode_points(DEPTHCODEC *dcp)
220     {
221     long n = (long)dcp->res.xr * dcp->res.yr;
222
223     if (!check_decode_worldpos(dcp))
224     return 0;
225
226     while (n-- > 0) {
227     FVECT wpos;
228     if (decode_worldpos_next(wpos, dcp) < 0) {
229     if (feof(dcp->finp)) {
230     fputs(dcp->inpname, stderr);
231     fputs(": unexpected EOF\n", stderr);
232     }
233     return 0;
234     }
235     output_worldpos(dcp, wpos);
236     }
237     return 1;
238     }
239
240
241     /* Decode world points at particular pixels given on standard input */
242     static int
243     pixel_points(DEPTHCODEC *dcp, int unbuf)
244     {
245     int xy[2];
246     FVECT wpos;
247
248     if (dcp->finp == stdin) {
249     fputs(progname, stderr);
250     fputs(": <stdin> used for encoded depths\n", stderr);
251     return 0;
252     }
253     if (!check_decode_worldpos(dcp))
254     return 0;
255 greg 2.11
256 greg 2.1 while (scanf("%d %d", &xy[0], &xy[1]) == 2) {
257 greg 2.12 loc2pix(xy, &dcp->res, xy[0]/(double)dcp->res.xr,
258     xy[1]/(double)dcp->res.yr);
259 greg 2.1 if (get_worldpos_pix(wpos, dcp, xy[0], xy[1]) < 0)
260     return 0;
261     output_worldpos(dcp, wpos);
262     if (unbuf && fflush(stdout) == EOF) {
263     fputs(progname, stderr);
264     fputs(": write error on output\n", stderr);
265     return 0;
266     }
267     }
268     if (!feof(stdin)) {
269     fputs(progname, stderr);
270     fputs(": non-integer as pixel index\n", stderr);
271     return 0;
272     }
273     return 1;
274     }
275
276
277     int
278     main(int argc, char *argv[])
279     {
280 greg 2.7 int xres=0, yres=0;
281 greg 2.1 int conversion = CV_FWD;
282     int bypixel = 0;
283     int unbuffered = 0;
284     DEPTHCODEC dc;
285     int a;
286 greg 2.13 /* set global progname */
287     fixargv0(argv[0]);
288 greg 2.1 set_dc_defaults(&dc);
289     dc.hdrflags = HF_ALL;
290     for (a = 1; a < argc && argv[a][0] == '-'; a++)
291     switch (argv[a][1]) {
292     case 'd':
293     strlcpy(dc.depth_unit, argv[++a], sizeof(dc.depth_unit));
294     dc.refdepth = atof(dc.depth_unit);
295     if (dc.refdepth <= .0) {
296     fputs(progname, stderr);
297     fputs(": illegal -d reference depth\n", stderr);
298     return 1;
299     }
300     break;
301     case 'r':
302     conversion = CV_REV;
303     break;
304     case 'p':
305     conversion = CV_PTS;
306     break;
307     case 'f':
308     switch (argv[a][2]) {
309     case 'f':
310     case 'd':
311     case 'a':
312     dc.format = argv[a][2];
313     break;
314     default:
315     fputs(progname, stderr);
316     fputs(": unsupported -f? format\n", stderr);
317     usage_exit(1);
318     }
319     break;
320     case 'h':
321     switch (argv[a][2]) {
322     case '\0':
323     dc.hdrflags &= ~(HF_HEADIN|HF_HEADOUT);
324     break;
325     case 'i':
326     case 'I':
327     dc.hdrflags &= ~HF_HEADIN;
328     break;
329     case 'o':
330     case 'O':
331     dc.hdrflags &= ~HF_HEADOUT;
332     break;
333     default:
334     usage_exit(1);
335     }
336     break;
337     case 'H':
338     switch (argv[a][2]) {
339     case '\0':
340     dc.hdrflags &= ~(HF_RESIN|HF_RESOUT);
341     break;
342     case 'i':
343     case 'I':
344     dc.hdrflags &= ~HF_RESIN;
345     break;
346     case 'o':
347     case 'O':
348     dc.hdrflags &= ~HF_RESOUT;
349     break;
350     default:
351     usage_exit(1);
352     }
353     break;
354 greg 2.7 case 'x':
355     xres = atoi(argv[++a]);
356     break;
357     case 'y':
358     yres = atoi(argv[++a]);
359     break;
360 greg 2.1 case 'i':
361     bypixel++;
362     break;
363     case 'u':
364     unbuffered++;
365     break;
366     default:
367     usage_exit(1);
368     }
369     dc.hdrflags |= (conversion == CV_FWD) * HF_ENCODE;
370
371 greg 2.7 if ((xres > 0) & (yres > 0)) {
372     dc.hdrflags &= ~HF_RESIN;
373     dc.res.rt = PIXSTANDARD;
374     dc.res.xr = xres;
375     dc.res.yr = yres;
376     } else if ((dc.hdrflags & (HF_RESIN|HF_RESOUT)) == HF_RESOUT) {
377 greg 2.1 fputs(progname, stderr);
378     fputs(": unknown resolution for output\n", stderr);
379     return 1;
380     }
381     if (bypixel) {
382     if (conversion == CV_FWD) {
383     fputs(progname, stderr);
384     fputs(": -i only supported with -r or -p option\n",
385     stderr);
386     usage_exit(1);
387     }
388     if (a >= argc) {
389     fputs(progname, stderr);
390     fputs(": -i option requires input file\n", stderr);
391     usage_exit(1);
392     }
393     if (!(dc.hdrflags & HF_RESIN)) {
394     fputs(progname, stderr);
395     fputs(": -i option requires input resolution\n", stderr);
396     usage_exit(1);
397     }
398 greg 2.4 dc.hdrflags &= ~HF_RESOUT;
399 greg 2.1 }
400     if (a < argc-2) {
401     fputs(progname, stderr);
402     fputs(": too many file arguments\n", stderr);
403     usage_exit(1);
404     }
405     if (a < argc && !(dc.finp = fopen(dc.inpname=argv[a], "r"))) {
406     fputs(dc.inpname, stderr);
407     fputs(": cannot open for reading\n", stderr);
408     return 1;
409     }
410     if (a+1 < argc && !freopen(argv[a+1], "w", stdout)) {
411     fputs(argv[a+1], stderr);
412     fputs(": cannot open for writing\n", stderr);
413     return 1;
414     }
415 greg 2.11 SET_FILE_BINARY(dc.finp); /* starting assumption */
416     SET_FILE_BINARY(stdout);
417 greg 2.1 #ifdef getc_unlocked /* avoid stupid semaphores */
418     flockfile(dc.finp);
419     flockfile(stdout);
420     #endif
421     /* read/copy header */
422 greg 2.2 if (!process_dc_header(&dc, a, argv))
423 greg 2.1 return 1;
424 greg 2.11
425     if ((conversion != CV_FWD) & (dc.format == 'a'))
426     SET_FILE_TEXT(stdout);
427 greg 2.1 /* process data */
428     switch (conversion) {
429     case CV_FWD: /* distance -> depth code */
430 greg 2.9 if (!strcmp(dc.depth_unit, "1")) {
431     fputs(progname, stderr);
432     fputs(": warning - using reference depth of 1.0\n",
433     stderr);
434     }
435 greg 2.1 if (!encode_depths(&dc))
436     return 1;
437     break;
438     case CV_REV: /* depth code -> distance */
439     if (!(bypixel ? pixel_depths(&dc, unbuffered) :
440     decode_depths(&dc)))
441     return 1;
442     break;
443     case CV_PTS: /* depth code -> world points */
444     if (!(bypixel ? pixel_points(&dc, unbuffered) :
445     decode_points(&dc)))
446     return 1;
447     break;
448     }
449     if (fflush(stdout) == EOF) {
450     fputs(progname, stderr);
451     fputs(": error writing output\n", stderr);
452     return 1;
453     }
454     return 0;
455     }
