--- ray/src/util/ranimove2.c 2003/02/22 02:07:30 3.1 +++ ray/src/util/ranimove2.c 2004/06/16 09:50:33 3.7 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: ranimove2.c,v 3.1 2003/02/22 02:07:30 greg Exp $"; +static const char RCSid[] = "$Id: ranimove2.c,v 3.7 2004/06/16 09:50:33 greg Exp $"; #endif /* * ranimove2.c @@ -9,63 +9,10 @@ static const char RCSid[] = "$Id: ranimove2.c,v 3.1 20 * Created by Gregory Ward on Wed Jan 08 2003. */ -/* ==================================================================== - * The Radiance Software License, Version 1.0 - * - * Copyright (c) 1990 - 2002 The Regents of the University of California, - * through Lawrence Berkeley National Laboratory. All rights reserved. - * - * Redistribution and use in source and binary forms, with or without - * modification, are permitted provided that the following conditions - * are met: - * - * 1. Redistributions of source code must retain the above copyright - * notice, this list of conditions and the following disclaimer. - * - * 2. Redistributions in binary form must reproduce the above copyright - * notice, this list of conditions and the following disclaimer in - * the documentation and/or other materials provided with the - * distribution. - * - * 3. The end-user documentation included with the redistribution, - * if any, must include the following acknowledgment: - * "This product includes Radiance software - * (http://radsite.lbl.gov/) - * developed by the Lawrence Berkeley National Laboratory - * (http://www.lbl.gov/)." - * Alternately, this acknowledgment may appear in the software itself, - * if and wherever such third-party acknowledgments normally appear. - * - * 4. The names "Radiance," "Lawrence Berkeley National Laboratory" - * and "The Regents of the University of California" must - * not be used to endorse or promote products derived from this - * software without prior written permission. For written - * permission, please contact radiance@radsite.lbl.gov. - * - * 5. Products derived from this software may not be called "Radiance", - * nor may "Radiance" appear in their name, without prior written - * permission of Lawrence Berkeley National Laboratory. - * - * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED - * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES - * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE - * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR - * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, - * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT - * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF - * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND - * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, - * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT - * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF - * SUCH DAMAGE. - * ==================================================================== - * - * This software consists of voluntary contributions made by many - * individuals on behalf of Lawrence Berkeley National Laboratory. For more - * information on Lawrence Berkeley National Laboratory, please see - * . - */ +#include "copyright.h" +#include + #include "ranimove.h" #include "random.h" @@ -74,9 +21,13 @@ static const char RCSid[] = "$Id: ranimove2.c,v 3.1 20 int cerrzero; /* is cerrmap all zeroes? */ +static int ppri_cmp(const void *pp1, const void *pp2); +static int ray_refine(int n); +static long refine_rays(long nrays); -int -refine_first() /* initial refinement pass */ + +extern int +refine_first(void) /* initial refinement pass */ { int *esamp = (int *)zprev; /* OK to reuse */ int hl_erri = errori(HL_ERR); @@ -91,7 +42,7 @@ refine_first() /* initial refinement pass */ printf("\tFirst refinement pass..."); fflush(stdout); } - bzero((void *)esamp, sizeof(int)*hres*vres); + memset((void *)esamp, '\0', sizeof(int)*hres*vres); /* * In our initial pass, we look for lower error pixels from * the same objects in the previous frame, and copy them here. @@ -104,10 +55,10 @@ refine_first() /* initial refinement pass */ if (xmbuffer[n] == MO_UNK) continue; xp = x + xmbuffer[n]; - if ((xp < 0 | xp >= hres)) + if ((xp < 0) | (xp >= hres)) continue; yp = y + ymbuffer[n]; - if ((yp < 0 | yp >= vres)) + if ((yp < 0) | (yp >= vres)) continue; np = fndx(xp, yp); /* make sure we hit same object */ @@ -170,9 +121,15 @@ struct ConspSum { static double pixel_deg; /* base pixel frequency */ static int fhsiz, fvsiz; /* foveal subimage size */ +static void clr_consp(struct ConspSum *cs); +static void sum_consp(struct ConspSum *cdest, struct ConspSum *cs); +static void est_consp(int x0, int y0, int x1, int y1, struct ConspSum *cs); +static void subconspicuity(int x0, int y0, int x1, int y1, struct ConspSum *cs); + static void -clr_consp(cs) /* initialize a conspicuity sum */ -register struct ConspSum *cs; +clr_consp( /* initialize a conspicuity sum */ + register struct ConspSum *cs +) { if (cs == NULL) return; @@ -185,10 +142,12 @@ register struct ConspSum *cs; } static void -sum_consp(cdest, cs) /* sum in conspicuity result */ -register struct ConspSum *cdest, *cs; +sum_consp( /* sum in conspicuity result */ + register struct ConspSum *cdest, + register struct ConspSum *cs +) { - if ((cdest == NULL | cs == NULL)) + if ((cdest == NULL) | (cs == NULL)) return; addcolor(cdest->vsum, cs->vsum); addcolor(cdest->v2sum, cs->v2sum); @@ -201,9 +160,13 @@ register struct ConspSum *cdest, *cs; } static void -est_consp(x0,y0,x1,y1, cs) /* estimate error conspicuity & update */ -int x0, y0, x1, y1; -register struct ConspSum *cs; +est_consp( /* estimate error conspicuity & update */ + int x0, + int y0, + int x1, + int y1, + register struct ConspSum *cs +) { double rad2, mtn2, cpd, vm, vr, csf, eest; /* do we care? */ @@ -218,7 +181,7 @@ register struct ConspSum *cs; } else eest = estimaterr(cs->vsum, cs->v2sum, cs->nsamp, cs->nsamp); - if ((x0 == x1-1 & y0 == y1-1)) { /* update pixel error */ + if ((x0 == x1-1) & (y0 == y1-1)) { /* update pixel error */ int n = fndx(x0, y0); int ai; int ne; @@ -270,30 +233,35 @@ register struct ConspSum *cs; /* worth the bother? */ if (eest <= .01) return; - /* sum into map */ + /* put into map */ for ( ; y0 < y1; y0++) { float *em0 = cerrmap + fndx(x0, y0); register float *emp = em0 + (x1-x0); while (emp-- > em0) - *emp += eest; + if (eest > *emp) + *emp = eest; } cerrzero = 0; } static void -subconspicuity(x0,y0,x1,y1, cs) /* compute subportion of conspicuity */ -int x0, y0, x1, y1; -struct ConspSum *cs; +subconspicuity( /* compute subportion of conspicuity */ + int x0, + int y0, + int x1, + int y1, + struct ConspSum *cs +) { struct ConspSum mysum; int i; - if ((x0 >= x1 | y0 >= y1)) + if ((x0 >= x1) | (y0 >= y1)) error(CONSISTENCY, "bad call to subconspicuity"); clr_consp(&mysum); /* prepare sum */ - if ((x0 == x1-1 & y0 == y1-1)) { /* single pixel */ + if ((x0 == x1-1) & (y0 == y1-1)) { /* single pixel */ double hls; register int n = fndx(x0, y0); if (sbuffer[n]) { @@ -342,14 +310,14 @@ struct ConspSum *cs; sum_consp(cs, &mysum); } -void -conspicuity() /* compute conspicuous error map */ +extern void +conspicuity(void) /* compute conspicuous error map */ { int fhres, fvres; int fx, fy; /* reuse previous z-buffer */ cerrmap = (float *)zprev; - bzero((void *)cerrmap, sizeof(float)*hres*vres); + memset((void *)cerrmap, '\0', sizeof(float)*hres*vres); cerrzero = 1; /* compute base pixel frequency */ pixel_deg = .5*(hres/vw.horiz + vres/vw.vert); @@ -383,8 +351,10 @@ static struct AmbSum { static int -ppri_cmp(pp1, pp2) /* pixel priority comparison */ -const void *pp1, *pp2; +ppri_cmp( /* pixel priority comparison */ + const void *pp1, + const void *pp2 +) { double se1 = cerrmap[*(const int *)pp1]; double se2 = cerrmap[*(const int *)pp2]; @@ -404,12 +374,11 @@ const void *pp1, *pp2; static int -ray_refine(n) /* refine the given pixel by tracing a ray */ -register int n; +ray_refine( /* refine the given pixel by tracing a ray */ + register int n +) { RAY ir; - int neigh[NSAMPOK]; - int nc; COLOR ctmp; int i; @@ -442,9 +411,9 @@ register int n; if (sbuffer[n] != 1) error(CONSISTENCY, "bad code in ray_refine"); if (getambcolor(ctmp, obuffer[n]) && - (colval(ctmp,RED) > 0.01 & - colval(ctmp,GRN) > 0.01 & - colval(ctmp,BLU) > 0.01)) { + (colval(ctmp,RED) > 0.01) & + (colval(ctmp,GRN) > 0.01) & + (colval(ctmp,BLU) > 0.01)) { for (i = 0; i < 3; i++) asump->diffsum[i] += (colval(ir.rcol,i) - colval(cbuffer[n],i)) @@ -472,8 +441,9 @@ register int n; static long -refine_rays(nrays) /* compute refinement rays */ -long nrays; +refine_rays( /* compute refinement rays */ + long nrays +) { int *pord; int ntodo; @@ -481,7 +451,7 @@ long nrays; int i; /* skip if nothing significant */ if (ndtset && cerrzero) - return; + return(0); /* initialize priority list */ pord = (int *)malloc(sizeof(int)*hres*vres); for (i = hres*vres; i--; ) @@ -516,21 +486,22 @@ long nrays; } -int -refine_frame(pass) /* refine current frame */ -int pass; +extern int +refine_frame( /* refine current frame */ + int pass +) { static double rtime_used = 0; static long ray_cnt = 0; static double ctime_used = 0; static int csp_cnt = 0; - int timed = (fcur > fbeg | pass > 0 | quickstart); + int timed = (fcur > fbeg) | (pass > 0) | (quickstart); double time_start, rtime_start, time_done; struct AmbSum myAmbSum; long rays_todo, nr; register int n; /* IBR refinement? */ - if ((pass == 0 & fcur > fbeg)) + if ((pass == 0) & (fcur > fbeg)) return(refine_first()); /* any time left? */ time_start = getTime(); @@ -607,7 +578,7 @@ if (pass == 1) { /* compute refinement rays */ if (!silent) { printf("\tRefinement pass %d...", - pass+1, rays_todo); + pass+1); /*, rays_todo); */ fflush(stdout); } if (asump != NULL) /* flag low-quality samples */ @@ -617,7 +588,7 @@ if (pass == 1) { /* trace those rays */ nr = refine_rays(rays_todo); if (!silent) - printf("traced %d HQ rays\n", nr); + printf("traced %ld HQ rays\n", nr); if (nr <= 0) return(0); /* update timing stats */ @@ -652,7 +623,7 @@ if (pass == 1) { return(1); nomore: /* make sure error map is updated */ - if ((fcur == fbeg | pass > 1)) + if ((fcur == fbeg) | (pass > 1)) comp_frame_error(); return(0); }
