--- ray/src/util/ranimove2.c 2003/02/22 02:07:30 3.1
+++ ray/src/util/ranimove2.c 2016/04/18 22:39:13 3.10
@@ -1,71 +1,18 @@
#ifndef lint
-static const char RCSid[] = "$Id: ranimove2.c,v 3.1 2003/02/22 02:07:30 greg Exp $";
+static const char RCSid[] = "$Id: ranimove2.c,v 3.10 2016/04/18 22:39:13 greg Exp $";
#endif
* ranimove2.c
- * Frame refinement routines for ranimate(1).
+ * Frame refinement routines for ranimove(1).
* Created by Gregory Ward on Wed Jan 08 2003.
- * The Radiance Software License, Version 1.0
- * Copyright (c) 1990 - 2002 The Regents of the University of California,
- * through Lawrence Berkeley National Laboratory. All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in
- * the documentation and/or other materials provided with the
- * distribution.
- * 3. The end-user documentation included with the redistribution,
- * if any, must include the following acknowledgment:
- * "This product includes Radiance software
- * (http://radsite.lbl.gov/)
- * developed by the Lawrence Berkeley National Laboratory
- * (http://www.lbl.gov/)."
- * Alternately, this acknowledgment may appear in the software itself,
- * if and wherever such third-party acknowledgments normally appear.
- * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
- * and "The Regents of the University of California" must
- * not be used to endorse or promote products derived from this
- * software without prior written permission. For written
- * permission, please contact radiance@radsite.lbl.gov.
- * 5. Products derived from this software may not be called "Radiance",
- * nor may "Radiance" appear in their name, without prior written
- * permission of Lawrence Berkeley National Laboratory.
- * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
- * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
- * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
- * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
- * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
- * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
- * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
- * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
- * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
- * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
- * This software consists of voluntary contributions made by many
- * individuals on behalf of Lawrence Berkeley National Laboratory. For more
- * information on Lawrence Berkeley National Laboratory, please see
+#include "copyright.h"
+#include
#include "ranimove.h"
#include "random.h"
@@ -74,16 +21,20 @@ static const char RCSid[] = "$Id: ranimove2.c,v 3.1 20
int cerrzero; /* is cerrmap all zeroes? */
+static int ppri_cmp(const void *pp1, const void *pp2);
+static int ray_refine(int n);
+static long refine_rays(long nrays);
int
-refine_first() /* initial refinement pass */
+refine_first(void) /* initial refinement pass */
int *esamp = (int *)zprev; /* OK to reuse */
int hl_erri = errori(HL_ERR);
int nextra = 0;
int x, y, xp, yp;
int neigh;
- register int n, np;
+ int n, np;
if (sizeof(int) < sizeof(*zprev))
error(CONSISTENCY, "code error in refine_first");
@@ -91,7 +42,7 @@ refine_first() /* initial refinement pass */
printf("\tFirst refinement pass...");
fflush(stdout);
- bzero((void *)esamp, sizeof(int)*hres*vres);
+ memset((void *)esamp, '\0', sizeof(int)*hres*vres);
* In our initial pass, we look for lower error pixels from
* the same objects in the previous frame, and copy them here.
@@ -104,10 +55,10 @@ refine_first() /* initial refinement pass */
if (xmbuffer[n] == MO_UNK)
continue;
xp = x + xmbuffer[n];
- if ((xp < 0 | xp >= hres))
+ if ((xp < 0) | (xp >= hres))
continue;
yp = y + ymbuffer[n];
- if ((yp < 0 | yp >= vres))
+ if ((yp < 0) | (yp >= vres))
continue;
np = fndx(xp, yp);
/* make sure we hit same object */
@@ -170,9 +121,15 @@ struct ConspSum {
static double pixel_deg; /* base pixel frequency */
static int fhsiz, fvsiz; /* foveal subimage size */
+static void clr_consp(struct ConspSum *cs);
+static void sum_consp(struct ConspSum *cdest, struct ConspSum *cs);
+static void est_consp(int x0, int y0, int x1, int y1, struct ConspSum *cs);
+static void subconspicuity(int x0, int y0, int x1, int y1, struct ConspSum *cs);
static void
-clr_consp(cs) /* initialize a conspicuity sum */
-register struct ConspSum *cs;
+clr_consp( /* initialize a conspicuity sum */
+ struct ConspSum *cs
if (cs == NULL)
return;
@@ -185,10 +142,12 @@ register struct ConspSum *cs;
static void
-sum_consp(cdest, cs) /* sum in conspicuity result */
-register struct ConspSum *cdest, *cs;
+sum_consp( /* sum in conspicuity result */
+ struct ConspSum *cdest,
- if ((cdest == NULL | cs == NULL))
+ if ((cdest == NULL) | (cs == NULL))
return;
addcolor(cdest->vsum, cs->vsum);
addcolor(cdest->v2sum, cs->v2sum);
@@ -201,9 +160,13 @@ register struct ConspSum *cdest, *cs;
static void
-est_consp(x0,y0,x1,y1, cs) /* estimate error conspicuity & update */
-int x0, y0, x1, y1;
+est_consp( /* estimate error conspicuity & update */
+ int x0,
+ int y0,
+ int x1,
+ int y1,
double rad2, mtn2, cpd, vm, vr, csf, eest;
/* do we care? */
@@ -218,7 +181,7 @@ register struct ConspSum *cs;
} else
eest = estimaterr(cs->vsum, cs->v2sum, cs->nsamp, cs->nsamp);
- if ((x0 == x1-1 & y0 == y1-1)) { /* update pixel error */
+ if ((x0 == x1-1) & (y0 == y1-1)) { /* update pixel error */
int n = fndx(x0, y0);
int ai;
int ne;
@@ -270,32 +233,37 @@ register struct ConspSum *cs;
/* worth the bother? */
if (eest <= .01)
return;
- /* sum into map */
+ /* put into map */
for ( ; y0 < y1; y0++) {
float *em0 = cerrmap + fndx(x0, y0);
- register float *emp = em0 + (x1-x0);
+ float *emp = em0 + (x1-x0);
while (emp-- > em0)
- *emp += eest;
+ if (eest > *emp)
+ *emp = eest;
cerrzero = 0;
static void
-subconspicuity(x0,y0,x1,y1, cs) /* compute subportion of conspicuity */
-struct ConspSum *cs;
+subconspicuity( /* compute subportion of conspicuity */
+ int x0,
+ int y0,
+ int x1,
+ int y1,
struct ConspSum mysum;
int i;
- if ((x0 >= x1 | y0 >= y1))
+ if ((x0 >= x1) | (y0 >= y1))
error(CONSISTENCY, "bad call to subconspicuity");
clr_consp(&mysum); /* prepare sum */
- if ((x0 == x1-1 & y0 == y1-1)) { /* single pixel */
+ if ((x0 == x1-1) & (y0 == y1-1)) { /* single pixel */
double hls;
- register int n = fndx(x0, y0);
+ int n = fndx(x0, y0);
if (sbuffer[n]) {
copycolor(mysum.vsum, cbuffer[n]);
copycolor(mysum.v2sum, val2map[n]);
@@ -343,13 +311,13 @@ struct ConspSum *cs;
void
-conspicuity() /* compute conspicuous error map */
+conspicuity(void) /* compute conspicuous error map */
int fhres, fvres;
int fx, fy;
/* reuse previous z-buffer */
cerrmap = (float *)zprev;
- bzero((void *)cerrmap, sizeof(float)*hres*vres);
+ memset((void *)cerrmap, '\0', sizeof(float)*hres*vres);
cerrzero = 1;
/* compute base pixel frequency */
pixel_deg = .5*(hres/vw.horiz + vres/vw.vert);
@@ -383,8 +351,10 @@ static struct AmbSum {
static int
-ppri_cmp(pp1, pp2) /* pixel priority comparison */
-const void *pp1, *pp2;
+ppri_cmp( /* pixel priority comparison */
+ const void *pp1,
+ const void *pp2
double se1 = cerrmap[*(const int *)pp1];
double se2 = cerrmap[*(const int *)pp2];
@@ -404,12 +374,11 @@ const void *pp1, *pp2;
static int
-ray_refine(n) /* refine the given pixel by tracing a ray */
-register int n;
+ray_refine( /* refine the given pixel by tracing a ray */
+ int n
RAY ir;
- int neigh[NSAMPOK];
- int nc;
COLOR ctmp;
int i;
@@ -427,7 +396,7 @@ register int n;
return(-1);
if (nprocs > 1) {
int rval;
- rayorigin(&ir, NULL, PRIMARY, 1.0);
+ rayorigin(&ir, PRIMARY, NULL, NULL);
ir.rno = n;
rval = ray_pqueue(&ir);
if (!rval)
@@ -442,9 +411,9 @@ register int n;
if (sbuffer[n] != 1)
error(CONSISTENCY, "bad code in ray_refine");
if (getambcolor(ctmp, obuffer[n]) &&
- (colval(ctmp,RED) > 0.01 &
- colval(ctmp,GRN) > 0.01 &
- colval(ctmp,BLU) > 0.01)) {
+ (colval(ctmp,RED) > 0.01) &
+ (colval(ctmp,GRN) > 0.01) &
+ (colval(ctmp,BLU) > 0.01)) {
for (i = 0; i < 3; i++)
asump->diffsum[i] +=
(colval(ir.rcol,i) - colval(cbuffer[n],i))
@@ -472,8 +441,9 @@ register int n;
static long
-refine_rays(nrays) /* compute refinement rays */
-long nrays;
+refine_rays( /* compute refinement rays */
+ long nrays
int *pord;
int ntodo;
@@ -481,7 +451,7 @@ long nrays;
int i;
/* skip if nothing significant */
if (ndtset && cerrzero)
- return;
+ return(0);
/* initialize priority list */
pord = (int *)malloc(sizeof(int)*hres*vres);
for (i = hres*vres; i--; )
@@ -517,20 +487,21 @@ long nrays;
int
-refine_frame(pass) /* refine current frame */
-int pass;
+refine_frame( /* refine current frame */
+ int pass
static double rtime_used = 0;
static long ray_cnt = 0;
static double ctime_used = 0;
static int csp_cnt = 0;
- int timed = (fcur > fbeg | pass > 0 | quickstart);
+ int timed = (fcur > fbeg) | (pass > 0) | (quickstart);
double time_start, rtime_start, time_done;
struct AmbSum myAmbSum;
long rays_todo, nr;
- register int n;
+ int n;
/* IBR refinement? */
- if ((pass == 0 & fcur > fbeg))
+ if ((pass == 0) & (fcur > fbeg))
return(refine_first());
/* any time left? */
time_start = getTime();
@@ -607,7 +578,7 @@ if (pass == 1) {
if (!silent) {
printf("\tRefinement pass %d...",
- pass+1, rays_todo);
+ pass+1); /*, rays_todo); */
fflush(stdout);
if (asump != NULL) /* flag low-quality samples */
@@ -617,7 +588,7 @@ if (pass == 1) {
/* trace those rays */
nr = refine_rays(rays_todo);
if (!silent)
- printf("traced %d HQ rays\n", nr);
+ printf("traced %ld HQ rays\n", nr);
if (nr <= 0)
return(0);
/* update timing stats */
@@ -652,7 +623,7 @@ if (pass == 1) {
return(1);
nomore:
/* make sure error map is updated */
- if ((fcur == fbeg | pass > 1))
+ if ((fcur == fbeg) | (pass > 1))
comp_frame_error();
return(0);
