| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: ranimove1.c,v 3.4 2003/06/30 14:59:13 schorsch Exp $";
| 3 |
#endif
| 4 |
| 5 |
* ranimove1.c
| 6 |
| 7 |
* Basic frame rendering routines for ranimate(1).
| 8 |
| 9 |
* Created by Gregory Ward on Wed Jan 08 2003.
| 10 |
| 11 |
| 12 |
#include "copyright.h"
| 13 |
| 14 |
#include <string.h>
| 15 |
| 16 |
#include "platform.h"
| 17 |
#include "ranimove.h"
| 18 |
#include "otypes.h"
| 19 |
#include "random.h"
| 20 |
| 21 |
double acctab[256]; /* accuracy value table */
| 22 |
| 23 |
int hres, vres; /* frame resolution (fcur) */
| 24 |
double pixaspect; /* pixel aspect ratio */
| 25 |
| 26 |
VIEW vw; /* view for this frame */
| 27 |
COLOR *cbuffer; /* color at each pixel */
| 28 |
float *zbuffer; /* depth at each pixel */
| 29 |
OBJECT *obuffer; /* object id at each pixel */
| 30 |
short *xmbuffer; /* x motion at each pixel */
| 31 |
short *ymbuffer; /* y motion at each pixel */
| 32 |
BYTE *abuffer; /* accuracy at each pixel */
| 33 |
BYTE *sbuffer; /* sample count per pixel */
| 34 |
| 35 |
VIEW vwprev; /* last frame's view */
| 36 |
COLOR *cprev; /* last frame colors */
| 37 |
float *zprev; /* last frame depth */
| 38 |
OBJECT *oprev; /* last frame objects */
| 39 |
BYTE *aprev; /* last frame accuracy */
| 40 |
| 41 |
float *cerrmap; /* conspicuous error map */
| 42 |
COLOR *val2map; /* value-squared map for variance */
| 43 |
| 44 |
double frm_stop; /* when to stop rendering this frame */
| 45 |
| 46 |
double hlsmax; /* maximum high-level saliency this frame */
| 47 |
| 48 |
| 49 |
void
| 50 |
write_map(mp, fn) /* write out float map (debugging) */
| 51 |
float *mp;
| 52 |
char *fn;
| 53 |
| 54 |
FILE *fp = fopen(fn, "w");
| 55 |
COLOR scanbuf[2048];
| 56 |
int x, y;
| 57 |
| 58 |
if (fp == NULL)
| 59 |
return;
| 60 |
newheader("RADIANCE", fp);
| 61 |
fputformat(COLRFMT, fp);
| 62 |
fputc('\n', fp); /* end header */
| 63 |
fprtresolu(hres, vres, fp);
| 64 |
for (y = vres; y--; ) { /* write scanlines */
| 65 |
float *bp = mp + (y+1)*hres - 1;
| 66 |
for (x = hres; x--; bp--)
| 67 |
setcolor(scanbuf[x], *bp, *bp, *bp);
| 68 |
if (fwritescan(scanbuf, hres, fp) < 0)
| 69 |
break;
| 70 |
| 71 |
fclose(fp);
| 72 |
| 73 |
| 74 |
| 75 |
static void
| 76 |
next_frame() /* prepare next frame buffer */
| 77 |
| 78 |
VIEW *fv;
| 79 |
char *err;
| 80 |
/* get previous view */
| 81 |
if (vw.type != 0)
| 82 |
vwprev = vw;
| 83 |
else if (fcur > 1 && (fv = getview(fcur-1)) != NULL) {
| 84 |
vwprev = *fv;
| 85 |
if (setview(&vwprev) != NULL)
| 86 |
vwprev.type = 0;
| 87 |
| 88 |
/* get current view */
| 89 |
if ((fv = getview(fcur)) == NULL) {
| 90 |
sprintf(errmsg, "cannot get view for frame %d", fcur);
| 91 |
error(USER, errmsg);
| 92 |
| 93 |
vw = *fv;
| 94 |
if ((err = setview(&vw)) != NULL) {
| 95 |
sprintf(errmsg, "view error at frame %d: %s", fcur, err);
| 96 |
| 97 |
| 98 |
if (cbuffer == NULL) {
| 99 |
/* compute resolution and allocate */
| 100 |
switch (sscanf(vval(RESOLUTION), "%d %d %lf",
| 101 |
&hres, &vres, &pixaspect)) {
| 102 |
case 1:
| 103 |
vres = hres;
| 104 |
/* fall through */
| 105 |
case 2:
| 106 |
pixaspect = 1.;
| 107 |
/* fall through */
| 108 |
case 3:
| 109 |
if ((hres > 0 & vres > 0))
| 110 |
break;
| 111 |
/* fall through */
| 112 |
default:
| 113 |
sprintf(errmsg, "bad %s value", vnam(RESOLUTION));
| 114 |
| 115 |
| 116 |
normaspect(viewaspect(&vw), &pixaspect, &hres, &vres);
| 117 |
cbuffer = (COLOR *)malloc(sizeof(COLOR)*hres*vres);
| 118 |
zbuffer = (float *)malloc(sizeof(float)*hres*vres);
| 119 |
obuffer = (OBJECT *)malloc(sizeof(OBJECT)*hres*vres);
| 120 |
xmbuffer = (short *)malloc(sizeof(short)*hres*vres);
| 121 |
ymbuffer = (short *)malloc(sizeof(short)*hres*vres);
| 122 |
abuffer = (BYTE *)calloc(hres*vres, sizeof(BYTE));
| 123 |
sbuffer = (BYTE *)calloc(hres*vres, sizeof(BYTE));
| 124 |
cprev = (COLOR *)malloc(sizeof(COLOR)*hres*vres);
| 125 |
zprev = (float *)malloc(sizeof(float)*hres*vres);
| 126 |
oprev = (OBJECT *)malloc(sizeof(OBJECT)*hres*vres);
| 127 |
aprev = (BYTE *)malloc(sizeof(BYTE)*hres*vres);
| 128 |
if ((cbuffer==NULL | zbuffer==NULL | obuffer==NULL |
| 129 |
xmbuffer==NULL | ymbuffer==NULL |
| 130 |
abuffer==NULL | sbuffer==NULL |
| 131 |
cprev==NULL | zprev == NULL |
| 132 |
oprev==NULL | aprev==NULL))
| 133 |
error(SYSTEM, "out of memory in init_frame");
| 134 |
frm_stop = getTime() + rtperfrm;
| 135 |
} else {
| 136 |
COLOR *cp; /* else just swap buffers */
| 137 |
float *fp;
| 138 |
OBJECT *op;
| 139 |
BYTE *bp;
| 140 |
cp = cprev; cprev = cbuffer; cbuffer = cp;
| 141 |
fp = zprev; zprev = zbuffer; zbuffer = fp;
| 142 |
op = oprev; oprev = obuffer; obuffer = op;
| 143 |
bp = aprev; aprev = abuffer; abuffer = bp;
| 144 |
memset(abuffer, '\0', sizeof(BYTE)*hres*vres);
| 145 |
memset(sbuffer, '\0', sizeof(BYTE)*hres*vres);
| 146 |
frm_stop += rtperfrm;
| 147 |
| 148 |
cerrmap = NULL;
| 149 |
val2map = NULL;
| 150 |
| 151 |
| 152 |
| 153 |
#define SAMPDIST 3 /* Maximum distance to neighbor sample */
| 154 |
#define SAMPDIST2 (SAMPDIST*SAMPDIST)
| 155 |
| 156 |
| 157 |
static int
| 158 |
sample_here(x, y) /* 4x4 quincunx sample at this pixel? */
| 159 |
register int x, y;
| 160 |
| 161 |
if (y & 0x1) /* every other row has samples */
| 162 |
return(0);
| 163 |
if (y & 0x3) /* every fourth row is offset */
| 164 |
x += 2;
| 165 |
return((x & 0x3) == 0); /* every fourth column is sampled */
| 166 |
| 167 |
| 168 |
| 169 |
void
| 170 |
sample_pos(hv, x, y, sn) /* compute jittered sample position */
| 171 |
double hv[2];
| 172 |
int x, y;
| 173 |
int sn;
| 174 |
| 175 |
int hl[2];
| 176 |
| 177 |
hl[0] = x; hl[1] = y;
| 178 |
multisamp(hv, 2, urand(ilhash(hl,2) + sn));
| 179 |
hv[0] = ((double)x + hv[0]) / (double)hres;
| 180 |
hv[1] = ((double)y + hv[1]) / (double)vres;
| 181 |
| 182 |
| 183 |
| 184 |
double
| 185 |
sample_wt(xo, yo) /* compute interpolant sample weight */
| 186 |
int xo, yo;
| 187 |
| 188 |
static double etab[400];
| 189 |
int rad2 = xo*xo + yo*yo;
| 190 |
int i;
| 191 |
| 192 |
if (etab[0] <= FTINY) /* initialize exponent table */
| 193 |
for (i = 400; i--; )
| 194 |
etab[i] = exp(-0.1*i);
| 195 |
| 196 |
/* look up Gaussian */
| 197 |
i = (int)((10.*3./(double)SAMPDIST2)*rad2 + .5);
| 198 |
if (i >= 400)
| 199 |
return(0.0);
| 200 |
return(etab[i]);
| 201 |
| 202 |
| 203 |
| 204 |
static int
| 205 |
offset_cmp(p1, p2) /* compare offset distances */
| 206 |
const void *p1, *p2;
| 207 |
| 208 |
return(*(const int *)p1 - *(const int *)p2);
| 209 |
| 210 |
| 211 |
| 212 |
int
| 213 |
getclosest(iarr, nc, x, y) /* get nc closest neighbors on same object */
| 214 |
int *iarr;
| 215 |
int nc;
| 216 |
int x, y;
| 217 |
| 218 |
#define NSCHECK ((2*SAMPDIST+1)*(2*SAMPDIST+1))
| 219 |
static int hro, vro;
| 220 |
static int ioffs[NSCHECK];
| 221 |
OBJECT myobj;
| 222 |
int i0, nf;
| 223 |
register int i, j;
| 224 |
/* get our object number */
| 225 |
myobj = obuffer[fndx(x, y)];
| 226 |
/* special case for borders */
| 227 |
if ((x < SAMPDIST | x >= hres-SAMPDIST |
| 228 |
y < SAMPDIST | y >= vres-SAMPDIST)) {
| 229 |
int tndx[NSCHECK][2];
| 230 |
nf = 0;
| 231 |
for (j = y - SAMPDIST; j <= y + SAMPDIST; j++) {
| 232 |
if (j >= vres) break;
| 233 |
if (j < 0) j = 0;
| 234 |
for (i = x - SAMPDIST; i <= x + SAMPDIST; i++) {
| 235 |
if (i >= hres) break;
| 236 |
if (i < 0) i = 0;
| 237 |
i0 = fndx(i, j);
| 238 |
if (!sbuffer[i0])
| 239 |
continue;
| 240 |
if ((myobj != OVOID & obuffer[i0] != myobj))
| 241 |
continue;
| 242 |
tndx[nf][0] = (i-x)*(i-x) + (j-y)*(j-y);
| 243 |
tndx[nf][1] = i0;
| 244 |
nf++;
| 245 |
| 246 |
| 247 |
qsort((void *)tndx, nf, 2*sizeof(int), offset_cmp);
| 248 |
if (nf > nc)
| 249 |
nf = nc;
| 250 |
for (i = nf; i--; )
| 251 |
iarr[i] = tndx[i][1];
| 252 |
return(nf);
| 253 |
| 254 |
/* initialize offset array */
| 255 |
if ((hres != hro | vres != vro)) {
| 256 |
int toffs[NSCHECK][2];
| 257 |
i0 = fndx(SAMPDIST, SAMPDIST);
| 258 |
nf = 0;
| 259 |
for (i = 0; i <= 2*SAMPDIST; i++)
| 260 |
for (j = 0; j <= 2*SAMPDIST; j++) {
| 261 |
toffs[nf][0] = (i-SAMPDIST)*(i-SAMPDIST) +
| 262 |
(j-SAMPDIST)*(j-SAMPDIST);
| 263 |
toffs[nf][1] = fndx(i, j) - i0;
| 264 |
nf++;
| 265 |
| 266 |
qsort((void *)toffs, nf, 2*sizeof(int), offset_cmp);
| 267 |
for (i = NSCHECK; i--; )
| 268 |
ioffs[i] = toffs[i][1];
| 269 |
hro = hres;
| 270 |
vro = vres;
| 271 |
| 272 |
/* find up to nc neighbors */
| 273 |
i0 = fndx(x, y);
| 274 |
for (j = 0, nf = 0; (j < NSCHECK & nf < nc); j++) {
| 275 |
i = i0 + ioffs[j];
| 276 |
if (sbuffer[i] && (myobj == OVOID | obuffer[i] == myobj))
| 277 |
iarr[nf++] = i;
| 278 |
| 279 |
/* return number found */
| 280 |
return(nf);
| 281 |
#undef NSCHECK
| 282 |
| 283 |
| 284 |
| 285 |
static void
| 286 |
setmotion(n, wpos) /* compute motion vector for this pixel */
| 287 |
register int n;
| 288 |
FVECT wpos;
| 289 |
| 290 |
FVECT ovp;
| 291 |
MAT4 xfm;
| 292 |
double d;
| 293 |
int moi;
| 294 |
int xp, yp;
| 295 |
/* ID object and update maximum HLS */
| 296 |
moi = getmove(obuffer[n]);
| 297 |
if (moi >= 0 && obj_move[moi].cprio > hlsmax)
| 298 |
hlsmax = obj_move[moi].cprio;
| 299 |
if (vwprev.type == 0) /* return leaves MO_UNK */
| 300 |
return;
| 301 |
if (moi >= 0) { /* move object point back */
| 302 |
multp3(ovp, wpos, obj_move[moi].bxfm);
| 303 |
wpos = ovp;
| 304 |
| 305 |
viewloc(ovp, &vwprev, wpos);
| 306 |
if (ovp[2] <= FTINY)
| 307 |
return;
| 308 |
xp = (int)(ovp[0]*hres);
| 309 |
yp = (int)(ovp[1]*vres);
| 310 |
xmbuffer[n] = xp - (n % hres);
| 311 |
ymbuffer[n] = yp - (n / hres);
| 312 |
if ((xp < 0 | xp >= hres))
| 313 |
return;
| 314 |
if ((yp < 0 | yp >= vres))
| 315 |
return;
| 316 |
n = fndx(xp, yp);
| 317 |
if ((zprev[n] < 0.97*ovp[2] | zprev[n] > 1.03*ovp[2]))
| 318 |
oprev[n] = OVOID; /* assume it's a bad match */
| 319 |
| 320 |
| 321 |
| 322 |
static void
| 323 |
init_frame_sample() /* sample our initial frame */
| 324 |
| 325 |
RAY ir;
| 326 |
int x, y;
| 327 |
register int n;
| 328 |
| 329 |
if (!silent) {
| 330 |
printf("\tComputing initial samples...");
| 331 |
fflush(stdout);
| 332 |
| 333 |
hlsmax = CSF_SMN;
| 334 |
| 335 |
for (x = hres; x--; ) {
| 336 |
double hv[2];
| 337 |
n = fndx(x, y);
| 338 |
xmbuffer[n] = MO_UNK;
| 339 |
ymbuffer[n] = MO_UNK;
| 340 |
sample_pos(hv, x, y, 0);
| 341 |
ir.rmax = viewray(ir.rorg, ir.rdir, &vw, hv[0], hv[1]);
| 342 |
if (ir.rmax < -FTINY) {
| 343 |
setcolor(cbuffer[n], 0., 0., 0.);
| 344 |
zbuffer[n] = FHUGE;
| 345 |
obuffer[n] = OVOID;
| 346 |
abuffer[n] = ADISTANT;
| 347 |
continue;
| 348 |
| 349 |
if (!sample_here(x, y)) { /* just cast */
| 350 |
rayorigin(&ir, NULL, PRIMARY, 1.0);
| 351 |
if (!localhit(&ir, &thescene)) {
| 352 |
if (ir.ro != &Aftplane)
| 353 |
sourcehit(&ir);
| 354 |
copycolor(cbuffer[n], ir.rcol);
| 355 |
zbuffer[n] = ir.rot;
| 356 |
obuffer[n] = ir.robj;
| 357 |
| 358 |
sbuffer[n] = 1;
| 359 |
} else {
| 360 |
| 361 |
| 362 |
setmotion(n, ir.rop);
| 363 |
| 364 |
continue;
| 365 |
| 366 |
if (nprocs > 1) { /* get sample */
| 367 |
int rval;
| 368 |
| 369 |
ir.rno = n;
| 370 |
rval = ray_pqueue(&ir);
| 371 |
if (!rval)
| 372 |
continue;
| 373 |
if (rval < 0)
| 374 |
quit(1);
| 375 |
n = ir.rno;
| 376 |
} else
| 377 |
ray_trace(&ir);
| 378 |
| 379 |
| 380 |
| 381 |
sbuffer[n] = 1;
| 382 |
if (ir.rot >= FHUGE)
| 383 |
| 384 |
else {
| 385 |
abuffer[n] = ALOWQ;
| 386 |
| 387 |
| 388 |
| 389 |
if (nprocs > 1) /* get stragglers */
| 390 |
while (ray_presult(&ir, 0)) {
| 391 |
n = ir.rno;
| 392 |
| 393 |
| 394 |
| 395 |
sbuffer[n] = 1;
| 396 |
| 397 |
| 398 |
else {
| 399 |
abuffer[n] = ALOWQ;
| 400 |
| 401 |
| 402 |
| 403 |
/* ambiguate object boundaries */
| 404 |
for (y = vres-1; y--; )
| 405 |
for (x = hres-1; x--; ) {
| 406 |
OBJECT obj;
| 407 |
n = fndx(x, y);
| 408 |
if ((obj = obuffer[n]) == OVOID)
| 409 |
continue;
| 410 |
if ((obuffer[n+1] != OVOID & obuffer[n+1] != obj)) {
| 411 |
obuffer[n] = OVOID;
| 412 |
obuffer[n+1] = OVOID;
| 413 |
| 414 |
if ((obuffer[n+hres] != OVOID & obuffer[n+hres] != obj)) {
| 415 |
obuffer[n] = OVOID;
| 416 |
obuffer[n+hres] = OVOID;
| 417 |
| 418 |
| 419 |
| 420 |
if (!silent)
| 421 |
printf("done\n");
| 422 |
| 423 |
| 424 |
| 425 |
int
| 426 |
getambcolor(clr, obj) /* get ambient color for object if we can */
| 427 |
COLOR clr;
| 428 |
int obj;
| 429 |
| 430 |
register OBJREC *op;
| 431 |
| 432 |
if (obj == OVOID)
| 433 |
return(0);
| 434 |
op = objptr(obj);
| 435 |
if ((op->otype == OBJ_INSTANCE & op->omod == OVOID))
| 436 |
return(0);
| 437 |
/* search for material */
| 438 |
do {
| 439 |
if (op->omod == OVOID || ofun[op->otype].flags & T_X)
| 440 |
return(0);
| 441 |
op = objptr(op->omod);
| 442 |
} while (!ismaterial(op->otype));
| 443 |
| 444 |
* Since this routine is called to compute the difference
| 445 |
* from rendering with and without interreflections,
| 446 |
* we don't want to return colors for materials that are
| 447 |
* explicitly excluded from the HQ ambient calculation.
| 448 |
| 449 |
if (hirendparams.ambincl >= 0) {
| 450 |
int i;
| 451 |
char *lv;
| 452 |
for (i = 0; (lv = rpambmod(&hirendparams,i)) != NULL; i++)
| 453 |
if (lv[0] == op->oname[0] &&
| 454 |
!strcmp(lv+1, op->oname+1))
| 455 |
break;
| 456 |
if ((lv != NULL) != hirendparams.ambincl)
| 457 |
return(0);
| 458 |
| 459 |
switch (op->otype) {
| 460 |
case MAT_PLASTIC:
| 461 |
case MAT_METAL:
| 462 |
case MAT_PLASTIC2:
| 463 |
case MAT_METAL2:
| 464 |
case MAT_PFUNC:
| 465 |
case MAT_MFUNC:
| 466 |
case MAT_PDATA:
| 467 |
case MAT_MDATA:
| 468 |
case MAT_TRANS:
| 469 |
case MAT_TRANS2:
| 470 |
case MAT_TFUNC:
| 471 |
case MAT_TDATA:
| 472 |
if (op->oargs.nfargs < 3)
| 473 |
return(0);
| 474 |
setcolor(clr, op->oargs.farg[0], op->oargs.farg[1],
| 475 |
op->oargs.farg[2]);
| 476 |
return(1);
| 477 |
case MAT_BRTDF:
| 478 |
if (op->oargs.nfargs < 6)
| 479 |
return(0);
| 480 |
setcolor(clr, op->oargs.farg[0]+op->oargs.farg[3],
| 481 |
op->oargs.farg[1]+op->oargs.farg[4],
| 482 |
op->oargs.farg[2]+op->oargs.farg[5]);
| 483 |
scalecolor(clr, 0.5);
| 484 |
return(1);
| 485 |
case MAT_LIGHT:
| 486 |
case MAT_GLOW:
| 487 |
case MAT_ILLUM:
| 488 |
setcolor(clr, 0., 0., 0.);
| 489 |
return(1);
| 490 |
| 491 |
return(0);
| 492 |
| 493 |
| 494 |
| 495 |
double
| 496 |
estimaterr(cs, cs2, ns, ns0) /* estimate relative error from samples */
| 497 |
COLOR cs, cs2;
| 498 |
int ns;
| 499 |
| 500 |
double d, d2, brt;
| 501 |
| 502 |
if (ns <= 1 || (brt = bright(cs)/ns) < 1e-14)
| 503 |
return(1.0);
| 504 |
/* use largest of RGB std. dev. */
| 505 |
d2 = colval(cs2,RED) - colval(cs,RED)*colval(cs,RED)/ns;
| 506 |
d = colval(cs2,GRN) - colval(cs,GRN)*colval(cs,GRN)/ns;
| 507 |
if (d > d2) d2 = d;
| 508 |
d = colval(cs2,BLU) - colval(cs,BLU)*colval(cs,BLU)/ns;
| 509 |
if (d > d2) d2 = d;
| 510 |
/* use s.d. if <= 1 central sample */
| 511 |
if (ns0 <= 1)
| 512 |
return(sqrt(d2/(ns-1))/brt);
| 513 |
/* use s.d./sqrt(ns0) otherwise */
| 514 |
return(sqrt(d2/((ns-1)*ns0))/brt);
| 515 |
| 516 |
| 517 |
| 518 |
double
| 519 |
comperr(neigh, nc, ns0) /* estimate relative error in neighborhood */
| 520 |
int *neigh;
| 521 |
int nc;
| 522 |
int ns0;
| 523 |
| 524 |
COLOR csum, csum2;
| 525 |
COLOR ctmp;
| 526 |
int i;
| 527 |
int ns;
| 528 |
register int n;
| 529 |
/* add together samples */
| 530 |
setcolor(csum, 0., 0., 0.);
| 531 |
setcolor(csum2, 0., 0., 0.);
| 532 |
for (i = 0, ns = 0; (i < nc & ns < NSAMPOK); i++) {
| 533 |
n = neigh[i];
| 534 |
addcolor(csum, cbuffer[n]);
| 535 |
if (val2map != NULL) {
| 536 |
addcolor(csum2, val2map[n]);
| 537 |
ns += sbuffer[n];
| 538 |
continue;
| 539 |
| 540 |
if (sbuffer[n] != 1)
| 541 |
error(CONSISTENCY, "bad count in comperr");
| 542 |
setcolor(ctmp,
| 543 |
colval(cbuffer[n],RED)*colval(cbuffer[n],RED),
| 544 |
colval(cbuffer[n],GRN)*colval(cbuffer[n],GRN),
| 545 |
colval(cbuffer[n],BLU)*colval(cbuffer[n],BLU));
| 546 |
addcolor(csum2, ctmp);
| 547 |
ns++;
| 548 |
| 549 |
return(estimaterr(csum, csum2, ns, ns0));
| 550 |
| 551 |
| 552 |
| 553 |
void
| 554 |
comp_frame_error() /* initialize frame error values */
| 555 |
| 556 |
BYTE *edone = NULL;
| 557 |
COLOR objamb;
| 558 |
double eest;
| 559 |
int neigh[NSAMPOK];
| 560 |
int nc;
| 561 |
int x, y, i, j;
| 562 |
register int n;
| 563 |
| 564 |
if (!silent) {
| 565 |
printf("\tComputing error map\n");
| 566 |
fflush(stdout);
| 567 |
| 568 |
if (acctab[0] <= FTINY) /* initialize accuracy table */
| 569 |
for (i = 256; i--; )
| 570 |
acctab[i] = errorf(i);
| 571 |
/* estimate sample error */
| 572 |
if (!curparams->ambounce && hirendparams.ambounce) {
| 573 |
| 574 |
* Our error estimate for the initial value is based
| 575 |
* on the assumption that most of it comes from the
| 576 |
* lack of an interreflection calculation. The relative
| 577 |
* error should be less than the ambient value divided
| 578 |
* by the returned ray value -- we take half of this.
| 579 |
| 580 |
edone = (BYTE *)calloc(hres*vres, sizeof(BYTE));
| 581 |
| 582 |
| 583 |
n = fndx(x, y);
| 584 |
if ((abuffer[n] != ALOWQ | obuffer[n] == OVOID))
| 585 |
continue;
| 586 |
if (!getambcolor(objamb, obuffer[n]))
| 587 |
continue;
| 588 |
multcolor(objamb, ambval);
| 589 |
if ((eest = bright(cbuffer[n])) <= FTINY)
| 590 |
continue;
| 591 |
eest = bright(objamb) / eest;
| 592 |
if (eest > 1.) /* should we report this? */
| 593 |
continue;
| 594 |
eest *= 0.50; /* use 50% ambient error */
| 595 |
i = errori(eest);
| 596 |
if (i < AMIN) i = AMIN;
| 597 |
else if (i >= ADISTANT/2) i = ADISTANT/2-1;
| 598 |
abuffer[n] = i;
| 599 |
edone[n] = 1;
| 600 |
| 601 |
| 602 |
/* final statistical estimate */
| 603 |
| 604 |
| 605 |
n = fndx(x, y);
| 606 |
if (abuffer[n] == ADISTANT)
| 607 |
continue; /* don't update these */
| 608 |
if (edone != NULL && edone[n])
| 609 |
continue; /* already done this */
| 610 |
if (sbuffer[n] >= 255) {
| 611 |
| 612 |
continue; /* can't take any more */
| 613 |
| 614 |
nc = getclosest(neigh, NSAMPOK, x, y);
| 615 |
if (nc <= 0) {
| 616 |
abuffer[n] = ANOVAL;
| 617 |
continue; /* no clue what to do for him */
| 618 |
| 619 |
i = errori(comperr(neigh, nc, sbuffer[n]));
| 620 |
| 621 |
else if (i >= ADISTANT) i = ADISTANT-1;
| 622 |
abuffer[n] = i;
| 623 |
/* can't be better than closest */
| 624 |
if (i < abuffer[neigh[0]] && abuffer[neigh[0]] >= AMIN)
| 625 |
abuffer[n] = abuffer[neigh[0]];
| 626 |
| 627 |
if (edone != NULL)
| 628 |
free((void *)edone);
| 629 |
| 630 |
| 631 |
| 632 |
void
| 633 |
init_frame() /* render base (low quality) frame */
| 634 |
| 635 |
int restart;
| 636 |
| 637 |
/* allocate/swap buffers */
| 638 |
next_frame();
| 639 |
/* check rendering status */
| 640 |
restart = (!nobjects || vdef(MOVE));
| 641 |
if (!restart && curparams != &lorendparams && nprocs > 1)
| 642 |
restart = -1;
| 643 |
if (restart > 0) {
| 644 |
if (nprocs > 1)
| 645 |
ray_pdone(1);
| 646 |
else
| 647 |
ray_done(1);
| 648 |
| 649 |
/* post low quality parameters */
| 650 |
if (curparams != &lorendparams)
| 651 |
ray_restore(curparams = &lorendparams);
| 652 |
if (restart > 0) { /* load new octree */
| 653 |
char *oct = getoctspec(fcur);
| 654 |
if (oct == NULL) {
| 655 |
sprintf(errmsg, "cannot get scene for frame %d", fcur);
| 656 |
| 657 |
| 658 |
if (!silent) {
| 659 |
printf("\tLoading octree...");
| 660 |
fflush(stdout);
| 661 |
| 662 |
if (nprocs > 1)
| 663 |
ray_pinit(oct, nprocs);
| 664 |
else
| 665 |
ray_init(oct);
| 666 |
} else if (restart < 0) { /* update children */
| 667 |
if (!silent) {
| 668 |
printf("\tRestarting %d processes...", nprocs);
| 669 |
fflush(stdout);
| 670 |
| 671 |
ray_pclose(0);
| 672 |
ray_popen(nprocs);
| 673 |
| 674 |
if (restart && !silent)
| 675 |
printf("done\n");
| 676 |
/* sample frame buffer */
| 677 |
init_frame_sample();
| 678 |
/* initialize frame error */
| 679 |
comp_frame_error();
| 680 |
return;
| 681 |
| 682 |
float *ebuf = (float *)malloc(sizeof(float)*hres*vres);
| 683 |
char fnm[256];
| 684 |
register int n;
| 685 |
for (n = hres*vres; n--; )
| 686 |
ebuf[n] = acctab[abuffer[n]];
| 687 |
sprintf(fnm, vval(BASENAME), fcur);
| 688 |
strcat(fnm, "_inerr.pic");
| 689 |
write_map(ebuf, fnm);
| 690 |
free((void *)ebuf);
| 691 |
| 692 |
| 693 |
| 694 |
| 695 |
void
| 696 |
filter_frame() /* interpolation, motion-blur, and exposure */
| 697 |
| 698 |
double expval = expspec_val(getexp(fcur));
| 699 |
int x, y;
| 700 |
int neigh[NPINTERP];
| 701 |
int nc;
| 702 |
COLOR cval;
| 703 |
double w, wsum;
| 704 |
register int n;
| 705 |
| 706 |
#if 0
| 707 |
/* XXX TEMPORARY!! */
| 708 |
conspicuity();
| 709 |
write_map(cerrmap, "outcmap.pic");
| 710 |
| 711 |
| 712 |
| 713 |
| 714 |
write_map(ebuf, "outerr.pic");
| 715 |
free((void *)ebuf);
| 716 |
| 717 |
#endif
| 718 |
| 719 |
if (!silent) {
| 720 |
printf("\tFiltering frame\n");
| 721 |
fflush(stdout);
| 722 |
| 723 |
/* normalize samples */
| 724 |
| 725 |
| 726 |
n = fndx(x, y);
| 727 |
if (sbuffer[n] <= 1)
| 728 |
continue;
| 729 |
w = 1.0/(double)sbuffer[n];
| 730 |
scalecolor(cbuffer[n], w);
| 731 |
| 732 |
/* interpolate samples */
| 733 |
| 734 |
| 735 |
n = fndx(x, y);
| 736 |
if (sbuffer[n])
| 737 |
continue;
| 738 |
nc = getclosest(neigh, NPINTERP, x, y);
| 739 |
| 740 |
wsum = 0.;
| 741 |
while (nc-- > 0) {
| 742 |
copycolor(cval, cbuffer[neigh[nc]]);
| 743 |
w = sample_wt((neigh[nc]%hres) - x,
| 744 |
(neigh[nc]/hres) - y);
| 745 |
scalecolor(cval, w);
| 746 |
addcolor(cbuffer[n], cval);
| 747 |
wsum += w;
| 748 |
| 749 |
if (wsum > FTINY) {
| 750 |
w = 1.0/wsum;
| 751 |
| 752 |
| 753 |
| 754 |
/* motion blur if requested */
| 755 |
if (mblur > .02) {
| 756 |
int len;
| 757 |
int xs, ys, xl, yl;
| 758 |
int rise, run;
| 759 |
long rise2, run2;
| 760 |
int n2;
| 761 |
int cnt;
| 762 |
/* sum in motion streaks */
| 763 |
memset(outbuffer, '\0', sizeof(COLOR)*hres*vres);
| 764 |
memset(wbuffer, '\0', sizeof(float)*hres*vres);
| 765 |
| 766 |
| 767 |
n = fndx(x, y);
| 768 |
if (xmbuffer[n] == MO_UNK) {
| 769 |
run = rise = 0;
| 770 |
} else {
| 771 |
run = (int)(mblur*xmbuffer[n]);
| 772 |
rise = (int)(mblur*ymbuffer[n]);
| 773 |
| 774 |
if (!(run | rise)) {
| 775 |
addcolor(outbuffer[n], cbuffer[n]);
| 776 |
wbuffer[n] += 1.;
| 777 |
continue;
| 778 |
| 779 |
xl = x - run/4;
| 780 |
yl = y - rise/4;
| 781 |
if (run < 0) { xs = -1; run = -run; }
| 782 |
else xs = 1;
| 783 |
if (rise < 0) { ys = -1; rise = -rise; }
| 784 |
else ys = 1;
| 785 |
rise2 = run2 = 0L;
| 786 |
if (rise > run) {
| 787 |
cnt = rise + 1;
| 788 |
w = 1./cnt;
| 789 |
copycolor(cval, cbuffer[n]);
| 790 |
| 791 |
while (cnt)
| 792 |
if (rise2 >= run2) {
| 793 |
if ((xl >= 0 & xl < hres &
| 794 |
yl >= 0 & yl < vres)) {
| 795 |
n2 = fndx(xl, yl);
| 796 |
addcolor(outbuffer[n2],
| 797 |
cval);
| 798 |
wbuffer[n2] += w;
| 799 |
| 800 |
yl += ys;
| 801 |
run2 += run;
| 802 |
cnt--;
| 803 |
} else {
| 804 |
xl += xs;
| 805 |
rise2 += rise;
| 806 |
| 807 |
} else {
| 808 |
cnt = run + 1;
| 809 |
w = 1./cnt;
| 810 |
| 811 |
| 812 |
while (cnt)
| 813 |
if (run2 >= rise2) {
| 814 |
| 815 |
| 816 |
n2 = fndx(xl, yl);
| 817 |
| 818 |
cval);
| 819 |
wbuffer[n2] += w;
| 820 |
| 821 |
xl += xs;
| 822 |
rise2 += rise;
| 823 |
cnt--;
| 824 |
} else {
| 825 |
yl += ys;
| 826 |
run2 += run;
| 827 |
| 828 |
| 829 |
| 830 |
/* compute final results */
| 831 |
| 832 |
| 833 |
n = fndx(x, y);
| 834 |
if (wbuffer[n] <= FTINY)
| 835 |
continue;
| 836 |
w = 1./wbuffer[n];
| 837 |
scalecolor(outbuffer[n], w);
| 838 |
| 839 |
} else
| 840 |
| 841 |
copycolor(outbuffer[n], cbuffer[n]);
| 842 |
| 843 |
| 844 |
if (!sbuffer[n])
| 845 |
setcolor(outbuffer[n], 0., 0., 0.);
| 846 |
| 847 |
/* adjust exposure */
| 848 |
if ((expval < 0.99 | expval > 1.01))
| 849 |
| 850 |
scalecolor(outbuffer[n], expval);
| 851 |
return;
| 852 |
| 853 |
float *sbuf = (float *)malloc(sizeof(float)*hres*vres);
| 854 |
char fnm[256];
| 855 |
| 856 |
strcat(fnm, "_outsamp.pic");
| 857 |
| 858 |
sbuf[n] = (float)sbuffer[n];
| 859 |
write_map(sbuf, fnm);
| 860 |
free((void *)sbuf);
| 861 |
| 862 |
| 863 |
| 864 |
| 865 |
void
| 866 |
send_frame() /* send frame to destination */
| 867 |
| 868 |
char pfname[1024];
| 869 |
double d;
| 870 |
FILE *fp;
| 871 |
int y;
| 872 |
/* open output picture */
| 873 |
sprintf(pfname, vval(BASENAME), fcur);
| 874 |
strcat(pfname, ".pic");
| 875 |
fp = fopen(pfname, "w");
| 876 |
if (fp == NULL) {
| 877 |
sprintf(errmsg, "cannot open output frame \"%s\"", pfname);
| 878 |
error(SYSTEM, errmsg);
| 879 |
| 880 |
SET_FILE_BINARY(fp);
| 881 |
if (!silent) {
| 882 |
printf("\tWriting to \"%s\"\n", pfname);
| 883 |
fflush(stdout);
| 884 |
| 885 |
/* write header */
| 886 |
| 887 |
printargs(gargc, gargv, fp);
| 888 |
fprintf(fp, "SOFTWARE= %s\n", VersionID);
| 889 |
fprintf(fp, "FRAME=%d\n", fcur);
| 890 |
fputnow(fp);
| 891 |
fputs(VIEWSTR, fp); fprintview(&vw, fp); fputc('\n', fp);
| 892 |
d = expspec_val(getexp(fcur));
| 893 |
if ((d < 0.99 | d > 1.01))
| 894 |
fputexpos(d, fp);
| 895 |
d = viewaspect(&vw) * hres / vres;
| 896 |
| 897 |
fputaspect(d, fp);
| 898 |
| 899 |
| 900 |
| 901 |
if (fflush(fp) == EOF)
| 902 |
goto writerr;
| 903 |
#if (PIXSTANDARD != (YMAJOR|YDECR))
| 904 |
error(CONSISTENCY, "bad code in send_frame");
| 905 |
#endif
| 906 |
for (y = vres; y--; ) /* write scanlines */
| 907 |
if (fwritescan(outbuffer+y*hres, hres, fp) < 0)
| 908 |
goto writerr;
| 909 |
if (fclose(fp) == EOF)
| 910 |
goto writerr;
| 911 |
return; /* all is well */
| 912 |
writerr:
| 913 |
sprintf(errmsg, "error writing frame \"%s\"", pfname);
| 914 |
| 915 |
| 916 |
| 917 |
| 918 |
void
| 919 |
free_frame() /* free frame allocation */
| 920 |
| 921 |
| 922 |
return;
| 923 |
free((void *)cbuffer); cbuffer = NULL;
| 924 |
free((void *)zbuffer); zbuffer = NULL;
| 925 |
free((void *)obuffer); obuffer = NULL;
| 926 |
free((void *)xmbuffer); xmbuffer = NULL;
| 927 |
free((void *)ymbuffer); ymbuffer = NULL;
| 928 |
free((void *)cprev); cprev = NULL;
| 929 |
free((void *)zprev); zprev = NULL;
| 930 |
free((void *)oprev); oprev = NULL;
| 931 |
cerrmap = NULL;
| 932 |
val2map = NULL;
| 933 |
hres = vres = 0;
| 934 |
vw.type = vwprev.type = 0;
| 935 |
frm_stop = 0;
| 936 |
