| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: ranimove1.c,v 3.24 2018/11/17 20:15:51 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* ranimove1.c
| 6 |
| 7 |
* Basic frame rendering routines for ranimove(1).
| 8 |
| 9 |
* Created by Gregory Ward on Wed Jan 08 2003.
| 10 |
| 11 |
| 12 |
#include "copyright.h"
| 13 |
| 14 |
#include <string.h>
| 15 |
| 16 |
#include "platform.h"
| 17 |
#include "ranimove.h"
| 18 |
#include "otypes.h"
| 19 |
#include "otspecial.h"
| 20 |
#include "source.h"
| 21 |
#include "random.h"
| 22 |
| 23 |
double acctab[256]; /* accuracy value table */
| 24 |
| 25 |
int hres, vres; /* frame resolution (fcur) */
| 26 |
double pixaspect; /* pixel aspect ratio */
| 27 |
| 28 |
VIEW vw; /* view for this frame */
| 29 |
COLOR *cbuffer; /* color at each pixel */
| 30 |
float *zbuffer; /* depth at each pixel */
| 31 |
OBJECT *obuffer; /* object id at each pixel */
| 32 |
short *xmbuffer; /* x motion at each pixel */
| 33 |
short *ymbuffer; /* y motion at each pixel */
| 34 |
uby8 *abuffer; /* accuracy at each pixel */
| 35 |
uby8 *sbuffer; /* sample count per pixel */
| 36 |
| 37 |
VIEW vwprev; /* last frame's view */
| 38 |
COLOR *cprev; /* last frame colors */
| 39 |
float *zprev; /* last frame depth */
| 40 |
OBJECT *oprev; /* last frame objects */
| 41 |
uby8 *aprev; /* last frame accuracy */
| 42 |
| 43 |
float *cerrmap; /* conspicuous error map */
| 44 |
COLOR *val2map; /* value-squared map for variance */
| 45 |
| 46 |
double frm_stop; /* when to stop rendering this frame */
| 47 |
| 48 |
double hlsmax; /* maximum high-level saliency this frame */
| 49 |
| 50 |
| 51 |
static void next_frame(void);
| 52 |
static int sample_here(int x, int y);
| 53 |
static int offset_cmp(const void *p1, const void *p2);
| 54 |
static void setmotion(int n, FVECT wpos);
| 55 |
static void init_frame_sample(void);
| 56 |
| 57 |
| 58 |
#if 0
| 59 |
void
| 60 |
write_map( /* write out float map (debugging) */
| 61 |
float *mp,
| 62 |
char *fn
| 63 |
| 64 |
| 65 |
FILE *fp = fopen(fn, "w");
| 66 |
COLOR scanbuf[2048];
| 67 |
int x, y;
| 68 |
| 69 |
if (fp == NULL)
| 70 |
return;
| 71 |
newheader("RADIANCE", fp);
| 72 |
fputformat(COLRFMT, fp);
| 73 |
fputc('\n', fp); /* end header */
| 74 |
fprtresolu(hres, vres, fp);
| 75 |
for (y = vres; y--; ) { /* write scanlines */
| 76 |
float *bp = mp + (y+1)*hres - 1;
| 77 |
for (x = hres; x--; bp--)
| 78 |
setcolor(scanbuf[x], *bp, *bp, *bp);
| 79 |
if (fwritescan(scanbuf, hres, fp) < 0)
| 80 |
break;
| 81 |
| 82 |
fclose(fp);
| 83 |
| 84 |
#endif
| 85 |
| 86 |
| 87 |
static void
| 88 |
next_frame(void) /* prepare next frame buffer */
| 89 |
| 90 |
VIEW *fv;
| 91 |
char *err;
| 92 |
/* get previous view */
| 93 |
if (vw.type != 0)
| 94 |
vwprev = vw;
| 95 |
else if (fcur > 1 && (fv = getview(fcur-1)) != NULL) {
| 96 |
vwprev = *fv;
| 97 |
if (setview(&vwprev) != NULL)
| 98 |
vwprev.type = 0;
| 99 |
| 100 |
/* get current view */
| 101 |
if ((fv = getview(fcur)) == NULL) {
| 102 |
sprintf(errmsg, "cannot get view for frame %d", fcur);
| 103 |
error(USER, errmsg);
| 104 |
| 105 |
vw = *fv;
| 106 |
if ((err = setview(&vw)) != NULL) {
| 107 |
sprintf(errmsg, "view error at frame %d: %s", fcur, err);
| 108 |
| 109 |
| 110 |
if (cbuffer == NULL) {
| 111 |
int n;
| 112 |
/* compute resolution and allocate */
| 113 |
switch (sscanf(vval(RESOLUTION), "%d %d %lf",
| 114 |
&hres, &vres, &pixaspect)) {
| 115 |
case 1:
| 116 |
vres = hres;
| 117 |
/* fall through */
| 118 |
case 2:
| 119 |
pixaspect = 1.;
| 120 |
/* fall through */
| 121 |
case 3:
| 122 |
if ((hres > 0) & (vres > 0))
| 123 |
break;
| 124 |
/* fall through */
| 125 |
default:
| 126 |
sprintf(errmsg, "bad %s value", vnam(RESOLUTION));
| 127 |
| 128 |
| 129 |
normaspect(viewaspect(&vw), &pixaspect, &hres, &vres);
| 130 |
cbuffer = (COLOR *)malloc(sizeof(COLOR)*hres*vres);
| 131 |
zbuffer = (float *)malloc(sizeof(float)*hres*vres);
| 132 |
obuffer = (OBJECT *)malloc(sizeof(OBJECT)*hres*vres);
| 133 |
xmbuffer = (short *)malloc(sizeof(short)*hres*vres);
| 134 |
ymbuffer = (short *)malloc(sizeof(short)*hres*vres);
| 135 |
abuffer = (uby8 *)calloc(hres*vres, sizeof(uby8));
| 136 |
sbuffer = (uby8 *)calloc(hres*vres, sizeof(uby8));
| 137 |
cprev = (COLOR *)malloc(sizeof(COLOR)*hres*vres);
| 138 |
zprev = (float *)malloc(sizeof(float)*hres*vres);
| 139 |
oprev = (OBJECT *)malloc(sizeof(OBJECT)*hres*vres);
| 140 |
aprev = (uby8 *)malloc(sizeof(uby8)*hres*vres);
| 141 |
if ((cbuffer==NULL) | (zbuffer==NULL) | (obuffer==NULL) |
| 142 |
(xmbuffer==NULL) | (ymbuffer==NULL) |
| 143 |
(abuffer==NULL) | (sbuffer==NULL) |
| 144 |
(cprev==NULL) | (zprev == NULL) |
| 145 |
(oprev==NULL) | (aprev==NULL))
| 146 |
error(SYSTEM, "out of memory in init_frame");
| 147 |
for (n = hres*vres; n--; ) {
| 148 |
zprev[n] = -1.f;
| 149 |
oprev[n] = OVOID;
| 150 |
| 151 |
frm_stop = getTime() + rtperfrm;
| 152 |
} else {
| 153 |
COLOR *cp; /* else just swap buffers */
| 154 |
float *fp;
| 155 |
OBJECT *op;
| 156 |
uby8 *bp;
| 157 |
cp = cprev; cprev = cbuffer; cbuffer = cp;
| 158 |
fp = zprev; zprev = zbuffer; zbuffer = fp;
| 159 |
op = oprev; oprev = obuffer; obuffer = op;
| 160 |
bp = aprev; aprev = abuffer; abuffer = bp;
| 161 |
memset(abuffer, '\0', sizeof(uby8)*hres*vres);
| 162 |
memset(sbuffer, '\0', sizeof(uby8)*hres*vres);
| 163 |
frm_stop += rtperfrm;
| 164 |
| 165 |
cerrmap = NULL;
| 166 |
val2map = NULL;
| 167 |
| 168 |
| 169 |
| 170 |
#define SAMPDIST 3 /* Maximum distance to neighbor sample */
| 171 |
#define SAMPDIST2 (SAMPDIST*SAMPDIST)
| 172 |
| 173 |
| 174 |
static int
| 175 |
sample_here( /* 4x4 quincunx sample at this pixel? */
| 176 |
int x,
| 177 |
int y
| 178 |
| 179 |
| 180 |
if (y & 0x1) /* every other row has samples */
| 181 |
return(0);
| 182 |
if (y & 0x3) /* every fourth row is offset */
| 183 |
x += 2;
| 184 |
return((x & 0x3) == 0); /* every fourth column is sampled */
| 185 |
| 186 |
| 187 |
| 188 |
void
| 189 |
sample_pos( /* compute jittered sample position */
| 190 |
double hv[2],
| 191 |
int x,
| 192 |
int y,
| 193 |
int sn
| 194 |
| 195 |
| 196 |
int hl[2];
| 197 |
| 198 |
hl[0] = x; hl[1] = y;
| 199 |
multisamp(hv, 2, urand(ilhash(hl,2) + sn));
| 200 |
hv[0] = ((double)x + hv[0]) / (double)hres;
| 201 |
hv[1] = ((double)y + hv[1]) / (double)vres;
| 202 |
| 203 |
| 204 |
| 205 |
double
| 206 |
sample_wt( /* compute interpolant sample weight */
| 207 |
int xo,
| 208 |
int yo
| 209 |
| 210 |
| 211 |
static double etab[400];
| 212 |
/* we can't use the name rad2 here, for some reason Visual C
| 213 |
thinks that is a constant (compiler bug?) */
| 214 |
int rad_2 = xo*xo + yo*yo;
| 215 |
int i;
| 216 |
| 217 |
if (etab[0] <= FTINY) /* initialize exponent table */
| 218 |
for (i = 400; i--; )
| 219 |
etab[i] = exp(-0.1*i);
| 220 |
| 221 |
/* look up Gaussian */
| 222 |
i = (int)((10.*3./(double)SAMPDIST2)*rad_2 + .5);
| 223 |
if (i >= 400)
| 224 |
return(0.0);
| 225 |
return(etab[i]);
| 226 |
| 227 |
| 228 |
| 229 |
static int
| 230 |
offset_cmp( /* compare offset distances */
| 231 |
const void *p1,
| 232 |
const void *p2
| 233 |
| 234 |
| 235 |
return(*(const int *)p1 - *(const int *)p2);
| 236 |
| 237 |
| 238 |
| 239 |
int
| 240 |
getclosest( /* get nc closest neighbors on same object */
| 241 |
int *iarr,
| 242 |
int nc,
| 243 |
int x,
| 244 |
int y
| 245 |
| 246 |
| 247 |
#define NSCHECK ((2*SAMPDIST+1)*(2*SAMPDIST+1))
| 248 |
static int hro, vro;
| 249 |
static int ioffs[NSCHECK];
| 250 |
OBJECT myobj;
| 251 |
int i0, nf;
| 252 |
int i, j;
| 253 |
/* get our object number */
| 254 |
myobj = obuffer[fndx(x, y)];
| 255 |
/* special case for borders */
| 256 |
if ((x < SAMPDIST) | (x >= hres-SAMPDIST) |
| 257 |
(y < SAMPDIST) | (y >= vres-SAMPDIST)) {
| 258 |
int tndx[NSCHECK][2];
| 259 |
nf = 0;
| 260 |
for (j = y - SAMPDIST; j <= y + SAMPDIST; j++) {
| 261 |
if (j >= vres) break;
| 262 |
if (j < 0) j = 0;
| 263 |
for (i = x - SAMPDIST; i <= x + SAMPDIST; i++) {
| 264 |
if (i >= hres) break;
| 265 |
if (i < 0) i = 0;
| 266 |
i0 = fndx(i, j);
| 267 |
if (!sbuffer[i0])
| 268 |
continue;
| 269 |
if ((myobj != OVOID) & (obuffer[i0] != myobj))
| 270 |
continue;
| 271 |
tndx[nf][0] = (i-x)*(i-x) + (j-y)*(j-y);
| 272 |
tndx[nf][1] = i0;
| 273 |
nf++;
| 274 |
| 275 |
| 276 |
qsort((void *)tndx, nf, 2*sizeof(int), offset_cmp);
| 277 |
if (nf > nc)
| 278 |
nf = nc;
| 279 |
for (i = nf; i--; )
| 280 |
iarr[i] = tndx[i][1];
| 281 |
return(nf);
| 282 |
| 283 |
/* initialize offset array */
| 284 |
if ((hres != hro) | (vres != vro)) {
| 285 |
int toffs[NSCHECK][2];
| 286 |
i0 = fndx(SAMPDIST, SAMPDIST);
| 287 |
nf = 0;
| 288 |
for (i = 0; i <= 2*SAMPDIST; i++)
| 289 |
for (j = 0; j <= 2*SAMPDIST; j++) {
| 290 |
toffs[nf][0] = (i-SAMPDIST)*(i-SAMPDIST) +
| 291 |
(j-SAMPDIST)*(j-SAMPDIST);
| 292 |
toffs[nf][1] = fndx(i, j) - i0;
| 293 |
nf++;
| 294 |
| 295 |
qsort((void *)toffs, nf, 2*sizeof(int), offset_cmp);
| 296 |
for (i = NSCHECK; i--; )
| 297 |
ioffs[i] = toffs[i][1];
| 298 |
hro = hres;
| 299 |
vro = vres;
| 300 |
| 301 |
/* find up to nc neighbors */
| 302 |
i0 = fndx(x, y);
| 303 |
for (j = 0, nf = 0; (j < NSCHECK) & (nf < nc); j++) {
| 304 |
i = i0 + ioffs[j];
| 305 |
if (sbuffer[i] && (myobj == OVOID) | (obuffer[i] == myobj))
| 306 |
iarr[nf++] = i;
| 307 |
| 308 |
/* return number found */
| 309 |
return(nf);
| 310 |
#undef NSCHECK
| 311 |
| 312 |
| 313 |
| 314 |
static void
| 315 |
setmotion( /* compute motion vector for this pixel */
| 316 |
int n,
| 317 |
FVECT wpos
| 318 |
| 319 |
| 320 |
FVECT ovp;
| 321 |
int moi;
| 322 |
int xp, yp;
| 323 |
/* ID object and update maximum HLS */
| 324 |
moi = getmove(obuffer[n]);
| 325 |
if (moi >= 0 && obj_move[moi].cprio > hlsmax)
| 326 |
hlsmax = obj_move[moi].cprio;
| 327 |
if (vwprev.type == 0) /* return leaves MO_UNK */
| 328 |
return;
| 329 |
if (moi >= 0) { /* move object point back */
| 330 |
multp3(ovp, wpos, obj_move[moi].bxfm);
| 331 |
wpos = ovp;
| 332 |
| 333 |
if (viewloc(ovp, &vwprev, wpos) <= 0)
| 334 |
return;
| 335 |
xp = (int)(ovp[0]*hres);
| 336 |
yp = (int)(ovp[1]*vres);
| 337 |
xmbuffer[n] = xp - (n % hres);
| 338 |
ymbuffer[n] = yp - (n / hres);
| 339 |
if ((xp < 0) | (xp >= hres))
| 340 |
return;
| 341 |
if ((yp < 0) | (yp >= vres))
| 342 |
return;
| 343 |
n = fndx(xp, yp);
| 344 |
if ((zprev[n] < 0.97*ovp[2]) | (zprev[n] > 1.03*ovp[2]))
| 345 |
oprev[n] = OVOID; /* assume it's a bad match */
| 346 |
| 347 |
| 348 |
| 349 |
static void
| 350 |
init_frame_sample(void) /* sample our initial frame */
| 351 |
| 352 |
RAY ir;
| 353 |
int x, y;
| 354 |
int n;
| 355 |
| 356 |
if (!silent) {
| 357 |
printf("\tComputing initial samples...");
| 358 |
fflush(stdout);
| 359 |
| 360 |
hlsmax = CSF_SMN;
| 361 |
| 362 |
for (x = hres; x--; ) {
| 363 |
double hv[2];
| 364 |
n = fndx(x, y);
| 365 |
xmbuffer[n] = ymbuffer[n] = MO_UNK;
| 366 |
sample_pos(hv, x, y, 0);
| 367 |
ir.rmax = viewray(ir.rorg, ir.rdir, &vw, hv[0], hv[1]);
| 368 |
if (ir.rmax < -FTINY) {
| 369 |
setcolor(cbuffer[n], 0., 0., 0.);
| 370 |
zbuffer[n] = FHUGE;
| 371 |
obuffer[n] = OVOID;
| 372 |
abuffer[n] = ADISTANT;
| 373 |
continue;
| 374 |
| 375 |
if (!sample_here(x, y)) { /* just cast */
| 376 |
rayorigin(&ir, PRIMARY, NULL, NULL);
| 377 |
if (!localhit(&ir, &thescene)) {
| 378 |
if (ir.ro != &Aftplane && sourcehit(&ir)) {
| 379 |
rayshade(&ir, ir.ro->omod);
| 380 |
rayparticipate(&ir);
| 381 |
| 382 |
copycolor(cbuffer[n], ir.rcol);
| 383 |
zbuffer[n] = ir.rot;
| 384 |
obuffer[n] = ir.robj;
| 385 |
| 386 |
sbuffer[n] = 1;
| 387 |
} else {
| 388 |
| 389 |
| 390 |
setmotion(n, ir.rop);
| 391 |
| 392 |
continue;
| 393 |
| 394 |
if (nprocs > 1) { /* get sample */
| 395 |
int rval;
| 396 |
| 397 |
ir.rno = n;
| 398 |
rval = ray_pqueue(&ir);
| 399 |
if (!rval)
| 400 |
continue;
| 401 |
if (rval < 0)
| 402 |
quit(1);
| 403 |
n = ir.rno;
| 404 |
} else
| 405 |
ray_trace(&ir);
| 406 |
| 407 |
| 408 |
| 409 |
sbuffer[n] = 1;
| 410 |
if (ir.rot >= 0.99*FHUGE)
| 411 |
| 412 |
else {
| 413 |
abuffer[n] = ALOWQ;
| 414 |
| 415 |
| 416 |
| 417 |
if (nprocs > 1) /* get stragglers */
| 418 |
while (ray_presult(&ir, 0)) {
| 419 |
n = ir.rno;
| 420 |
| 421 |
| 422 |
| 423 |
sbuffer[n] = 1;
| 424 |
| 425 |
| 426 |
else {
| 427 |
abuffer[n] = ALOWQ;
| 428 |
| 429 |
| 430 |
| 431 |
/* ambiguate object boundaries */
| 432 |
for (y = vres-1; y--; )
| 433 |
for (x = hres-1; x--; ) {
| 434 |
OBJECT obj;
| 435 |
n = fndx(x, y);
| 436 |
if ((obj = obuffer[n]) == OVOID)
| 437 |
continue;
| 438 |
if ((obuffer[n+1] != OVOID) & (obuffer[n+1] != obj)) {
| 439 |
obuffer[n] = OVOID;
| 440 |
obuffer[n+1] = OVOID;
| 441 |
| 442 |
if ((obuffer[n+hres] != OVOID) & (obuffer[n+hres] != obj)) {
| 443 |
obuffer[n] = OVOID;
| 444 |
obuffer[n+hres] = OVOID;
| 445 |
| 446 |
| 447 |
| 448 |
if (!silent)
| 449 |
printf("done\n");
| 450 |
| 451 |
| 452 |
| 453 |
int
| 454 |
getambcolor( /* get ambient color for object if we can */
| 455 |
COLOR clr,
| 456 |
int obj
| 457 |
| 458 |
| 459 |
OBJREC *op;
| 460 |
| 461 |
if (obj == OVOID)
| 462 |
return(0);
| 463 |
op = objptr(obj); /* search for material */
| 464 |
if (op->omod == OVOID)
| 465 |
return(0);
| 466 |
op = findmaterial(objptr(op->omod));
| 467 |
if (op == NULL)
| 468 |
return(0);
| 469 |
| 470 |
* Since this routine is called to compute the difference
| 471 |
* from rendering with and without interreflections,
| 472 |
* we don't want to return colors for materials that are
| 473 |
* explicitly excluded from the HQ ambient calculation.
| 474 |
| 475 |
if (hirendparams.ambincl >= 0) {
| 476 |
int i;
| 477 |
char *lv;
| 478 |
for (i = 0; (lv = rpambmod(&hirendparams,i)) != NULL; i++)
| 479 |
if (lv[0] == op->oname[0] &&
| 480 |
!strcmp(lv+1, op->oname+1))
| 481 |
break;
| 482 |
if ((lv != NULL) ^ hirendparams.ambincl)
| 483 |
return(0);
| 484 |
| 485 |
switch (op->otype) {
| 486 |
case MAT_PLASTIC:
| 487 |
case MAT_METAL:
| 488 |
case MAT_PLASTIC2:
| 489 |
case MAT_METAL2:
| 490 |
case MAT_PFUNC:
| 491 |
case MAT_MFUNC:
| 492 |
case MAT_PDATA:
| 493 |
case MAT_MDATA:
| 494 |
case MAT_TRANS:
| 495 |
case MAT_TRANS2:
| 496 |
case MAT_TFUNC:
| 497 |
case MAT_TDATA:
| 498 |
if (op->oargs.nfargs < 3)
| 499 |
return(0);
| 500 |
setcolor(clr, op->oargs.farg[0], op->oargs.farg[1],
| 501 |
op->oargs.farg[2]);
| 502 |
return(1);
| 503 |
case MAT_BRTDF:
| 504 |
if (op->oargs.nfargs < 6)
| 505 |
return(0);
| 506 |
setcolor(clr, op->oargs.farg[0]+op->oargs.farg[3],
| 507 |
op->oargs.farg[1]+op->oargs.farg[4],
| 508 |
op->oargs.farg[2]+op->oargs.farg[5]);
| 509 |
scalecolor(clr, 0.5);
| 510 |
return(1);
| 511 |
case MAT_LIGHT:
| 512 |
case MAT_GLOW:
| 513 |
case MAT_ILLUM:
| 514 |
setcolor(clr, 0., 0., 0.);
| 515 |
return(1);
| 516 |
| 517 |
return(0);
| 518 |
| 519 |
| 520 |
| 521 |
double
| 522 |
estimaterr( /* estimate relative error from samples */
| 523 |
COLOR cs,
| 524 |
COLOR cs2,
| 525 |
int ns,
| 526 |
int ns0
| 527 |
| 528 |
| 529 |
double d, d2, brt;
| 530 |
| 531 |
if (ns <= 1 || (brt = bright(cs)/ns) < 1e-14)
| 532 |
return(1.0);
| 533 |
/* use largest of RGB std. dev. */
| 534 |
d2 = colval(cs2,RED) - colval(cs,RED)*colval(cs,RED)/ns;
| 535 |
d = colval(cs2,GRN) - colval(cs,GRN)*colval(cs,GRN)/ns;
| 536 |
if (d > d2) d2 = d;
| 537 |
d = colval(cs2,BLU) - colval(cs,BLU)*colval(cs,BLU)/ns;
| 538 |
if (d > d2) d2 = d;
| 539 |
/* use s.d. if <= 1 central sample */
| 540 |
if (ns0 <= 1)
| 541 |
return(sqrt(d2/(ns-1))/brt);
| 542 |
/* use s.d./sqrt(ns0) otherwise */
| 543 |
return(sqrt(d2/((ns-1)*ns0))/brt);
| 544 |
| 545 |
| 546 |
| 547 |
double
| 548 |
comperr( /* estimate relative error in neighborhood */
| 549 |
int *neigh,
| 550 |
int nc,
| 551 |
int ns0
| 552 |
| 553 |
| 554 |
COLOR csum, csum2;
| 555 |
COLOR ctmp;
| 556 |
int i;
| 557 |
int ns;
| 558 |
int n;
| 559 |
/* add together samples */
| 560 |
setcolor(csum, 0., 0., 0.);
| 561 |
setcolor(csum2, 0., 0., 0.);
| 562 |
for (i = 0, ns = 0; (i < nc) & (ns < NSAMPOK); i++) {
| 563 |
n = neigh[i];
| 564 |
addcolor(csum, cbuffer[n]);
| 565 |
if (val2map != NULL) {
| 566 |
addcolor(csum2, val2map[n]);
| 567 |
ns += sbuffer[n];
| 568 |
continue;
| 569 |
| 570 |
if (sbuffer[n] != 1)
| 571 |
error(CONSISTENCY, "bad count in comperr");
| 572 |
setcolor(ctmp,
| 573 |
colval(cbuffer[n],RED)*colval(cbuffer[n],RED),
| 574 |
colval(cbuffer[n],GRN)*colval(cbuffer[n],GRN),
| 575 |
colval(cbuffer[n],BLU)*colval(cbuffer[n],BLU));
| 576 |
addcolor(csum2, ctmp);
| 577 |
ns++;
| 578 |
| 579 |
return(estimaterr(csum, csum2, ns, ns0));
| 580 |
| 581 |
| 582 |
| 583 |
void
| 584 |
comp_frame_error(void) /* initialize frame error values */
| 585 |
| 586 |
uby8 *edone = NULL;
| 587 |
COLOR objamb;
| 588 |
double eest;
| 589 |
int neigh[NSAMPOK];
| 590 |
int nc;
| 591 |
int x, y, i;
| 592 |
int n;
| 593 |
| 594 |
if (!silent) {
| 595 |
printf("\tComputing error map\n");
| 596 |
fflush(stdout);
| 597 |
| 598 |
if (acctab[0] <= FTINY) /* initialize accuracy table */
| 599 |
for (i = 256; i--; )
| 600 |
acctab[i] = errorf(i);
| 601 |
/* estimate sample error */
| 602 |
if (!curparams->ambounce && hirendparams.ambounce) {
| 603 |
| 604 |
* Our error estimate for the initial value is based
| 605 |
* on the assumption that most of it comes from the
| 606 |
* lack of an interreflection calculation. The relative
| 607 |
* error should be less than the ambient value divided
| 608 |
* by the returned ray value -- we take half of this.
| 609 |
| 610 |
edone = (uby8 *)calloc(hres*vres, sizeof(uby8));
| 611 |
| 612 |
if ((abuffer[n] != ALOWQ) | (obuffer[n] == OVOID))
| 613 |
continue;
| 614 |
if (!getambcolor(objamb, obuffer[n]))
| 615 |
continue;
| 616 |
multcolor(objamb, ambval);
| 617 |
if ((eest = bright(cbuffer[n])) <= FTINY)
| 618 |
continue;
| 619 |
eest = bright(objamb) / eest;
| 620 |
if (eest > 1.) /* should we report this? */
| 621 |
continue;
| 622 |
eest *= 0.50; /* use 50% ambient error */
| 623 |
i = errori(eest);
| 624 |
if (i < AMIN) i = AMIN;
| 625 |
else if (i >= ADISTANT/2) i = ADISTANT/2-1;
| 626 |
abuffer[n] = i;
| 627 |
edone[n] = 1;
| 628 |
| 629 |
| 630 |
/* final statistical estimate */
| 631 |
| 632 |
| 633 |
n = fndx(x, y);
| 634 |
if (abuffer[n] == ADISTANT)
| 635 |
continue; /* don't update these */
| 636 |
if (edone != NULL && edone[n])
| 637 |
continue; /* already done this */
| 638 |
if (sbuffer[n] >= 255) {
| 639 |
| 640 |
continue; /* can't take any more */
| 641 |
| 642 |
nc = getclosest(neigh, NSAMPOK, x, y);
| 643 |
if (nc <= 0) {
| 644 |
abuffer[n] = ANOVAL;
| 645 |
continue; /* no clue what to do for him */
| 646 |
| 647 |
i = errori(comperr(neigh, nc, sbuffer[n]));
| 648 |
| 649 |
else if (i >= ADISTANT) i = ADISTANT-1;
| 650 |
abuffer[n] = i;
| 651 |
/* can't be better than closest */
| 652 |
if (i < abuffer[neigh[0]] && abuffer[neigh[0]] >= AMIN)
| 653 |
abuffer[n] = abuffer[neigh[0]];
| 654 |
| 655 |
if (edone != NULL)
| 656 |
free((void *)edone);
| 657 |
| 658 |
| 659 |
| 660 |
void
| 661 |
init_frame(void) /* render base (low quality) frame */
| 662 |
| 663 |
int restart;
| 664 |
/* allocate/swap buffers */
| 665 |
next_frame();
| 666 |
/* check rendering status */
| 667 |
restart = (!nobjects || vdef(MOVE));
| 668 |
if (!restart && curparams != &lorendparams && nprocs > 1)
| 669 |
restart = -1;
| 670 |
/* post low quality parameters */
| 671 |
if (curparams != &lorendparams)
| 672 |
ray_restore(curparams = &lorendparams);
| 673 |
if (restart > 0) { /* load new octree */
| 674 |
char *oct = getoctspec(fcur);
| 675 |
if (oct == NULL) {
| 676 |
sprintf(errmsg, "cannot get scene for frame %d", fcur);
| 677 |
| 678 |
| 679 |
if (!silent) {
| 680 |
printf("\tLoading octree...");
| 681 |
fflush(stdout);
| 682 |
| 683 |
if (nprocs > 1)
| 684 |
ray_pinit(oct, nprocs);
| 685 |
else
| 686 |
ray_init(oct);
| 687 |
} else if (restart < 0) { /* update children */
| 688 |
if (!silent) {
| 689 |
printf("\tRestarting %d processes...", nprocs);
| 690 |
fflush(stdout);
| 691 |
| 692 |
ray_pclose(0);
| 693 |
ray_popen(nprocs);
| 694 |
| 695 |
if (restart && !silent)
| 696 |
printf("done\n");
| 697 |
/* sample frame buffer */
| 698 |
init_frame_sample();
| 699 |
/* initialize frame error */
| 700 |
comp_frame_error();
| 701 |
#if 0
| 702 |
| 703 |
float *ebuf = (float *)malloc(sizeof(float)*hres*vres);
| 704 |
char fnm[256];
| 705 |
int n;
| 706 |
| 707 |
ebuf[n] = acctab[abuffer[n]];
| 708 |
sprintf(fnm, vval(BASENAME), fcur);
| 709 |
strcat(fnm, "_inerr.pic");
| 710 |
write_map(ebuf, fnm);
| 711 |
free((void *)ebuf);
| 712 |
| 713 |
#endif
| 714 |
| 715 |
| 716 |
| 717 |
void
| 718 |
filter_frame(void) /* interpolation, motion-blur, and exposure */
| 719 |
| 720 |
const double expval = expspec_val(getexp(fcur));
| 721 |
int x, y;
| 722 |
int neigh[NPINTERP];
| 723 |
int nc;
| 724 |
COLOR cval;
| 725 |
double w, wsum;
| 726 |
int n;
| 727 |
| 728 |
#if 0
| 729 |
/* XXX TEMPORARY!! */
| 730 |
conspicuity();
| 731 |
write_map(cerrmap, "outcmap.pic");
| 732 |
| 733 |
| 734 |
| 735 |
| 736 |
write_map(ebuf, "outerr.pic");
| 737 |
free((void *)ebuf);
| 738 |
| 739 |
#endif
| 740 |
if (!silent) {
| 741 |
printf("\tFiltering frame\n");
| 742 |
fflush(stdout);
| 743 |
| 744 |
/* normalize samples */
| 745 |
| 746 |
if (sbuffer[n] <= 1)
| 747 |
continue;
| 748 |
w = 1.0/(double)sbuffer[n];
| 749 |
scalecolor(cbuffer[n], w);
| 750 |
| 751 |
/* interpolate samples */
| 752 |
| 753 |
| 754 |
n = fndx(x, y);
| 755 |
if (sbuffer[n])
| 756 |
continue;
| 757 |
nc = getclosest(neigh, NPINTERP, x, y);
| 758 |
| 759 |
if (nc <= 0) { /* no acceptable neighbors */
| 760 |
if (y < vres-1)
| 761 |
nc = fndx(x, y+1);
| 762 |
else if (x < hres-1)
| 763 |
nc = fndx(x+1, y);
| 764 |
else
| 765 |
continue;
| 766 |
copycolor(cbuffer[n], cbuffer[nc]);
| 767 |
continue;
| 768 |
| 769 |
wsum = 0.;
| 770 |
while (nc-- > 0) {
| 771 |
copycolor(cval, cbuffer[neigh[nc]]);
| 772 |
w = sample_wt((neigh[nc]%hres) - x,
| 773 |
(neigh[nc]/hres) - y);
| 774 |
scalecolor(cval, w);
| 775 |
addcolor(cbuffer[n], cval);
| 776 |
wsum += w;
| 777 |
| 778 |
w = 1.0/wsum;
| 779 |
| 780 |
| 781 |
/* motion blur if requested */
| 782 |
if (mblur > .02) {
| 783 |
int xs, ys, xl, yl;
| 784 |
int rise, run;
| 785 |
long rise2, run2;
| 786 |
int n2;
| 787 |
int cnt;
| 788 |
/* sum in motion streaks */
| 789 |
memset(outbuffer, '\0', sizeof(COLOR)*hres*vres);
| 790 |
memset(wbuffer, '\0', sizeof(float)*hres*vres);
| 791 |
| 792 |
| 793 |
n = fndx(x, y);
| 794 |
if (xmbuffer[n] == MO_UNK) {
| 795 |
run = rise = 0;
| 796 |
} else {
| 797 |
run = (int)(mblur*xmbuffer[n]);
| 798 |
rise = (int)(mblur*ymbuffer[n]);
| 799 |
| 800 |
if (!(run | rise)) {
| 801 |
addcolor(outbuffer[n], cbuffer[n]);
| 802 |
wbuffer[n] += 1.;
| 803 |
continue;
| 804 |
| 805 |
xl = x - run/4;
| 806 |
yl = y - rise/4;
| 807 |
if (run < 0) { xs = -1; run = -run; }
| 808 |
else xs = 1;
| 809 |
if (rise < 0) { ys = -1; rise = -rise; }
| 810 |
else ys = 1;
| 811 |
rise2 = run2 = 0L;
| 812 |
if (rise > run) {
| 813 |
cnt = rise + 1;
| 814 |
w = 1./cnt;
| 815 |
copycolor(cval, cbuffer[n]);
| 816 |
| 817 |
while (cnt)
| 818 |
if (rise2 >= run2) {
| 819 |
if ((xl >= 0) & (xl < hres) &
| 820 |
(yl >= 0) & (yl < vres)) {
| 821 |
n2 = fndx(xl, yl);
| 822 |
addcolor(outbuffer[n2],
| 823 |
cval);
| 824 |
wbuffer[n2] += w;
| 825 |
| 826 |
yl += ys;
| 827 |
run2 += run;
| 828 |
cnt--;
| 829 |
} else {
| 830 |
xl += xs;
| 831 |
rise2 += rise;
| 832 |
| 833 |
} else {
| 834 |
cnt = run + 1;
| 835 |
w = 1./cnt;
| 836 |
| 837 |
| 838 |
while (cnt)
| 839 |
if (run2 >= rise2) {
| 840 |
| 841 |
| 842 |
n2 = fndx(xl, yl);
| 843 |
| 844 |
cval);
| 845 |
wbuffer[n2] += w;
| 846 |
| 847 |
xl += xs;
| 848 |
rise2 += rise;
| 849 |
cnt--;
| 850 |
} else {
| 851 |
yl += ys;
| 852 |
run2 += run;
| 853 |
| 854 |
| 855 |
| 856 |
/* compute final results */
| 857 |
| 858 |
if (wbuffer[n] <= FTINY)
| 859 |
continue;
| 860 |
w = expval/wbuffer[n];
| 861 |
scalecolor(outbuffer[n], w);
| 862 |
| 863 |
} else { /* no blur -- just exposure */
| 864 |
memcpy(outbuffer, cbuffer, sizeof(COLOR)*hres*vres);
| 865 |
for (n = ((expval < 0.99) | (expval > 1.01))*hres*vres; n--; )
| 866 |
scalecolor(outbuffer[n], expval);
| 867 |
| 868 |
| 869 |
| 870 |
if (!sbuffer[n])
| 871 |
setcolor(outbuffer[n], 0., 0., 0.);
| 872 |
| 873 |
#if 0
| 874 |
| 875 |
float *sbuf = (float *)malloc(sizeof(float)*hres*vres);
| 876 |
char fnm[256];
| 877 |
| 878 |
strcat(fnm, "_outsamp.pic");
| 879 |
| 880 |
sbuf[n] = (float)sbuffer[n];
| 881 |
write_map(sbuf, fnm);
| 882 |
free((void *)sbuf);
| 883 |
| 884 |
#endif
| 885 |
| 886 |
| 887 |
| 888 |
void
| 889 |
send_frame(void) /* send frame to destination */
| 890 |
| 891 |
char fname[1024];
| 892 |
double d;
| 893 |
FILE *fp;
| 894 |
int y;
| 895 |
/* open output picture */
| 896 |
sprintf(fname, vval(BASENAME), fcur);
| 897 |
strcat(fname, ".hdr");
| 898 |
fp = fopen(fname, "w");
| 899 |
if (fp == NULL) {
| 900 |
sprintf(errmsg, "cannot open output frame \"%s\"", fname);
| 901 |
error(SYSTEM, errmsg);
| 902 |
| 903 |
SET_FILE_BINARY(fp);
| 904 |
if (!silent) {
| 905 |
printf("\tWriting to \"%s\"\n", fname);
| 906 |
fflush(stdout);
| 907 |
| 908 |
/* write header */
| 909 |
| 910 |
printargs(gargc, gargv, fp);
| 911 |
fprintf(fp, "SOFTWARE= %s\n", VersionID);
| 912 |
fprintf(fp, "FRAME=%d\n", fcur);
| 913 |
fputnow(fp);
| 914 |
fputs(VIEWSTR, fp); fprintview(&vw, fp); fputc('\n', fp);
| 915 |
d = expspec_val(getexp(fcur));
| 916 |
if ((d < 0.99) | (d > 1.01))
| 917 |
fputexpos(d, fp);
| 918 |
d = viewaspect(&vw) * hres / vres;
| 919 |
| 920 |
fputaspect(d, fp);
| 921 |
| 922 |
| 923 |
| 924 |
if (fflush(fp) == EOF)
| 925 |
goto writerr;
| 926 |
#if (PIXSTANDARD != (YMAJOR|YDECR))
| 927 |
error(CONSISTENCY, "bad code in send_frame");
| 928 |
#endif
| 929 |
for (y = vres; y--; ) /* write scanlines */
| 930 |
if (fwritescan(outbuffer+y*hres, hres, fp) < 0)
| 931 |
goto writerr;
| 932 |
if (fclose(fp) == EOF)
| 933 |
goto writerr;
| 934 |
if (vdef(ZNAME)) { /* output z-buffer */
| 935 |
sprintf(fname, vval(ZNAME), fcur);
| 936 |
strcat(fname, ".zbf");
| 937 |
| 938 |
if (fp == NULL) {
| 939 |
sprintf(errmsg, "cannot open z-file \"%s\"\n", fname);
| 940 |
| 941 |
| 942 |
| 943 |
if (!silent) {
| 944 |
printf("\tWriting depths to \"%s\"\n", fname);
| 945 |
fflush(stdout);
| 946 |
| 947 |
| 948 |
if (fwrite(zbuffer+y*hres, sizeof(float),
| 949 |
hres, fp) != hres)
| 950 |
goto writerr;
| 951 |
| 952 |
goto writerr;
| 953 |
| 954 |
if (vdef(MNAME)) { /* output motion buffer */
| 955 |
unsigned short *mbuffer = (unsigned short *)malloc(
| 956 |
sizeof(unsigned short)*3*hres);
| 957 |
int x, n;
| 958 |
if (mbuffer == NULL)
| 959 |
error(SYSTEM, "out of memory in send_frame");
| 960 |
sprintf(fname, vval(MNAME), fcur);
| 961 |
strcat(fname, ".mvo");
| 962 |
| 963 |
if (fp == NULL) {
| 964 |
sprintf(errmsg, "cannot open motion file \"%s\"\n",
| 965 |
fname);
| 966 |
| 967 |
| 968 |
| 969 |
if (!silent) {
| 970 |
printf("\tWriting motion vectors to \"%s\"\n", fname);
| 971 |
fflush(stdout);
| 972 |
| 973 |
| 974 |
| 975 |
n = fndx(x,y);
| 976 |
mbuffer[3*x] = xmbuffer[n] + 0x8000;
| 977 |
mbuffer[3*x+1] = ymbuffer[n] + 0x8000;
| 978 |
mbuffer[3*x+2] = (oprev[n]!=OVOID)*0x8000;
| 979 |
| 980 |
if (fwrite(mbuffer, sizeof(*mbuffer),
| 981 |
3*hres, fp) != 3*hres)
| 982 |
goto writerr;
| 983 |
| 984 |
free((void *)mbuffer);
| 985 |
| 986 |
goto writerr;
| 987 |
| 988 |
return; /* all is well */
| 989 |
writerr:
| 990 |
sprintf(errmsg, "error writing file \"%s\"", fname);
| 991 |
| 992 |
| 993 |
| 994 |
| 995 |
void
| 996 |
free_frame(void) /* free frame allocation */
| 997 |
| 998 |
| 999 |
return;
| 1000 |
free((void *)cbuffer); cbuffer = NULL;
| 1001 |
free((void *)zbuffer); zbuffer = NULL;
| 1002 |
free((void *)obuffer); obuffer = NULL;
| 1003 |
free((void *)xmbuffer); xmbuffer = NULL;
| 1004 |
free((void *)ymbuffer); ymbuffer = NULL;
| 1005 |
free((void *)cprev); cprev = NULL;
| 1006 |
free((void *)zprev); zprev = NULL;
| 1007 |
free((void *)oprev); oprev = NULL;
| 1008 |
cerrmap = NULL;
| 1009 |
val2map = NULL;
| 1010 |
hres = vres = 0;
| 1011 |
vw.type = vwprev.type = 0;
| 1012 |
frm_stop = 0;
| 1013 |
