root/radiance/ray/src/util/ranimove1.c
Wed Jul 2 16:54:44 2025 UTC (6 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 3.28: +2 -2 lines
Diff to previous 3.28
perf: Made +/-0.5% threshold for caring about pixel aspect ratio consistent
Tue Jul 1 19:40:35 2025 UTC (6 weeks, 1 day ago) by greg
Changes since 3.27: +2 -2 lines
Diff to previous 3.27
fix: Made PIXASPECT= output a little more stringent (+/-0.1% rather than 1%)
Fri Nov 17 20:02:08 2023 UTC (20 months, 3 weeks ago) by greg
Changes since 3.26: +4 -4 lines
Diff to previous 3.26
Thu May 14 20:58:03 2020 UTC (5 years, 3 months ago) by greg
CVS Tags: rad5R3, rad5R4
Changes since 3.25: +2 -2 lines
Diff to previous 3.25
Thu Mar 12 17:19:18 2020 UTC (5 years, 5 months ago) by greg
Diff to previous 3.24
Added precautionary testing when checking for FHUGE
Sat Nov 17 20:15:51 2018 UTC (6 years, 8 months ago) by greg
Changes since 3.23: +2 -1 lines
Diff to previous 3.23
Fixed missing header from findmaterial() move
Wed Jan 24 04:39:52 2018 UTC (7 years, 6 months ago) by greg
Changes since 3.22: +2 -3 lines
Diff to previous 3.22
Fri Oct 5 01:03:22 2012 UTC (12 years, 10 months ago) by greg
Changes since 3.21: +27 -42 lines
Diff to previous 3.21
Backed out unintentional commit
Fri Oct 5 00:59:38 2012 UTC (12 years, 10 months ago) by greg
Changes since 3.20: +43 -28 lines
Diff to previous 3.20
Tue Oct 2 21:56:20 2012 UTC (12 years, 10 months ago) by greg
Changes since 3.19: +12 -14 lines
Diff to previous 3.19
Minor improvements -- motion blur still incorrect
Sun Sep 30 19:18:41 2012 UTC (12 years, 10 months ago) by greg
Changes since 3.18: +32 -40 lines
Diff to previous 3.18
Minor code clean-ups and efficiency improvements
Fri Sep 28 22:20:49 2012 UTC (12 years, 10 months ago) by greg
Changes since 3.17: +72 -18 lines
Diff to previous 3.17
Fri May 20 02:06:39 2011 UTC (14 years, 2 months ago) by greg
Changes since 3.16: +12 -12 lines
Diff to previous 3.16
Fri Nov 5 04:36:24 2010 UTC (14 years, 9 months ago) by greg
Changes since 3.15: +17 -13 lines
Diff to previous 3.15
Fixed bug in distant sources (sky, etc.)
Mon Nov 10 19:08:20 2008 UTC (16 years, 9 months ago) by greg
Diff to previous 3.14
Thu Apr 17 14:49:59 2008 UTC (17 years, 4 months ago) by greg
Changes since 3.13: +5 -8 lines
Diff to previous 3.13
Eliminated unnecessary bits of code
Thu Apr 17 14:44:25 2008 UTC (17 years, 4 months ago) by greg
Changes since 3.12: +3 -4 lines
Diff to previous 3.12
Changed octree reload so fonts and data files not lost.
Tue Dec 20 03:49:51 2005 UTC (19 years, 7 months ago) by greg
Changes since 3.11: +13 -5 lines
Diff to previous 3.11
Eliminated black pixels when no neighbor samples are acceptable
Sun Jul 24 21:11:53 2005 UTC (20 years ago) by greg
Diff to previous 3.10
Fixed comments
Tue Apr 19 01:15:07 2005 UTC (20 years, 4 months ago) by greg
Changes since 3.9: +3 -3 lines
Diff to previous 3.9
Thu May 13 15:45:43 2004 UTC (21 years, 3 months ago) by greg
Changes since 3.8: +90 -96 lines
Diff to previous 3.8
Fixed infinite loop introduced during "beautification" of for loops
Fri Mar 26 21:36:20 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 3.7: +197 -168 lines
Diff to previous 3.7
Continued ANSIfication.
Tue Oct 21 19:19:29 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 3.6: +5 -3 lines
Diff to previous 3.6
Sun Jul 27 22:12:03 2003 UTC (22 years ago) by schorsch
Changes since 3.5: +28 -28 lines
Diff to previous 3.5
Mon Jul 21 22:30:19 2003 UTC (22 years ago) by schorsch
Changes since 3.4: +6 -5 lines
Diff to previous 3.4
Mon Jun 30 14:59:13 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 3.3: +7 -5 lines
Diff to previous 3.3
Thu Jun 5 19:29:35 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 3.2: +3 -4 lines
Tue Feb 25 02:47:24 2003 UTC (22 years, 5 months ago) by greg
Changes since 3.1: +1 -56 lines
Sat Feb 22 02:07:30 2003 UTC (22 years, 5 months ago) by greg
