--- ray/src/util/ranimove1.c 2008/04/17 14:44:25 3.13 +++ ray/src/util/ranimove1.c 2008/04/17 14:49:59 3.14 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: ranimove1.c,v 3.13 2008/04/17 14:44:25 greg Exp $"; +static const char RCSid[] = "$Id: ranimove1.c,v 3.14 2008/04/17 14:49:59 greg Exp $"; #endif /* * ranimove1.c @@ -54,6 +54,7 @@ static void setmotion(int n, FVECT wpos); static void init_frame_sample(void); +#if 0 extern void write_map( /* write out float map (debugging) */ float *mp, @@ -79,6 +80,7 @@ write_map( /* write out float map (debugging) */ } fclose(fp); } +#endif static void @@ -664,12 +666,6 @@ init_frame(void) /* render base (low quality) frame restart = (!nobjects || vdef(MOVE)); if (!restart && curparams != &lorendparams && nprocs > 1) restart = -1; - if (restart > 0) { - if (nprocs > 1) - ray_pdone(0); - else - ray_done(0); - } /* post low quality parameters */ if (curparams != &lorendparams) ray_restore(curparams = &lorendparams); @@ -701,7 +697,7 @@ init_frame(void) /* render base (low quality) frame init_frame_sample(); /* initialize frame error */ comp_frame_error(); -return; +#if 0 { float *ebuf = (float *)malloc(sizeof(float)*hres*vres); char fnm[256]; @@ -713,6 +709,7 @@ return; write_map(ebuf, fnm); free((void *)ebuf); } +#endif }
