| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id$";
| 3 |
#endif
| 4 |
| 5 |
* ranimove2.c
| 6 |
| 7 |
* Frame refinement routines for ranimate(1).
| 8 |
| 9 |
* Created by Gregory Ward on Wed Jan 08 2003.
| 10 |
| 11 |
| 12 |
#include "copyright.h"
| 13 |
| 14 |
#include "ranimove.h"
| 15 |
#include "random.h"
| 16 |
| 17 |
| 18 |
#define HL_ERR 0.32 /* highlight error threshold */
| 19 |
| 20 |
int cerrzero; /* is cerrmap all zeroes? */
| 21 |
| 22 |
| 23 |
int
| 24 |
refine_first() /* initial refinement pass */
| 25 |
| 26 |
int *esamp = (int *)zprev; /* OK to reuse */
| 27 |
int hl_erri = errori(HL_ERR);
| 28 |
int nextra = 0;
| 29 |
int x, y, xp, yp;
| 30 |
int neigh;
| 31 |
register int n, np;
| 32 |
| 33 |
if (sizeof(int) < sizeof(*zprev))
| 34 |
error(CONSISTENCY, "code error in refine_first");
| 35 |
if (!silent) {
| 36 |
printf("\tFirst refinement pass...");
| 37 |
fflush(stdout);
| 38 |
| 39 |
bzero((void *)esamp, sizeof(int)*hres*vres);
| 40 |
| 41 |
* In our initial pass, we look for lower error pixels from
| 42 |
* the same objects in the previous frame, and copy them here.
| 43 |
| 44 |
for (y = vres; y--; )
| 45 |
for (x = hres; x--; ) {
| 46 |
n = fndx(x, y);
| 47 |
if (obuffer[n] == OVOID)
| 48 |
continue;
| 49 |
if (xmbuffer[n] == MO_UNK)
| 50 |
continue;
| 51 |
xp = x + xmbuffer[n];
| 52 |
if ((xp < 0 | xp >= hres))
| 53 |
continue;
| 54 |
yp = y + ymbuffer[n];
| 55 |
if ((yp < 0 | yp >= vres))
| 56 |
continue;
| 57 |
np = fndx(xp, yp);
| 58 |
/* make sure we hit same object */
| 59 |
if (oprev[np] != obuffer[n])
| 60 |
continue;
| 61 |
/* is previous frame error lower? */
| 62 |
if (aprev[np] < AMIN + ATIDIFF)
| 63 |
continue;
| 64 |
if (aprev[np] <= abuffer[n] + ATIDIFF)
| 65 |
continue;
| 66 |
/* shadow & highlight detection */
| 67 |
if (abuffer[n] > hl_erri &&
| 68 |
getclosest(&neigh, 1, x, y) &&
| 69 |
bigdiff(cbuffer[neigh], cprev[np],
| 70 |
HL_ERR*(.9+.2*frandom())))
| 71 |
continue;
| 72 |
abuffer[n] = aprev[np] - ATIDIFF;
| 73 |
copycolor(cbuffer[n], cprev[np]);
| 74 |
esamp[n] = 1; /* record extrapolated sample */
| 75 |
nextra++;
| 76 |
| 77 |
for (n = hres*vres; n--; ) /* update sample counts */
| 78 |
if (esamp[n])
| 79 |
sbuffer[n] = 1;
| 80 |
if (!silent)
| 81 |
printf("extrapolated %d pixels\n", nextra);
| 82 |
return(1);
| 83 |
| 84 |
| 85 |
| 86 |
| 87 |
* We use a recursive computation of the conspicuity
| 88 |
* map to avoid associated memory costs and simplify
| 89 |
* coding. We create a virtual image pyramid, pooling
| 90 |
* variance calculations, etc. The top of the pyramid
| 91 |
* corresponds to the foveal resolution, as there should
| 92 |
* not be any interesting mechanisms above this level.
| 93 |
| 94 |
| 95 |
#define CSF_C0 1.14
| 96 |
#define CSF_C1 0.67
| 97 |
#define CSF_C2 1.7
| 98 |
#define CSF_S1 6.1
| 99 |
#define CSF_S2 7.3
| 100 |
#define CSF_P1 45.9
| 101 |
#define CSF_PC (30./45.9*CSF_P1)
| 102 |
#define CSF_VR0 0.15
| 103 |
#define CSF_VRC 80.
| 104 |
| 105 |
struct ConspSum {
| 106 |
COLOR vsum; /* value sum */
| 107 |
COLOR v2sum; /* value^2 sum */
| 108 |
long nsamp; /* number of samples */
| 109 |
long xmsum; /* x-motion sum */
| 110 |
long ymsum; /* y-motion sum */
| 111 |
int npix; /* number of pixels */
| 112 |
double hls; /* high-level saliency */
| 113 |
| 114 |
| 115 |
static double pixel_deg; /* base pixel frequency */
| 116 |
static int fhsiz, fvsiz; /* foveal subimage size */
| 117 |
| 118 |
static void
| 119 |
clr_consp(cs) /* initialize a conspicuity sum */
| 120 |
register struct ConspSum *cs;
| 121 |
| 122 |
if (cs == NULL)
| 123 |
return;
| 124 |
setcolor(cs->vsum, 0., 0., 0.);
| 125 |
setcolor(cs->v2sum, 0., 0., 0.);
| 126 |
cs->nsamp = 0;
| 127 |
cs->xmsum = cs->ymsum = 0;
| 128 |
cs->npix = 0;
| 129 |
cs->hls = 0;
| 130 |
| 131 |
| 132 |
static void
| 133 |
sum_consp(cdest, cs) /* sum in conspicuity result */
| 134 |
register struct ConspSum *cdest, *cs;
| 135 |
| 136 |
if ((cdest == NULL | cs == NULL))
| 137 |
return;
| 138 |
addcolor(cdest->vsum, cs->vsum);
| 139 |
addcolor(cdest->v2sum, cs->v2sum);
| 140 |
cdest->nsamp += cs->nsamp;
| 141 |
cdest->xmsum += cs->xmsum;
| 142 |
cdest->ymsum += cs->ymsum;
| 143 |
cdest->npix += cs->npix;
| 144 |
if (cs->hls > cdest->hls)
| 145 |
cdest->hls = cs->hls;
| 146 |
| 147 |
| 148 |
static void
| 149 |
est_consp(x0,y0,x1,y1, cs) /* estimate error conspicuity & update */
| 150 |
int x0, y0, x1, y1;
| 151 |
| 152 |
| 153 |
double rad2, mtn2, cpd, vm, vr, csf, eest;
| 154 |
/* do we care? */
| 155 |
if (cs->hls <= FTINY)
| 156 |
return;
| 157 |
/* get relative error */
| 158 |
if (cs->nsamp < NSAMPOK) {
| 159 |
int neigh[NSAMPOK]; /* gather neighbors */
| 160 |
eest = comperr(neigh,
| 161 |
getclosest(neigh, NSAMPOK, (x0+x1)>>1, (y0+y1)>>1),
| 162 |
cs->nsamp);
| 163 |
} else
| 164 |
eest = estimaterr(cs->vsum, cs->v2sum, cs->nsamp, cs->nsamp);
| 165 |
| 166 |
if ((x0 == x1-1 & y0 == y1-1)) { /* update pixel error */
| 167 |
int n = fndx(x0, y0);
| 168 |
int ai;
| 169 |
int ne;
| 170 |
if (sbuffer[n] >= 255) {
| 171 |
abuffer[n] = ADISTANT;
| 172 |
} else {
| 173 |
ai = errori(eest);
| 174 |
if (ai < AMIN) ai = AMIN;
| 175 |
else if (ai >= ADISTANT) ai = ADISTANT-1;
| 176 |
abuffer[n] = ai;
| 177 |
/* can't improve on closest */
| 178 |
if (!cs->nsamp && getclosest(&ne, 1, x0, y0) &&
| 179 |
abuffer[ne] < ai &&
| 180 |
abuffer[ne] >= AMIN)
| 181 |
abuffer[n] = abuffer[ne];
| 182 |
| 183 |
| 184 |
/* compute radius^2 */
| 185 |
rad2 = 0.125*((x1-x0)*(x1-x0) + (y1-y0)*(y1-y0));
| 186 |
| 187 |
/* average motion^2 */
| 188 |
mtn2 = (double)cs->xmsum*cs->xmsum + (double)cs->ymsum*cs->ymsum;
| 189 |
mtn2 /= (double)(cs->npix*cs->npix);
| 190 |
/* motion blur hides us? */
| 191 |
if (mblur*mblur*mtn2 >= 4.*rad2)
| 192 |
return;
| 193 |
/* too small to see? */
| 194 |
cpd = pixel_deg * pixel_deg / rad2;
| 195 |
if (cpd > CSF_PC*CSF_PC)
| 196 |
return;
| 197 |
cpd = sqrt(cpd);
| 198 |
/* compute CSF [Daley98] */
| 199 |
vm = rate * sqrt(mtn2) / pixel_deg;
| 200 |
vr = cs->hls/hlsmax*vm + CSF_VR0; /* use hls tracking eff. */
| 201 |
if (vr > CSF_VRC) vr = CSF_VRC;
| 202 |
vr = vm - vr;
| 203 |
if (vr < 0) vr = -vr;
| 204 |
csf = log(CSF_C2*(1./3.)*vr);
| 205 |
if (csf < 0) csf = -csf;
| 206 |
csf = CSF_S1 + CSF_S2*csf*csf*csf;
| 207 |
csf *= CSF_C0*CSF_C2*4.*PI*PI*CSF_C1*CSF_C1*cpd*cpd;
| 208 |
csf *= exp(-CSF_C1*4.*PI/CSF_P1*(CSF_C2*vr + 2.)*cpd);
| 209 |
/* compute visible error */
| 210 |
eest = eest*csf/ndthresh - 1.;
| 211 |
if (eest <= FTINY)
| 212 |
return;
| 213 |
/* scale by saleincy */
| 214 |
eest *= cs->hls;
| 215 |
/* worth the bother? */
| 216 |
if (eest <= .01)
| 217 |
return;
| 218 |
/* sum into map */
| 219 |
for ( ; y0 < y1; y0++) {
| 220 |
float *em0 = cerrmap + fndx(x0, y0);
| 221 |
register float *emp = em0 + (x1-x0);
| 222 |
while (emp-- > em0)
| 223 |
*emp += eest;
| 224 |
| 225 |
cerrzero = 0;
| 226 |
| 227 |
| 228 |
static void
| 229 |
subconspicuity(x0,y0,x1,y1, cs) /* compute subportion of conspicuity */
| 230 |
int x0, y0, x1, y1;
| 231 |
| 232 |
| 233 |
struct ConspSum mysum;
| 234 |
int i;
| 235 |
| 236 |
if ((x0 >= x1 | y0 >= y1))
| 237 |
error(CONSISTENCY, "bad call to subconspicuity");
| 238 |
| 239 |
clr_consp(&mysum); /* prepare sum */
| 240 |
| 241 |
if ((x0 == x1-1 & y0 == y1-1)) { /* single pixel */
| 242 |
double hls;
| 243 |
register int n = fndx(x0, y0);
| 244 |
if (sbuffer[n]) {
| 245 |
copycolor(mysum.vsum, cbuffer[n]);
| 246 |
copycolor(mysum.v2sum, val2map[n]);
| 247 |
mysum.nsamp = sbuffer[n];
| 248 |
| 249 |
if ((mysum.xmsum = xmbuffer[n]) == MO_UNK)
| 250 |
mysum.xmsum = 0;
| 251 |
else
| 252 |
mysum.ymsum = ymbuffer[n];
| 253 |
mysum.npix = 1;
| 254 |
/* max. hls in fovea */
| 255 |
mysum.hls = obj_prio(obuffer[n]);
| 256 |
if (x0 >= fhsiz) {
| 257 |
hls = obj_prio(obuffer[fndx(x0-fhsiz,y0)]);
| 258 |
if (hls > mysum.hls) mysum.hls = hls;
| 259 |
| 260 |
if (x0 < hres-fhsiz) {
| 261 |
hls = obj_prio(obuffer[fndx(x0+fhsiz,y0)]);
| 262 |
| 263 |
| 264 |
if (y0 >= fvsiz) {
| 265 |
hls = obj_prio(obuffer[fndx(x0,y0-fvsiz)]);
| 266 |
| 267 |
| 268 |
if (y0 < vres-fvsiz) {
| 269 |
hls = obj_prio(obuffer[fndx(x0,y0+fvsiz)]);
| 270 |
| 271 |
| 272 |
} else if (x0 == x1-1) { /* vertical pair */
| 273 |
for (i = y0 ; i < y1; i++)
| 274 |
subconspicuity(x0, i, x1, i+1, &mysum);
| 275 |
} else if (y0 == y1-1) { /* horizontal pair */
| 276 |
for (i = x0 ; i < x1; i++)
| 277 |
subconspicuity(i, y0, i+1, y1, &mysum);
| 278 |
} else { /* rectangle */
| 279 |
subconspicuity(x0, y0, (x0+x1)>>1, (y0+y1)>>1, &mysum);
| 280 |
subconspicuity((x0+x1)>>1, y0, x1, (y0+y1)>>1, &mysum);
| 281 |
subconspicuity(x0, (y0+y1)>>1, (x0+x1)>>1, y1, &mysum);
| 282 |
subconspicuity((x0+x1)>>1, (y0+y1)>>1, x1, y1, &mysum);
| 283 |
| 284 |
/* update conspicuity */
| 285 |
est_consp(x0, y0, x1, y1, &mysum);
| 286 |
/* sum into return value */
| 287 |
sum_consp(cs, &mysum);
| 288 |
| 289 |
| 290 |
void
| 291 |
conspicuity() /* compute conspicuous error map */
| 292 |
| 293 |
int fhres, fvres;
| 294 |
int fx, fy;
| 295 |
/* reuse previous z-buffer */
| 296 |
cerrmap = (float *)zprev;
| 297 |
bzero((void *)cerrmap, sizeof(float)*hres*vres);
| 298 |
cerrzero = 1;
| 299 |
/* compute base pixel frequency */
| 300 |
pixel_deg = .5*(hres/vw.horiz + vres/vw.vert);
| 301 |
/* compute foveal resolution */
| 302 |
fhres = vw.horiz/FOV_DEG + 0.5;
| 303 |
if (fhres <= 0) fhres = 1;
| 304 |
else if (fhres > hres) fhres = hres;
| 305 |
fvres = vw.vert/FOV_DEG + 0.5;
| 306 |
if (fvres <= 0) fvres = 1;
| 307 |
else if (fvres > vres) fvres = vres;
| 308 |
fhsiz = hres/fhres;
| 309 |
fvsiz = vres/fvres;
| 310 |
/* call our foveal subroutine */
| 311 |
for (fy = fvres; fy--; )
| 312 |
for (fx = fhres; fx--; )
| 313 |
subconspicuity(hres*fx/fhres, vres*fy/fvres,
| 314 |
hres*(fx+1)/fhres, vres*(fy+1)/fvres,
| 315 |
NULL);
| 316 |
| 317 |
| 318 |
| 319 |
| 320 |
* The following structure is used to collect data on the
| 321 |
* initial error in the ambient value estimate, in order
| 322 |
* to correct for it in the subsequent frames.
| 323 |
| 324 |
static struct AmbSum {
| 325 |
double diffsum[3]; /* sum of (correct - ambval) */
| 326 |
long nsamps; /* number of values in sum */
| 327 |
} *asump = NULL;
| 328 |
| 329 |
| 330 |
static int
| 331 |
ppri_cmp(pp1, pp2) /* pixel priority comparison */
| 332 |
const void *pp1, *pp2;
| 333 |
| 334 |
double se1 = cerrmap[*(const int *)pp1];
| 335 |
double se2 = cerrmap[*(const int *)pp2];
| 336 |
int adiff;
| 337 |
/* higher conspicuity to front */
| 338 |
if (se1 < se2) return(1);
| 339 |
if (se1 > se2) return(-1);
| 340 |
/* else higher error to front */
| 341 |
adiff = (int)abuffer[*(const int *)pp1] -
| 342 |
(int)abuffer[*(const int *)pp2];
| 343 |
if (adiff)
| 344 |
return(adiff);
| 345 |
/* else fewer samples to front */
| 346 |
return((int)sbuffer[*(const int *)pp1] -
| 347 |
(int)sbuffer[*(const int *)pp2]);
| 348 |
| 349 |
| 350 |
| 351 |
static int
| 352 |
ray_refine(n) /* refine the given pixel by tracing a ray */
| 353 |
register int n;
| 354 |
| 355 |
RAY ir;
| 356 |
int neigh[NSAMPOK];
| 357 |
int nc;
| 358 |
COLOR ctmp;
| 359 |
int i;
| 360 |
| 361 |
if (n < 0) { /* fetching stragglers */
| 362 |
if (nprocs <= 1 || !ray_presult(&ir, 0))
| 363 |
return(-1);
| 364 |
n = ir.rno;
| 365 |
} else { /* else tracing a new ray */
| 366 |
double hv[2];
| 367 |
if (sbuffer[n] >= 255) /* reached limit? */
| 368 |
return(-1);
| 369 |
sample_pos(hv, n%hres, n/hres, sbuffer[n]);
| 370 |
ir.rmax = viewray(ir.rorg, ir.rdir, &vw, hv[0], hv[1]);
| 371 |
if (ir.rmax < -FTINY)
| 372 |
return(-1);
| 373 |
if (nprocs > 1) {
| 374 |
int rval;
| 375 |
rayorigin(&ir, NULL, PRIMARY, 1.0);
| 376 |
ir.rno = n;
| 377 |
rval = ray_pqueue(&ir);
| 378 |
if (!rval)
| 379 |
return(-1);
| 380 |
if (rval < 0)
| 381 |
quit(1);
| 382 |
n = ir.rno;
| 383 |
} else
| 384 |
ray_trace(&ir);
| 385 |
| 386 |
if (abuffer[n] == ALOWQ && asump != NULL) {
| 387 |
if (sbuffer[n] != 1)
| 388 |
error(CONSISTENCY, "bad code in ray_refine");
| 389 |
if (getambcolor(ctmp, obuffer[n]) &&
| 390 |
(colval(ctmp,RED) > 0.01 &
| 391 |
colval(ctmp,GRN) > 0.01 &
| 392 |
colval(ctmp,BLU) > 0.01)) {
| 393 |
for (i = 0; i < 3; i++)
| 394 |
asump->diffsum[i] +=
| 395 |
(colval(ir.rcol,i) - colval(cbuffer[n],i))
| 396 |
/ colval(ctmp,i);
| 397 |
asump->nsamps++;
| 398 |
| 399 |
sbuffer[n] = 0;
| 400 |
| 401 |
setcolor(ctmp,
| 402 |
colval(ir.rcol,RED)*colval(ir.rcol,RED),
| 403 |
colval(ir.rcol,GRN)*colval(ir.rcol,GRN),
| 404 |
colval(ir.rcol,BLU)*colval(ir.rcol,BLU));
| 405 |
if (!sbuffer[n]) { /* first sample */
| 406 |
copycolor(cbuffer[n], ir.rcol);
| 407 |
copycolor(val2map[n], ctmp);
| 408 |
abuffer[n] = AHIGHQ;
| 409 |
sbuffer[n] = 1;
| 410 |
} else { /* else sum in sample */
| 411 |
addcolor(cbuffer[n], ir.rcol);
| 412 |
addcolor(val2map[n], ctmp);
| 413 |
sbuffer[n]++;
| 414 |
| 415 |
return(n);
| 416 |
| 417 |
| 418 |
| 419 |
static long
| 420 |
refine_rays(nrays) /* compute refinement rays */
| 421 |
long nrays;
| 422 |
| 423 |
int *pord;
| 424 |
int ntodo;
| 425 |
long rdone;
| 426 |
int i;
| 427 |
/* skip if nothing significant */
| 428 |
if (ndtset && cerrzero)
| 429 |
return;
| 430 |
/* initialize priority list */
| 431 |
pord = (int *)malloc(sizeof(int)*hres*vres);
| 432 |
for (i = hres*vres; i--; )
| 433 |
pord[i] = i;
| 434 |
/* sort our priorities */
| 435 |
ntodo = hres*vres;
| 436 |
if (nrays < ntodo)
| 437 |
qsort((void *)pord, hres*vres, sizeof(int), ppri_cmp);
| 438 |
i = 0;
| 439 |
/* trace rays in list */
| 440 |
for (rdone = 0; rdone < nrays; rdone++) {
| 441 |
if (ndtset && i >= 1000 && cerrmap[pord[i]] <= FTINY)
| 442 |
ntodo = i;
| 443 |
if (i >= ntodo) { /* redo conspicuity & priority */
| 444 |
while (ray_refine(-1) >= 0)
| 445 |
| 446 |
conspicuity();
| 447 |
| 448 |
break;
| 449 |
| 450 |
ntodo = hres*vres/8;
| 451 |
i = 0;
| 452 |
| 453 |
/* sample next pixel */
| 454 |
ray_refine(pord[i++]);
| 455 |
| 456 |
/* clean up and return */
| 457 |
| 458 |
| 459 |
free((void *)pord);
| 460 |
return(rdone);
| 461 |
| 462 |
| 463 |
| 464 |
int
| 465 |
refine_frame(pass) /* refine current frame */
| 466 |
int pass;
| 467 |
| 468 |
static double rtime_used = 0;
| 469 |
static long ray_cnt = 0;
| 470 |
static double ctime_used = 0;
| 471 |
static int csp_cnt = 0;
| 472 |
int timed = (fcur > fbeg | pass > 0 | quickstart);
| 473 |
double time_start, rtime_start, time_done;
| 474 |
struct AmbSum myAmbSum;
| 475 |
long rays_todo, nr;
| 476 |
register int n;
| 477 |
/* IBR refinement? */
| 478 |
if ((pass == 0 & fcur > fbeg))
| 479 |
return(refine_first());
| 480 |
/* any time left? */
| 481 |
time_start = getTime();
| 482 |
if (timed) {
| 483 |
if (time_start >= frm_stop)
| 484 |
goto nomore;
| 485 |
if (csp_cnt > 0 && time_start + ctime_used/csp_cnt >= frm_stop)
| 486 |
goto nomore;
| 487 |
| 488 |
asump = NULL; /* use resampling to update ambval? */
| 489 |
if (!curparams->ambounce && hirendparams.ambounce) {
| 490 |
myAmbSum.diffsum[RED] =
| 491 |
myAmbSum.diffsum[GRN] =
| 492 |
myAmbSum.diffsum[BLU] = 0;
| 493 |
myAmbSum.nsamps = 0;
| 494 |
asump = &myAmbSum;
| 495 |
| 496 |
/* initialize value-squared map */
| 497 |
if (val2map == NULL) {
| 498 |
val2map = cprev; /* OK to reuse at this point */
| 499 |
n = (asump == NULL) ? hres*vres : 0;
| 500 |
while (n--)
| 501 |
if (sbuffer[n])
| 502 |
setcolor(val2map[n],
| 503 |
colval(cbuffer[n],RED)*colval(cbuffer[n],RED),
| 504 |
colval(cbuffer[n],GRN)*colval(cbuffer[n],GRN),
| 505 |
colval(cbuffer[n],BLU)*colval(cbuffer[n],BLU));
| 506 |
else
| 507 |
setcolor(val2map[n], 0., 0., 0.);
| 508 |
| 509 |
/* compute conspicuity */
| 510 |
if (!silent) {
| 511 |
printf("\tComputing conspicuity map\n");
| 512 |
fflush(stdout);
| 513 |
| 514 |
conspicuity();
| 515 |
csp_cnt++;
| 516 |
#if 0
| 517 |
if (pass == 1) {
| 518 |
char fnm[256];
| 519 |
sprintf(fnm, vval(BASENAME), fcur);
| 520 |
strcat(fnm, "_incmap.pic");
| 521 |
write_map(cerrmap, fnm);
| 522 |
| 523 |
#endif
| 524 |
/* get ray start time */
| 525 |
rtime_start = getTime();
| 526 |
ctime_used += rtime_start - time_start;
| 527 |
if (timed && rtime_start >= frm_stop)
| 528 |
return(0); /* error done but out of time */
| 529 |
if (rtime_used <= FTINY) {
| 530 |
if (quickstart)
| 531 |
rays_todo = 1000;
| 532 |
else
| 533 |
rays_todo = hres*vres;
| 534 |
} else {
| 535 |
rays_todo = (long)((frm_stop - rtime_start) *
| 536 |
ray_cnt / rtime_used);
| 537 |
if (rays_todo < 1000)
| 538 |
return(0); /* let's call it a frame */
| 539 |
| 540 |
/* set higher rendering quality */
| 541 |
if (twolevels && curparams != &hirendparams) {
| 542 |
ray_restore(curparams = &hirendparams);
| 543 |
if (nprocs > 1) { /* need to update children */
| 544 |
if (!silent) {
| 545 |
printf("\tRestarting %d processes\n", nprocs);
| 546 |
fflush(stdout);
| 547 |
| 548 |
ray_pclose(0);
| 549 |
ray_popen(nprocs);
| 550 |
| 551 |
| 552 |
| 553 |
if (!silent) {
| 554 |
printf("\tRefinement pass %d...",
| 555 |
pass+1, rays_todo);
| 556 |
fflush(stdout);
| 557 |
| 558 |
if (asump != NULL) /* flag low-quality samples */
| 559 |
| 560 |
if (sbuffer[n])
| 561 |
abuffer[n] = ALOWQ;
| 562 |
/* trace those rays */
| 563 |
nr = refine_rays(rays_todo);
| 564 |
if (!silent)
| 565 |
printf("traced %d HQ rays\n", nr);
| 566 |
if (nr <= 0)
| 567 |
return(0);
| 568 |
/* update timing stats */
| 569 |
while (ray_cnt >= 1L<<20) {
| 570 |
ray_cnt >>= 1;
| 571 |
rtime_used *= .5;
| 572 |
| 573 |
ray_cnt += nr;
| 574 |
time_done = getTime();
| 575 |
rtime_used += time_done - rtime_start;
| 576 |
if (!timed && time_done > frm_stop)
| 577 |
frm_stop = time_done;
| 578 |
/* update ambient value */
| 579 |
if (asump != NULL && asump->nsamps >= 1000) {
| 580 |
double sf = 1./(double)asump->nsamps;
| 581 |
for (n = 3; n--; ) {
| 582 |
asump->diffsum[n] *= sf;
| 583 |
asump->diffsum[n] += colval(lorendparams.ambval,n);
| 584 |
if (asump->diffsum[n] < 0) asump->diffsum[n] = 0;
| 585 |
| 586 |
setcolor(lorendparams.ambval,
| 587 |
asump->diffsum[RED],
| 588 |
asump->diffsum[GRN],
| 589 |
asump->diffsum[BLU]);
| 590 |
if (!silent)
| 591 |
printf("\tUpdated parameter: -av %f %f %f\n",
| 592 |
| 593 |
| 594 |
| 595 |
asump = NULL;
| 596 |
| 597 |
return(1);
| 598 |
nomore:
| 599 |
/* make sure error map is updated */
| 600 |
if ((fcur == fbeg | pass > 1))
| 601 |
comp_frame_error();
| 602 |
return(0);
| 603 |
